Hello,
My name is Joel.
I wanted to know how to start this stopped scheme
and initialize, when we press button 2
thanks for now...
My name is Joel.
// Granular Effect Example - Pitch shift or freeze sound
// This example is meant to be used with 3 buttons (pin 0,
// 1, 2) and 2 knobs (pins 16/A2, 17/A3), which are present
// on the audio tutorial kit.
// https://www.pjrc.com/store/audio_tutorial_kit.html
// Data files to put on your SD card can be downloaded here:
// http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
// This example code is in the public domain.
#include <SerialFlash.h>
#include <Bounce.h>
AudioPlaySdWav playSdWav1; //xy=163,135
AudioMixer4 mixer1; //xy=332,167
AudioEffectGranular granular1; //xy=504,155
AudioOutputI2S i2s1; //xy=664,185
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer1, 1);
AudioConnection patchCord3(mixer1, granular1);
AudioConnection patchCord4(granular1, 0, i2s1, 0);
AudioConnection patchCord5(granular1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=236,248
Bounce button0 = Bounce(0, 15);
Bounce button1 = Bounce(1, 15);
Bounce button2 = Bounce(2, 15);
#define GRANULAR_MEMORY_SIZE 12800 // enough for 290 ms at 44.1 kHz
int16_t granularMemory[GRANULAR_MEMORY_SIZE];
// Use these with the Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7 // Teensy 4 ignores this, uses pin 11
#define SDCARD_SCK_PIN 14 // Teensy 4 ignores this, uses pin 13
// Use these with the Teensy 3.5 & 3.6 & 4.1 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
#define NUM_FILES 4
const char *filenames[NUM_FILES]={"SDTEST1.WAV", "SDTEST2.WAV", "SDTEST3.WAV", "SDTEST4.WAV"};
int nextfile=0;
AudioMemory(10);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
// the Granular effect requires memory to operate
granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
if (playSdWav1.isPlaying() == false) {
// start the next song playing
playSdWav1.play(filenames[nextfile]);
Serial.print("Playing: ");
Serial.println(filenames[nextfile]);
delay(5); // brief delay for the library read WAV info
nextfile = nextfile + 1;
if (nextfile >= NUM_FILES) {
nextfile = 0;
// read pushbuttons
button0.update();
button1.update();
button2.update();
// read knobs, scale to 0-1.0 numbers
float knobA2 = (float)analogRead(A2) / 1023.0;
float knobA3 = (float)analogRead(A3) / 1023.0;
// Button 0 starts Freeze effect
if (button0.fallingEdge()) {
float msec = 100.0 + (knobA3 * 190.0);
granular1.beginFreeze(msec);
Serial.print("Begin granular freeze using ");
Serial.print(msec);
Serial.println(" grains");
if (button0.risingEdge()) {
granular1.stop();
// Button 1 starts Pitch Shift effect
if (button1.fallingEdge()) {
float msec = 25.0 + (knobA3 * 75.0);
granular1.beginPitchShift(msec);
Serial.print("Begin granular pitch phift using ");
Serial.print(msec);
if (button1.risingEdge()) {
granular1.stop();
// Continuously adjust the speed, based on the A3 pot
float ratio;
ratio = powf(2.0, knobA2 * 2.0 - 1.0); // 0.5 to 2.0
//ratio = powf(2.0, knobA2 * 6.0 - 3.0); // 0.125 to 8.0 -- uncomment for far too much range!
granular1.setSpeed(ratio);
thanks for now...
