I noticed the Wire.requestFrom( ) function signature has the quantity declared as a uint8_t, so I digged into the source code and found that the i2c buffer length for Teensy 3.2 (mk20dx256) is defined to be 72 bytes in WireKinetis.h
Is this a hardware limit of the chip? What happens if I increase this buffer size?
I'm writing a driver for the FLIR Lepton thermal camera. According to the datasheet, some i2c transfers may go up to 1KB in length.
