thecomfychair
I am trying to play audio from the Teensy 4.1's SD card with a VS1053b audio codec chip. I am using the library from Tobias van Dyk, who has ported the Adafruit library into a single sketch version for the T3.6 and T4.1 (super helpful, thanks Tobias!).
The breakout board that I'm using is from Aliexpress rather than Adafruit, since I don't need the spare SD card slot. It looks like this:
The library compiles and runs fine on my T4.1 (after commenting out any references to SREG). However I hear no audio through the headphone jack, just low-level white noise.
I added some debug printouts and it's not clear whether it gets past opening the audio file in the setup() function - often it doesn't make it to loop(). It doesn't seem to be any memory overruns or anything like that though, since the T4.1 stays running and doesn't reset.
I tried changing the volume values too, but this had no effect.
This is the same with two identical VS1053b breakout boards (I bought two just in case).
This is my current sketch. I have modified it slightly to change the pins used for XRST, XCS, XDCS, and XDREQ, as the pins specified in the example are already used in the project that I am trying to integrate this module into. However, I think I have taken care to select new pins with the same characteristics?
Serial debug is as follows:
Has anyone else worked with the VS1053b before, and know if there are any other commands or hardware requirements that need to be implemented to get sound out?
Arduino 1.8.19, TD 1.56
//https://github.com/TobiasVanDyk/VS1053B-Teensy36-Teensy41-SDCard-Music-Player
// Modified for Teensy 3.6 Tobias van Dyk October 2020
// Also based on PJRC.com Teensy libraries
This is a library for the Adafruit VS1053 Codec Breakout
Designed specifically to work with the Adafruit VS1053 Codec Breakout
----> https://www.adafruit.com/products/1381
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include <Arduino.h>
// Connect SCLK, MISO and MOSI to standard hardware SPI pins.
#define SCLK 13 // SPI Clock shared with SD card
//#define MISO 12 // Input data from vs1053 or SD card
//#define MOSI 11 // Output data to vs1053 or SD card
// These are the pins used for the Adafruit vs1053B breakout module
#define XRST 33 // vs1053 reset (output)
#define XCS 36 // vs1053 chip select (output)
#define XDCS 35 // vs1053 Data select (output)
#define XDREQ 34 // vs1053 Data Ready an Interrupt pin (input)
#define SDCS BUILTIN_SDCARD // Use Teensy built-in card
// For Teensy 3.5, 3.6, 4.0, 4.1 better to use its built-in SDCard
//#define SDCS 4 // Use vs1053 SDCard Card chip select pin
// vs1053B.h
#define vs1053_FILEPLAYER_TIMER0_INT 255 // allows useInterrupt to accept pins 0 to 254
#define vs1053_FILEPLAYER_PIN_INT 5 // Interrupt number from dreqinttable dreq pin # = 3
#define vs1053_SCI_READ 0x03
#define vs1053_SCI_WRITE 0x02
#define vs1053_REG_MODE 0x00
#define vs1053_REG_STATUS 0x01
#define vs1053_REG_BASS 0x02
#define vs1053_REG_CLOCKF 0x03
#define vs1053_REG_DECODETIME 0x04
#define vs1053_REG_AUDATA 0x05
#define vs1053_REG_WRAM 0x06
#define vs1053_REG_WRAMADDR 0x07
#define vs1053_REG_HDAT0 0x08
#define vs1053_REG_HDAT1 0x09
#define vs1053_REG_VOLUME 0x0B
#define vs1053_GPIO_DDR 0xC017
#define vs1053_GPIO_IDATA 0xC018
#define vs1053_GPIO_ODATA 0xC019
#define vs1053_INT_ENABLE 0xC01A
#define vs1053_MODE_SM_DIFF 0x0001
#define vs1053_MODE_SM_LAYER12 0x0002
#define vs1053_MODE_SM_RESET 0x0004
#define vs1053_MODE_SM_CANCEL 0x0008
#define vs1053_MODE_SM_EARSPKLO 0x0010
#define vs1053_MODE_SM_TESTS 0x0020
#define vs1053_MODE_SM_STREAM 0x0040
#define vs1053_MODE_SM_SDINEW 0x0800
#define vs1053_MODE_SM_ADPCM 0x1000
#define vs1053_MODE_SM_LINE1 0x4000
#define vs1053_MODE_SM_CLKRANGE 0x8000
#define vs1053_SCI_AIADDR 0x0A
#define vs1053_SCI_AICTRL0 0x0C
#define vs1053_SCI_AICTRL1 0x0D
#define vs1053_SCI_AICTRL2 0x0E
#define vs1053_SCI_AICTRL3 0x0F
#define vs1053_DATABUFFERLEN 32
File currentTrack;
boolean playingMusic;
uint8_t SoundBuffer[vs1053_DATABUFFERLEN];
// vs1053B.cpp
#define vs1053_CONTROL_SPI_SETTING SPISettings(250000, MSBFIRST, SPI_MODE0) // 2.5 MHz SPI speed Control
#define vs1053_DATA_SPI_SETTING SPISettings(8000000, MSBFIRST, SPI_MODE0) // 8 MHz SPI speed Data
// Configure interrupt for Data XDREQ from vs1053
// XDREQ is low while the receive buffer is full
void vs1053Interrupt()
{ SPI.usingInterrupt(XDREQ); // Disable Interrupt during SPI transactions
attachInterrupt(XDREQ, vs1053FeedBuffer, CHANGE); // Interrupt on Pin XDREQ state change
} // feeder->feedBuffer executed (lines 26, 209)
// Set the card to be disabled while we get the vs1053 up
void vs1053DisableCard ()
{ playingMusic = false;
pinMode(SDCS, OUTPUT);
digitalWrite(SDCS, HIGH);
// Play file without interrupts
boolean vs1053PlayFullFile(const char *trackname) {
Serial.print("Playing ");
Serial.println(trackname);
if (! vs1053StartPlayingFile(trackname)) return false;
while (playingMusic) { vs1053FeedBuffer(); }
return true;
void vs1053StopPlaying()
currentTrack.close();
void vs1053PausePlaying(boolean pause)
{ if (pause) playingMusic = false; else { playingMusic = true; vs1053FeedBuffer(); }
boolean vs1053Paused()
{ return (!playingMusic && currentTrack);
boolean vs1053Stopped()
{ return (!playingMusic && !currentTrack);
boolean vs1053StartPlayingFile(const char *trackname) {
Serial.println("vs1053StartPlayingFile");
currentTrack = SD.open(trackname);
if (!currentTrack) {
Serial.print("Failed to open from SD: ");
return false;
else{
Serial.print("Opened from SD: ");
while (!vs1053ReadyForData() ); // wait for ready for data
while (playingMusic && vs1053ReadyForData()) vs1053FeedBuffer(); // then send data
return true;
void vs1053FeedBuffer() { //debugging this function causes memory overruns
// Serial.println("vs1053FeedBuffer");
static uint8_t running = 0;
uint8_t sregsave;
// Do not allow 2 FeedBuffer instances to run concurrently
// SREG bit 7 = OFF => no interrupts until bit 7 = ON
// sregsave = SREG; // Status Register can clear/set interrupt enable bit 7 cli or sei
cli(); // Clear interrupt enable bit 7 in SREG => disable interrupts
// if (running) { SREG = sregsave; return; } else { running = 1; SREG = sregsave; }
// paused or stopped. no SDCard track open, XDREQ=0 receive buffer full
if ((!playingMusic)||(!currentTrack)||(!vs1053ReadyForData())) { running = 0; return; }
// if (!playingMusic){
// Serial.println("Paused or stopped");
// running = 0; return;
// if (!currentTrack){
// Serial.println("No track open from SD card");
// if(!vs1053ReadyForData()){
// Serial.println("XDREQ=0 receive buffer full");
// Serial.println("Ready to send buffer");
// Send buffer
while (vs1053ReadyForData())
{ int bytesread = currentTrack.read(SoundBuffer, vs1053_DATABUFFERLEN);
if (bytesread == 0) // End of File
running = 0;
return;
vs1053PlayData(SoundBuffer, bytesread);
running = 0;
return;
// XDREQ is true while the receive buffer has space
boolean vs1053ReadyForData()
{ return digitalRead(XDREQ);
void vs1053PlayData(uint8_t *buffer, uint8_t buffsiz)
{ SPI.beginTransaction(vs1053_DATA_SPI_SETTING);
digitalWrite(XDCS, LOW);
for (uint8_t i=0; i<buffsiz; i++) { vs1053SpiWrite(buffer[i]); } // buffsiz = 32
digitalWrite(XDCS, HIGH);
SPI.endTransaction();
void vs1053SetVolume(uint8_t left, uint8_t right)
{ uint16_t v;
v = left;
v <<= 8;
v |= right;
cli();
vs1053SciWrite(vs1053_REG_VOLUME, v);
sei();
uint16_t vs1053DecodeTime()
{ cli();
uint16_t t = vs1053SciRead(vs1053_REG_DECODETIME);
sei();
return t;
void vs1053SoftReset()
{ vs1053SciWrite(vs1053_REG_MODE, vs1053_MODE_SM_SDINEW | vs1053_MODE_SM_RESET);
void vs1053Reset()
{ if (XRST >= 0)
{ digitalWrite(XRST, LOW);
digitalWrite(XRST, HIGH);
digitalWrite(XCS, HIGH);
vs1053SoftReset();
vs1053SciWrite(vs1053_REG_CLOCKF, 0x6000);
vs1053SetVolume(40, 40);
uint8_t vs1053Begin()
{ if (XRST >= 0) { pinMode(XRST, OUTPUT); // if reset = -1 ignore
pinMode(XCS, OUTPUT);
pinMode(XDCS, OUTPUT);
pinMode(XDREQ, INPUT);
SPI.begin();
// SPI.setDataMode(SPI_MODE0);
// SPI.setBitOrder(MSBFIRST);
// SPI.setClockDivider(SPI_CLOCK_DIV128);
vs1053Reset();
return (vs1053SciRead(vs1053_REG_STATUS) >> 4) & 0x0F;
uint16_t vs1053SciRead(uint8_t addr)
{ uint16_t data;
SPI.beginTransaction(vs1053_CONTROL_SPI_SETTING);
digitalWrite(XCS, LOW);
vs1053SpiWrite(vs1053_SCI_READ);
vs1053SpiWrite(addr);
delayMicroseconds(10);
data = vs1053SpiRead();
data <<= 8;
data |= vs1053SpiRead();
return data;
void vs1053SciWrite(uint8_t addr, uint16_t data)
{ SPI.beginTransaction(vs1053_CONTROL_SPI_SETTING);
vs1053SpiWrite(vs1053_SCI_WRITE);
vs1053SpiWrite(data >> 8);
vs1053SpiWrite(data & 0xFF);
static volatile uint8_t *clkportreg;
static uint8_t clkpin;
uint8_t vs1053SpiRead()
{ int8_t x;
x = 0;
//clkportreg = portOutputRegister(digitalPinToPort(SCLK));
//clkpin = digitalPinToBitMask(SCLK);
// MSB first, clock low when inactive (CPOL 0), data valid on leading edge (CPHA 0)
// Make sure clock starts low
x = SPI.transfer(0x00);
// Make sure clock ends low
//*clkportreg &= ~clkpin;
return x;
void vs1053SpiWrite(uint8_t c)
{ // MSB first, clock low when inactive (CPOL 0), data valid on leading edge (CPHA 0)
SPI.transfer(c);
//*clkportreg &= ~clkpin; // Make sure clock ends low
// End .cpp
while (!Serial) ; // wait for Arduino Serial Monitor
Serial.println("Adafruit vs1053B SDCard Music Player Test");
if (! vs1053Begin()) { // initialise the music player
Serial.println(F("Couldn't find vs1053"));
while (1);
Serial.println(F("vs1053 found"));
SD.begin(SDCS); // initialise the SD card
// Set volume for left, right channels. lower numbers is higher volume
vs1053SetVolume(20,20);
// If XDREQ is on an interrupt pin (any Teensy pin) can do background audio playing
vs1053Interrupt(); // XDREQ int
// Play one file, don't return until complete - i.e. serial "s" or "p" will not interrupt
//Serial.println(F("Playing track 001"));
//vs1053PlayFullFile("track001.mp3");
// Serial.println(F("Playing track 008"));
// vs1053PlayFullFile("track008.wav");
// Serial.println(F("Playing SDTEST with super long file name.wav"));
// vs1053PlayFullFile("/SDTEST with super long file name.wav");
// Play another file in the background, use interrupt serial "s" or "p" will interrupt
// Can only do one buffer feed at a time
//Serial.println(F("Playing track 002 - press p to pause, s to stop"));
//vs1053StartPlayingFile("track002.mp3");
// Serial.println(F("Playing track 010 - press p to pause, s to stop"));
// vs1053StartPlayingFile("track010.wav");
Serial.println(F("Playing /MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3 - press p to pause, s to stop"));
vs1053StartPlayingFile("/MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3");
if(playingMusic){
Serial.println("Playback started");
else{ Serial.println("Playback failed");}
// File is playing in the background
if (vs1053Stopped()) {
Serial.println("Terminated");
while (1);
if (Serial.available()) {
char c = Serial.read();
// if we get an 's' on the serial console, stop!
if (c == 's') {
vs1053StopPlaying();
// if we get an 'p' on the serial console, pause/unpause!
if (c == 'p') {
if (! vs1053Paused()) {
Serial.println("Pause - press p to pause, s to stop");
vs1053PausePlaying(true);
Serial.println("Resumed - press p to pause, s to stop");
vs1053PausePlaying(false);
Serial.println("Loop running");
vs1053 found
Opened from SD: /MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3
