TeensyPhonon
Yes it is me again and I am here due to a delay issue (again).
This time, I am concentrating on playing and recording sound with one Teensy (I am using a Teensy 4.1 with the SPH0645 I2S microphone and the MAX98357A I2S amp). I wrote a simple code to do this:
I thought it worked perfectly, but it seems like, sometimes (like 1/100 or something), it introduces a random delay...
Here is a test where I emitted a chirp and observed the result 150 times (I correlated the received signal with the chirp to better see the delay).
It might seem okay for you, but I need to perform experiments where I need to do over 10,000 recordings like that, so it is really annoying...
I am using the bare minimum of the audio library:
Really, all of that looks like dark magic to me.
C++:
digitalWrite(0,LOW);
Q_in_L.begin();
Q_in_L.clear();
for (int i = 0; i < nfor; i++) {
while(Q_in_L.available() < 1);
sp_L = Q_out_L.getBuffer();
memcpy(sp_L, &chirp[partitionsize * i], 2*partitionsize);
Q_out_L.playBuffer();
sp_L = Q_in_L.readBuffer();
memcpy(&q15_buffer_L[partitionsize * i], sp_L, 2*partitionsize);
Q_in_L.freeBuffer();
//uploading data to the PC
char conv[2];
for (int i = 0; i < nc; i++) {
memcpy(conv, &q15_buffer_L[i], 2);
Serial.write(conv, 2);
if (i % Nflush == 1) {
Serial.flush();
digitalWrite(0, HIGH);
Q_in_L.end();
Q_in_L.clear();
C++:
AudioInputI2S i2s_in;
AudioRecordQueue Q_in_R;
AudioRecordQueue Q_in_L;
AudioPlayQueue Q_out_R;
AudioPlayQueue Q_out_L;
AudioOutputI2S i2s_out;
AudioConnection patchCord1(i2s_in, 0, Q_in_L, 0);
AudioConnection patchCord3(i2s_in, 1, Q_in_R, 0);
AudioConnection patchCord7(Q_out_R, 0, i2s_out, 1);
AudioConnection patchCord8(Q_out_L, 0, i2s_out, 0);
