I am simply trying to read the value of a linear potentiometer with the Teensy 3.1, and convert this to MIDI.
here is the code
_____________________
int a0 =0;
void setup(){
pinMode(15, INPUT);
void loop(){
a0 = analogRead(15);
usbMIDI.sendControlChange(1, a0, 1);
Serial.println(a0);
______________________
when I read the voltage of pin 15 - it linearly increases as I slide the pot. as its supposed to.
when I look at the values on the arduino serial monitor - it linearly increases (from 0 -1023) as I slide the pot. as its supposed to.
but the actual MIDI data that is sent is very hectic. It seems as though the slider is scrolling through random numbers 0-127...(except when all the way down it stays at 0, and all the way up, at 127) it isnt linear and is constantly jumping around. the only trend is that i tend to see values>100 mostly when the slider is in the middle of its track
any ideas??
here is the code
int a0 =0;
void setup(){
pinMode(15, INPUT);
void loop(){
Serial.println(a0);
any ideas??
