Porting moog ladder filters to audio objects?
Hello all, I'm super excited to use the filter. Flo mentioned it's in the "official" audio library now, but I don't see it in the GUI tool. Any tips on where to find it?
Hi Florian, good to hear you're enjoying the filter. On my system, I get 7% for POLY_FIR, and 5% for LINEAR. To reduce it further I suggest going to 2x oversampling. However, that requires a different set of FIR coefficients. The ones from the newer filter that already runs at 2x should be fine, but they are 32pt rather than 36 so the changes to the .h file include changing both INTERPOLATION from 4 to 2, and interpolation_taps form 36 to 32.
Hi Richard,
thank you, I changed the coefficients and corrected the bug you found in the poly update routine and now it works great with relatively low CPU usage (also 4% for 2x oversampling and linear interpolation on my system).
I will also have a look at the full model, but unfortunately, I need to economise on my CPU ressources.
Hello TigerBalm,
weird, I noticed too that somehow, there are different versions of the gui tool. (with different indexes? :confused:)
This here -> https://www.pjrc.com/teensy/gui/ does not include the filter, whereas
this here -> https://www.pjrc.com/teensy/gui/index2.html?info=AudioFilterLadder
has it in.
Greetings, flo
Here is an update of the new full-model filter_ladder2, which corrects a few minor issues, and adds linear interpolation as an option in the same way as the existing ladder filter.
filter_ladder2.cpp
/* Audio Library for Teensy, Ladder Filter
 * Copyright (c) 2021, Richard van Hoesel
 * THE SOFTWARE.
// AudioFilterLadder2 for Teensy Audio Library
// Based on Huovilainen's full model, presented at DAFX 2004
// Richard van Hoesel, March. 11, 2021
// v.1.02 includes linear interpolation option
// v.1.01 Adds a "resonanceLoudness" parameter (1.0 - 10.0)
//        to control resonance loudness
// v.1.0 Uses 2x oversampling. Host resonance range is 0-1.0.
// please retain this header if you use this code.
#include <Arduino.h>
#include "filter_ladder2.h"
#include "arm_math.h"
#include <math.h>
#include <stdint.h>
#define MAX_RESONANCE ((float)1.015)
#define MAX_FREQUENCY ((float)(AUDIO_SAMPLE_RATE_EXACT * 0.425f))
#define fI_NUM_SAMPLES  AUDIO_BLOCK_SAMPLES * INTERPOLATION
//=== 2 xOS, 32taps (88.2kHz)
static float AudioFilterLadder2 ::finterpolation_coeffs[AudioFilterLadder2::finterpolation_taps] = {
-129.6800658538650740E-6, 0.001562843504973615, 0.004914813078250063, 0.007186231102125209, 0.002728024844356039,-0.007973931496234599,-0.013255882861166815,-841.1646993462468340E-6,
 0.022309967341058432, 0.027240071522569135,-0.007073857882406733,-0.056523975383091875,-0.055929860712812876, 0.042278471323346570, 0.207056768528768836, 0.335633514003638445,
 0.335633514003638445, 0.207056768528768836, 0.042278471323346570,-0.055929860712812876,-0.056523975383091875,-0.007073857882406733, 0.027240071522569135, 0.022309967341058432,
-841.1646993462468340E-6,-0.013255882861166815,-0.007973931496234599, 0.002728024844356039, 0.007186231102125209, 0.004914813078250063, 0.001562843504973615,-129.6800658538650740E-6
void AudioFilterLadder2::initpoly()
  if (arm_fir_interpolate_init_f32(&interpolation, INTERPOLATION, finterpolation_taps,
     finterpolation_coeffs, finterpolation_state, AUDIO_BLOCK_SAMPLES)) {
    polyCapable = false;
    return;
  if (arm_fir_decimate_init_f32(&decimation, finterpolation_taps, INTERPOLATION,
     finterpolation_coeffs, fdecimation_state, fI_NUM_SAMPLES)) {
    return;
  // TODO: should we fill interpolation_state & decimation_state with zeros?
  polyCapable = true;
  polyOn = true;
void AudioFilterLadder2::interpolationMethod(AudioFilterLadderInterpolation imethod)
  if (imethod == LADDER_FILTER_INTERPOLATION_FIR_POLY && polyCapable == true) {
    // TODO: if polyOn == false, clear interpolation_state & decimation_state ??
    polyOn = true;
    polyOn = false;
void AudioFilterLadder2::resonanceLoudness(float v)  // input 1-10
  if(v<1) v=1;
  if(v>10) v=10;
  VTx2 =  v;
  inv2VT = 1.0/VTx2;
static inline float fast_exp2f(float x)
  float i;
  float f = modff(x, &i);
  f *= 0.693147f / 256.0f;
  f += 1.0f;
  f *= f;
  f *= f;
  f *= f;
  f *= f;
  f *= f;
  f *= f;
  f *= f;
  f *= f;
  f = ldexpf(f, i);
  return f;
void AudioFilterLadder2::inputDrive(float drive)
  if(drive<1)
      overdrive = 1.0f;
  if(drive>3)
     overdrive =  3.0f;
    overdrive = drive;
void AudioFilterLadder2::portamento(float pc)
  FcPorta = pc;
void AudioFilterLadder2::compute_coeffs(float freq, float res) // tuned for 2x os
    float fc, freq2, freq3;
    if (res > MAX_RESONANCE) res = MAX_RESONANCE ;
    if (res < 0.0f) res = 0.0f;    if (freq < 5) freq = 5;
    if (freq > MAX_FREQUENCY) freq = MAX_FREQUENCY;
    fc = freq *  FC_SCALER;
    freq2 = freq*freq;
    freq3 = freq2 * freq;
    float qa = 0.998f + 3.5e-5f * freq - 8e-10f * freq2 - 4e-14f * freq3;
    K = 4.0f * res * qa;
    float fa = 1.0036f - 2e-5f *freq + 1e-9f*freq2   - 1.75e-14f * freq3;
    Gx2Vt = float((1.0f - exp(-fc * fa)) * VTx2);
void AudioFilterLadder2::frequency(float c)
    if (c < 1) c = 1;
    if (c > MAX_FREQUENCY) c = MAX_FREQUENCY;
    targetFbase = c;
    //Fbase = c;
void AudioFilterLadder2::resonance(float res)
    res *= MAX_RESONANCE;                                 // normalize so host specifies 0-1 rather than 0-1.015
    Qbase = res;
void AudioFilterLadder2::octaveControl(float octaves)
  if (octaves > 10.0f) {             // increased range compared to previous filters to span full audio range with 0-1 envelope
    octaves = 10.0f;
  } else if (octaves < 0.0f) {
    octaves = 0.0f;
  octaveScale = octaves / 32768.0f;
static inline float fast_tanh(float x)
  if(x>3) return 1;
  if(x<-3) return -1;
  float x2 = x * x;
  return x * (27.0f + x2) / (27.0f + 9.0f * x2);
bool AudioFilterLadder2::resonating()
  for (int i=0; i < 4; i++) {
    if (fabsf(z0[i]) > 0.0001f) return true;
    if (fabsf(z1[i]) > 0.0001f) return true;
  return false;
void AudioFilterLadder2::update(void)
  audio_block_t *blocka, *blockb, *blockc;
  float ftot, qtot;
  bool FCmodActive = true;
  bool QmodActive = true;
      blocka = receiveWritable(0);
      blockb = receiveReadOnly(1);
      blockc = receiveReadOnly(2);
      if (!blocka) {
        if (resonating()) {
          // When no data arrives but the filter is still
          // resonating, we must continue computing the filter
          // with zero input to sustain the resonance
          blocka = allocate();
        if (!blocka) {
          if (blockb) release(blockb);
          if (blockc) release(blockc);
          return;
        for (int i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
          blocka->data[i] = 0;
      if (!blockb) {
        FCmodActive = false;
        ftot = Fbase;
      if (!blockc) {
        QmodActive = false;
        qtot = Qbase;
      float blockOut[AUDIO_BLOCK_SAMPLES];
      if (polyOn == true) {
        float blockIn[AUDIO_BLOCK_SAMPLES];
        float blockOS[fI_NUM_SAMPLES], blockOutOS[fI_NUM_SAMPLES];
          blockIn[i] = blocka->data[i]  * overdrive *  float(INTERPOLATION /32768.0f);
        arm_fir_interpolate_f32(&interpolation, blockIn, blockOS, AUDIO_BLOCK_SAMPLES);
          Fbase = FcPorta * Fbase + (1-FcPorta) * targetFbase;
          ftot = Fbase;
          if (FCmodActive) {
            float FCmod = blockb->data[i] * octaveScale;
            ftot = Fbase * fast_exp2f(FCmod);
          if (QmodActive) {
            float Qmod = blockc->data[i] * (1.0f/32768.0f);
            qtot = Qbase + Qmod;
          compute_coeffs(ftot,qtot) ;
          for(int os = 0; os < INTERPOLATION; os++)
            float input = blockOS[i * INTERPOLATION + os];
            filter_y1 = filter_y1 + Gx2Vt * (fast_tanh((input - K * filter_out) * inv2VT) - save_tan1);
            save_tan1=  fast_tanh(filter_y1 * inv2VT);
            filter_y2 = filter_y2 + Gx2Vt * (save_tan1 - save_tan2);
            save_tan2 = fast_tanh(filter_y2 * inv2VT);
            filter_y3 = filter_y3 + Gx2Vt * (save_tan2 - save_tan3);
            save_tan3 = fast_tanh(filter_y3 * inv2VT);
            filter_y4 = filter_y4 + Gx2Vt * (save_tan3 - fast_tanh(filter_y4 * inv2VT));
            filter_out = (filter_y4 + filter_y5) * 0.5f;
            filter_y5 = filter_y4;
            blockOutOS[i*INTERPOLATION + os] = filter_out;
        arm_fir_decimate_f32(&decimation, blockOutOS, blockOut, fI_NUM_SAMPLES);
      else {
          if (FCmodActive) {
          if (QmodActive) {
          float total = 0.0f;
          float interp = 0.0f;
          float input = blocka->data[i] * overdrive * (1.0f/32768.0f);
          for (int os = 0; os < INTERPOLATION; os++) {
            float inputOS = (interp * oldinput + (1.0f - interp) * input);
            filter_y1 = filter_y1 + Gx2Vt * (fast_tanh((inputOS - K * filter_out) * inv2VT) - save_tan1);
            total += filter_out * (1.0f / (float)INTERPOLATION);
            interp += (1.0f / (float)INTERPOLATION);
          blockOut[i] = total;
          oldinput = input;
      float absblk;
        absblk = 1.25f * blockOut[i];
        if(absblk<0) absblk=-absblk;
        if(absblk > 1)
           if(absblk > peak)
              peak = absblk;
        if(peak>1){
          pgain = 0.99f * pgain + 0.01f/peak;    // fast attack
          peak *=0.99995f;
        blocka->data[i] = blockOut[i]  * pgain * float(0.85f * float(32767.0));
      transmit(blocka);
      release(blocka);
filter_ladder2.h
 * THE SOFTWARE.
// https://forum.pjrc.com/threads/60488?p=269609&viewfull=1#post269609
#ifndef filter_ladder2_h_
#define filter_ladder2_h_
#include "Arduino.h"
#include "AudioStream.h"
#define MOOG_PI ((float)3.14159265358979323846264338327950288)
class AudioFilterLadder2: public AudioStream
public:
  AudioFilterLadder2() : AudioStream(3, inputQueueArray) { initpoly(); };
  void frequency(float FC);
  void resonance(float reson);
  void octaveControl(float octaves);
  void inputDrive(float drive);
  void portamento(float pcf);
  void compute_coeffs(float freq, float res);
  void initpoly();
  void interpolationMethod(AudioFilterLadderInterpolation im);
  void resonanceLoudness(float v);
  virtual void update(void);
private:
  static const int INTERPOLATION = 2;
  static const int finterpolation_taps = 32;
  static const float FC_SCALER = 2.0f * MOOG_PI / (INTERPOLATION * AUDIO_SAMPLE_RATE_EXACT);
  float finterpolation_state[(AUDIO_BLOCK_SAMPLES-1) + finterpolation_taps / INTERPOLATION];
  arm_fir_interpolate_instance_f32 interpolation;
  float fdecimation_state[(AUDIO_BLOCK_SAMPLES*INTERPOLATION-1) + finterpolation_taps];
  arm_fir_decimate_instance_f32 decimation;
  static float finterpolation_coeffs[finterpolation_taps];
  float Gx2Vt, K, filter_res, filter_y1, filter_y2, filter_y3, filter_y4, filter_y5, filter_out;
  float VTx2 = 5;
  float inv2VT = 1.0/VTx2;
  float Fbase=1000, Qbase=0.5;
  float overdrive=1;
  float ftot=Fbase, qtot=Qbase;
  bool  resonating();
  bool  polyCapable = false;
  bool  polyOn = false;    // FIR is default after initpoly()
  float octaveScale = 1.0f/32768.0f;
  float z0[4] = {0.0, 0.0, 0.0, 0.0};
  float z1[4] = {0.0, 0.0, 0.0, 0.0};
  float pbg=0;
  float save_tan1=0;
  float save_tan2=0;
  float save_tan4=0;
  float save_tan3=0;
  float peak=1.0;
  float pgain=1.0;
  float targetFbase = 1000;
  float FcPorta = 0;
  float oldinput=0;
  audio_block_t *inputQueueArray[3];
I want to experiment with the Audio Library version of this filter. As suggested by Paul in message #50 of this thread, I downloaded a zip version of https://github.com/PaulStoffregen/Audio and unzipped it to {Documents}/Arduino/libraries but it wasn't successful. I tried to run the example in message #50 and it didn't recognize the new filter class.
Is there a better way to get the ladder filter into my Arduino 1.8.13 environment?
I'd put it in your sketchbook/libraries - check the compiler versbose output as this should confirm which libraries are
being used.
The sketches on my windows 10 machine are located in {Documents}/Arduino/libraries. That is where I put it. The compiler said it found two Audio.h files and it automatically chose the original Audio.h.
I did finally got it to work by temporarily changing the name of the ladder filter Audio.h to temp_Audio,h and used #include temp_Audio.h in the sketch. I thought that if I put it in {Documents}/Arduino/libraries it was supposed to take precedence, but I guess that was an incorrect assumption.
I am running my project at 96000 Hz. Before I proceed I want to check an assumption I am making.
If, for example, I run the four stage ladder filter AudioFilterLadder::update() at a 88000 Hz rate and if I modify the ladder filter code to eliminate any interpolation, is that equivalent to running the ladder filter at 44000 Hz with INTERPOLATION = 2?
Hello good people,
I'm from the Axoloti world and just received my Teensy 4.0 board with the Audio Shield. Having fun testing out the capabilities and I'm impressed so far. I'd like to "port" a project of mine that's a Moog Taurus Bass Pedal emulator. I started this project as a Pure-Data model a few years back and I did use a model of Antti Huovilainen's Moog filter. It is excellent! Now, imagine my excitement when I discovered your thread!
Now, I've played with the "Ladder" filter that's included in the Audio library but I can't seem to figure out how can I use the updated (full model) version of this filter. Maybe I'm using the wrong dev tools? I'm using the basic Arduino/Teensyduino IDE. Thanks in advance guys and sorry for reviving an old thread.
Marc aka Khorus
PS: For the curious mind, here's a video of my current Taurus emulator that runs on Axoloti Core. https://www.facebook.com/727063099/videos/250096457328671/
My full model version of the filter isn't available through the standard audio library. You will have to copy the cpp and h files from my post #204 above and include them manually, either as stand alone files in your project directory (probably the easiest solution), or else incorporate them into your local version of the audio library.
Cheers,
Richard
Richard, I'm using your filter and it sounds amazing. It growls gracefully, my respect!
Have you ever looked into the following paper, written by
Stefan D'Angelo (Arturia's VA plugins & Neural DSP) and the legendary Vesa Välimäki?
An improved virtual analog model of the Moog ladder filter
Abstract:
In this paper we derive a novel circuit-based model for the Moog filter and discretize it using the bilinear transform. The proposed nonlinear digital filter compares favorably against Huovilainen's model, which is the best previous white-box model for the Moog filter. The harmonic distortion characteristics of the proposed model match closely with those of a SPICE simulation. Furthermore, the novel model realistically enters the self-oscillation mode and maintains it. The proposed model requires only 12 more basic operations per output sample than Huovilainen's model, but includes the same number of nonlinear functions, which dominate the computational load. The novel nonlinear digital filter is applicable in virtual analog music synthesis and in musical audio effects processing.
Abstract:
Yes, I've looked at Stefan's papers in the past. I was hoping to get around to trying out some of his ideas but haven't yet, and they're not trivial to implement if I remember correctly.
A bit strange to jump on a post that’s so old but read through this thread last night and was massively impressed at the effort. As a synth guy coming here and finding this filter and being able to use it. Hats off to you @rvh it sounds awesome and I have taken a copy of the code in post #204
I’m a believer in credit where credit is due and you have done an awesome job in creating a moog filter and the method and persistence you used is awesome.
I do wonder if you ever created any of the other filter types from the paper as well or maybe you’ve moved on to different fields.
Anyway just wanted to say thanks for the awesome filter
Thanks for your message and kind words. It's always good to see past efforts going to good use. I have since these posts also developed a zero-delay version of the ladder filter. It's computationally more expensive than the filters I posted here, and I can't really share it as it's part of a commercial product. But for anyone interested in pursuing that approach, I highly recommend "The art of VA filter design (2015)" by Vadim Zavalishin.
Took your advice and ended up printing off the book. I have used AI many times to try and build something that would work. Finally I have a va filter bank. It’s designed to drop in to other projects. It’ll get better with time but I’ve been focusing on finishing this project 1st
Many thanks for the inspiration (not so much for the complexity of software filters) the amount of time I chased collapsing maths. Then found out that changing one variable from int to float made it all work.
Now these are the 1st release. Oh obxa filter also in here just because I really like it.
This is all open source I will not be pursuing any products from this branch. So I hope people like the filters. Small changes to the resonance values can give you sore ears and crash the teensy.
Current project includes audiofiltervabank and audiofilterOBXa_OBXF
Code
can be pulled in to any project though as i tried to make it compatible
