I'm on my 5th iteration of a custom teensy board. The first 4 have worked, but, the current one is not, and, best I can tell the issue is DCDC_PSWITCH is at 2.3v instead of the 3.3v I see on my other boards.
Pin 1 of the bootloader is receiving 3.3v, and pin 3 of the bootloader is at 2.3v as well as R6 is at 2.3v.
1) would this apparently low voltage cause the teensy to not be recognized?
2) any idea what would cause the low voltage? Wrong r6 resistor value? Bad connection of the bootloader to the board? Short to ground?
Thanks.
Thanks.
