// SPDX-License-Identifier: CC0-1.0
// gcc -Wall -O2 this.c -lrt -o this && ./this /dev/ttyACM0
#define _POSIX_C_SOURCE 200809L
#define _DEFAULT_SOURCE
#include <stdlib.h>
#include <inttypes.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <termios.h>
#include <signal.h>
#include <time.h>
#include <string.h>
#include <stdio.h>
#include <errno.h>
/* Input buffer size. Use a power of two larger than 512; I'd recommend 4096 - 65536.
#ifndef BUFFER_SIZE
#define BUFFER_SIZE 512
/* Units of MB: 1000000 or 1048576
#ifndef MEGA
#define MEGA 1000000
/* Xorshift64* pseudo-random number generator. Zero state is invalid.
static uint64_t prng_state = 0;
/* Return only the upper 32 bits of XorShift64*. This passes BigCrunch tests.
static inline uint32_t prng_u32(void)
uint64_t x = prng_state;
x ^= x >> 12;
x ^= x << 25;
x ^= x >> 27;
prng_state = x;
return (x * UINT64_C(2685821657736338717)) >> 32;
/* Generate a 64-bit seed for the pseudo-random number generator.
static uint64_t prng_seed(void)
struct timespec now, boot;
pid_t pid;
uint64_t seed;
pid = getpid();
do {
clock_gettime(CLOCK_REALTIME, &now);
clock_gettime(CLOCK_BOOTTIME, &boot);
seed = (uint64_t)pid * UINT64_C(21272683)
+ (uint64_t)now.tv_sec * UINT64_C(113090255381)
+ (uint64_t)now.tv_nsec * UINT64_C(2470424306258081)
+ (uint64_t)boot.tv_sec * UINT64_C(9526198845596401)
+ (uint64_t)boot.tv_nsec * UINT64_C(9454161880954729);
} while (!seed);
prng_state = seed;
return seed;
/* When 'done' becomes nonzero, it is time to stop the measurement.
static volatile sig_atomic_t done = 0;
/* Signal handler for 'done'.
static void handle_done(int signum)
// Silence unused variable warning; generates no code.
(void)signum;
done = 1;
static int install_done(int signum)
struct sigaction act;
memset(&act, 0, sizeof act);
sigemptyset(&act.sa_mask);
act.sa_handler = handle_done;
act.sa_flags = 0; // Specifically, NO SA_RESTART flag.
return sigaction(signum, &act, NULL);
/* One-second interval timer. Simply sets 'update' to nonzero.
#ifndef UPDATE_SIGNAL
#define UPDATE_SIGNAL (SIGRTMIN+0)
static timer_t update_timer;
static volatile sig_atomic_t update = 0;
static void handle_update(int signum)
(void)signum;
update = 1;
static int install_update(void)
struct itimerspec spec;
struct sigevent ev;
act.sa_handler = handle_update;
act.sa_flags = SA_RESTART;
if (sigaction(UPDATE_SIGNAL, &act, NULL) == -1)
return -1;
ev.sigev_notify = SIGEV_SIGNAL;
ev.sigev_signo = UPDATE_SIGNAL;
ev.sigev_value.sival_ptr = NULL;
if (timer_create(CLOCK_BOOTTIME, &ev, &update_timer) == -1)
return -1;
spec.it_value.tv_sec = 1; // One second to first update
spec.it_value.tv_nsec = 0;
spec.it_interval.tv_sec = 1; // Repeat at one second intervals
spec.it_interval.tv_nsec = 0;
if (timer_settime(update_timer, 0, &spec, NULL) == -1)
return -1;
return 0;
/* USB serial port device handling.
static struct termios tty_settings;
static int tty_descriptor = -1;
static const char *tty_path = NULL;
static void tty_cleanup(void)
if (tty_descriptor != -1) {
if (tcsetattr(tty_descriptor, TCSANOW, &tty_settings) == -1)
fprintf(stderr, "Warning: %s: Cannot reset original termios settings: %s.\n", tty_path, strerror(errno));
tcflush(tty_descriptor, TCIOFLUSH);
if (close(tty_descriptor) == -1)
fprintf(stderr, "Warning: %s: Error closing device: %s.\n", tty_path, strerror(errno));
static int tty_open(const char *path)
struct termios raw;
int fd;
// NULL or empty path is invalid, and yields "no such file or directory" error.
if (!path || !*path) {
errno = ENOENT;
return -1;
// Fail if tty is already open.
errno = EALREADY;
return -1;
// Open the tty device.
do {
fd = open(path, O_RDWR | O_NOCTTY | O_CLOEXEC);
} while (fd == -1 && errno == EINTR);
if (fd == -1)
return -1;
// Set exclusive mode, so that others cannot open the device while we have it open.
if (ioctl(fd, TIOCEXCL) == -1)
fprintf(stderr, "Warning: %s: Cannot get exclusive access on tty device: %s.\n", path, strerror(errno));
// Drop any already pending data.
tcflush(fd, TCIOFLUSH);
// Obtain current termios settings.
if (tcgetattr(fd, &raw) == -1 || tcgetattr(fd, &tty_settings) == -1) {
fprintf(stderr, "%s: Cannot get termios settings: %s.\n", path, strerror(errno));
close(fd);
errno = 0; // Already reported
return -1;
// Raw 8-bit mode: no post-processing or special characters, 8-bit data.
raw.c_iflag &= ~( IGNBRK | BRKINT | PARMRK | INPCK | ISTRIP | INLCR | IGNCR | ICRNL | IXON | IUCLC | IUTF8 );
raw.c_oflag &= ~( OPOST );
raw.c_lflag &= ~( ECHO | ECHONL | ICANON | ISIG | IEXTEN );
raw.c_cflag &= ~( CSIZE | PARENB | CLOCAL );
raw.c_cflag |= CS8 | CREAD | HUPCL;
// Blocking reads.
raw.c_cc[VMIN] = 1;
raw.c_cc[VTIME] = 0;
if (tcsetattr(fd, TCSANOW, &raw) == -1) {
fprintf(stderr, "%s: Cannot set termios settings: %s.\n", path, strerror(errno));
close(fd);
return -1;
// Drop any already pending data, again. Just to make sure.
// Everything seems to be in order. Update state for tty_cleanup(), and return success.
tty_descriptor = fd;
tty_path = path;
return 0;
static inline double seconds_between(const struct timespec after, const struct timespec before)
return (double)(after.tv_sec - before.tv_sec)
+ (double)(after.tv_nsec - before.tv_nsec) / 1000000000.0;
int main(int argc, char *argv[])
const size_t buffer_size = BUFFER_SIZE;
size_t buffer_have = 0;
unsigned char *buffer_data = NULL;
struct timespec started, mark;
uint64_t received_before = 0; // Received till mark
uint64_t received = 0; // Received after mark
uint64_t sequence = 0;
uint64_t seed;
if (argc != 2 || !strcmp(argv[1], "-h") || !strcmp(argv[1], "--help")) {
const char *arg0 = (argc > 0 && argv && argv[0] && argv[0][0] != '\0') ? argv[0] : "(this)";
fprintf(stderr, "\n");
fprintf(stderr, "Usage: %s [ -h | --help ]\n", arg0);
fprintf(stderr, " %s DEVICE\n", arg0);
fprintf(stderr, "This writes a 64-bit XorShift64* seed to DEVICE, then reads the\n");
fprintf(stderr, "sequence of the generated numbers, 32 high bits each, verifying\n");
fprintf(stderr, "and reporting the transfer rate. Press CTRL+C or send SIGHUP,\n");
fprintf(stderr, "SIGINT, or SIGTERM signal to exit.\n");
return (argc == 1 || argc == 2) ? EXIT_SUCCESS : EXIT_FAILURE;
if (install_done(SIGHUP) ||
install_done(SIGINT) ||
install_done(SIGTERM)) {
fprintf(stderr, "Cannot install signal handlers: %s.\n", strerror(errno));
return EXIT_FAILURE;
buffer_data = malloc(buffer_size + 4);
if (!buffer_data) {
fprintf(stderr, "Not enough memory available for a %zu-byte input buffer.\n", buffer_size);
seed = prng_seed();
if (tty_open(argv[1])) {
if (errno)
fprintf(stderr, "%s: Cannot open device: %s.\n", argv[1], strerror(errno));
unsigned char request[8] = { seed & 255,
(seed >> 8) & 255,
(seed >> 16) & 255,
(seed >> 24) & 255,
(seed >> 32) & 255,
(seed >> 40) & 255,
(seed >> 48) & 255,
(seed >> 56) & 255 };
const unsigned char *const q = request + 8;
const unsigned char *p = request;
ssize_t n;
while (p < q) {
n = write(tty_descriptor, p, (size_t)(q - p));
if (n > 0) {
p += n;
} else
if (n != -1) {
fprintf(stderr, "%s: Invalid write (%zd)\n", tty_path, n);
} else
if (errno != EINTR) {
fprintf(stderr, "%s: Write error: %s.\n", tty_path, strerror(errno));
if (p != q) {
tty_cleanup();
if (install_update()) {
fprintf(stderr, "Cannot create a periodic update signal: %s.\n", strerror(errno));
tty_cleanup();
if (clock_gettime(CLOCK_BOOTTIME, &started) == -1) {
fprintf(stderr, "Cannot read BOOTTIME clock: %s.\n", strerror(errno));
tty_cleanup();
} else
mark = started;
while (!done) {
if (update) {
struct timespec now;
if (clock_gettime(CLOCK_BOOTTIME, &now) == -1) {
tty_cleanup();
const double sec_last = seconds_between(now, mark);
const double mib_last = (double)received / (double)(MEGA);
const double sec_total = seconds_between(now, started);
const double mib_total = (double)(received + received_before) / (double)(MEGA);
if (sec_last > 0.0 && sec_total > 0.0) {
printf("%.3f MB in %.0f seconds (%.3f MB/s on average); %.3f MB in last %.3f seconds (%.3f MB/s); %" PRIu64 " numbers verified\n",
mib_total, sec_total, mib_total/sec_total,
mib_last, sec_last, mib_last/sec_last,
sequence);
fflush(stdout);
received_before += received;
received = 0;
mark = now;
update = 0;
// Receive more data?
if (buffer_have < buffer_size) {
ssize_t n = read(tty_descriptor, buffer_data + buffer_have, buffer_size - buffer_have);
if (n > 0) {
buffer_have += n;
received += n;
} else
if (n != -1) {
fprintf(stderr, "%s: Unexpected read error (%zd).\n", tty_path, n);
tty_cleanup();
} else
fprintf(stderr, "%s: Read error: %s.\n", tty_path, strerror(errno));
tty_cleanup();
// Verify all full words thus far received.
if (buffer_have > 3) {
const unsigned char *next = buffer_data;
const unsigned char *const ends = buffer_data + buffer_have;
while (next + 4 <= ends) {
uint32_t u = (uint32_t)(next[0])
| ((uint32_t)(next[1]) << 8)
| ((uint32_t)(next[2]) << 16)
| ((uint32_t)(next[3]) << 24);
if (u == prng_u32()) {
sequence++;
next += 4;
fprintf(stderr, "Data mismatch at %" PRIu64 ". generated number.\n", sequence + 1);
tty_cleanup();
if (next < ends) {
memmove(buffer_data, next, (size_t)(ends - next));
buffer_have = (size_t)(ends - next);
buffer_have = 0;
tty_cleanup();
return EXIT_SUCCESS;
