TelephoneBill
I would like to experiment with the Teensy 3.5 comparators.
I know that Teensy 3.5 has 5 volt tolerance on digital pins. Does this also apply if I map a comparator input to for example Port C6 (Teensy Pin 11)?
I'm wondering what the issue is about 5v tolerance - is this only if a pin is in digital mode and is not the case for the internal analogue circuitry (such as comparators and ADC)? The signal I'm looking at sometimes peaks around 4 volts.
