After a long time not developing upon Teensy 4.1, I'm back.
Whenever I tried to upload a new firmware, I'm losing USB ports - including the Teensy port.
So I tried TyCommander as TeensyLoader is not helping me there.
I use the blink demo and set original delay of 1000ms to 100ms to make it blink faster (so I can distinguish it from the original firmware).
Settings are default (600MHz, Faster) except for USB serial : Raw HID (as I recall I was told the original BLINK was under that kind of USB port).
First, I started the very long process of "reseting" the T4.1 so I can see the Teensy port connected.
So far, so good.
Now, I upload the faster blink demo through TyCommander. Ok, I seem to have the same effect as with TeensyLoader.
Demo will blink twice as fast as the way I setup but then have a pause with no led then again two fast blinking and so on. I'm expecting simply fast and regular blinking. Not only that, my windows systray attempts to show what I think is an USB icon connection probably during the unexpected periodical pause but it disappears too fast. Going to windows setting to check USB devices, there is a very spurious apparition of a USB serial.
And TyCommander shows that:
Which is wrong, isn't it? It seems there is a timeout because that 12628860-Teensy then vanishes.
I could uses "USB port: Serial" but it would be the same.
It drives me crazy. It seem developing on Teensy 4.1 is a big no go.
So far, so good.
