Hi @all
Another Friday passed (i usually work on friday on my project) and after the problems with the IDE are solved i wanted to test some code.
Actually quite easy code read the button state on a pin and if the button is pressed it should trigger a relais to turn of or on depending on the previous state.
So wired up everything and instantly the relays went amok(turning of and on 3-6 times a second). So my first guess was that i receive all the time button state 1 so it tries to turn of and on every loop.
so i wired a little lamp into the circuit so see what happens. And the behaviour this lamp showed i made a video of it because i couldn't explain what happens.
https://goo.gl/photos/rtbu3QevH6r5LkUT6
(so no teensy included in this circuit) As you can see after the first 3 times it starts to delay or something, sometimes the lamp even stopped going on for several pushes. Anyone a idea whats going on here?
So i had the thing already once tested on a breadboard. (because i'm a completely beginner)
https://goo.gl/photos/RYwmQoQbiYfYpNnh8
there everything worked as expected... but i actually lost my code from past there...
So the funny thing was yesterday that if i wired the button to the pin 19 i always received state 1 on the serial monitor. if i wired it to the 23 i firstly didn't get any output so i would expect 0 until the first time i pressed the button from then on it kept it state to 1 independent of time and other button pushes. Did use the wrong method to read the pin?
and by the way whats the difference between digitalRead and digitalReadFast?
regards sev
#define USE_OCTOWS2811
#include "Table.h"
#include<OctoWS2811.h>
#include<FastLED.h>
#define NUM_LEDS_PER_STRIP 164
#define NUM_STRIPS 8
int numOfTopLeds= 168;
int numOfFrontLeds= 0;
int numOfLeftLeds= 0;
int numOfRightLeds= 0;
int numOfBackLeds= 0;
int numOfFeetLeds= 7;
const int maxBrightness=150;
int currentBrigthness =130;
Table table = Table();
//TODO need to check the pins in reality. these are just some random numbers.
//pin 18 is the airpump
int buttonMutePumpPin = 23;
int buttonBrightnessPin = 19;
int buttonNextAnimationPin =20;
int buttonUnknownsPin=21;
bool isButtonTogglePumpPressed =false;
bool isButtonBrightnessPressed=false;
bool isButtonNextAnimationPressed=false;
bool isButtonUnknownPressed=false;
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
Table::Table() {
// TODO Auto-generated constructor stub
Table::~Table() {
// TODO Auto-generated destructor stub
LEDS.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP);
//LEDS.addLeds(leds, 164);
LEDS.setBrightness(currentBrigthness);
FastLED.setBrightness(currentBrigthness);
pinMode(buttonMutePumpPin, INPUT);
pinMode(buttonBrightnessPin, INPUT);
pinMode(buttonNextAnimationPin, INPUT);
pinMode(buttonUnknownsPin, INPUT);
void Table::updateButtonStates(){
isButtonTogglePumpPressed=0;
bool isButtonTogglePumpPressed =digitalRead(buttonMutePumpPin);
bool isButtonBrightnessPressed=digitalRead(buttonBrightnessPin);
isButtonNextAnimationPressed=digitalRead(buttonNextAnimationPin);
isButtonUnknownPressed=digitalRead(buttonUnknownsPin);
if(isButtonTogglePumpPressed){
//table.airpump.toogleAirpumpState();
Serial.println(isButtonTogglePumpPressed);
if(isButtonBrightnessPressed){
currentBrigthness = currentBrigthness + 15;
if(currentBrigthness > maxBrightness){
currentBrigthness =10;
void someAnymation() {
static uint8_t hue = 0;
for (int i = 0; i < NUM_STRIPS; i++) {
for (int j = 0; j < NUM_LEDS_PER_STRIP; j++) {
leds[(i * NUM_LEDS_PER_STRIP) + j] = CHSV((32 * i) + hue + j, 192,
255);
// Set the first n leds on each strip to show which strip it is
for (int j = 0; j <= i; j++) {
leds[(i * NUM_LEDS_PER_STRIP) + j] = CRGB::Red;
hue++;
someAnymation();
//Fire2012();
LEDS.show();
LEDS.delay(10);
table.updateButtonStates();
regards sev
