OK, let me add some more detail about what I'm trying to sort out…
I have all the key parts of the project working separately, and have made everything (decoding TPMS, sensor inputs, output to display) work together with a different display, but can't yet achieve that with the Newhaven 4.3" display. My problem is getting the Teensy 4.0 talking properly to the CC1101 and the display at the same time.
I am currently trying to get the two SPI devices working on the main SPI bus, so have:
pin 11 - MOSI on both display and CC1101
pin 12 - MISO on both display and CC1101
pin 13 - SCK on both display and CC1101
pin 10 - CS on display
pin 27 - CS on CC1101
Both CC1101 and display are hooked up to +3.3V and GND, and the backlight power on the display to +5V
there's also a MicroSD card connected via an adapter, and a variable pot for an input to test analogue sensor inputs on A1, A2, A3 - these seem to be working OK
With this wiring, I can run EITHER a sketch that makes the display work with the dummy/temporary sensor inputs, OR a sketch that receives and decodes the TPMS data (shows it on serial monitor), but I can't seem to combine the code from both to get everything working at once - I've had a few attempts, and the best I've managed is the Newhaven display working with a sensor input for a few tens of seconds, and the CC1101 reporting to the serial monitor that it's being recognised correctly (as in Part and Version number are not both reported as zero, but no TPMS data reported)
I have an idea that it might be better to use separate SPI buses for the Newhaven display and the CC1101, but I'm not sure how to do this, and I clearly don't know how to get both these SPI devices working on the same bus properly.
Any pointers would be appreciated - I suspect I'm just missing/unaware of something quite basic
So this is the sketch for the display and test sensor inputs (thanks to TFTLCDCyg for writing the code that this is based on):
And this is the code for the TPMS sketch (which is receiving TPMS data and displaying it on the serial monitor... I've removed some code for the old Nextion display it was driving, but amongst other rubbish there's definitely some unnecessary code left over from the original version that drive a 128x64 OLED display, and also the next version that drove the Nextion display. Also, I haven't included display.h as it's no longer doing anything useful here):
cc1101.h:
globals.h:
toyotaread.h:
#include <GD23ZUTX.h>
#include <MegunoLink.h>
#include <Filter.h>
// 20 is the weight (20 => 20%)
// 0 is the initial value of the filter
ExponentialFilter<float> FilteredBattery(20, 0);
ExponentialFilter<float> FilteredBoost(8, 0);
ExponentialFilter<float> FilteredOilTemp(20, 0);
// uses serial 1 bus
// current version uses serial 1 for RF, serial 2 for screen
// will need to switch to serial 2 for RF
//Indicator needle
int Centro=150/2; //AE8.png, 400x400 px, Centro=400/2
float AnguloG=65; //offset to scale dial
float avance, rapidez;
//Aguja indicadora
float dato;
// for boost pressure sensor
int mapsen = A3; // Set MAP sensor input on Analog port 6, D4
int boost = 0; // Set boost value to 0
int mapval = 0; // Set raw map value to 0
int remapval = 0; // remapped boost
GD.begin();
GD.BitmapHandle(0);
GD.cmd_loadimage(0, 0);
GD.load("BG03_480_272_c.jpg");
GD.BitmapHandle(1);
GD.cmd_loadimage(-1, 0);
GD.load("AE8_180v2.png");
// tacometro();
void loop(){
mapval= analogRead(mapsen); //Reads the MAP sensor raw value on analog port 6 (D4)
mapval = mapval - 60; //quick and dirty fix for sensor over-read
// boost = (mapval*(.488)/(.022)+20); //Converts raw MAP value to Bar
FilteredBoost.Filter(mapval);
float SmoothBoost = FilteredBoost.Current();
remapval = map(SmoothBoost, 0, 676, 1, 126); // remaps 10-bit value with 5v max to suit 3.3v range and number of images
GD.Clear();
// I think this moves position of BG
GD.Begin(BITMAPS);
GD.Vertex2ii(0, 0, 0);
GD.End();
GD.SaveContext();
GD.Begin(BITMAPS);
// avance = (1.27*2)*dato;
avance = remapval;
dato = dato + rapidez;
// if((AnguloG+avance)>=275){rapidez=-0.5;}
// if((AnguloG+avance)<=66){rapidez=0.5;}
rapidez = remapval;
rotate_Center(DEGREES(1.2*(AnguloG+avance)), Centro);
GD.cmd_setmatrix();
// moves centre of rotation or position of needle
GD.Vertex2ii(165, 50, 1);
GD.cmd_loadidentity();
GD.End();
GD.RestoreContext();
GD.SaveContext();
// this stuff draws the numbers, penultimate variable sets decimal places
GD.ColorA(100); GD.ColorRGB(0,0,0); GD.printNfloat(405, 324, dato/10, 1, 29); GD.ColorA(255);
if (dato>=90){GD.ColorRGB(255,0,0);}else{GD.ColorRGB(255,255,255);}
GD.printNfloat(40, 30, dato/10, 1, 29);
GD.printNfloat(40, 55, dato, 0, 29);
GD.printNfloat(40, 230, dato/4, 1, 29);
GD.printNfloat(440, 30, dato/4, 1, 29);
// GD.printNfloat(440, 230, dato/4, 1, 29);
GD.printNfloat(440, 230, remapval, 1, 29);
Serial.println(mapval);
GD.swap();
static void rotate_Center(float a, int CXY)
GD.cmd_translate(F16(CXY),F16(CXY));
GD.cmd_rotate(a);
GD.cmd_translate(F16(-CXY), F16(-CXY));
// mostly working, but currently low temp is used as proxy fr low pressure, and pressure is x1000 to get into suitable rage for display
#include <EEPROM.h>
#include "globals.h"
#include "CC1101.h"
#include "Display.h"
#include "ToyotaRead.h"
#include <Filter.h>
// for oil temp sensor
// which analog pin to connect
#define THERMISTORPIN A1
// resistance at 25 degrees C, changed from 43300 after measuring!
#define THERMISTORNOMINAL 63300
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3832
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
float raw = 0;
float steinhart;
// for battery monitor, requires bridge with 4k7 and 980 resistors
#define Vin A2
const float Vref = 5.00;
const float R1 = 100000.0;
const float R2 = 22000.0;
float volts = 0;
const float resDiv = 1.095 * (R2/(R1 + R2)); // Resistor divider factor applied to measured voltage, constant added after calibration measurements
int oiltemp = 0;
String stringvolts = "";
String buffer = "";
int tempvalue = 1;
int LEDvalue = 127;
float oilaverage = 0;
float battaverage = 0;
int integervolts = 0;
int temp=0; // for oil temp
int test;
void SendDebug(String Mess)
Serial.println(Mess);
int DecodeBitArray()
//convert 1s and 0s array to byte array
int i;
int n = 0;
byte b = 0;
RXByteCount = 0;
for (i = 0; i < BitCount; i++)
b = b << 1;
b = b + IncomingBits[i];
n++;
if (n == 8)
RXBytes[RXByteCount] = b;
RXByteCount++;
n = 0;
b = 0;
return (RXByteCount);
// analogReference(DEFAULT); // for oil temp and possibly other analogue pins
pinMode(A2, INPUT); // Set A2 as INPUT to read battery voltage
Serial1.begin(9600);
myMP3.begin(Serial1);
myMP3.volume(15);
Serial2.begin(9600); // Start Serial2 comunication at baud=9600
// I am going to change the Serial2 baud to a faster rate.
delay(500); // This delay is just in case the nextion display didn't start yet, to be sure it will receive the following command.
Serial2.print("baud=115200"); // Set new baud rate of nextion to 115200, but it's temporal. Next time nextion is power on,
// it will retore to default baud of 9600.
// To take effect, make sure to reboot the arduino (reseting arduino is not enough).
// If you want to change the default baud, send the command as "bauds=115200", instead of "baud=115200".
// If you change the default baud, everytime the nextion is power ON is going to have that baud rate, and
// would not be necessery to set the baud on the setup anymore.
Serial2.write(0xff); // We always have to send this three lines after each command sent to nextion.
Serial2.end(); // End the Serial2 comunication of baud=9600
Serial2.begin(115200); // Start Serial2 comunication at baud=115200
// sensor stuff ends
byte resp;
unsigned int t;
int LEDState = LOW;
int i;
int mcount;
//SPI CC1101 chip select set up
pinMode(CC1101_CS, OUTPUT);
digitalWrite(CC1101_CS, HIGH);
pinMode(LED_RX, OUTPUT);
pinMode(RXPin, INPUT);
SPI.begin();
//initialise the CC1101
CC1101_reset();
delay(2000);
Serial.println("Starting...");
setIdleState();
digitalWrite(LED_RX, LED_OFF);
resp = readStatusReg(CC1101_PARTNUM);
Serial.print(F("Part no: "));
Serial.println(resp, HEX);
resp = readStatusReg(CC1101_VERSION);
Serial.print(F("Version: "));
#if USE_ADAFRUIT
if (!display.begin(SSD1306_EXTERNALVCC, I2C_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
#else
Wire.begin();
Wire.setClock(400000L);
display.begin(&Adafruit128x64, I2C_ADDRESS);
display.setFont(Adafruit5x7);
Serial.println(F("SSD1306 initialised OK"));
digitalWrite(LED_RX, LED_ON);
LEDState = HIGH;
pinMode(DEBUGPIN, OUTPUT);
#ifndef USE_PROGMEMCRC
CalulateTable_CRC8();
// Clear the buffer
#if USE_ADAFRUIT
display.clearDisplay();
display.display();
#else
display.clear();
InitTPMS();
setRxState();
// boost sensor stuff
//battery reading
// raw += analogRead(Vin);
// added 0.9133 fix to make reading accurate after checks
float RawBattery = (analogRead(A2)/ 1024.0) * Vref;
FilteredBattery.Filter(RawBattery);
float SmoothBattery = FilteredBattery.Current();
volts = (SmoothBattery / resDiv);
float adjustedvolts = volts*10;
int integervolts = int(10*volts);
// oil temp stuff
int oilaverage = analogRead(THERMISTORPIN);
FilteredOilTemp.Filter(oilaverage);
float SmoothOilTemp = FilteredOilTemp.Current();
// convert the value to resistance
SmoothOilTemp = 708 / SmoothOilTemp - 1;
SmoothOilTemp = SERIESRESISTOR / SmoothOilTemp;
float steinhart;
steinhart = SmoothOilTemp / THERMISTORNOMINAL; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to C
temp = round(steinhart);
// temp = analogRead(A5);
// listen for touch screen input
if(Serial2.available()) {
String data_from_display="";
delay(2);
while (Serial2.available()){
data_from_display += char(Serial2.read());
Serial.println(data_from_display);
sendDisplayData(data_from_display);
if (warning == 1) {
myMP3.play(1);
delay(1700);
int i;
static long lastts = millis();
float diff;
int RXBitCount = 0;
int ByteCount = 0;
byte crcResult;
boolean TPMS_Changed;
TPMS_Changed = Check_TPMS_Timeouts();
InitDataBuffer();
//wait for carrier status to go low
while (GetCarrierStatus() == true)
//wait for carrier status to go high looking for rising edge
while (GetCarrierStatus() == false)
if (GetCarrierStatus() == true)
{ //looks like some data coming in...
RXBitCount = ReceiveMessage();
if (RXBitCount == 72 )
ByteCount = DecodeBitArray();
crcResult = Compute_CRC8(ByteCount);
if (crcResult != 0)
//Serial.print(F("CRC: "));
//Serial.println(crcResult, HEX);
//Serial.println(F("CRC Check failed"));
//PrintData(BitCount);
//decode the message...
DecodeTPMS();
TPMS_Changed = true; //indicates the display needs to be updated.
if (TPMS_Changed)
// UpdateBigDisplay();
TPMS_Changed = false;
void sendDisplayData(String data_from_display){
if (data_from_display == "volchange") {
if (warning == 0) {
warning = 1;
if (warning == 1) {
warning = 0;
cc1101.h:
enum RFSTATE
RFSTATE_IDLE = 0,
RFSTATE_RX,
RFSTATE_TX
// SPIClass spi;
* Frequency channels
#define NUMBER_OF_FCHANNELS 10
* Type of transfers
#define WRITE_BURST 0x40
#define READ_SINGLE 0x80
#define READ_BURST 0xC0
* Type of register
#define CC1101_CONFIG_REGISTER READ_SINGLE
#define CC1101_STATUS_REGISTER READ_BURST
* Buffer and data lengths
#define CCPACKET_BUFFER_LEN 64
#define CCPACKET_DATA_LEN CCPACKET_BUFFER_LEN - 3
* Class: CCPACKET
* Description:
* CC1101 data packet class
struct CCPACKET
public:
//Data length
unsigned char length;
// Data buffer
unsigned char data[CCPACKET_DATA_LEN];
//* CRC OK flag
bool crc_ok;
// Received Strength Signal Indication
unsigned char rssi;
// Link Quality Index
unsigned char lqi;
* Macros
#define wait_Miso() delay(3)
//while(digitalRead(PORT_SPI_MISO))
// Get GDO0 pin state
#define getGDO0state() digitalRead(PORT_GDO0)
// Wait until GDO0 line goes high
#define wait_GDO0_high() while(!getGDO0state()) {delay(1);}
// Wait until GDO0 line goes low
#define wait_GDO0_low() while(getGDO0state()) {delay(1);}
* PATABLE & FIFO's
#define CC1101_PATABLE 0x3E // PATABLE address
#define CC1101_TXFIFO 0x3F // TX FIFO address
#define CC1101_RXFIFO 0x3F // RX FIFO address
* Command strobes
#define CC1101_SRES 0x30 // Reset CC1101 chip
#define CC1101_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1). If in RX (with CCA):
// Go to a wait state where only the synthesizer is running (for quick RX / TX turnaround).
#define CC1101_SXOFF 0x32 // Turn off crystal oscillator
#define CC1101_SCAL 0x33 // Calibrate frequency synthesizer and turn it off. SCAL can be strobed from IDLE mode without
// setting manual calibration mode (MCSM0.FS_AUTOCAL=0)
#define CC1101_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and MCSM0.FS_AUTOCAL=1
#define CC1101_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if MCSM0.FS_AUTOCAL=1.
// If in RX state and CCA is enabled: Only go to TX if channel is clear
#define CC1101_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit Wake-On-Radio mode if applicable
#define CC1101_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio) as described in Section 19.5 if
// WORCTRL.RC_PD=0
#define CC1101_SPWD 0x39 // Enter power down mode when CSn goes high
#define CC1101_SFRX 0x3A // Flush the RX FIFO buffer. Only issue SFRX in IDLE or RXFIFO_OVERFLOW states
#define CC1101_SFTX 0x3B // Flush the TX FIFO buffer. Only issue SFTX in IDLE or TXFIFO_UNDERFLOW states
#define CC1101_SWORRST 0x3C // Reset real time clock to Event1 value
#define CC1101_SNOP 0x3D // No operation. May be used to get access to the chip status byte
* CC1101 configuration registers
#define CC1101_IOCFG2 0x00 // GDO2 Output Pin Configuration
#define CC1101_IOCFG1 0x01 // GDO1 Output Pin Configuration
#define CC1101_IOCFG0 0x02 // GDO0 Output Pin Configuration
#define CC1101_FIFOTHR 0x03 // RX FIFO and TX FIFO Thresholds
#define CC1101_SYNC1 0x04 // Sync Word, High Byte
#define CC1101_SYNC0 0x05 // Sync Word, Low Byte
#define CC1101_PKTLEN 0x06 // Packet Length
#define CC1101_PKTCTRL1 0x07 // Packet Automation Control
#define CC1101_PKTCTRL0 0x08 // Packet Automation Control
#define CC1101_ADDR 0x09 // Device Address
#define CC1101_CHANNR 0x0A // Channel Number
#define CC1101_FSCTRL1 0x0B // Frequency Synthesizer Control
#define CC1101_FSCTRL0 0x0C // Frequency Synthesizer Control
#define CC1101_FREQ2 0x0D // Frequency Control Word, High Byte
#define CC1101_FREQ1 0x0E // Frequency Control Word, Middle Byte
#define CC1101_FREQ0 0x0F // Frequency Control Word, Low Byte
#define CC1101_MDMCFG4 0x10 // Modem Configuration
#define CC1101_MDMCFG3 0x11 // Modem Configuration
#define CC1101_MDMCFG2 0x12 // Modem Configuration
#define CC1101_MDMCFG1 0x13 // Modem Configuration
#define CC1101_MDMCFG0 0x14 // Modem Configuration
#define CC1101_DEVIATN 0x15 // Modem Deviation Setting
#define CC1101_MCSM2 0x16 // Main Radio Control State Machine Configuration
#define CC1101_MCSM1 0x17 // Main Radio Control State Machine Configuration
#define CC1101_MCSM0 0x18 // Main Radio Control State Machine Configuration
#define CC1101_FOCCFG 0x19 // Frequency Offset Compensation Configuration
#define CC1101_BSCFG 0x1A // Bit Synchronization Configuration
#define CC1101_AGCCTRL2 0x1B // AGC Control
#define CC1101_AGCCTRL1 0x1C // AGC Control
#define CC1101_AGCCTRL0 0x1D // AGC Control
#define CC1101_WOREVT1 0x1E // High Byte Event0 Timeout
#define CC1101_WOREVT0 0x1F // Low Byte Event0 Timeout
#define CC1101_WORCTRL 0x20 // Wake On Radio Control
#define CC1101_FREND1 0x21 // Front End RX Configuration
#define CC1101_FREND0 0x22 // Front End TX Configuration
#define CC1101_FSCAL3 0x23 // Frequency Synthesizer Calibration
#define CC1101_FSCAL2 0x24 // Frequency Synthesizer Calibration
#define CC1101_FSCAL1 0x25 // Frequency Synthesizer Calibration
#define CC1101_FSCAL0 0x26 // Frequency Synthesizer Calibration
#define CC1101_RCCTRL1 0x27 // RC Oscillator Configuration
#define CC1101_RCCTRL0 0x28 // RC Oscillator Configuration
#define CC1101_FSTEST 0x29 // Frequency Synthesizer Calibration Control
#define CC1101_PTEST 0x2A // Production Test
#define CC1101_AGCTEST 0x2B // AGC Test
#define CC1101_TEST2 0x2C // Various Test Settings
#define CC1101_TEST1 0x2D // Various Test Settings
#define CC1101_TEST0 0x2E // Various Test Settings
* Status registers
#define CC1101_PARTNUM 0x30 // Chip ID
#define CC1101_VERSION 0x31 // Chip ID
#define CC1101_FREQEST 0x32 // Frequency Offset Estimate from Demodulator
#define CC1101_LQI 0x33 // Demodulator Estimate for Link Quality
#define CC1101_RSSI 0x34 // Received Signal Strength Indication
#define CC1101_MARCSTATE 0x35 // Main Radio Control State Machine State
#define CC1101_WORTIME1 0x36 // High Byte of WOR Time
#define CC1101_WORTIME0 0x37 // Low Byte of WOR Time
#define CC1101_PKTSTATUS 0x38 // Current GDOx Status and Packet Status
#define CC1101_VCO_VC_DAC 0x39 // Current Setting from PLL Calibration Module
#define CC1101_TXBYTES 0x3A // Underflow and Number of Bytes
#define CC1101_RXBYTES 0x3B // Overflow and Number of Bytes
#define CC1101_RCCTRL1_STATUS 0x3C // Last RC Oscillator Calibration Result
#define CC1101_RCCTRL0_STATUS 0x3D // Last RC Oscillator Calibration Result
#define CC1101_DEFVAL_IOCFG2 0x0D // GDO2 Output Pin Configuration - Serial out
#define CC1101_DEFVAL_IOCFG1 0x2E // GDO1 Output Pin Configuration - not used
//#define CC1101_DEFVAL_IOCFG0 0x0D // GDO0 Output Pin Configuration
#define CC1101_DEFVAL_IOCFG0 0x0E // GDO0 Output Pin Configuration - Carrier Sense output
#define CC1101_DEFVAL_FIFOTHR 0x0F // RX FIFO and TX FIFO Thresholds - 64 bytes in FIFO
#define CC1101_DEFVAL_SYNC1 0xD5 // Synchronization word, high byte 11010101 01001111
#define CC1101_DEFVAL_SYNC0 0x4F // Synchronization word, low byte
#define CC1101_DEFVAL_PKTLEN 0x09 // Packet Length
#define CC1101_DEFVAL_PKTCTRL1 0x00 // Packet Automation Control
#define CC1101_DEFVAL_PKTCTRL0 0x30 // Packet Automation Control
#define CC1101_DEFVAL_ADDR 0x00 // Device Address
#define CC1101_DEFVAL_CHANNR 0x00 // Channel Number
#define CC1101_DEFVAL_FSCTRL1 0x0F // Frequency Synthesizer Control (was 0x06)
#define CC1101_DEFVAL_FSCTRL0 0x00 // Frequency Synthesizer Control
// Carrier frequency = 868 MHz (not used)
//#define CC1101_DEFVAL_FREQ2_868 0x21 // Frequency Control Word, High Byte
//#define CC1101_DEFVAL_FREQ1_868 0x65 // Frequency Control Word, Middle Byte
//#define CC1101_DEFVAL_FREQ0_868 0xCC // Frequency Control Word, Low Byte
// Carrier frequency = 433.8798 MHz
#define CC1101_DEFVAL_FREQ2_433 0x10 // Frequency Control Word, High Byte
#define CC1101_DEFVAL_FREQ1_433 0xB0 // Frequency Control Word, Middle Byte
#define CC1101_DEFVAL_FREQ0_433 0x0C // Frequency Control Word, Low Byte
#define CC1101_DEFVAL_MDMCFG4 0x59 // Modem Configuration (59 = data rate = 20kHz - actual data rate is 10kHz but due to bi-phase coding need to double the rate, RX bandwidth 325kHz)
#define CC1101_DEFVAL_MDMCFG3 0x93 // Modem Configuration (now 93 = data rate = 20kHz)
#define CC1101_DEFVAL_MDMCFG2 0x10 // Modem Configuration (GFSK, No Sync or Manchester coding)
#define CC1101_DEFVAL_MDMCFG1 0x22 // Modem Configuration Channel spacing 200kHz
#define CC1101_DEFVAL_MDMCFG0 0xF8 // Modem Configuration
#define CC1101_DEFVAL_DEVIATN 0x41 // Modem Deviation Setting (+/-28.56kHz)
#define CC1101_DEFVAL_MCSM2 0x07 // Main Radio Control State Machine Configuration
//#define CC1101_DEFVAL_MCSM1 0x30 // Main Radio Control State Machine Configuration
#define CC1101_DEFVAL_MCSM1 0x3C // Main Radio Control State Machine Configuration
#define CC1101_DEFVAL_MCSM0 0x18 // Main Radio Control State Machine Configuration
#define CC1101_DEFVAL_FOCCFG 0x16 // Frequency Offset Compensation Configuration
#define CC1101_DEFVAL_BSCFG 0x6C // Bit Synchronization Configuration
//#define CC1101_DEFVAL_AGCCTRL2 0x43 // AGC Control
#define CC1101_DEFVAL_AGCCTRL2 0xC6 // AGC Control
//#define CC1101_DEFVAL_AGCCTRL1 0x40 // AGC Control
#define CC1101_DEFVAL_AGCCTRL1 0x50 // AGC Control
#define CC1101_DEFVAL_AGCCTRL0 0x80 // AGC Control
#define CC1101_DEFVAL_WOREVT1 0x87 // High Byte Event0 Timeout
#define CC1101_DEFVAL_WOREVT0 0x6B // Low Byte Event0 Timeout
#define CC1101_DEFVAL_WORCTRL 0xFB // Wake On Radio Control
#define CC1101_DEFVAL_FREND1 0x56 // Front End RX Configuration
#define CC1101_DEFVAL_FREND0 0x10 // Front End TX Configuration
#define CC1101_DEFVAL_FSCAL3 0xE9 // Frequency Synthesizer Calibration
#define CC1101_DEFVAL_FSCAL2 0x2A // Frequency Synthesizer Calibration
#define CC1101_DEFVAL_FSCAL1 0x00 // Frequency Synthesizer Calibration
#define CC1101_DEFVAL_FSCAL0 0x1F // Frequency Synthesizer Calibration
#define CC1101_DEFVAL_RCCTRL1 0x41 // RC Oscillator Configuration
#define CC1101_DEFVAL_RCCTRL0 0x00 // RC Oscillator Configuration
#define CC1101_DEFVAL_FSTEST 0x59 // Frequency Synthesizer Calibration Control
#define CC1101_DEFVAL_PTEST 0x7F // Production Test
#define CC1101_DEFVAL_AGCTEST 0x3F // AGC Test
#define CC1101_DEFVAL_TEST2 0x81 // Various Test Settings
#define CC1101_DEFVAL_TEST1 0x35 // Various Test Settings
#define CC1101_DEFVAL_TEST0 0x09 // Various Test Settings
* Alias for some default values
#define CCDEF_CHANNR CC1101_DEFVAL_CHANNR
#define CCDEF_SYNC0 CC1101_DEFVAL_SYNC0
#define CCDEF_SYNC1 CC1101_DEFVAL_SYNC1
#define CCDEF_ADDR CC1101_DEFVAL_ADDR
* Macros
// Read CC1101 Config register
#define readConfigReg(regAddr) readReg(regAddr, CC1101_CONFIG_REGISTER)
// Read CC1101 Status register
#define readStatusReg(regAddr) readReg(regAddr, CC1101_STATUS_REGISTER)
// Enter Rx state
//#define setRxState() cmdStrobe(CC1101_SRX)
// Enter Tx state
//#define setTxState() cmdStrobe(CC1101_STX)
// Enter IDLE state
#define setIdleState() cmdStrobe(CC1101_SIDLE)
// Flush Rx FIFO
#define flushRxFifo() cmdStrobe(CC1101_SFRX)
// Flush Tx FIFO
#define flushTxFifo() cmdStrobe(CC1101_SFTX)
// Disable address check
#define disableAddressCheck() writeReg(CC1101_PKTCTRL1, 0x04)
// Enable address check
#define enableAddressCheck() writeReg(CC1101_PKTCTRL1, 0x06)
// Disable CCA
#define disableCCA() writeReg(CC1101_MCSM1, 0)
// Enable CCA
#define enableCCA() writeReg(CC1101_MCSM1, CC1101_DEFVAL_MCSM1)
// Set PATABLE single byte
#define setTxPowerAmp(setting) paTableByte = setting
// PATABLE values
#define PA_LowPower 0x60
#define PA_LongDistance 0xC0
// Select (SPI) CC1101
void cc1101_Select(){
//delayMicroseconds(150);
//spi.begin();
SPI.beginTransaction(SPISettings(5000000,MSBFIRST,SPI_MODE0));
digitalWrite(CC1101_CS, LOW);
void cc1101_Deselect(){
//spi.end();
//delayMicroseconds(50);
SPI.endTransaction();
* wakeUp
* Wake up CC1101 from Power Down state
void wakeUp(void)
cc1101_Select(); // Select CC1101
wait_Miso(); // Wait until MISO goes low
cc1101_Deselect(); // Deselect CC1101
* writeReg
* Write single register into the CC1101 IC via SPI
* 'regAddr' Register address
* 'value' Value to be writen
void writeReg(byte regAddr, byte value)
//wait_Miso(); // Wait until MISO goes low
SPI.transfer(regAddr); // Send register address
SPI.transfer(value); // Send value
* readReg
* Read CC1101 register via SPI
* 'regType' Type of register: CC1101_CONFIG_REGISTER or CC1101_STATUS_REGISTER
* Return:
* Data byte returned by the CC1101 IC
byte readReg(byte regAddr, byte regType)
byte addr, val;
addr = regAddr | regType;
SPI.transfer(addr); // Send register address
val = SPI.transfer(0x00); // Read result
return val;
* setCCregs
* Configure CC1101 registers
void setCCregs(void)
writeReg(CC1101_IOCFG2, CC1101_DEFVAL_IOCFG2);
writeReg(CC1101_IOCFG1, CC1101_DEFVAL_IOCFG1);
writeReg(CC1101_IOCFG0, CC1101_DEFVAL_IOCFG0);
writeReg(CC1101_FIFOTHR, CC1101_DEFVAL_FIFOTHR);
writeReg(CC1101_PKTLEN, CC1101_DEFVAL_PKTLEN);
writeReg(CC1101_PKTCTRL1, CC1101_DEFVAL_PKTCTRL1);
writeReg(CC1101_PKTCTRL0, CC1101_DEFVAL_PKTCTRL0);
// Set default synchronization word
//setSyncWord(syncWord);
// Set default device address
//setDevAddress(devAddress);
// Set default frequency channel
//setChannel(channel);
writeReg(CC1101_FSCTRL1, CC1101_DEFVAL_FSCTRL1);
writeReg(CC1101_FSCTRL0, CC1101_DEFVAL_FSCTRL0);
// // Set default carrier frequency = 868 MHz
// //setCarrierFreq(carrierFreq);
// writeReg(CC1101_FREQ2, CC1101_DEFVAL_FREQ2_868);
// writeReg(CC1101_FREQ1, CC1101_DEFVAL_FREQ1_868);
// writeReg(CC1101_FREQ0, CC1101_DEFVAL_FREQ0_868);
// Set default carrier frequency = 433 MHz
writeReg(CC1101_FREQ2, CC1101_DEFVAL_FREQ2_433);
writeReg(CC1101_FREQ1, CC1101_DEFVAL_FREQ1_433);
writeReg(CC1101_FREQ0, CC1101_DEFVAL_FREQ0_433);
writeReg(CC1101_MDMCFG4, CC1101_DEFVAL_MDMCFG4);
writeReg(CC1101_MDMCFG3, CC1101_DEFVAL_MDMCFG3);
writeReg(CC1101_MDMCFG2, CC1101_DEFVAL_MDMCFG2);
writeReg(CC1101_MDMCFG1, CC1101_DEFVAL_MDMCFG1);
writeReg(CC1101_MDMCFG0, CC1101_DEFVAL_MDMCFG0);
writeReg(CC1101_DEVIATN, CC1101_DEFVAL_DEVIATN);
writeReg(CC1101_MCSM2, CC1101_DEFVAL_MCSM2);
writeReg(CC1101_MCSM1, CC1101_DEFVAL_MCSM1);
writeReg(CC1101_MCSM0, CC1101_DEFVAL_MCSM0);
writeReg(CC1101_FOCCFG, CC1101_DEFVAL_FOCCFG);
writeReg(CC1101_BSCFG, CC1101_DEFVAL_BSCFG);
writeReg(CC1101_AGCCTRL2, CC1101_DEFVAL_AGCCTRL2);
writeReg(CC1101_AGCCTRL1, CC1101_DEFVAL_AGCCTRL1);
writeReg(CC1101_AGCCTRL0, CC1101_DEFVAL_AGCCTRL0);
writeReg(CC1101_WOREVT1, CC1101_DEFVAL_WOREVT1);
writeReg(CC1101_WOREVT0, CC1101_DEFVAL_WOREVT0);
writeReg(CC1101_WORCTRL, CC1101_DEFVAL_WORCTRL);
writeReg(CC1101_FREND1, CC1101_DEFVAL_FREND1);
writeReg(CC1101_FREND0, CC1101_DEFVAL_FREND0);
writeReg(CC1101_FSCAL3, CC1101_DEFVAL_FSCAL3);
writeReg(CC1101_FSCAL2, CC1101_DEFVAL_FSCAL2);
writeReg(CC1101_FSCAL1, CC1101_DEFVAL_FSCAL1);
writeReg(CC1101_FSCAL0, CC1101_DEFVAL_FSCAL0);
writeReg(CC1101_RCCTRL1, CC1101_DEFVAL_RCCTRL1);
writeReg(CC1101_RCCTRL0, CC1101_DEFVAL_RCCTRL0);
writeReg(CC1101_FSTEST, CC1101_DEFVAL_FSTEST);
writeReg(CC1101_PTEST, CC1101_DEFVAL_PTEST);
writeReg(CC1101_AGCTEST, CC1101_DEFVAL_AGCTEST);
writeReg(CC1101_TEST2, CC1101_DEFVAL_TEST2);
writeReg(CC1101_TEST1, CC1101_DEFVAL_TEST1);
writeReg(CC1101_TEST0, CC1101_DEFVAL_TEST0);
// Send empty packet
// CCPACKET packet;
// packet.length = 0;
// sendData(packet);
* cmdStrobe
* Send command strobe to the CC1101 IC via SPI
* 'cmd' Command strobe
void cmdStrobe(byte cmd)
SPI.transfer(cmd); // Send strobe command
* setRxState
* Enter Rx state
void setRxState()
cmdStrobe(CC1101_SRX);
void setTxState()
cmdStrobe(CC1101_STX);
* reset
* Reset CC1101
void CC1101_reset(void)
delayMicroseconds(5);
delayMicroseconds(10);
delayMicroseconds(41);
SPI.transfer(CC1101_SRES); // Send reset command strobe
setCCregs(); // Reconfigure CC1101
boolean GetCarrierStatus()
byte ret;
ret = readStatusReg(CC1101_PKTSTATUS);
if ((ret & 0x40) == 0)
return(false);
return(true);
void WaitCarrierEnd()
//wait for carrier detect to change to low state
delayMicroseconds(100);
globals.h:
#define USE_PROGMEMCRC 1
#define SHOWDEGUGINFO 1
#define I2C_ADDRESS 0x3C
#define LED_RX 17
#define LED_OFF HIGH
#define LED_ON LOW
#define TPMS_TIMEOUT 900000 //(15 * 60 * 1000) 15 minutes
#define FONTBAR_7 123
#define FONTBAR_5 124
#define FONTBAR_3 125
#define FONTBAR_2 126
#define FONTBAR_1 127
#define FONTBAR_0 32
int intpressure;
int warning = 0;
const int CC1101_CS = 27; // Define the Chip Select pin
const int RXPin = 6; // changed this from 7 to free that pin for Rx from display
const int DEBUGPIN = 6;
const int MAXBITS = 100;
//const long Tlong_us = 100;
//const long Tshort_us = Tlong_us/2;
const int Ttol_l_us = 25;
const int Ttol_s_us = 13;
volatile static unsigned long LastEdgeTime_us = 0;
volatile static bool ValidBlock = false;
volatile static bool WaitingFirstEdge = true;
volatile byte Timings[256];
volatile uint8_t TimingsIndex = 0;
uint8_t CheckIndex = 0;
bool SyncFound = false;
unsigned long CD_Width;
byte StartDataIndex = 0;
bool IncomingBits[MAXBITS];
unsigned int BitIndex = 0;
unsigned int BitCount = 0;
unsigned int FreqOffset;
unsigned int DemodLinkQuality;
unsigned int RSSIvalue;
int RawCount = 0;
//byte ManchesterRX[64]; //holds received Manchester byte message (converted from the rawdata)
byte RXBytes[10]; //holds the raw incoming databytes from the CC1101 serial port
int RXByteCount;
unsigned long IncomingAddress;
//this table (and its order define known TPMS IDs so that they their values are always displayed in the same order
const unsigned long PROGMEM IDLookup[]
0xF0117227, 0xF0117281,
0xF0117204, 0xF0117255
#ifdef USE_PROGMEMCRC
////CRCTable
const byte PROGMEM crctable2[] =
0x00, 0x07, 0x0E, 0x09, 0x1C, 0x1B, 0x12, 0x15, 0x38, 0x3F, 0x36, 0x31, 0x24, 0x23, 0x2A, 0x2D,
0x70, 0x77, 0x7E, 0x79, 0x6C, 0x6B, 0x62, 0x65, 0x48, 0x4F, 0x46, 0x41, 0x54, 0x53, 0x5A, 0x5D,
0xE0, 0xE7, 0xEE, 0xE9, 0xFC, 0xFB, 0xF2, 0xF5, 0xD8, 0xDF, 0xD6, 0xD1, 0xC4, 0xC3, 0xCA, 0xCD,
0x90, 0x97, 0x9E, 0x99, 0x8C, 0x8B, 0x82, 0x85, 0xA8, 0xAF, 0xA6, 0xA1, 0xB4, 0xB3, 0xBA, 0xBD,
0xC7, 0xC0, 0xC9, 0xCE, 0xDB, 0xDC, 0xD5, 0xD2, 0xFF, 0xF8, 0xF1, 0xF6, 0xE3, 0xE4, 0xED, 0xEA,
0xB7, 0xB0, 0xB9, 0xBE, 0xAB, 0xAC, 0xA5, 0xA2, 0x8F, 0x88, 0x81, 0x86, 0x93, 0x94, 0x9D, 0x9A,
0x27, 0x20, 0x29, 0x2E, 0x3B, 0x3C, 0x35, 0x32, 0x1F, 0x18, 0x11, 0x16, 0x03, 0x04, 0x0D, 0x0A,
0x57, 0x50, 0x59, 0x5E, 0x4B, 0x4C, 0x45, 0x42, 0x6F, 0x68, 0x61, 0x66, 0x73, 0x74, 0x7D, 0x7A,
0x89, 0x8E, 0x87, 0x80, 0x95, 0x92, 0x9B, 0x9C, 0xB1, 0xB6, 0xBF, 0xB8, 0xAD, 0xAA, 0xA3, 0xA4,
0xF9, 0xFE, 0xF7, 0xF0, 0xE5, 0xE2, 0xEB, 0xEC, 0xC1, 0xC6, 0xCF, 0xC8, 0xDD, 0xDA, 0xD3, 0xD4,
0x69, 0x6E, 0x67, 0x60, 0x75, 0x72, 0x7B, 0x7C, 0x51, 0x56, 0x5F, 0x58, 0x4D, 0x4A, 0x43, 0x44,
0x19, 0x1E, 0x17, 0x10, 0x05, 0x02, 0x0B, 0x0C, 0x21, 0x26, 0x2F, 0x28, 0x3D, 0x3A, 0x33, 0x34,
0x4E, 0x49, 0x40, 0x47, 0x52, 0x55, 0x5C, 0x5B, 0x76, 0x71, 0x78, 0x7F, 0x6A, 0x6D, 0x64, 0x63,
0x3E, 0x39, 0x30, 0x37, 0x22, 0x25, 0x2C, 0x2B, 0x06, 0x01, 0x08, 0x0F, 0x1A, 0x1D, 0x14, 0x13,
0xAE, 0xA9, 0xA0, 0xA7, 0xB2, 0xB5, 0xBC, 0xBB, 0x96, 0x91, 0x98, 0x9F, 0x8A, 0x8D, 0x84, 0x83,
0xDE, 0xD9, 0xD0, 0xD7, 0xC2, 0xC5, 0xCC, 0xCB, 0xE6, 0xE1, 0xE8, 0xEF, 0xFA, 0xFD, 0xF4, 0xF3
#else
static byte crctable[256];
struct TPMS_entry
unsigned long TPMS_ID;
unsigned long lastupdated;
unsigned int TPMS_Status;
float TPMS_Pressure;
float TPMS_Temperature;
int TPMS_Intpressure;
} TPMS[4];
enum RXStates
Waiting_Byte33 = 0,
Got_Byte33,
Got_Byte55,
Got_Byte53,
Manch1,
Manch2
toyotaread.h:
void ClearTPMSData(int i)
if (i > 4)
return;
TPMS[i].TPMS_ID = 0;
TPMS[i].lastupdated = 0;
void PulseDebugPin(int width_us)
digitalWrite(DEBUGPIN, HIGH);
delayMicroseconds(width_us);
digitalWrite(DEBUGPIN, LOW);
int GetPreferredIndex(unsigned long ID)
int i;
for (i = 0; i < (sizeof(IDLookup) / sizeof(IDLookup[0])); i++)
if (IDLookup[i] == ID)
return (i);
return (-1);
void PrintTimings(byte StartPoint, byte Count)
byte i;
for (i = 0; i < Count; i++)
Serial.print(Timings[StartPoint + i]);
Serial.print(F(","));
Serial.println(F(""));
// for (i = 0;i<Count;i++)
// Serial.print(BitTimings[StartPoint + i]);
// Serial.print(",");
// Serial.println("");
void PrintData(byte Count)
byte i;
byte hexdata;
Serial.print(IncomingBits[i]);
hexdata = (hexdata << 1) + IncomingBits[i];
if ((i + 1) % 8 == 0)
Serial.print(F(" ["));
Serial.print(hexdata, HEX);
Serial.print(F("] "));
hexdata = 0;
void InitTPMS()
int i;
for (i = 0; i < 4; i++)
ClearTPMSData(i);
UpdateBigDisplay();
void UpdateTPMSData(int index, unsigned long ID, unsigned int status, float Temperature, float Pressure, int intpressure)
if (index >= 4)
return;
TPMS[index].TPMS_ID = ID;
TPMS[index].TPMS_Status = status;
TPMS[index].lastupdated = millis();
TPMS[index].TPMS_Temperature = Temperature;
TPMS[index].TPMS_Pressure = Pressure;
TPMS[index].TPMS_Intpressure = intpressure;
void DisplayStatusInfo()
Serial.print (F("FreqOffset: "));
Serial.print (FreqOffset);
Serial.print (F(" DemodLinkQuality: "));
Serial.print (DemodLinkQuality);
Serial.print (F(" RSSI: "));
Serial.println (RSSIvalue);
boolean Check_TPMS_Timeouts()
byte i;
boolean ret = false;
//clear any data not updated in the last 5 minutes
// #ifdef SHOWDEGUGINFO
// Serial.print(TPMS[i].TPMS_ID, HEX);
// Serial.print(F(" "));
// #endif
if ((TPMS[i].TPMS_ID != 0) && (millis() - TPMS[i].lastupdated > TPMS_TIMEOUT))
// Serial.print(F("Clearing ID "));
// Serial.println(TPMS[i].TPMS_ID, HEX);
// #endif
ClearTPMSData(i);
ret = true;
return(ret);
void DecodeTPMS()
int i;
unsigned long id = 0;
unsigned int status, pressure1, pressure2, temp;
float realpressure;
float realtemp;
bool IDFound = false;
int prefindex;
id = id << 8;
id = id + RXBytes[i];
// id = (unsigned)RXBytes[0] << 24 | RXBytes[1] << 16 | RXBytes[2] << 8 | RXBytes[3];
status = (RXBytes[4] & 0x80) | (RXBytes[6] & 0x7f); // status bit and 0 filler
pressure1 = (RXBytes[4] & 0x7f) << 1 | RXBytes[5] >> 7;
temp = (RXBytes[5] & 0x7f) << 1 | RXBytes[6] >> 7;
pressure2 = RXBytes[7] ^ 0xff;
if (pressure1 != pressure2)
Serial.println(F("Pressure check mis-match"));
return;
realpressure = 1100 * (pressure1 * 0.25 - 7.0);
realtemp = temp - 40.0;
intpressure = (int) realpressure;
Serial.print(F("ID: "));
Serial.print(id, HEX);
Serial.print(F(" Status: "));
Serial.print(status);
Serial.print(F(" Temperature: "));
Serial.print(realtemp);
Serial.print(F(" Tyre Pressure: "));
Serial.print(realpressure);
Serial.print(F(" Adjusted Pressure: "));
Serial.print(intpressure);
if (realtemp < 23 && 1 < realtemp) {
warning = 1;
//DisplayStatusInfo();
//update the array of tyres data
{ //find a matching ID if it already exists
if (id == TPMS[i].TPMS_ID)
UpdateTPMSData(i, id, status, realtemp, realpressure, intpressure);
IDFound = true;
//no matching IDs in the array, so see if there is an empty slot to add it into, otherwise, ignore it.
if (IDFound == false)
prefindex = GetPreferredIndex(id);
if (prefindex == -1)
{ //not found a specified index, so use the next available one..
if (TPMS[i].TPMS_ID == 0)
{ //found a match in the known ID list...
UpdateTPMSData(prefindex, id, status, realtemp, realpressure, intpressure);
void CalulateTable_CRC8()
const byte generator = 0x07;
/* iterate over all byte values 0 - 255 */
for (int divident = 0; divident < 256; divident++)
byte currByte = (byte)divident;
/* calculate the CRC-8 value for current byte */
for (byte bit = 0; bit < 8; bit++)
if ((currByte & 0x80) != 0)
currByte <<= 1;
currByte ^= generator;
currByte <<= 1;
/* store CRC value in lookup table */
crctable[divident] = currByte;
Serial.print("0x");
if (currByte < 16)
Serial.print("0");
Serial.print(currByte,HEX);
Serial.print(", ");
byte Compute_CRC8( int bcount)
byte crc = 0x80;
int c;
for (c = 0; c < bcount; c++)
byte b = RXBytes[c];
/* XOR-in next input byte */
byte data = (byte)(b ^ crc);
/* get current CRC value = remainder */
crc = (byte)(pgm_read_byte(&crctable2[data]));
#else
crc = (byte)(crctable[data]);
return crc;
void ClearRXBuffer()
int i;
for (i = 0; i < sizeof(RXBytes); i++)
RXBytes[i] = 0;
void EdgeInterrupt()
unsigned long ts = micros();
unsigned long BitWidth;
if (TimingsIndex == 255)
return;
BitWidth = ts - LastEdgeTime_us;
if (BitWidth <= 12) //ignore glitches
return;
if (BitWidth > 255)
BitWidth = 255;
LastEdgeTime_us = ts;
// if ((BitWidth >= 38) && (BitWidth <= 250))
// {//ignore out of spec pulses
Timings[TimingsIndex++] = (byte)BitWidth;
// digitalWrite(DEBUGPIN,HIGH);
// delayMicroseconds(3);
// digitalWrite(DEBUGPIN,LOW);
bool IsValidSync(byte Width)
if (Width >= 175)
return (true);
return (false);
bool IsValidShort(byte Width)
if ((Width >= 40) && (Width <= 60))
return (true);
return (false);
bool IsValidLong(byte Width)
if ((Width >= 80) && (Width <= 120))
return (true);
return (false);
int ValidateBit()
byte BitWidth = Timings[CheckIndex];
byte BitWidthNext = Timings[CheckIndex + 1];
if (IsValidLong(BitWidth))
return (1);
if (IsValidShort(BitWidth))
return (0);
if (IsValidSync(BitWidth))
return (2);
return (-1);
void ValidateTimings()
byte BitWidth;
byte BitWidthNext;
byte BitWidthNextPlus1;
byte BitWidthPrevious;
byte diff = TimingsIndex - CheckIndex;
//unsigned long tmp;
bool WaitingTrailingZeroEdge = false;
int ret;
StartDataIndex = 0;
if (diff < 72)
{ //not enough in the buffer to consider a valid message
Serial.println(F("Insufficient data in buffer"));
return;
SyncFound = true;
while ((diff > 0) && (BitCount < 72))
{ //something in buffer to process...
if (SyncFound == false)
SyncFound = true;
BitIndex = 0;
BitCount = 0;
StartDataIndex = CheckIndex + 1;
ret = ValidateBit();
switch (ret)
case -1:
//invalid bit
BitIndex = 0;
BitCount = 0;
case 0:
if (WaitingTrailingZeroEdge)
//BitTimings[BitIndex] = BitWidth;
IncomingBits[BitIndex++] = 0;
BitCount++;
WaitingTrailingZeroEdge = true;
case 1:
{ //shouldn't get a long pulse when waiting for the second short pulse (i.e. expecting bit = 0)
//try to resync from here?
BitIndex = 0;
BitCount = 0;
CheckIndex--; //recheck this entry
IncomingBits[BitIndex++] = 1;
BitCount++;
case 2:
SyncFound = true;
BitIndex = 0;
BitCount = 0;
CheckIndex++;
void InitDataBuffer()
BitIndex = 0;
BitCount = 0;
ValidBlock = false;
//WaitingTrailingZeroEdge = false;
CheckIndex = 0;
TimingsIndex = 0;
SyncFound = false;
//digitalWrite(DEBUGPIN, LOW);
void UpdateStatusInfo()
FreqOffset = readStatusReg(CC1101_FREQEST);
DemodLinkQuality = readStatusReg(CC1101_LQI);
RSSIvalue = readStatusReg(CC1101_RSSI);
int ReceiveMessage()
//Check bytes in FIFO
int FIFOcount;
int resp;
//set up timing of edges using interrupts...
LastEdgeTime_us = micros();
CD_Width = micros();
attachInterrupt(digitalPinToInterrupt(RXPin), EdgeInterrupt, CHANGE);
detachInterrupt(digitalPinToInterrupt(RXPin));
//digitalWrite(DEBUGPIN,LOW);
CD_Width = micros() - CD_Width;
if ((CD_Width >= 7600) && (CD_Width <= 8200))
//Serial.println(F("Checking"));
digitalWrite(LED_RX,LED_ON);
CheckIndex = 0;
ValidateTimings();
//Serial.println(F("Checking complete"));
digitalWrite(LED_RX,LED_OFF);
return (BitCount);
return (0);
