screaminkleeman
Just looking for a quick gut-check on choosing an appropriate MOSFET and calculating the resistors properly. I'm a software guy and never really "got it" with electronics.
I have done this same setup with an older Teensy 3.x and a TIP120 MOSFET, but am now using a Teensy 4.0 and notice that the max pin current is lower so I'd rather not fry it (and my research suggests that the TIP120 is not the best choice for several reasons aside from lack of availability).
I'm using the PWM pins for dimmable lighting using white 3.3v/20mA LEDs varying from 6 at a time up to 40 so I need up to 800 mA (my diagram only shows 3 for simplicity).
I'm using an external 5V/6A power supply, and landed on this MOSFET:
https://www.mouser.com/ProductDetail/Microchip-Technology/VN3205N3-G?qs=M32N5aAaIfN9C45hhAlIdQ==
Have I selected an appropriate MOSFET and have I calculated the resistors correctly?
And follow-up, If I wanted to do the same thing with a 24V RGB LED strip, I'd be looking at this MOSFET:
https://www.mouser.com/ProductDetail/Diodes-Incorporated/DMT6009LCT?qs=rN85NNvew/SKNXyjWLi4/w==
TIA for your input!
TIA for your input!
