Improvements to FFT
h4yn0nnym0u5e
Hi folks
I've been tinkering with the FFT code in the audio library, and think I've made some improvements:
  • processing is now spread across update() calls, so the peak CPU load has dropped (slightly)
  • works with smaller values of AUDIO_BLOCK_SAMPLES, and some larger ones (up to the FFT size)
    • I could probably make it work with even larger block sizes, but mostly people want smaller to reduce latency
    • there was untested and broken code for 64-sample blocks, apparently for Teensy LC, dating from 2015: I removed this
  • AudioAnalyzeFFT1024 can now do averaging, as AudioAnalyzeFFT256 already could
  • there's now only one pair of files, analyze_fft.cpp and .h, as pretty much all the code is common to both classes
It should all work exactly the same as before for existing code, with the exception that AudioAnalyzeFFT1024 objects now consume an extra 2kB of RAM for the averaging. If that's a problem it'd be very easy to revert it, and add a new object called something like AudioAnalyzeFFT1024Averaging.
The relevant branch can be found here. As ever, if you try it and find issues, please post a simple sketch which demonstrates the problem, that can be compiled using the Arduino IDE, and that requires no extra hardware.
Sorry, but could explain the algorithm how you distribute, say a 1024 point FFT over eight 128 data blocks (i.e. 8 update() calls). This is not obvious from the code, at least to me.
To a large extent, I don't. I'm not even sure it's mathematically feasible to compute a partial FFT with only some of the data available, and finish it later... Someone with maths skillz will no doubt be along to clear that up :)
The original code stored 8 128-sample blocks, and every 4th update windowed all 1024 samples and computed the FFT, which means 1 in every 4 updates takes much more CPU. What I've done is to compute (part of) the windowed data on each update, and only compute the FFT on the 4th update. This is still more computationally intensive, but at least it spreads the load a bit better.
Additionally, I noticed that it's not necessary to store 8 blocks, only 4. On each update an old block is windowed and discarded, and the new block is stored (in the old block's slot) and windowed. For AudioAnalyzeFFT256 it's a bit simpler, because the FFT is just computed every 256 samples - there's no 50% overlap as there is with AudioAnalyzeFFT1024.
All the above changes with a change of AUDIO_BLOCK_SAMPLES, but that's now taken care of automatically at compile time - if you use 32-sample blocks, then 16 are stored and an FFT is computed every 16th update(). That wasn't the case before - the code just broke horribly due to being littered with magic numbers and assumptions that the value of AUDIO_BLOCK_SAMPLES would be 128.
The FFT requires all the data up-front before it can start. But you don't have to do all the FFT computation in one go once you have that data, you could do a few stages at a time on each update, but that would increase latency. A 1024 point FFT has 10 stages, so doing 3 per update would take 4 updates to finish for instance, not 1 update.
One issue with the standard FFT classes are they use 16 bit intermediate results, whereas for numerical precision you need more (guard bits). The result is the signal/noise ratio of the FFT spectra is definitely worse than it could be.
Does the ARM library give API access to each of those individual stages? I had a quick look and didn’t spot anything, but could easily have missed it, there was a lot of terminology that went way over my head :)
To my mind an extra 12ms of latency wouldn’t be a big issue, but I know Paul’s hot on keeping backwards compatibility so it’d probably be a case of adding a couple of new FFT classes … at which point improvement to the S/N ratio would be on the table.
Thinking about it, it would possibly make sense to do only windowing into the buffer in the audio update(), and have the read-out methods do the FFT. It uses about 4% CPU every 12ms, and there must be many applications which don’t need a new set of values that often.
@h4yn0nnym0u5e , I guess your approach is not good, and is destroying the spectrum.
For an 1024 point FFT you need 1024 points spanning 8 blocks of 128 samples. Of course, you can construct your own algorithm and process the 8 blocks individually and combine the frequencies. For this to work efficiently, the algorithm consists of 1024 point FFT on 128 input samples, with pruning the zero data that is they do not contributing to the calculation. Every 1024 pt FFT would then work on different 128 samples. The results (frequencies) are then accumulate appropriately. Pruning algorithms for the first 128 samples are trivial and published years and years ago. I have not seen algorithms that have pruning in the beginning and end of the timeseries, but as FFT assume cyclic data, this may be possible.
I don't think I've destroyed anything, though I'm prepared to be proved wrong :) I've probably explained myself poorly, though...
The 1024 point FFT is done on 1024 points taken from 8 consecutive blocks, as before. However, what I've improved (I think) is to copy each block to the buffer as it is received, windowing it using the relevant section of the 1024-value window array. In the old code all the copying was done when the 8th block arrived, followed by another pass across the buffer to apply the window. The copy / window is not a huge burden compared to the FFT, of course, it's just a bunch of multiplications, so there's still a spike in CPU use when the FFT is done, just it's smaller by about 0.3% (4.15% down to 3.85%, but some of that is other audio processing).
Sorry for reviving this but, i'm really confused about whether FFT256 uses 50% overlap or not.
At above and many other posts, people say FFT256 does not use 50% overlap. Even at the official "Advanced Microcontroller Audio Workshop" page 29, states that "Teensy Audio Library uses 50% overlap in its fft1024 object", implying FFT256 object doesn't use 50% overlap.
But, AudioAnalyzeFFT256 documentation at "Audio System Design Tool" states that "New data is produced very radidly, approximately 344 times per second" at averageTogether() method description, which mathematically means FFT256 uses 50% overlap. Because that coincides with the update() call frequency of 344, so FFT256 (w/o averaging) must output result at every update() with 128 new samples, which is only possible by using 50% overlap.
Also, looking AudioAnalyzeFFT256 code line 98, seems like 50% overlap implementation:
C++:
release(prevblock);
prevblock = block;
Just as in AudioAnalyzeFFT1024 code line 118.
So, my conclusion is that FFT256 does use 50% overlap as well, producing result every ~2.9 ms, being every audio update() call, when averaging is not used (by averageTogether(1)). Is this correct?
I think you're correct. I need to dig out / create a test sketch to make sure I've reproduced the output of the original code accurately, while making it more efficient ...
OK, I've hacked together a test sketch which can compare the old and new FFTs. I'm fairly content that they produce identical results where possible (which I'm sure I would've tested, though I can't find the relevant code...). I can't compare the averaging for the FFT1024, because the old version didn't implement it.
As you say, the FFT256 does use an overlap on every update(). However, in a fit of poor documentation, it fails to mention that it defaults to averaging over 8 updates, so it doesn't produce new data at 344Hz, but 43Hz. That should be sensible for most use cases, but you'd have to explicitly apply averageTogether(1) if you wanted 344Hz updates.
Test sketch attached - use the Audio library branch with the updated FFTs: the sketch contains its own copies of the original FFT files for comparison.
  • TestBetterFFT.zip
Ok, thank you for the clarification.
For the sake of completeness, here is a table showing output generation rates of FFT objects, in their original source codes, sorted by their result generation rates, from more frequent to less frequent.
|                     | result every | result every |  N results   |
|                     |  N updates   |     N ms     |  per second  |
| FFT256 w/o aver.    |      1       |     ~2.9     |     344      |
| FFT1024 (no aver.)  |      4       |    ~11.6     |      86      |
| FFT256 def.aver.(8) |      8       |    ~23.2     |      43      |
Just an addendum to my earlier comment about FFT precision, I've some simulation of this is Python to demonstrate how much information the 16-bit FFTs lose for quiet signal components - comparing precise FFT on 16 bit data to various levels of fixed-point precision from 16 to 24 bits, with N=4096:
The last plot in green uses data where the individual tones were mixed at 16 bit precision (rather than being summed as doubles and then quantized) - this means 7 lots of quantization noise instead of 1, raising the noise floor 8.5dB or so.
Also note that the red trace has 128-fold spectrum averaging to make the noise floor flatter, the others are un-averaged spectra. The flat floors in some are simply a reflection that the FFT bins are zero to the relevant resolution.
I think its true that a 2^N FFT needs about N guard bits in its calculation to reveal all the information, certainly 24 bits to calculate FFT for 16 bit data is clearly way better than 16 bit calculation.
Please note, my intention for these improvements was solely to fix bugs, allow use of different audio block sizes, improve efficiency (slightly) and improve versatility (add 1024-point averaging), while retaining compatibility with the original code - same input gives same output. As the original uses the opaque ARM q15 FFT code, that’s retained.
If it’s possible to get a better noise floor etc. for the same (or less) CPU load, and a reasonably similar memory footprint (Flash and RAM), I’d imagine that would be a very acceptable PR. It’s also way outside my skill set and enthusiasm envelope…
I do wonder if the Audio library should have some speed v. quality configuration setting - on T4.x high quality could mean using floats rather than 16 bit fixed-point. I know its a lot of work of course...
It’s not only a lot of work, but would probably just compound the existing maintenance nightmare.
For the standard 16-bit audio library, there are 59 outstanding PRs, 82 issues, and the version number hasn’t changed in 10 years despite most source files being more recent than that.
The float library only has 13 PRs and 13 issues, and gets round the version number problem by simply not having one, so the user has no false sense that someone’s keeping track of stuff.
As both these libraries can be used together, there’s usually a way of hacking up a suitable mix of speed and quality for any given application.
It would be fantastic if some of the recent (i.e. “in the last 5+ years or so”) innovations could be rolled in sometime. There are some great effects, improvements to various synth modules, way better filesystem playback and recording etc. all just waiting in the wings for a wider audience. Proper use of branches in GitHub (rather than just chucking everything into master) would allow development and testing of such an all-singing all-dancing Audio 2.0 library, ready to be included in Teensyduino once it’d gained a bit of maturity, while still allowing audio enthusiasts a one stop shop for all the innovations rather than having to piece stuff together from multiple sources.
