I'm trying to incorporate Paul's suggested SD list code (see link below) into an application using the Teensy 3.2, PJRC Audio Shield card and the ILI9341 touch screen. The SD list code works fine listing all 34 wave files so I know the hardware is good. However, when I include the ILI9341 assignments/definitions listed in my code below, I get the following serial monitor message:
Initializing SD card...initialization done.
No more files, last entry = 0
No files found, done!
I'm wondering if there is a conflict with the SPI touch screen initialization and the SD listing function during setup. Has anyone experienced this issue before? I would appreciate any suggestions you have.
SD List Code:
https://github.com/PaulStoffregen/S...67c3b7b20c6be1/examples/CardInfo/CardInfo.ino
My code:
Hardware: Teensy 3.2, PJRC Audio Shield, ILI9341_Touch
Software: Arduino IDE 1.8.5 with TeensyDuino
Wiring: Teensy stacked on Audio Shield with wiring to ILI9341 per Paul's audio workshop 3.3 example
SD List Code:
My code:
#include <Arduino.h>
#include <XPT2046_Touchscreen.h>
#include <ILI9341_t3.h>
#include <font_ArialBold.h> // from ILI9341_t3
#include <Audio.h> //Audio Library
#include <SPI.h> //For LCD display
#include <SD.h> //For SD Card
//#include <SerialFlash.h>
File root;
// -------------------------- Set Up LCD Pins ---------------------------
//Set up ILI9341 Display
#define TFT_DC 20 //TFT LCD data control
#define TFT_CS 21 //TFT LCD chip select
#define TFT_RST 255 // 255 = unused, connect to 3.3V
#define SDCARD_CS_PIN 10 //SD card select pin
//const int chipSelect = 10;
#define TFT_MOSI 7 //Also used for SDCARD_MOSI
#define TFT_SCLK 14 //Also used for SDCARD_SCK
#define TFT_MISO 12 //TFT LCD I2S output
//Set up XPT2046_Touch screen display interrupt
#define CS_PIN 8 //Touch screen chip select
#define TIRQ_PIN 3 //IRQ pin
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN);
AudioControlSGTL5000 sgtl5000_1; //Define audio card processor
pinMode(CS_PIN, OUTPUT);
pinMode(TIRQ_PIN, INPUT_PULLUP); //IRQ for LCD
AudioMemory(SDCARD_CS_PIN); //SD card SS pin
sgtl5000_1.enable();
sgtl5000_1.volume(0.7); //Increased, was 0.5
// Initialize the SD card/TFT LCD I2S pins
SPI.setMOSI(TFT_MOSI);
SPI.setSCK(TFT_SCLK);
Serial.begin(9600); //SERIAL USB buad rate
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// -------------------------- Setup SD -----------------------------
if (!SD.begin(SDCARD_CS_PIN)) {
return;
Serial.println("initialization done.");
root = SD.open("/");
printDirectory(root, 0);
Serial.println("done!");
// ts.begin(); //Begin touch screen interface after SD initialized!
} //----------------------------- Set-up End -------------------------------
//Nothing done here to make this example simple
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
Serial.print("No more files, last entry = "); Serial.println(numTabs);
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
Serial.print("No files found, ");
