I am using teensy 4.1 CAN3 port with CJMCU-230 to read CANFD frames ( 64Byte buffer with 32bit Floats). But when I try to print the buffer, it only prints first 8 bytes and rest is 0.
Here is the code:
#include <FlexCAN_T4.h>
FlexCAN_T4FD<CAN3, RX_SIZE_1024, TX_SIZE_16> myFD;
CANFD_message_t msgFD;
void setup(void) {
CANFD_timings_t config;
config.clock = CLK_40MHz;
config.baudrate = 1000000;
config.baudrateFD = 1000000;
myFD.begin();
myFD.setBaudRate(config);
if ( myFD.read(msgFD) ) {
Serial.print("CAN1 ");
Serial.print("MB: "); Serial.print(msgFD.mb);
Serial.print(" ID: 0x"); Serial.print(msgFD.id, HEX );
Serial.print(" EXT: "); Serial.print(msgFD.flags.extended);
Serial.print(" LEN: "); Serial.print(msgFD.len);
Serial.print(" DATA: ");
for ( uint8_t i = 0; i < msgFD.len; i++ ) {
Serial.print(msgFD.buf); Serial.print(" ");
Serial.print(" TS: "); Serial.println(msgFD.timestamp);
Here is the code:
void setup(void) {
myFD.begin();
