Getting temp from MPU6050 that is returned in 2's compliment
KrisKasprzak
All,
I'm using an MPU605 with Teensy 3.2 and I'm trying to get the temp, which is returned in 16-bit 2's compliment. I've found some explanations on converting but my conversions are way off.
int16_t MPU6050::getTemperature() {
    I2Cdev::readBytes(devAddr, (MPU6050_IMU::MPU6050_RA_TEMP_OUT_H), 2, buffer);
    return (((int16_t)buffer[0]) << 8) | buffer[1];
My MCU and MPU605 are currently at around 73 deg f and the MPU6050 is returning -2857 or so.
Anyone have some code to go from 16-bit 2's compliment to it's decimal?
That actually looks correct to me. Look at the register map and the formula is:
Temperature in degrees C = (TEMP_OUT Register Value as a signed quantity)/340 + 36.53
For your example, I get 28 C, about 83 F. Considering it's die temperature, I would expect it to read a little higher than room temp.
Edit, here's a link to the register map for that IMU:
https://invensense.tdk.com/wp-content/uploads/2015/02/MPU-6000-Register-Map1.pdf
Also, I have a library for working with the InvenSense IMUs - currently it doesn't have the MPU-6050 in it, but shouldn't be hard to adapt to that sensor:
https://github.com/bolderflight/invensense-imu
Twos complement is just the typical number format used by machines.
From the MPU6050 register map and descriptions datasheet:
The temperature in degrees C for a given register value may be computed as:
-2857 / 340 + 36.53 = 28.127 degrees celsius = 82.63 degrees F.
My reply was beaten while looking stuff up.
