C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Paultop\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Paultop\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Paultop\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10804 -build-path C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705 -warnings=none -build-cache C:\Users\Paultop\AppData\Local\Temp\arduino_cache_149425 -verbose C:\Users\Paultop\Documents\Arduino\TBG_Graph\TBG_Graph.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Paultop\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Paultop\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Paultop\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10804 -build-path C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705 -warnings=none -build-cache C:\Users\Paultop\AppData\Local\Temp\arduino_cache_149425 -verbose C:\Users\Paultop\Documents\Arduino\TBG_Graph\TBG_Graph.ino
Using board 'teensy35' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Build options changed, rebuilding all
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\TBG_Graph.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\HSBColor.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\OctoWS2811.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\bitmap.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\TBG_Graph.ino.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\HSBColor.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\HSBColor.cpp.o"
HSBColor.cpp: In function 'int H2R_HSBtoRGB(int, int, int)':
HSBColor.cpp:11: warning: variable 'colors' set but not used
byte colors[3];
HSBColor.cpp:84: warning: control reaches end of non-void function
HSBColor.cpp:79: warning: 'g' may be used uninitialized in this function
color = g<<8 | color ;
HSBColor.cpp:78: warning: 'r' may be used uninitialized in this function
color = r<<16 | color ;
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\OctoWS2811.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\OctoWS2811.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\TBG_Graph.ino.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\TBG_Graph.ino.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\bitmap.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\bitmap.cpp.o"
Compiling libraries...
Compiling core...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\math_helper.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\mk20dx128.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\pins_teensy.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\ser_print.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial1.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial2.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial3.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial4.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial5.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial6.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial6.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial6_lpuart.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial6_lpuart.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\touch.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_desc.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_dev.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_dev.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_joystick.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_joystick.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_keyboard.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_keyboard.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mem.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mem.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_midi.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_midi.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mouse.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mouse.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mtp.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mtp.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_rawhid.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_seremu.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_serial.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_touch.c" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\AudioStream.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\DMAChannel.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\EventResponder.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\EventResponder.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial1.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial2.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial3.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial4.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial5.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IPAddress.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\avr_emulation.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\main.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_audio.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_flightsim.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10804 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\yield.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\math_helper.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\mk20dx128.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\pins_teensy.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\ser_print.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial1.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial2.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial3.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial4.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial5.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial6.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\serial6_lpuart.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_dev.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_joystick.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_keyboard.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mem.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_midi.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mouse.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_mtp.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\EventResponder.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\avr_emulation.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\main.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_audio.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_flightsim.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\core.a" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\core\yield.cpp.o"
Archiving built core (caching) in: C:\Users\Paultop\AppData\Local\Temp\arduino_cache_149425\core\core_teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1523959906 "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/mk64fx512.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.elf" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\HSBColor.cpp.o" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\OctoWS2811.cpp.o" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\TBG_Graph.ino.cpp.o" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705\sketch\bitmap.cpp.o" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/core\core.a" "-LC:\Users\Paultop\AppData\Local\Temp\arduino_build_767705" -larm_cortexM4lf_math -lm
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.elf" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.elf" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/stdout_redirect" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.lst" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.elf"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/stdout_redirect" "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.sym" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705/TBG_Graph.ino.elf"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile" "-file=TBG_Graph.ino" "-path=C:\Users\Paultop\AppData\Local\Temp\arduino_build_767705" "-tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" "-board=TEENSY35"
Sketch uses 25564 bytes (4%) of program storage space. Maximum is 524288 bytes.
Global variables use 17860 bytes (9%) of dynamic memory, leaving 178748 bytes for local variables. Maximum is 196608 bytes.
