Teensy perform some function automatically sometime.out of code
charnjit
sir ,
i have use keypad library to add lot of push button.
these button perform differents keboard & Mouse commands.
every functions is controlled by use "if" . No any function is written in sketch to do automatically.
wiring is also correct. No any row is shorted to row or column to column. every push button between row &
column is connectd wia 1N4148 Doide.
when any button is pressed, function is being done, which is written for that button.
sometime it is working fine .But , sometime some functions are being automatically .
what is wrong here......
code and my wiring is below.
 #include <Keypad.h>                 //   patch press & hold not working,,    remove patch block with new rows funcction
 #include <Encoder.h>
const byte ROWS = 6; //four rows
const byte COLS = 9; //three columns             // tested ok display Key number
char keys[ROWS][COLS] = {
{1,2,3,4,5,6,7,8,9},
{10,11,12,13,14,15,16,17,18,},
{19,20,21,22,23,24,25,26,27},
{28,29,30,31,32,33,34,35,36},
{37,38,39,40,41,42,43,44,45},                 //   6 x 9
{46,47,48,49,50,51,52,53,54},
byte rowPins[ROWS] = {0, 1, 4, 5, 6, 7 }; //connect to the row pinouts of the kpd
byte colPins[COLS] = { 8, 9,  10, 11, 12, 13, 14, 16, 17}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Encoder myEnc(2, 3);     // which pins are connected to Encoder
     Mouse.screenSize(1366, 768);  // configure screen size
long oldPosition  = -999;
  // +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++Encoder begin
  long newPosition = myEnc.read();
    if (newPosition > oldPosition) {
    oldPosition = newPosition;
     Mouse.moveTo(512, 54);    //  put here action to be, when Encoder is rotated upward
    Mouse.scroll(+1);
    Mouse.moveTo(345, 94);
   if (newPosition < oldPosition) {
     Mouse.moveTo(512, 54);     //  put here action to be, when Encoder is rotated Downward
    Mouse.scroll(-1);
//  +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++Encoder end
    if (kpd.getKeys())
        for (int i=0; i<LIST_MAX; i++)   // Scan the whole key list.
            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 1))   // ----------------------------------------Tempo UP-----begin 1
                switch (kpd.key[i].kstate) {  // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
                    case PRESSED:
                          Mouse.moveTo(512, 54);       // point to pixel at 512, 54
                          Mouse.scroll(+1);           // turn scroll wheel upward 1 step
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
            }  // *********************************************************************************************************************end 1
                        if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 6))   // -------------------------------Tempo DOWN---begin 1
                    case PRESSED:
                               Mouse.scroll(-1);           // turn scroll wheel downward 1 step
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                    if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 2))   // ---------------------------Tempo TAP---begin 1
                    case PRESSED:
    Keyboard.set_modifier(MODIFIERKEY_CTRL);  //Press ctrl  key
    Keyboard.send_now();
    Keyboard.set_key1(KEY_F5);      //Press  F5
    Keyboard.set_modifier(0);    // Release  ctrl key
    Keyboard.set_key1(0);       // Release F5
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                           if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 8))   // ---------------------------ENTER---begin 1
                    case PRESSED:
    Keyboard.set_key1(KEY_ENTER);      //Press  ENTER
    Keyboard.set_key1(0);       // Release ENTER
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 10))   // ---------------------Pitch UP-------begin 1
                    case PRESSED:
                             Mouse.moveTo(357, 36);      // point to pixel at (357, 36)
                             Mouse.set_buttons(1, 0, 0);  // hold left button
                             Mouse.moveTo(357, 31);
                             Mouse.set_buttons(0, 0, 0);  // hold left button
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                           if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 3))   // -------------Pitch DOWN----begin 1
                    case PRESSED:
                                   Mouse.moveTo(357, 41);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                           if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 17))   // -------------F6-------------begin 1
                    case PRESSED:
                                      Keyboard.set_key1(KEY_F6);  // Press F6
                                      Keyboard.set_key1(0);       //Release F6
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                 if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 18))   // ----------------------FOLDER OPEN------begin 1
                    case PRESSED:
                             Mouse.moveTo(332, 748);      // point to pixel at (332, 748)  where window exploreler is in taskbar
                             Mouse.set_buttons(1, 0, 0);  // click
                             Mouse.set_buttons(0, 0, 0);  // release click
                             Mouse.moveTo(1050, 233);      // point to pixel at (1050, 233)
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                       if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 7))   // ----------------------NO cencal------begin 1
                    case PRESSED:
    Keyboard.set_key1(KEY_RIGHT);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                             if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 16))   // -----------------------NUMERIC (-)------------------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_MINUS);  // Press -
                           Keyboard.set_key1(0);       //Release -
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                              if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 13))   // ----------------NUMERIC (+)-----------begin 1
                    case PRESSED:
                               Keyboard.set_key1(KEYPAD_PLUS);  // Press +
                               Keyboard.set_key1(0);       //Release +
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                              if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 11))   // ----------------------SPACE----------begin 1
                    case PRESSED:
                          Keyboard.set_key1(KEY_SPACE);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                              if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 12))   // ----------------BACK SLASH------------begin 1
                    case PRESSED:
                             Keyboard.set_key1(KEYPAD_SLASH);  // Press    ( / )
                             Keyboard.set_key1(0);       //Release     ( / )
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                               if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 15))   // --------------(VOL+)--------------begin 1
                    case PRESSED:
                          Keyboard.press(KEY_MEDIA_VOLUME_INC);
                          Keyboard.release(KEY_MEDIA_VOLUME_INC);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                              if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 4))   // -----------------(VOL-)-----------begin 1
                    case PRESSED:
                             Keyboard.press(KEY_MEDIA_VOLUME_DEC);
                             Keyboard.release(KEY_MEDIA_VOLUME_DEC);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                             if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 25))   // -------------------PAT 1  ---------begin 1
                    case PRESSED:
                             Keyboard.set_key1(KEYPAD_1);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 26))   // ------------------PAT 2 ----------begin 1
                    case PRESSED:
                             Keyboard.set_key1(KEYPAD_2);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 27))   // -------------------PAT 3 ---------begin 1
                    case PRESSED:
                                 Keyboard.set_key1(KEYPAD_3);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 22))   // -----------------PAT 4 -----------begin 1
                    case PRESSED:
                               Keyboard.set_key1(KEYPAD_4);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                             if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 23))   // ---------------------PAT 5 -------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_5);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 24))   // --------------------PAT 6 --------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_6);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                               if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 21))   // -------------------PAT 7 ---------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_7);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 20))   // ------------------- PAT 8 ---------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_8);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 19))   // --------------------PAT 9--------begin 1
                    case PRESSED:
                           Keyboard.set_key1(KEYPAD_9);
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                            if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 34))   // -------------------PAT 10 ---------begin 1
                    case PRESSED:
    Mouse.moveTo(330, 94);      //  Mouse Go to pixel at (330, 94)
    Mouse.set_buttons(1, 0, 0);  // lEFT CLICK
    Mouse.moveTo(330, 288);     //  where  your  Pattern
    Mouse.set_buttons(1, 0, 0);  //  CLICKWERT
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                             if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 35))   // --------------------PAT 11 --------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 306);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 36))   // ------------------PAT 12----------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 325);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                               if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 31))   // --------------------PAT 13--------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 344);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                              if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 32))   // ----------------------PAT 14------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 364);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                           if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 33))   // --------------------PAT 15--------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 383);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                             if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 30))   // --------------------PAT 16--------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 402);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                         if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 29))   // --------------------PAT 17--------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 421);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                         if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 28))   // --------------------PAT 18--------begin 1
                    case PRESSED:
    Mouse.moveTo(338, 439);     //  where  your  Pattern
                    case HOLD:
                   //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                         if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 43))   // --------------------Patch 1 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,135);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
            }  // ***************************************************************************************************************Patch******end 1
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 44))   // --------------------Patch 2 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,167);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 45))   // --------------------Patch 3 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,195);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 40))   // --------------------Patch 4 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,227);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 41))   // --------------------Patch 5 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,257);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 42))   // --------------------Patch 6 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,286);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 39))   // --------------------Patch 7 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,317);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 38))   // --------------------Patch 8 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,347);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 37))   // --------------------Patch 9 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,377);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 52))   // --------------------Patch 10 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,408);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 53))   // --------------------Patch 11 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,437);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 54))   // --------------------Patch 12 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,468);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 49))   // --------------------Patch 13 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,498);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 32 ))   // --------------------Patch 14 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,528);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 51))   // --------------------Patch 15 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,558);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 48))   // --------------------Patch 16 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,586);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 47))   // --------------------Patch 17 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,616);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
                                                     if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 46))   // --------------------Patch 18 --------begin 1
                    case PRESSED:
                                    Mouse.moveTo(275,650);      //  Mouse Go to pixel at (330, 94)
                    case HOLD:
                         //  Do when Hold
                    case RELEASED:
                    //  Do when Released
                /*    case IDLE:
                    //  Do when IDLE     */
I don't see you setting the input more of any of the pins. You might need to configure the inputs to use pull down resistors so they don't float and give occasional wrong values.
Why did you start another thread on your keypad??? you already had an active thread
https://forum.pjrc.com/threads/5379...-result-according-sketch-using-keypad-library
you might check the de-bounce logic in the keypad library.
In my old Post senior members suggested me to start New thread , when you get solved your issue ,. So I have got solved my previous issue . By using latest teensyduino 1.43. now board is getting new sketches successfully. I am not so familiar to keyboard library & Arduino language.but I will try, what you suggest me .... thanks you....is.my wiring correct????
