BriComp
Can you attach the full code so that I can compile it.I installed the EBYTE library but there is an error while uploading code to the teensy.
// i recommend putting this code in a .h file and including it
// from both the receiver and sender modules
// these are just dummy variables, replace with your own
struct DATA {
unsigned long Count;
int Bits;
float Volts;
float Amps;
int Chan;
DATA MyData;
unsigned long Last;
// create the transceiver object, passing in the serial and pins
EBYTE Transceiver(&ESerial, PIN_M0, PIN_M1, PIN_AX);
// wait for the serial to connect
while (!Serial) {}
// start the transceiver serial port--i have yet to get a different
// baud rate to work--data sheet says to keep on 9600
ESerial.begin(9600);
Serial.println("Starting Reader");
// this init will set the pinModes for you
Transceiver.init();
// all these calls are optional but shown to give examples of what you can do
Serial.println(Transceiver.GetAirDataRate());
Serial.println(Transceiver.GetChannel());
Transceiver.SetAddressH(1);
Transceiver.SetAddressL(0);
Chan = 5;
Transceiver.SetChannel(Chan);
save the parameters to the unit,
Transceiver.SaveParameters(PERMANENT);
// you can print all parameters and is good for debugging
// if your units will not communicate, print the parameters
// for both sender and receiver and make sure air rates, channel
// and address is the same
Transceiver.PrintParameters();
// if the transceiver serial is available, proces incoming data
// you can also use ESerial.available()
if (Transceiver.available()) {
// i highly suggest you send data using structures and not
// a parsed data--i've always had a hard time getting reliable data using
// a parsing method
Transceiver.GetStruct(&MyData, sizeof(MyData));
// You only really need this library to program these EBYTE units.
// For reading data structures, you can call readBytes directly on the EBYTE Serial object
// ESerial.readBytes((uint8_t*)& MyData, (uint8_t) sizeof(MyData));
// dump out what was just received
Serial.print("Count: "); Serial.println(MyData.Count);
Serial.print("Bits: "); Serial.println(MyData.Bits);
Serial.print("Volts: "); Serial.println(MyData.Volts);
// if you got data, update the checker
Last = millis();
else {
// if the time checker is over some prescribed amount
// let the user know there is no incoming data
if ((millis() - Last) > 1000) {
Serial.println("Searching: ");
Last = millis();
#include <EBYTE_E32.h>
#define PIN_M0 7 // This is the Teensy pin which connects with EBYTE E32 M0 pin
#define PIN_M1 6 // This is the Teensy pin which connects with EBYTE E32 M1 pin
#define PIN_AX 5 // This is the Teensy pin which connects with EBYTE E32 AUX pin
// NOTE that Teensy Serial Tx pin (1) MUST connect to EBYTE E32 Rx pin.
// NOTE that Teensy Serial Rx pin (0) MUST connect to EBYTE E32 Rx pin.
#define radioSerial Serial1
struct DATA {
int Bits;
float Volts;
float Amps;
int Chan;
DATA MyData;
unsigned long Last;
// create the radio object, passing in the serial and pins
EBYTE_E32 radio(&radioSerial, PIN_M0, PIN_M1, PIN_AX);
while (!Serial) {}
// start the radio serial port--i have yet to get a different
radioSerial.begin(9600);
radio.init();
Serial.println(radio.GetAirDataRate());
Serial.println(radio.GetChannel());
radio.SetAddressH(1);
radio.SetAddressL(0);
Chan = 5;
radio.SetChannel(Chan);
radio.SaveParameters(PERMANENT);
radio.PrintParameters();
// if the radio serial is available, proces incoming data
if (radio.available()) {
// a parsing method
radio.GetStruct(&MyData, sizeof(MyData));
Last = millis();
else {
Last = millis();
#pragma once
// Certain modifications made by REB - Search for (**)
The MIT License (MIT)
Copyright (c) 2019 Kris Kasrpzak
Permission is hereby granted, free of charge, to any person obtaining a copy of
this software and associated documentation files (the "Software"), to deal in
the Software without restriction, including without limitation the rights to
use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
the Software, and to permit persons to whom the Software is furnished to do so,
subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
On a personal note, if you develop an application or product using this library
and make millions of dollars, I'm happy for you!
Code by Kris Kasprzak kris.kasprzak@yahoo.com https://github.com/KrisKasprzak/EBYTE_32
This library is intended to be used with EBYTE_32 transcievers, small wireless units for MCU's such as
Teensy and Arduino. This library let's users program the operating parameters and both send and recieve data.
This company makes several modules with different capabilities, but most #defines here should be compatible with them
All constants were extracted from several data sheets and listed in binary as that's how the data sheet represented each setting
Hopefully, any changes or additions to constants can be a matter of copying the data sheet constants directly into these #defines
Usage of this library consumes around 970 bytes
Revision Data Author Description
1.0 3/6/2019 Kasprzak Initial creation
2.0 3/2/2020 Kasprzak Added all functions to build the options bit (FEC, Pullup, and TransmissionMode
3.0 3/27/2020 Kasprzak Added more Get functions
4.0 6/23/2020 Kasprzak Added private method to clear the buffer to ensure read methods would not be filled with buffered data
5.0 12/4/2020 Kasprzak moved Reset to public, added Clear to SetMode to avoid buffer corruption during programming
Module connection
Module MCU Description
MO Any digital pin* pin to control working/program modes
M1 Any digital pin* pin to control working/program modes
Rx Any digital pin pin to MCU TX pin (module transmits to MCU, hence MCU must recieve data from module
Tx Any digital pin pin to MCU RX pin (module transmits to MCU, hence MCU must recieve data from module
AUX Any digital pin pin to indicate when an operation is complete (low is busy, high is done)
Vcc +3v3 or 5V0
Vcc Ground Ground must be common to module and MCU
notes:
* caution in connecting to Arduino pin 0 and 1 as those pins are for USB connection to PC
you may need a 4K7 pullup to Rx and AUX pins (possibly Tx) if using and Arduino
Module source
http://www.EBYTE_32.com/en/
example module this library is intended to be used with
http://www.EBYTE_32.com/en/product-view-news.aspx?id=174
Code usage
1. Create a serial object
2. Create EBYTE_32 object that uses the serail object
3. begin the serial object
4. init the EBYTE_32 object
5. set parameters (optional but required if sender and reciever are different)
6. send or listen to sent data
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
// if you seem to get "corrupt settings add this line to your .ino
// #include <avr/io.h>
if modules don't seem to save, you will have to adjust this value
when settin M0 an M1 there is gererally a short time for the transceiver modules
to react, some say only 10 ms, but I've found it can be much lonnger, I'm using
100 ms below and maybe too long, but it seemed to work in my cases
#define PIN_RECOVER 15
// modes NORMAL send and recieve for example Changed to ENUM (**)
enum MODE_TYPE {
MODE_NORMAL = 0, // can send and recieve
MODE_WAKEUP = 1, // sends a preamble to waken receiver
MODE_POWERDOWN = 2, // can't transmit but receive works only in wake up mode
MODE_PROGRAM = 3 // for programming
// options to save change permanently or temp (power down and restart will restore settings to last saved options
#define PERMANENT 0xC0
#define TEMPORARY 0xC2
// parity bit options (must be the same for transmitter and reveiver)
#define PB_8N1 0b00 // default
#define PB_8O1 0b01
#define PB_8E1 0b11
//UART data rates
// (can be different for transmitter and reveiver)
#define UDR_1200 0b000 // 1200 baud
#define UDR_2400 0b001 // 2400 baud
#define UDR_4800 0b010 // 4800 baud
#define UDR_9600 0b011 // 9600 baud default
#define UDR_19200 0b100 // 19200 baud
#define UDR_38400 0b101 // 34800 baud
#define UDR_57600 0b110 // 57600 baud
#define UDR_115200 0b111 // 115200 baud
// air data rates (certian types of modules)
// (must be the same for transmitter and reveiver)
#define ADR_300 0b000 // 300 baud
#define ADR_1200 0b001 // 1200 baud
#define ADR_2400 0b010 // 2400 baud
#define ADR_4800 0b011 // 4800 baud
#define ADR_9600 0b100 // 9600 baud
#define ADR_19200 0b101 // 19200 baud
// air data rates (other types of modules)
#define ADR_1K 0b000 // 1k baud
#define ADR_2K 0b001 // 2K baud
#define ADR_5K 0b010 // 4K baud
#define ADR_8K 0b011 // 8K baud
#define ADR_10K 0b100 // 10K baud
#define ADR_15K 0b101 // 15K baud
#define ADR_20K 0b110 // 20K baud
#define ADR_25K 0b111 // 25K baud
// various options
#define OPT_FixedModeDISABLE 0b0 // Names Changed by REB to make them more understandable <<default (**)
#define OPT_FixedModeENABLE 0b1 // Names Changed by REB to make them more understandable (**)
#define OPT_IOOPENDRAIN 0b0
#define OPT_IOPUSHPULL 0b1
#define OPT_WAKEUP250 0b000
#define OPT_WAKEUP500 0b001
#define OPT_WAKEUP750 0b010
#define OPT_WAKEUP1000 0b011
#define OPT_WAKEUP1250 0b100
#define OPT_WAKEUP1500 0b101
#define OPT_WAKEUP1750 0b110
#define OPT_WAKEUP2000 0b111
#define OPT_FECDISABLE 0b0
#define OPT_FECENABLE 0b1
// transmitter output power--check government regulations on legal transmit power
// refer to the data sheet as not all modules support these power levels
// constants for 1W units
//#define OPT_TP30 0b00 // 30 db
//#define OPT_TP27 0b01 // 27 db
//#define OPT_TP24 0b10 // 24 db
//#define OPT_TP21 0b11 // 21 db
// constants or 500 mW units
//#define OPT_TP27 0b00 // 27 db
//#define OPT_TP24 0b01 // 24 db
//#define OPT_TP21 0b10 // 21 db
//#define OPT_TP18 0b11 // 17 db
//#define OPT_TP17 0b11 // 17 db
// constants or 100 mW units
#define OPT_TP20 0b00 // 20 db
#define OPT_TP17 0b01 // 17 db
#define OPT_TP14 0b10 // 14 db
#define OPT_TP11 0b11 // 10 db
#define OPT_TP10 0b11 // 10 db
class Stream;
class EBYTE_E32 {
public:
EBYTE_E32(Stream *s, uint8_t PIN_M0 = 4, uint8_t PIN_M1 = 5, uint8_t PIN_AUX = 6);
// code to initialize the library
// this method reads all parameters from the module and stores them in memory
// library modifications could be made to only read upon a change at a savings of 30 or so bytes
// the issue with these modules are some parameters are a collection of several options AND
// ALL parameters must be sent even if only one option is changed--hence get all parameters initially
// so you know what the non changed parameters are know for resending back
bool init();
// methods to set modules working parameters NOTHING WILL BE SAVED UNLESS SaveParameters() is called
void SetMode(uint8_t mode = MODE_NORMAL);
void SetAddress(uint16_t val = 0);
void SetAddressH(uint8_t val = 0);
void SetAddressL(uint8_t val = 0);
void SetAirDataRate(uint8_t val);
void SetUARTBaudRate(uint8_t val);
void SetSpeed(uint8_t val);
void SetOptions(uint8_t val);
void SetChannel(uint8_t val);
void SetParityBit(uint8_t val);
//functions to set the options
void SetTransmissionMode(uint8_t val);
void SetPullupMode(uint8_t val);
void SetWORTIming(uint8_t val);
void SetFECMode(uint8_t val);
void SetTransmitPower(uint8_t val);
bool GetAux();
bool available();
void flush();
// methods to get some operating parameters
uint16_t GetAddress();
// methods to get module data
uint8_t GetModel();
uint8_t GetVersion();
uint8_t GetFeatures();
uint8_t GetAddressH();
uint8_t GetAddressL();
uint8_t GetAirDataRate();
uint8_t GetUARTBaudRate();
uint8_t GetChannel();
uint8_t GetParityBit();
uint8_t GetTransmissionMode();
uint8_t GetPullupMode();
uint8_t GetWORTIming();
uint8_t GetFECMode();
uint8_t GetTransmitPower();
uint8_t GetOptions();
uint8_t GetSpeed();
// methods to get data from sending unit
uint8_t GetByte();
bool GetStruct(const void *TheStructure, uint16_t size_);
// method to send to data to receiving unit
void SendByte(uint8_t ThEBYTE);
bool SendStruct(const void *TheStructure, uint16_t size_);
// mehod to print parameters
void PrintParameters();
// parameters are set above but NOT saved, here's how you save parameters
// notion here is you can set several but save once as opposed to saving on each parameter change
// you can save permanently (retained at start up, or temp which is ideal for dynamically changing the address or frequency
void SaveParameters(uint8_t val = PERMANENT);
// MFG is not clear on what Reset does, but my testing indicates it clears buffer
// I use this when needing to restart the EBYTE_32 after programming while data is still streaming in
// it does NOT return the EBYTE_32 back to factory defaults
void Reset();
// uint8_t _buf; //REB Change 20Apr 2021 - used for size at various locations
protected:
// function to read modules parameters
bool ReadParameters();
// method to let method know of module is busy doing something (timeout provided to avoid lockups)
void CompleteTask(unsigned long timeout = 0);
// utility funciton to build the "speed byte" which is a collection of a few different parameters
void BuildSpeedByte();
// utility funciton to build the "options byte" which is a collection of a few different parameters
void BuildOptionByte();
private:
bool ReadModelData();
void ClearBuffer();
// variable for the serial stream
Stream* _s;
Stream* _TD;
// pin variables
int8_t _M0;
int8_t _M1;
int8_t _AUX;
// variable for the 6 bytes that are sent to the module to program it
// or bytes received to indicate modules programmed settings
uint8_t _Params[6];
// indicidual variables for each of the 6 bytes
// _Params could be used as the main variable storage, but since some bytes
// are a collection of several options, let's just make storage consistent
// also Param[1] is different data depending on the _Save variable
uint8_t _Save;
uint8_t _AddressHigh;
uint8_t _AddressLow;
uint8_t _Speed;
uint8_t _Channel;
uint8_t _Options;
// individual variables for all the options
uint8_t _ParityBit;
uint8_t _UARTDataRate;
uint8_t _AirDataRate;
uint8_t _OptionTrans;
uint8_t _OptionPullup;
uint8_t _OptionWakeup;
uint8_t _OptionFEC;
uint8_t _OptionPower;
uint16_t _Address;
uint8_t _Model;
uint8_t _Version;
uint8_t _Features;
uint8_t _buf; // REB Change 20 Apr 2021 - Made public
This library is intended to be used with EBYTE transcievers, small wireless units for MCU's such as
5.0a 14/11/2021 Bridges all digitalWrites set to DigiatWriteFast, pinMode Changed from INPUT to UNPUT_PULLUP,
all digitalReads changed to digitalReadFast.
#include <Stream.h>
#if ARDUINO >= 100
#else
create the transciever object
EBYTE_E32::EBYTE_E32(Stream *s, uint8_t PIN_M0, uint8_t PIN_M1, uint8_t PIN_AUX)
_s = s;
_M0 = PIN_M0;
_M1 = PIN_M1;
_AUX = PIN_AUX;
Initialize the unit--basicall this reads the modules parameters and stores the parameters
for potential future module programming
bool EBYTE_E32::init() {
bool ok = true;
pinMode(_AUX, INPUT_PULLUP); //(**) pinMode Changed from INPUT to UNPUT_PULLUP
pinMode(_M0, OUTPUT);
pinMode(_M1, OUTPUT);
SetMode(MODE_NORMAL);
// first get the module data (must be called first for some odd reason
delay(100); //(**)
ok = ReadModelData();
if (!ok) {
return false;
// now get parameters to put unit defaults into the class variables
ok = ReadParameters();
if (!ok) {
return false;
return true;
Method to indicate availability
bool EBYTE_E32::available() {
return _s->available();
void EBYTE_E32::flush() {
_s->flush();
Method to write a single byte...not sure how useful this really is. If you need to send
more that one byte, put the data into a data structure and send it in a big chunk
void EBYTE_E32::SendByte( uint8_t TheByte) {
_s->write(TheByte);
Method to get a single byte...not sure how useful this really is. If you need to get
more that one byte, put the data into a data structure and send/receive it in a big chunk
uint8_t EBYTE_E32::GetByte() {
return _s->read();
Method to send a chunk of data provided data is in a struct--my personal favorite as you
need not parse or worry about sprintf() inability to handle floats
TTP: put your structure definition into a .h file and include in both the sender and reciever
sketches
NOTE: of your sender and receiver MCU's are different (Teensy and Arduino) caution on the data
types each handle ints floats differently
bool EBYTE_E32::SendStruct(const void *TheStructure, uint16_t size_) {
_buf = _s->write((uint8_t *) TheStructure, size_);
CompleteTask(1000);
return (_buf == size_);
Method to get a chunk of data provided data is in a struct--my personal favorite as you
sketches
bool EBYTE_E32::GetStruct(const void *TheStructure, uint16_t size_) {
_buf = _s->readBytes((uint8_t *) TheStructure, size_);
CompleteTask(1000);
Utility method to wait until module is doen tranmitting
a timeout is provided to avoid an infinite loop
void EBYTE_E32::CompleteTask(unsigned long timeout) {
unsigned long t = millis();
// make darn sure millis() is not about to reach max data type limit and start over
if (((unsigned long) (t + timeout)) == 0){
t = 0;
// if AUX pin was supplied and look for HIGH state
// note you can omit using AUX if no pins are available, but you will have to use delay() to let module finish
if (_AUX != -1) {
while (digitalRead(_AUX) == LOW) {
if ((millis() - t) > timeout){
else {
// if you can't use aux pin, use 4K7 pullup with Arduino
// you may need to adjust this value if transmissions fail
// per data sheet control after aux goes high is 2ms so delay for at least that long)
//SmartDelay(20);
delay(20);
method to set the mode (program, normal, etc.)
void EBYTE_E32::SetMode(uint8_t mode) {
// data sheet claims module needs some extra time after mode setting (2ms)
// most of my projects uses 10 ms, but 40ms is safer
delay(PIN_RECOVER);
if (mode == MODE_NORMAL) {
digitalWrite(_M0, LOW); // (**) all digitalWrites set to DigiatWriteFast
digitalWrite(_M1, LOW);
else if (mode == MODE_WAKEUP) {
digitalWrite(_M0, HIGH);
else if (mode == MODE_POWERDOWN) {
digitalWrite(_M1, HIGH);
else if (mode == MODE_PROGRAM) {
// data sheet says 2ms later control is returned, let's give just a bit more time
// these modules can take time to activate pins
delay(PIN_RECOVER);
// clear out any junk
// added rev 5
// i've had some issues where after programming, the returned model is 0, and all settings appear to be corrupt
// i imagine the issue is due to the internal buffer full of junk, hence clearing
// Reset() *MAY* work but this seems better.
ClearBuffer();
// wait until aux pin goes back low
CompleteTask(4000);
// i've asked EBYTE what's supposed to happen--got an unclear answer
// but my testing indicates it clears buffer
// I use this when needing to restart the EBYTE after programming while data is still streaming in
// to let the unit start reading from a cleared internal buffer
// it does NOT return the ebyte back to factory defaults
// if your unit gets corrupt or you need to restore values, you will have to do brute force
// example for and E44-915
// look at the data sheet for default values
// Trans.SetAddressH(0);
// Trans.SetAddressL(0);
// Trans.SetSpeed(0b00011100);
// Trans.SetChannel(1);
// Trans.SetOptions(0b01000100);
// Trans.SaveParameters(PERMANENT);
void EBYTE_E32::Reset() {
SetMode(MODE_PROGRAM);
delay(50); // not sure you need this
_s->write(0xC4);
_s->write(0xC4);
_s->write(0xC4);
CompleteTask(4000);
void EBYTE_E32::SetSpeed(uint8_t val) {
_Speed = val;
void EBYTE_E32::SetOptions(uint8_t val) {
_Options = val;
uint8_t EBYTE_E32::GetSpeed() {
return _Speed ;
uint8_t EBYTE_E32::GetOptions() {
return _Options;
method to set the high bit of the address
void EBYTE_E32::SetAddressH(uint8_t val) {
_AddressHigh = val;
uint8_t EBYTE_E32::GetAddressH() {
return _AddressHigh;
method to set the lo bit of the address
void EBYTE_E32::SetAddressL(uint8_t val) {
_AddressLow = val;
uint8_t EBYTE_E32::GetAddressL() {
return _AddressLow;
method to set the channel
void EBYTE_E32::SetChannel(uint8_t val) {
_Channel = val;
uint8_t EBYTE_E32::GetChannel() {
return _Channel;
method to set the air data rate
void EBYTE_E32::SetAirDataRate(uint8_t val) {
_AirDataRate = val;
BuildSpeedByte();
uint8_t EBYTE_E32::GetAirDataRate() {
return _AirDataRate;
method to set the parity bit
void EBYTE_E32::SetParityBit(uint8_t val) {
_ParityBit = val;
BuildSpeedByte();
uint8_t EBYTE_E32::GetParityBit( ) {
return _ParityBit;
method to set the options bits
void EBYTE_E32::SetTransmissionMode(uint8_t val) {
_OptionTrans = val;
BuildOptionByte();
uint8_t EBYTE_E32::GetTransmissionMode( ) {
return _OptionTrans;
void EBYTE_E32::SetPullupMode(uint8_t val) {
_OptionPullup = val;
BuildOptionByte();
uint8_t EBYTE_E32::GetPullupMode( ) {
return _OptionPullup;
void EBYTE_E32::SetWORTIming(uint8_t val) {
_OptionWakeup = val;
BuildOptionByte();
uint8_t EBYTE_E32::GetWORTIming() {
return _OptionWakeup;
void EBYTE_E32::SetFECMode(uint8_t val) {
_OptionFEC = val;
BuildOptionByte();
uint8_t EBYTE_E32::GetFECMode( ) {
return _OptionFEC;
void EBYTE_E32::SetTransmitPower(uint8_t val) {
_OptionPower = val;
BuildOptionByte();
uint8_t EBYTE_E32::GetTransmitPower() {
return _OptionPower;
method to compute the address based on high and low bits
void EBYTE_E32::SetAddress(uint16_t Val) {
_AddressHigh = ((Val & 0xFFFF) >> 8);
_AddressLow = (Val & 0xFF);
method to get the address which is a collection of hi and lo bytes
uint16_t EBYTE_E32::GetAddress() {
return (_AddressHigh << 8) | (_AddressLow );
set the UART baud rate
void EBYTE_E32::SetUARTBaudRate(uint8_t val) {
_UARTDataRate = val;
BuildSpeedByte();
uint8_t EBYTE_E32::GetUARTBaudRate() {
return _UARTDataRate;
method to build the byte for programming (notice it's a collection of a few variables)
void EBYTE_E32::BuildSpeedByte() {
_Speed = 0;
_Speed = ((_ParityBit & 0xFF) << 6) | ((_UARTDataRate & 0xFF) << 3) | (_AirDataRate & 0xFF);
method to build the option byte for programming (notice it's a collection of a few variables)
void EBYTE_E32::BuildOptionByte() {
_Options = 0;
_Options = ((_OptionTrans & 0xFF) << 7) | ((_OptionPullup & 0xFF) << 6) | ((_OptionWakeup & 0xFF) << 3) | ((_OptionFEC & 0xFF) << 2) | (_OptionPower&0b11);
bool EBYTE_E32::GetAux() {
return digitalRead(_AUX); // (**) changed from digitalRead to digitalReadFast
method to save parameters to the module
void EBYTE_E32::SaveParameters(uint8_t val) {
// ClearBuffer();
// here you can save permanenly or temp
delay(5);
Serial.print("val: ");
Serial.println(val);
Serial.print("_AddressHigh: ");
Serial.println(_AddressHigh);
Serial.print("_AddressLow: ");
Serial.println(_AddressLow);
Serial.print("_Speed: ");
Serial.println(_Speed);
Serial.print("_Channel: ");
Serial.println(_Channel);
Serial.print("_Options: ");
Serial.println(_Options);
_s->write(val);
_s->write(_AddressHigh);
_s->write(_AddressLow);
_s->write(_Speed);
_s->write(_Channel);
_s->write(_Options);
delay(50);
CompleteTask(4000);
method to print parameters, this can be called anytime after init(), because init gets parameters
and any method updates the variables
void EBYTE_E32::PrintParameters() {
_ParityBit = (_Speed & 0XC0) >> 6;
_UARTDataRate = (_Speed & 0X38) >> 3;
_AirDataRate = _Speed & 0X07;
_OptionTrans = (_Options & 0X80) >> 7;
_OptionPullup = (_Options & 0X40) >> 6;
_OptionWakeup = (_Options & 0X38) >> 3;
_OptionFEC = (_Options & 0X07) >> 2;
_OptionPower = (_Options & 0X03);
Serial.println("----------------------------------------");
Serial.print(F("Model no.: ")); Serial.println(_Model, HEX);
Serial.print(F("Version : ")); Serial.println(_Version, HEX);
Serial.print(F("Features : ")); Serial.println(_Features, HEX);
Serial.println(F(" "));
Serial.print(F("Mode (HEX/DEC/BIN): ")); Serial.print(_Save, HEX); Serial.print(F("/")); Serial.print(_Save, DEC); Serial.print(F("/")); Serial.println(_Save, BIN);
Serial.print(F("AddH (HEX/DEC/BIN): ")); Serial.print(_AddressHigh, HEX); Serial.print(F("/")); Serial.print(_AddressHigh, DEC); Serial.print(F("/")); Serial.println(_AddressHigh, BIN);
Serial.print(F("AddL (HEX/DEC/BIN): ")); Serial.print(_AddressLow, HEX); Serial.print(F("/")); Serial.print(_AddressLow, DEC); Serial.print(F("/")); Serial.println(_AddressLow, BIN);
Serial.print(F("Sped (HEX/DEC/BIN): ")); Serial.print(_Speed, HEX); Serial.print(F("/")); Serial.print(_Speed, DEC); Serial.print(F("/")); Serial.println(_Speed, BIN);
Serial.print(F("Chan (HEX/DEC/BIN): ")); Serial.print(_Channel, HEX); Serial.print(F("/")); Serial.print(_Channel, DEC); Serial.print(F("/")); Serial.println(_Channel, BIN);
Serial.print(F("Optn (HEX/DEC/BIN): ")); Serial.print(_Options, HEX); Serial.print(F("/")); Serial.print(_Options, DEC); Serial.print(F("/")); Serial.println(_Options, BIN);
Serial.print(F("Addr (HEX/DEC/BIN): ")); Serial.print(GetAddress(), HEX); Serial.print(F("/")); Serial.print(GetAddress(), DEC); Serial.print(F("/")); Serial.println(GetAddress(), BIN);
Serial.print(F("SpeedParityBit (HEX/DEC/BIN) : ")); Serial.print(_ParityBit, HEX); Serial.print(F("/")); Serial.print(_ParityBit, DEC); Serial.print(F("/")); Serial.println(_ParityBit, BIN);
Serial.print(F("SpeedUARTDataRate (HEX/DEC/BIN) : ")); Serial.print(_UARTDataRate, HEX); Serial.print(F("/")); Serial.print(_UARTDataRate, DEC); Serial.print(F("/")); Serial.println(_UARTDataRate, BIN);
Serial.print(F("SpeedAirDataRate (HEX/DEC/BIN) : ")); Serial.print(_AirDataRate, HEX); Serial.print(F("/")); Serial.print(_AirDataRate, DEC); Serial.print(F("/")); Serial.println(_AirDataRate, BIN);
Serial.print(F("OptionTrans (HEX/DEC/BIN) : ")); Serial.print(_OptionTrans, HEX); Serial.print(F("/")); Serial.print(_OptionTrans, DEC); Serial.print(F("/")); Serial.println(_OptionTrans, BIN);
Serial.print(F("OptionPullup (HEX/DEC/BIN) : ")); Serial.print(_OptionPullup, HEX); Serial.print(F("/")); Serial.print(_OptionPullup, DEC); Serial.print(F("/")); Serial.println(_OptionPullup, BIN);
Serial.print(F("OptionWakeup (HEX/DEC/BIN) : ")); Serial.print(_OptionWakeup, HEX); Serial.print(F("/")); Serial.print(_OptionWakeup, DEC); Serial.print(F("/")); Serial.println(_OptionWakeup, BIN);
Serial.print(F("OptionFEC (HEX/DEC/BIN) : ")); Serial.print(_OptionFEC, HEX); Serial.print(F("/")); Serial.print(_OptionFEC, DEC); Serial.print(F("/")); Serial.println(_OptionFEC, BIN);
Serial.print(F("OptionPower (HEX/DEC/BIN) : ")); Serial.print(_OptionPower, HEX); Serial.print(F("/")); Serial.print(_OptionPower, DEC); Serial.print(F("/")); Serial.println(_OptionPower, BIN);
method to read parameters,
bool EBYTE_E32::ReadParameters() {
_Params[0] = 0;
_Params[1] = 0;
_Params[2] = 0;
_Params[3] = 0;
_Params[4] = 0;
_Params[5] = 0;
_s->write(0xC1);
_s->write(0xC1);
_s->write(0xC1);
_s->readBytes((uint8_t*)&_Params, (uint8_t) sizeof(_Params));
_Save = _Params[0];
_AddressHigh = _Params[1];
_AddressLow = _Params[2];
_Speed = _Params[3];
_Channel = _Params[4];
_Options = _Params[5];
_Address = (_AddressHigh << 8) | (_AddressLow);
if (0xC0 != _Params[0]){
return false;
return true;
bool EBYTE_E32::ReadModelData() {
_Params[0] = 0;
_Params[1] = 0;
_Params[2] = 0;
_Params[3] = 0;
_Params[4] = 0;
_Params[5] = 0;
bool found = false;
int i = 0;
_s->write(0xC3);
_s->write(0xC3);
_s->write(0xC3);
_s->readBytes((uint8_t*)& _Params, (uint8_t) sizeof(_Params));
_Save = _Params[0];
_Model = _Params[1];
_Version = _Params[2];
_Features = _Params[3];
if (0xC3 != _Params[0]) {
for (i = 0; i < 5; i++){
Serial.print("trying: "); Serial.println(i);
_Params[0] = 0;
_Params[1] = 0;
_Params[2] = 0;
_Params[3] = 0;
_Params[4] = 0;
_Params[5] = 0;
_s->write(0xC3);
_s->write(0xC3);
_s->write(0xC3);
if (0xC3 == _Params[0]){
found = true;
else {
found = true;
CompleteTask(1000);
return found;
method to get module model and E50-TTL-100 will return 50
uint8_t EBYTE_E32::GetModel() {
return _Model;
method to get module version (undocumented as to the value)
uint8_t EBYTE_E32::GetVersion() {
return _Version;
uint8_t EBYTE_E32::GetFeatures() {
return _Features;
method to clear the serial buffer
without clearing the buffer, i find getting the parameters very unreliable after programming.
i suspect stuff in the buffer affects rogramming
hence, let's clean it out
this is called as part of the setmode
void EBYTE_E32::ClearBuffer(){
unsigned long amt = millis();
while(_s->available()) {
_s->read();
if ((millis() - amt) > 5000) {
Serial.println("runaway");
#pragma pack(push,1)
struct DATA {
int Bits;
float Volts;
float Amps;
int Chan;
DATA MyData;
#pragma pack(pop)
#pragma once
#define Hi_addr 0
#define Lo_addr 0
#define chan 1
#include <AddrAndChan.h>
struct DATA {
int Bits;
float Volts;
float Amps;
int Chan;
DATA MyData;
unsigned long Last;
while (!Serial) {}
radio.init();
radio.SetAddressH(Hi_addr);
radio.SetAddressL(Lo_addr);
radio.SetChannel(chan);
Chan = 5;
// a parsing method
Last = millis();
else {
Last = millis();
