Tactif CIE
I've read several threads on the forum about generating clock signals, timer but I'm puzzled I don't see how to achieve what I want
I'm trying to use a T3.6 as a "glue" to an NMOS 6502 CPU - At this stage 28 meaningful signals from the 6502 are wired to Teensy pins and I triple checked the connections, and even arranged pins usage to be grouped by port with the future hope to handling ports instead of handling pins
I've spent countless hours trying to get some results without stable clock (main loop speed IS the clock) but I very often only get erratic behaviour from the CPU. Might be caused by a bunch of reasons : Me doing things the wrong way, wrong phase timing (clock HI, read address bus, clock LOW), or this NMOS 6502 could not really like being driven at 3.3v, or too much noise from the breadboard wiring forest...
But before giving up, or trying with a 65C02 (CMOS version which is known to be happy under 3.3v, even if some source says that 3.3v could be ok with some NMOS series) I would like to try something : generate a stable clock signal from a timer, A 1MHZ one - Of course there's https://www.pjrc.com/teensy/td_pulse.html but that does not seems to fit my bill because I need to run code during the HI state - Then attachInterrupt and try to get pin change for some signals (R/W and PHI2)
How can I do this ? I mean coding this fast interrupt timer... Is there a teensy lib that I've missed ? Or some example code somewhere ? Or I'm left with the K66P144M180SF5RMV2.pdf bible and dissecting the Teensy core lib ?
EDIT : I wonder if I could use a 1 microsecond IntervalTimer, that would mean 1 000 000 calls per second, which is 1MHZ
