I am making the Vox Imperium trooper amp seen here: https://learn.sparkfun.com/tutorials/vox-imperium-stormtrooper-voice-changer/all. I got all the parts listed, and was able to get the unit to function. But as I am trying to hide all the circuitry in the helmet, I noticed it would be real nice if the mic input could be set to pin A9 (aka 23) instead of A2 (aka 16). This way I would be able to use a 3 wire connector and hit my GND, 3v3, and Audio-In all next to each other.
I looked at the pinouts and the different notes about the ADC, and I "think" I read correctly that I can change the following lines of code and I will be good. I just want to make sure what I am thinking is correct.
Original Code using A2 (pin 16):
Modified code using A9 (pin 23):
The unit I have assembled I am going to leave as-is, but I have the parts to build a 2nd module, and if this will work, I plan on making the change to that unit.
Below is the complete code:
AudioInputAnalog adc1;
AudioInputAnalog adc1(A9);
#include <SerialFlash.h>
AudioInputAnalog adc1; //xy=255,182
AudioFilterBiquad biquad1; //xy=394,182
AudioPlaySerialflashRaw playFlashRaw1; //xy=535,319
AudioFilterStateVariable filter1; //xy=558,189
AudioAnalyzePeak peak1; //xy=559,255
AudioMixer4 mixer1; //xy=710,196
AudioOutputAnalog dac1; //xy=844,196
AudioConnection patchCord1(adc1, biquad1);
AudioConnection patchCord2(biquad1, 0, filter1, 0);
AudioConnection patchCord3(biquad1, peak1);
AudioConnection patchCord4(playFlashRaw1, 0, mixer1, 2);
AudioConnection patchCord5(filter1, 0, mixer1, 0);
AudioConnection patchCord6(filter1, 2, mixer1, 1);
AudioConnection patchCord7(mixer1, dac1);
// Parameters
const bool DEBUG = false;
const bool BEGIN_CLICK = true; // Play click on voice start
const bool END_SOUND = true; // Play click/burst on voice end
const bool FEEDBACK_SUPPRESSION = false; // Enables input filter
const unsigned int LOWPASS_CUTOFF = 2200; // Hz
const unsigned int CROSSOVER_FREQ = 2000; // Filter center freq
const float BASS_GAIN_ON = 0.01;
const float BASS_GAIN_OFF = 0.0;
const float TREBLE_GAIN_ON = 0.25; // Voice output volume
const float TREBLE_GAIN_OFF = 0.0;
const float SFX_GAIN = 0.5; // Sound clip volume
const float SQUELCH_CUTOFF = 0.10; // Voice threshold
const int HYSTERESIS_TIME_ON = 20; // Milliseconds
const int HYSTERESIS_TIME_OFF = 400; // Milliseconds
// Pins
const int FLASH_CS = 6; // Serial flash chip select
const int AMP_ENABLE = 5; // Amplifier enable pin
// On/Off state machine states
typedef enum volState {
QUIET,
QUIET_TO_LOUD,
LOUD,
LOUD_TO_QUIET,
} VolState;
// Global variables
elapsedMillis fps; // Sample peak only if we have available cycles
VolState state = QUIET;
unsigned long timer;
if ( DEBUG ) {
// Initialize amplifier
AudioMemory(20);
dac1.analogReference(EXTERNAL); // much louder!
delay(50); // time for DAC voltage stable
pinMode(AMP_ENABLE, OUTPUT);
// wait up to 10 seconds for Arduino Serial Monitor
unsigned long startMillis = millis();
if ( DEBUG ) {
while ( !Serial && ( millis() - startMillis < 10000 ) );
// Butterworth lowpass filter (reduces audio feedback)
if ( FEEDBACK_SUPPRESSION ) {
biquad1.setLowpass(0, LOWPASS_CUTOFF, 0.707);
biquad1.setLowpass(0, 8000, 0.707);
// Configure the State Variable filter
filter1.frequency(CROSSOVER_FREQ);
filter1.resonance(0.707);
// Adjust gain into the mixer
mixer1.gain(0, BASS_GAIN_OFF);
mixer1.gain(1, TREBLE_GAIN_OFF);
mixer1.gain(2, SFX_GAIN);
// Initialize serial flash
if ( !SerialFlash.begin(FLASH_CS) ) {
if ( DEBUG ) {
Serial.println( "Unable to access SPI Flash chip" );
// Use the time since boot as a seed (I know, not great, but
// the audio toolbox took away my analogRead)
int seed = micros() % 32767;
if ( DEBUG ) {
Serial.print("Seed: ");
Serial.println(seed);
randomSeed(seed);
if ( DEBUG ) {
Serial.println("Finished init");
if ( (fps > 24) && peak1.available() ) {
// State machine
switch ( state ) {
// Wait until the mic picks up some sound
case QUIET:
if ( peak1.read() > SQUELCH_CUTOFF ) {
timer = millis();
state = QUIET_TO_LOUD;
// If sound continues, play sound effect
case QUIET_TO_LOUD:
if ( peak1.read() <= SQUELCH_CUTOFF ) {
state = QUIET;
if ( millis() > timer + HYSTERESIS_TIME_ON ) {
if ( DEBUG ) {
Serial.println("ON");
// Turn on amp, play sound, turn on mic
digitalWrite(AMP_ENABLE, HIGH);
if ( BEGIN_CLICK ) {
playFile("click.raw");
mixer1.gain(0, BASS_GAIN_ON);
mixer1.gain(1, TREBLE_GAIN_ON);
// Go to next state
state = LOUD;
// Filter mic input and play it through speakers
case LOUD:
timer = millis();
state = LOUD_TO_QUIET;
// If no sound for a time, play click or burst
case LOUD_TO_QUIET:
state = LOUD;
if ( millis() > timer + HYSTERESIS_TIME_OFF ) {
if ( DEBUG ) {
Serial.println("OFF");
// Play a random sound
if ( END_SOUND ) {
if ( random(2) ) {
playFile("click.raw"); // orig = break.raw
// Turn off mic and amp
digitalWrite(AMP_ENABLE, LOW);
state = QUIET;
// You really shouldn't get here
default:
// Play a sound clip from serial flash
void playFile( const char* filename ) {
if ( DEBUG ) {
Serial.print("Playing file: ");
Serial.print(filename);
// Start playing the file
playFlashRaw1.play(filename);
// A brief delay for the library read info
delay(5);
// Wait for the file to finish playing
while ( playFlashRaw1.isPlaying() );
if ( DEBUG ) {
Serial.println("...done");
