Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 51 to 75 of 135
Thread: ILI9341 and XPT2046 for Teensy Touchscreen 320x240 display
  1. #51
    9,668
    And the answer is . . . 42 . . . lines of code to activate interrupts on the Touch Driver.
    UPDATED SAMPLE: onoffbutton3i/onoffbutton3i.ino
    > Using PIN Interrupt results in NO POLLING when there is no touch, sets flag to allow reading/polling on next request.
    > Using Timer Interrupt supports 'timed' POLLING to detect touch, sets flag to allow reading/polling on next request.
    BOTH: Once touch detected the user code can call/poll as desired to track the touch while present.
    Given Paul's dire warning - I really overthought this! When I took out the extra steps and checks - I don't see missed touches on T3.1.
    Simplified:
    > Use Pin Interrupt if specified (no time wasted to deactivate it)
    > Or use Timer interrupt if specified
    > Interrupt is either WAIT'ing or ACTIVE
    > Two state flag for Interrupt: WAIT or ACTIVE
    > no extra logic or code to slow the process
    > This may explain why I never saw it until I plugged in a Teensy LC, will test again on LC.
    > And on T_3.1 it explains why the more code and debug spew I added the worse it got.
    Will post updated copy of driver lib code that handles this transparently [with edit to .begin()] to my Examples GitHub for testing ASAP.
  2. #52
    9,668
    I need some help with CPP doing :: attachInterrupt( PinInt, TS_isrPin, FALLING ); Is there a similar solution in an included library that I didn't find?
    Where "void TS_isrPin(void)" needs to be callable during on the interrupt and have access to a class variable isrWake ?
    So it can't be a CPP class member? But needs a way to access the private isrWake?
    bool XPT2046_Touchscreen::begin()
    	SPI.begin();
    	pinMode(csPin, OUTPUT);
    	digitalWrite(csPin, HIGH);
    	if (255 != tirqPin) {
    		pinMode( tirqPin, INPUT );
    		attachInterrupt( tirqPin, XPT2046_Touchscreen::TS_isrPin(void), FALLING );
    	return true;
    void XPT2046_Touchscreen::TS_isrPin( void )
        isrWake = true;
    Other than this - dropping my 42 lines of code into the XPT2046_TOUCH library is trivial; and under like 20 lines of code - I decided to forgo the TimerInterrupt I put in for testing as I didn't want to require #include <TimerOne.h>, the user can easily enough duplicate this behavior.
  3. #53
    Germany NRW
    5,679
    That's a bit tricky.
    I had the same problem with the audiocodecs. perhaps you want to look here.
    My ISR is a normal C function. I have a global pointer to the object ("AudioPlaySdMp3 *mp3objptr;") and use that pointer to access the variables in it.
    There might be better ways, but that worked for me.
  4. #54
    9,668
    @Frank - Thanks that is close to the only other scheme I came across - only programmed for Current compiler versus this 2002 DrDobbs: Implementing Interrupt Service Routines in C++.
  5. #55
    9,668
    Thank you Frank! Your example followed my expectations - and what I found on the web as noted - but gave a clean example to follow - and make sure it was as 'legitimate' a hack as possible. The last link in this post will be the updated XPT2046_Touchscreen library code.
    I modified the TeensyDuino library to have native Interrupt detection and prevent user polling over SPI unless a Touch interrupt has been recorded.
    See: XPT2046_Touch_Examples/tree/master
    I have converted a single sample ready to use the modified library - once you update the library any old code can enable the interrupts during 'ts' creation:
    onoffbutton4_Pull
    This documents the change needed to
    #define CS_PIN 8
    XPT2046_Touchscreen ts(CS_PIN);  // Param 2 - NULL - No interrupts
    // Second PARAM on XPT2046_Touchscreen requires modified interrupt aware XPT2046_Touchscreen library
    #define TIRQ_PIN  2
    //XPT2046_Touchscreen ts(CS_PIN, 255);  // Param 2 - 255 - No interrupts
    //XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN);  // Param 2 - Touch IRQ Pin - interrupt enabled polling
    These two files have been modified to allow the hardware interrupt pin to refuse SPI POLL requests when no TOUCH interrupt has been detected:
    https://github.com/Defragster/XPT204...46_Touchscreen
    If anyone pulls this code down and tries it let me know - I'll adjust the default library examples so PJRC can consider a pull request. Anyone who wants to see how simple it was I checked in the 1.26 source files so the DIFF you see is all I changed.
    How you know it is working? The Teensy LED in the default configuration sits on the SPI bus and flickers with any transfer - screen update or Touch poll request. Run one of the samples without the interrupt aware code and your LED will be lit with the intensity of the testing for a touch. Once you install the updated library code and enable the interrupt on your wired pin - you should see a DARK LED - until the touch happens no matter how often you use any of these functions. While you touch the screen - these functions will hit the SPI bus as fast as every 3 ms and the LED will become very bright.
    	TS_Point getPoint();
    	bool touched();
    	void readData(uint16_t *x, uint16_t *y, uint8_t *z);
  6. #56
    9,668
    @Paul - if you are watching this development and are interested I'll be doing a pull request soon - you can see the code and preview the DIFFs if you have time. I was modifying the exisiting library examples and decided to offer a loop() with no delay on polling to show the value in this mod to take the LED from all but on to OFF until untouched.
    NOTE: Problem area identified and addressed. The failure to register touch on interrupt was easily fixed running within the library. That simplification I noted a couple of posts back was working on the symptom. In doing an no delay() extreme test to show the interrupt usefulness in stopping SPI polling/thrashing I came across a repeatable touch that left the touch unseen until re-touched.
    That correction is made here using a lesser threshold to ignore the interrupt - but not change the value returned to the user: XPT2046_Touchscreen/XPT2046_Touchscreen.cpp#L137
    Here is the ugly sample that was behind the change: TouchTest/TouchTest.ino
    Using the proposed code as indicated then watch the non-interrupt code - then enable interrupt and LED goes from bright to black and doesn't miss a touch - versus the delay(100) version for sure.
  7. #57
    20,544
    If you do any SPI stuff inside the interrupt, don't forget to call SPI.usingInterrupt() before attachInterrupt().
  8. #58
    9,668
    The ISR code is pretty simple:
    Credit to Frank for writing half this function.
  9. #59
    Germany NRW
    5,679
    haha :-)
    no, all credits to defragster.
  10. #60
    9,668
    Pull request submitted: https://github.com/PaulStoffregen/XP...hscreen/pull/2
    I powered up a Teensy LC and it ran fine as well.
  11. #61
    9,668
    PJRC put in tree for 1.27 when it comes out - let me know if any issues show on testing the code in : https://github.com/Defragster/XPT204...es/tree/master The GitHub is messy for now.
  12. #62
    9,668
    Implemented Code suggested in post #25: User code loops and draws colored buttons on screen.
    USB Prints the needed struct data to match it with simple buttons.
    Putting that struct data back into code uses it as modified
    Button #1 rotates screen clockwise, buttons are redrawn and those buttons leaving the screen are clipped.
    The struct version in the code on GitHub currently clips 8 buttons in portrait, the USB output shifts buttons left and only 4 are clipped when in portrait layout. If you take the structure output and replace in the sketch it will change that.
    ColorButtonsTest/ColorButtonsTest.ino
    All displayed buttons will respond with Serial.print of the button number.
    Constant press on SAME button registers once until 50ms between touches
    SWIPING the buttons will register them in turn as pressed
    Setting "#define LC 1" will use slower Adafruit driver and work on the Teensy LC (or T_3.x)
    As saved expects to use interrupt pin code :: XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN); // Param 2 - Touch IRQ Pin - interrupt enabled polling
    If changed to not specify the interrupt it works the same as the "TS_LIMIT" POLLING rate is 10ms and the LED will be BRIGHT
  13. #63
    Oct 2015
    227
    Nice work...!!!
  14. #64
    Senior Member Wozzy's Avatar
    354
    Really Nice Work!
    Working well on Teensy 3.2 with Arduino1.6.6 & Teensyduino1.26-b3
    Also works with the enhanced ILI4391_T3 Fonts I'm using DroidSans_24_Bold
    Since the XTP2046 registers touch pressure, it would be interesting to use pressure sense to regulate the rate, for example:
    1. Quick tap increments or decrements by one
    2. Light continuous touch counts up or down slowly
    3. Firm continuous touch counts up or down quickly
  15. #65
    9,668
    Rfresh737 & Wozzy - Thanks. Did you try it - with the INT code or without? It works 'the same' both ways - but no SPI noise trusting the touch int.
    Wozzy - Looks nicer with your font. Let me know if you cut and paste the left adjust into the code to see the button clipping. Did this on the way to making an alpha keyboard and other edits - started there just to answer the prior post.
    Run a pressure display example like TouchTest and watch the pressure as you touch - let me know if there is any usable info there.
    By the way Teensduino 1.26 has left beta.
  16. #66
    Oct 2015
    227
    I'm getting a compile error on line 20:
    Arduino: 1.6.5 (Windows 7), TD: 1.26-beta3, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
    ColorButtonsTest:20: error: no matching function for call to 'XPT2046_Touchscreen::XPT2046_Touchscreen(int, int)'
    ColorButtonsTest.ino:20:35: note: candidates are:
    In file included from ColorButtonsTest.ino:14:0:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\XPT204 6_Touchscreen/XPT2046_Touchscreen.h:44:2: note: XPT2046_Touchscreen::XPT2046_Touchscreen(uint8_t)
    XPT2046_Touchscreen(uint8_t cspin);
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\XPT204 6_Touchscreen/XPT2046_Touchscreen.h:44:2: note: candidate expects 1 argument, 2 provided
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\XPT204 6_Touchscreen/XPT2046_Touchscreen.h:42:7: note: constexpr XPT2046_Touchscreen::XPT2046_Touchscreen(const XPT2046_Touchscreen&)
    class XPT2046_Touchscreen {
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\XPT204 6_Touchscreen/XPT2046_Touchscreen.h:42:7: note: candidate expects 1 argument, 2 provided
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\XPT204 6_Touchscreen/XPT2046_Touchscreen.h:42:7: note: constexpr XPT2046_Touchscreen::XPT2046_Touchscreen(XPT2046_T ouchscreen&&)
    Multiple libraries were found for "Adafruit_ILI9341.h"
    Used: C:\Users\fresh1011\Documents\Arduino\libraries\Ada fruit_ILI9341
    Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafru it_ILI9341
    enabled in File > Preferences.
  17. #67
    9,668
    BUSTED - you haven't taken my Interrupt touch code so you need to read the comments and adjust accordingly. Thanks for testing - I never tried to compile with the 1.26 library.
    //XPT2046_Touchscreen ts(CS_PIN);  // Param 2 - NULL - No interrupts
    #define TIRQ_PIN  2
    Are you using an LC? If you are not you can activate the "#include <ILI9341_t3.h>" instead of the slower adafruit SPI code.
  18. #68
    Oct 2015
    227
    I'm trying it without the interrupts. I'm using a Teensy 3.2 board.
    #define CS_PIN 8
    #define TIRQ_PIN  2
  19. #69
    9,668
    You'll get the same error with that.
    //#define LC 1
  20. #70
    Oct 2013
    Rogersville MO
    253
    Does anyone know if the screen read function was ever implemented? That would make the possibility of pop-up keyboards ( numeric and alpha ) very interesting. Probably could do it anyway, would have to rebuild the screen from scratch each time. Great work defragster have the code running on a 3.0 at the moment.
  21. #71
    20,544
    Quote Originally Posted by cartere View Post
    Yes, it was.
    Not long ago I committed this fix. The ILI9341 only reliably reads with a much slower SPI clock speed.
  22. #72
    20,544
    Oh, looks like readRect() still has the fast SPI clock speed, so it's almost certainly not working. I only tested readPixel().
    Please feel free to apply this fix and submit a pull request....
  23. #73
    9,668
    Great to know it works on the T_3 too! Are you using it with the INT coded version private library?
    I don't know that there was an effective screen read - the time and buffering memory and then restoring would probably be prohibitive? The buttons can be redrawn at any time - as you can see on rotation. On my list was drop down sub menus or alternate screens - by swapping TS_BUTTON buttons[.
  24. #74
    354
    Thanks Defragster,
    Yes, I am using the T_IRQ interrupt on Pin 2
    No I didn't need to change the left adjust
    I simply included the custom font in the header:
    #include "font_DroidSans_Bold.h"
    And set the tft_font in the setup routine:
    tft.setFont(DroidSans_24_Bold);
    Yes, the TS_Point p = ts.getPoint(); function returns a p.z value that ranges from about 1000 for a light touch to about 3400 for a firm touch.
    Thanks... I didn't see an announcement on the Forum, But I was able download the Final Teensyduino 1.26 from the Teensyduino Page http://www.pjrc.com/teensy/td_download.html
    I then updated the XPT2046 library from your GitHub Repository https://github.com/Defragster/XPT204...46_Touchscreen
  25. #75
    9,668
    Quote Originally Posted by Wozzy View Post
    Thanks Defragster,
    :-) Good news on the T-IRQ use! Yeah - the finalizing of 1.26 from Beta was when Paul was heading to the ConHack thing and I only saw inadvertent note about it being live.
    The code edit moves landscape off center - but proves the concept and keeps another row of buttons on screen in portrait rotations.
    Will add a FONT size to the per button struct - will leave it up to the user to set the font as you did.
    When I look at the p.z it varies wildly from side to side and top to bottom even doing your best to maintain constant pressure. It is a function of the cumulative resistive value across the X and Y planes so it varies - it would take a serious mapping effort to plot that and then apply it dynamically. For a given point yes, more pressure higher value - less pressure lower - but not edge to edge consistent in any way.
    In that sample I pulled the ILI9341 color table into the array - the colors displayed are not all unique or in keeping with their names. I did math
    (array_colors[ kk ] & 0xFFEF ) > 0x8419 ? ILI9341_BLACK : ILI9341_WHITE
    to pick the forground color based on how 'white' the color was. I'm not sure my math is on the right 'bit field' boundaries - but it works to pick white or black in some general fashion as show in the pics.
