Thanks.
I will do these steps, one by one, because i'm going to restore the windows with a clean installation (without drivers and software), in order to know when the operation system crashes.
About the driver USB/COM, i use the official teensy "WINDOWS DRIVER INSTALLER" before connecting the teensy 3.1
https://www.pjrc.com/teensy/serial_install.exe
PS.I have seen this in last link
I will check it again. Installing it as administrator. (although the driver was recognized correctly without "Run as administrator")
PS. This is the fail detail
On Windows, this Windows Driver Installer is needed. On Vista or Windows 7, right click and choose "Run as administrator". After installation, Windows 7 will should work automatically. Windows XP and Vista will still show the New Hardware Wizard, but it will be able to find the driver with the default choices.
Firma con problemas:
Nombre del evento de problema: BlueScreen
Versión del sistema operativo: 6.1.7601.2.1.0.256.48
Id. de configuración regional: 3082
Información adicional del problema:
BCCode: fe
BCP1: 0000000000000004
BCP2: FFFFFA80074D5010
BCP3: FFFFFA80069E3620
BCP4: FFFFFA800AECAC30
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Archivos que ayudan a describir el problema:
C:\Windows\Minidump\080214-27674-01.dmp
C:\Users\CARLOS\AppData\Local\Temp\WER-40139-0.sysdata.xml
Lea nuestra declaración de privacidad en línea:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0c0a
Si la declaración de privacidad en línea no está disponible, lea la declaración de privacidad sin conexión:
C:\Windows\system32\es-ES\erofflps.txt
