Teensy 4.1 appears to load from Arduino without error but still runs old code.
FLL-Freak
I have a Teensy 4.1 connected to a new install of Ubuntu 24.04 box with a fresh Arduino "app" image. I have place the App image in /opt and added the udev rules. I compile a program with no errors and when it then uploads to the Teensy it gives no errors. But the code that runs afterwards is a completely different program. It is one that I somehow loaded (likely from a different computer) months ago. What follows is the output of the command window that includes initialization of Arduino, a compile, and an upload. Nothing in it seems to be overly wrong except perhaps this line:
2025-04-08T00:57:22.846Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: </home/skye/Arduino/junk/junk.ino>, response: </home/skye/Arduino/junk>.
Hints?
skye@Pascal:/opt$ ./arduino-ide_2.3.5_Linux_64bit.AppImage
Arduino IDE 2.3.5
Checking for frontend application configuration customizations. Module path: /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/electron-main.js, destination 'package.json': /tmp/.mount_arduinnLHvsN/resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.5" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-02T13:10:22.343Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"theia"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.5","cliVersion":"1.2.0","buildDate":"2025-04-02T13:10:22.343Z"}
Starting backend process. PID: 4317
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///home/skye/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-04-08T00:57:21.731Z root INFO Backend u.initialize: 24.2 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.737Z root INFO Backend Object.initialize: 23.5 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.737Z root INFO Backend a.initialize: 0.6 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.737Z root INFO Backend a.initialize: 0.5 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.737Z root INFO Backend u.initialize: 0.6 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.738Z root INFO Backend l.initialize: 24.1 ms [Finished 0.322 s after backend start]
2025-04-08T00:57:21.741Z root INFO configured all backend app contributions
2025-04-08T00:57:21.741Z root INFO Backend l.onStart: 0.6 ms [Finished 0.333 s after backend start]
2025-04-08T00:57:21.741Z root INFO Backend d.onStart: 0.0 ms [Finished 0.333 s after backend start]
2025-04-08T00:57:21.742Z root INFO Backend a.onStart: 0.1 ms [Finished 0.333 s after backend start]
2025-04-08T00:57:21.742Z config INFO >>> Initializing CLI configuration...
2025-04-08T00:57:21.742Z root INFO Backend x.onStart: 0.1 ms [Finished 0.333 s after backend start]
2025-04-08T00:57:21.742Z config INFO Loading CLI configuration from /home/skye/.arduinoIDE/arduino-cli.yaml...
2025-04-08T00:57:21.742Z daemon INFO Starting daemon from /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/resources/arduino-cli...
2025-04-08T00:57:21.742Z root INFO Backend w.onStart: 0.2 ms [Finished 0.334 s after backend start]
2025-04-08T00:57:21.742Z discovery-log INFO start
2025-04-08T00:57:21.742Z discovery-log INFO start new deferred
2025-04-08T00:57:21.742Z root INFO Backend v.onStart: 0.1 ms [Finished 0.334 s after backend start]
2025-04-08T00:57:21.742Z root INFO Backend a.onStart: 0.0 ms [Finished 0.334 s after backend start]
2025-04-08T00:57:21.744Z root INFO Theia app listening on http://127.0.0.1:43393.
2025-04-08T00:57:21.744Z root INFO Finished starting backend application: 1.8 ms [Finished 0.336 s after backend start]
Restoring workspace roots: /home/skye/Arduino/junk
2025-04-08T00:57:21.744Z root WARN The local plugin referenced by local-dir:/home/skye/.arduinoIDE/plugins does not exist.
2025-04-08T00:57:21.744Z root WARN The local plugin referenced by local-dir:/home/skye/.arduinoIDE/deployedPlugins does not exist.
isTempSketch: false. Input was /home/skye/Arduino/junk/junk.ino
2025-04-08T00:57:21.751Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://www.pjrc.com/teensy/package_teensy_index.json"]},"directories":{"builtin":{"libraries":"/home/skye/.arduino15/libraries"},"data":"/home/skye/.arduino15","user":"/home/skye/Arduino"},"locale":"en"}
2025-04-08T00:57:21.751Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-04-08T00:57:21.751Z config INFO Loaded the CLI configuration.
2025-04-08T00:57:21.752Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///home/skye/.arduino15","sketchDirUri":"file:///home/skye/Arduino","additionalUrls":["https://www.pjrc.com/teensy/package_teensy_index.json"],"network":"none","locale":"en"}
2025-04-08T00:57:21.752Z config INFO Validating the CLI configuration...
2025-04-08T00:57:21.752Z config INFO The CLI config is valid.
2025-04-08T00:57:21.752Z config INFO <<< Initialized the CLI configuration.
2025-04-08T00:57:21.813Z root INFO Resolve plugins list: 70.4 ms [Finished 0.405 s after backend start]
2025-04-08T00:57:21.881Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="arduino-cli version 1.2.0"
2025-04-08T00:57:21.882Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Using config file: /home/skye/.arduinoIDE/arduino-cli.yaml"
time="2025-04-07T20:57:21-04:00" level=info msg="Executing `arduino-cli daemon`"
2025-04-08T00:57:21.890Z daemon INFO Daemon is now listening on 127.0.0.1:38313
{"IP":"127.0.0.1","Port":"38313"}
2025-04-08T00:57:21.890Z daemon INFO Daemon is running.
2025-04-08T00:57:21.945Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Checking signature" index=/home/skye/.arduino15/package_index.json signatureFile=/home/skye/.arduino15/package_index.json.sig trusted=true
time="2025-04-07T20:57:21-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/package_teensy_index.json
time="2025-04-07T20:57:21-04:00" level=info msg="Loading hardware from: /home/skye/.arduino15/packages"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading package arduino from: /home/skye/.arduino15/packages/arduino/hardware"
time="2025-04-07T20:57:21-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
time="2025-04-07T20:57:21-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-04-07T20:57:21-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/arduino/tools"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/arduino/tools"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading package builtin from: /home/skye/.arduino15/packages/builtin"
time="2025-04-07T20:57:21-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/builtin/tools"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/builtin/tools"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading package teensy from: /home/skye/.arduino15/packages/teensy/hardware"
time="2025-04-07T20:57:21-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/installed.json
2025-04-08T00:57:21.945Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded platform" platform="teensy:avr@1.59.0"
2025-04-08T00:57:21.945Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/teensy/tools"
time="2025-04-07T20:57:21-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/teensy/tools"
2025-04-08T00:57:21.946Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="teensy:teensy-discovery@1.59.0"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="teensy:teensy-monitor@1.59.0"
time="2025-04-07T20:57:21-04:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.59.0"
2025-04-08T00:57:21.947Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:21.947Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:21.947Z daemon INFO time="2025-04-07T20:57:21-04:00" level=info msg="Loading libraries index file" index=/home/skye/.arduino15/library_index.json
2025-04-08T00:57:22.077Z daemon INFO time="2025-04-07T20:57:22-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
2025-04-08T00:57:22.077Z daemon INFO time="2025-04-07T20:57:22-04:00" level=info msg="Adding libraries dir" dir=/home/skye/Arduino/libraries isSingleLibrary=false location=user
2025-04-08T00:57:22.221Z discovery-log INFO start resolved watching
2025-04-08T00:57:22.260Z root INFO Deploy plugins list: 517.5 ms [Finished 0.852 s after backend start]
2025-04-08T00:57:22.416Z root INFO creating connection for 1
2025-04-08T00:57:22.836Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
2025-04-08T00:57:22.881Z root INFO Start frontend contributions: 128.7 ms [Finished 1.125 s after frontend start]
2025-04-08T00:57:22.882Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-04-08T00:57:22.891Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-04-08T00:57:22.891Z root INFO >>> Restoring the layout state...
2025-04-08T00:57:22.902Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Waiting for backend deployment: 27.4 ms [Finished 1.151 s after frontend start]
2025-04-08T00:57:23.159Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453) starting instance
[Object: null prototype] {}
2025-04-08T00:57:23.442Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Sync of 23 plugins: 540.9 ms [Finished 1.692 s after frontend start]
2025-04-08T00:57:23.452Z root INFO ------- SERIALIZED LAYOUT DATA -------
2025-04-08T00:57:23.452Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///home/skye/Arduino/junk/junk.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":26,\"column\":19},\"position\":{\"lineNumber\":26,\"column\":19}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":32,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":333,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"multiline\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"serial-monitor"}
2025-04-08T00:57:23.452Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2025-04-08T00:57:23.567Z root INFO <<< The layout has been successfully restored.
2025-04-08T00:57:23.600Z root INFO Initialize the workbench layout: 676.3 ms [Finished 1.817 s after frontend start]
2025-04-08T00:57:23.600Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-04-08T00:57:23.600Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Loading plugin contributions
2025-04-08T00:57:23.600Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Load contributions of 23 plugins: 31.2 ms [Finished 1.849 s after frontend start]
2025-04-08T00:57:23.622Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-04-08T00:57:23.622Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2025-04-08T00:57:23.703Z root ERROR [hosted-plugin: 4453] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-04-08T00:57:23.708Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): PluginManagerExtImpl/init()
2025-04-08T00:57:23.708Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-arduino-api@0.1.2 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.743Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(json-language-features@1.88.1 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.745Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(cortex-debug@1.5.1 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.745Z root INFO [hosted-plugin: 4453] Debugger contribution has been registered: cortex-debug
2025-04-08T00:57:23.746Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-arduino-tools@0.1.3 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.747Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(cpp@1.88.1 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.748Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(json@1.88.1 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.749Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-bg@1.48.3 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.750Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-cs@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.751Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-de@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.751Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-es@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.752Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-fr@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.752Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-hu@1.48.3 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.752Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-it@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.752Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-ja@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.752Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-ko@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-nl@1.48.3 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-pl@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-pt-BR@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-ru@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-tr@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-uk@1.48.3 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.753Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-zh-hans@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.754Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): initializing(vscode-language-pack-zh-hant@1.96.0 with /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/plugin-vscode-init)
2025-04-08T00:57:23.755Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduinnLHvsN/resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/node/jsonClientMain)
2025-04-08T00:57:23.780Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduinnLHvsN/resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2025-04-08T00:57:23.792Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduinnLHvsN/resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2025-04-08T00:57:23.793Z root INFO [hosted-plugin: 4453] calling activation function on VS Code Arduino Tools
2025-04-08T00:57:23.793Z root INFO [hosted-plugin: 4453] calling activation function on Arduino IDE API for VS Code extensions
2025-04-08T00:57:23.805Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Starting plugins.
2025-04-08T00:57:23.820Z root INFO [hosted-plugin: 4453] PLUGIN_HOST(4453): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduinnLHvsN/resources/app/plugins/cortex-debug/extension/dist/extension.js)
2025-04-08T00:57:23.835Z root INFO [hosted-plugin: 4453] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-04-08T00:57:23.835Z root INFO [hosted-plugin: 4453] calling activation function on Cortex-Debug
2025-04-08T00:57:23.836Z root INFO [hosted-plugin: 4453] GDB server console created
2025-04-08T00:57:23.840Z root INFO [76bc204f-f665-4351-a1cb-23709482e989] Start of 23 plugins: 239.4 ms [Finished 2.090 s after frontend start]
2025-04-08T00:57:23.891Z root INFO [hosted-plugin: 4453] calling activation function on JSON Language Features (built-in)
2025-04-08T00:57:24.488Z root INFO Frontend application start: 1677.0 ms [Finished 3.080 s after backend start]
2025-04-08T00:57:24.510Z root INFO Replace loading indicator with ready workbench UI (animation): 817.1 ms [Finished 2.667 s after frontend start]
2025-04-08T00:57:24.510Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-04-08T00:57:24.510Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-04-08T00:57:24.535Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-04-07T20:57:24-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-04-07T20:57:24-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-04-08T00:57:24.540Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-04-08T00:57:24.540Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-04-08T00:57:24.574Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-compile@11.3.1"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-tools@1.59.0"
2025-04-08T00:57:24.575Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-monitor@1.59.0"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-08T00:57:24.575Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-07T20:57:24-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-discovery@1.59.0"
2025-04-08T00:57:24.575Z root ERROR Failed to get debug config: teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us, undefined Error: Debugging is not supported.
    at Object.callback (/tmp/.mount_arduinnLHvsN/resources/app/lib/backend/main.js:2:4749606)
    at Object.onReceiveStatus (/tmp/.mount_arduinnLHvsN/resources/app/lib/backend/main.js:2:3783165)
    at Object.onReceiveStatus (/tmp/.mount_arduinnLHvsN/resources/app/lib/backend/main.js:2:2216666)
    at Object.onReceiveStatus (/tmp/.mount_arduinnLHvsN/resources/app/lib/backend/main.js:2:2216111)
    at /tmp/.mount_arduinnLHvsN/resources/app/lib/backend/main.js:2:4354455
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2025-04-08T00:57:24.694Z root ERROR ---- !!!SLOW!!! DURATION: search took 183.864 ms. Args: [{"type":"Updatable"}] ----
2025-04-08T00:57:24.695Z root INFO Starting language server: teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us
2025-04-08T00:57:24.734Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Updating index" url="https://www.pjrc.com/teensy/package_teensy_index.json"
2025-04-08T00:57:24.735Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Starting download" url="https://www.pjrc.com/teensy/package_teensy_index.json"
2025-04-08T00:57:24.735Z root INFO core-client-provider [platform-index] Downloading index: package_teensy_index.json
2025-04-08T00:57:24.786Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
time="2025-04-07T20:57:24-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:24.786Z daemon INFO time="2025-04-07T20:57:24-04:00" level=info msg="Adding libraries dir" dir=/home/skye/Arduino/libraries isSingleLibrary=false location=user
2025-04-08T00:57:25.604Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Checking signature" index=/home/skye/.arduino15/package_index.json signatureFile=/home/skye/.arduino15/package_index.json.sig trusted=true
2025-04-08T00:57:25.605Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/package_teensy_index.json
2025-04-08T00:57:25.605Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loading hardware from: /home/skye/.arduino15/packages"
2025-04-08T00:57:25.605Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loading package arduino from: /home/skye/.arduino15/packages/arduino/hardware"
2025-04-08T00:57:25.605Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-04-07T20:57:25-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/arduino/tools"
time="2025-04-07T20:57:25-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/arduino/tools"
time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loading package builtin from: /home/skye/.arduino15/packages/builtin"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/builtin/tools"
time="2025-04-07T20:57:25-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/builtin/tools"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loading package teensy from: /home/skye/.arduino15/packages/teensy/hardware"
2025-04-08T00:57:25.606Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Missing signature file" index=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/installed.json
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2025-04-07T20:57:25-04:00" level=info msg="Loaded platform" platform="teensy:avr@1.59.0"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Checking existence of 'tools' path: /home/skye/.arduino15/packages/teensy/tools"
time="2025-04-07T20:57:25-04:00" level=info msg="Loading tools from dir: /home/skye/.arduino15/packages/teensy/tools"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="teensy:teensy-discovery@1.59.0"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="teensy:teensy-monitor@1.59.0"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.59.0"
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
2025-04-08T00:57:25.607Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/Arduino/libraries isSingleLibrary=false location=user
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Discovery event channel closed teensy:teensy-discovery. Exiting goroutine."
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Closed and removed discovery teensy:teensy-discovery"
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=error msg="Stopped decode loop: EOF" discovery="teensy:teensy-discovery"
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
2025-04-08T00:57:25.654Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2025-04-08T00:57:25.655Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2025-04-08T00:57:25.655Z daemon INFO time="2025-04-07T20:57:25-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
2025-04-08T00:57:25.658Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:25.658Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:25.658Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Loading libraries index file" index=/home/skye/.arduino15/library_index.json
2025-04-08T00:57:25.758Z daemon INFO time="2025-04-07T20:57:25-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
2025-04-08T00:57:31.220Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/006 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["name","Teensy"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:31.223Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/006 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:31.226Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/006 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:31.370Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Starting monitor process" monitor=teensy-monitor
2025-04-08T00:57:31.370Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Monitor process started successfully!" monitor=teensy-monitor
time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.2.0\"" monitor=teensy-monitor
2025-04-08T00:57:31.371Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=hello message=OK monitor=teensy-monitor
time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command=DESCRIBE monitor=teensy-monitor
2025-04-08T00:57:31.371Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=describe message=OK monitor=teensy-monitor
time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command=QUIT monitor=teensy-monitor
2025-04-08T00:57:31.371Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=quit message=OK monitor=teensy-monitor
2025-04-08T00:57:31.371Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Killing monitor process" monitor=teensy-monitor
2025-04-08T00:57:31.372Z monitor-service INFO starting monitor
2025-04-08T00:57:31.372Z daemon INFO time="2025-04-07T20:57:31-04:00" level=error msg="stopped decode loop: EOF" monitor=teensy-monitor
time="2025-04-07T20:57:31-04:00" level=info msg="Monitor process killed" monitor=teensy-monitor
2025-04-08T00:57:31.372Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Starting monitor process" monitor=teensy-monitor
2025-04-08T00:57:31.372Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Monitor process started successfully!" monitor=teensy-monitor
2025-04-08T00:57:31.372Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.2.0\"" monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=hello message=OK monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command=DESCRIBE monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=describe message=OK monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command=QUIT monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=quit message=OK monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Killing monitor process" monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=error msg="stopped decode loop: EOF" monitor=teensy-monitor
2025-04-08T00:57:31.373Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Monitor process killed" monitor=teensy-monitor
2025-04-08T00:57:31.375Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Starting monitor process" monitor=teensy-monitor
2025-04-08T00:57:31.375Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Monitor process started successfully!" monitor=teensy-monitor
2025-04-08T00:57:31.375Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=hello message=OK monitor=teensy-monitor
2025-04-08T00:57:31.375Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command=DESCRIBE monitor=teensy-monitor
2025-04-08T00:57:31.375Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=describe message=OK monitor=teensy-monitor
2025-04-08T00:57:31.376Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="sending command" command="OPEN 127.0.0.1:33369 usb3/3-5" monitor=teensy-monitor
2025-04-08T00:57:31.376Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="received message" error=false event_type=open message=OK monitor=teensy-monitor
2025-04-08T00:57:31.376Z daemon INFO time="2025-04-07T20:57:31-04:00" level=info msg="Port usb3/3-5 successfully opened"
2025-04-08T00:57:31.376Z monitor-service INFO Using port configuration for teensy:usb3/3-5: {"settingsList":[]}
2025-04-08T00:57:31.376Z monitor-service INFO started monitor to usb3/3-5 using teensy
2025-04-08T00:57:31.386Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor teensy:usb3/3-5.
2025-04-08T00:57:31.463Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/ttyACM0","label":"/dev/ttyACM0","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0483"],["serialNumber","15106930"],["vid","0x16c0"]],"hardwareId":"15106930"}},"error":""}
2025-04-08T00:57:31.463Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/ttyACM0 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:38.852Z daemon INFO time="2025-04-07T20:57:38-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
time="2025-04-07T20:57:38-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
2025-04-08T00:57:38.852Z daemon INFO time="2025-04-07T20:57:38-04:00" level=info msg="Adding libraries dir" dir=/home/skye/Arduino/libraries isSingleLibrary=false location=user
2025-04-08T00:57:39.580Z root INFO Executing 'arduino.languageserver.notifyBuildDidComplete' with "file:///home/skye/.cache/arduino/sketches/32EDB0449F2E1A682701EE7231A1E616"
2025-04-08T00:57:39.581Z daemon INFO time="2025-04-07T20:57:39-04:00" level=info msg="sending command" command=CLOSE monitor=teensy-monitor
2025-04-08T00:57:39.593Z daemon INFO time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-compile@11.3.1"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-tools@1.59.0"
2025-04-08T00:57:39.593Z daemon INFO time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-monitor@1.59.0"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
time="2025-04-07T20:57:39-04:00" level=info msg="Tool required for debug" tool="teensy:teensy-discovery@1.59.0"
2025-04-08T00:57:39.594Z root ERROR Failed to get debug config: teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us, undefined Error: Debugging is not supported.
2025-04-08T00:57:40.590Z daemon INFO time="2025-04-07T20:57:40-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/libraries isSingleLibrary=false location=ide
time="2025-04-07T20:57:40-04:00" level=info msg="Adding libraries dir" dir=/home/skye/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries isSingleLibrary=false location=platform
time="2025-04-07T20:57:40-04:00" level=info msg="Adding libraries dir" dir=/home/skye/Arduino/libraries isSingleLibrary=false location=user
2025-04-08T00:57:41.581Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2025-04-08T00:57:44.582Z daemon INFO time="2025-04-07T20:57:44-04:00" level=info msg="sending command" command=QUIT monitor=teensy-monitor
2025-04-08T00:57:44.582Z daemon INFO time="2025-04-07T20:57:44-04:00" level=info msg="received message" error=false event_type=quit message=OK monitor=teensy-monitor
time="2025-04-07T20:57:44-04:00" level=info msg="Killing monitor process" monitor=teensy-monitor
2025-04-08T00:57:44.589Z daemon INFO time="2025-04-07T20:57:44-04:00" level=error msg="stopped decode loop: EOF" monitor=teensy-monitor
2025-04-08T00:57:44.589Z daemon INFO time="2025-04-07T20:57:44-04:00" level=info msg="Monitor process killed" monitor=teensy-monitor
2025-04-08T00:57:44.590Z monitor-service INFO monitor to usb3/3-5 using teensy closed by server
2025-04-08T00:57:44.741Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"/dev/ttyACM0","label":"","protocol":"serial","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2025-04-08T00:57:44.751Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"usb3/3-5","label":"","protocol":"teensy","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2025-04-08T00:57:45.318Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/007 Bootloader","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:45.320Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/007 Bootloader","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:45.321Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/007 Bootloader","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:45.323Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/007 Bootloader","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:46.172Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"usb3/3-5","label":"","protocol":"teensy","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2025-04-08T00:57:46.811Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/ttyACM0","label":"/dev/ttyACM0","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0483"],["serialNumber","15106930"],["vid","0x16c0"]],"hardwareId":"15106930"}},"error":""}
2025-04-08T00:57:46.816Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/008 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:46.818Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/008 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:46.819Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/bus/usb/003/008 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:46.851Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Teensy 4.1","fqbn":"teensy:avr:teensy41","isHidden":false}],"port":{"address":"usb3/3-5","label":"/dev/ttyACM0 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","propertiesMap":[["modelID","0x25"],["name","Teensy 4.1"]],"hardwareId":""}},"error":""}
2025-04-08T00:57:47.817Z root INFO Received port after upload [arduino+teensy://usb3/3-5, teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us, junk]. Before port: {"protocol":"teensy","address":"usb3/3-5"}, after port: {"address":"usb3/3-5","addressLabel":"/dev/bus/usb/003/008 Serial","protocol":"teensy","protocolLabel":"Teensy Ports","properties":{"modelID":"0x25","name":"Teensy 4.1"}}
2025-04-08T00:57:47.817Z monitor-service INFO starting monitor
2025-04-08T00:57:47.818Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Starting monitor process" monitor=teensy-monitor
2025-04-08T00:57:47.818Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Monitor process started successfully!" monitor=teensy-monitor
2025-04-08T00:57:47.818Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.2.0\"" monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=hello message=OK monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="sending command" command=DESCRIBE monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=describe message=OK monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="sending command" command=QUIT monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=quit message=OK monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Killing monitor process" monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=error msg="stopped decode loop: EOF" monitor=teensy-monitor
2025-04-08T00:57:47.819Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Monitor process killed" monitor=teensy-monitor
2025-04-08T00:57:47.820Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Starting monitor process" monitor=teensy-monitor
2025-04-08T00:57:47.820Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Monitor process started successfully!" monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=hello message=OK monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="sending command" command=DESCRIBE monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=describe message=OK monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="sending command" command="OPEN 127.0.0.1:37533 usb3/3-5" monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="received message" error=false event_type=open message=OK monitor=teensy-monitor
2025-04-08T00:57:47.821Z daemon INFO time="2025-04-07T20:57:47-04:00" level=info msg="Port usb3/3-5 successfully opened"
2025-04-08T00:57:47.822Z monitor-service INFO Using port configuration for teensy:usb3/3-5: {"settingsList":[]}
2025-04-08T00:57:47.822Z monitor-service INFO started monitor to usb3/3-5 using teensy
2025-04-08T00:57:47.829Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor teensy:usb3/3-5.
Did the small Teensy Loader window appear? It's the part that does the actual upload. In that tiny window, click the Help > Verbose Information menu to get detailed info about the attempted upload to Teensy. The verbose info window as a Log menu you can use the save all the info to a file, which you can share here with "Attach files".
The little Teensy box does pop up. This evening I collected a log from what I assumed was going to be an attempt to program "junk.ino". But strangely this is now working as it should. I am not sure what the difference is, but I will keep my eye on it for the next few days. Just for completeness, I have attached the log file.
  • log.txt
