I've just got a 8x8 Neo Trellis and soldered 2 out of the 4 boards together and then tested it using the i2c_address_detect script and its not detecting it:
I have it connected to the Teensy 4.1 as follows:
SDA > 18
SCL > 19
GND > GND
VIN > 3.3V
INT > not connected as using the onboard connector
I've soldered the A0 pad together on the 2nd board but as far as I understand it it should be detecting the 1st board regardless of any dodgy soldering or address mistakes on the 2nd board.
I2C address detection test
Did not find device at 0x10
SDA > 18
SCL > 19
GND > GND
VIN > 3.3V
#include <Adafruit_I2CDevice.h>
Adafruit_I2CDevice i2c_dev = Adafruit_I2CDevice(0x10);
while (!Serial) { delay(10); }
Serial.println("I2C address detection test");
if (!i2c_dev.begin()) {
Serial.print("Did not find device at 0x");
Serial.println(i2c_dev.address(), HEX);
while (1);
Serial.print("Device found on address 0x");
