Adaptative filters for noise reduction, teensy audio shield
Hi! I'm new using the teensy and its audio shield, anyone knows how to implement an adaptative filter for noise reduction? need help with that cause honestly I have no idea how to start
Huge topic.
What kind of noise are you looking to reduce?
  • Noise Source: Real-world noise from your environment picked up by your mic, or electronic noise that's somehow electrically getting into your signal?
  • Frequency Characteristics: Broadband noise? hissy noise? Noise that sounds narrow like tones? 60/50Hz noise?
  • Time Characteristics: is the noise steady or variable? Does it vary quickly or slowly? Is the noise there most of the time or only occasionally?
Each type of noise has its own challenges. Can you describe the noise that you're looking to reduce? Can you share an audio file with the noise? Can you share a spectrogram of it?
Also, what's your experience level with signal processing?
Chip
Huge topic.
Chip
Real-world noise from the enviroment, kinda like the background noise reduction used in hearing aids. A lot of experience with signal processing for a student, but not so much about it on hardware (just had one lab and the different between that and using arduino is lowkey overwhelming hehe
That OpenMHA link is great. It's not specific to Teensy, but it is still good work.
If you want something that is more specific to Teensy, you should look at what the Tympan folks have done (I'm a founding member). Like OpenMHA, Tympan is also aimed at Hearing Aid researchers...but unlike OpenMHA, Tympan is a Teensy. You can use Tympan algorithms directly in your Teensy project.
The Tympan project is about both hardware and software, but you can use just the software. While the Tympan hardware is nice (it is a Teensy 4.1 with better audio and a bunch of other extras), the Teensy audio card is much cheaper. So, if you just want to use the Tympan Library with your normal Teensy hardware, that's great!
The Tympan Audio Library is built on the Teensy Audio Library, so it won't be alien. Just like the Teensy audio library, you use it within the Arduino IDE and you compile it just like any other Teensy program. It includes lots of examples. The Tympan Library is here: https://github.com/Tympan/Tympan_Library
Here is the noise reduction example: https://github.com/Tympan/Tympan_Li...omain/NoiseReduction_FD/NoiseReduction_FD.ino
This example calls the noise reduction processing block. The processing block ("AudioEffectNoiseReduction_FD_F32") is defined right there on another tab within the example. If you look at this example, you'll see that it does the noise reduction in the frequency domain, which means that it does an FFT -> does the noise reduction -> does an IFFT. This is a common framework for noise reduction algorithms, though there are many variations within this framework.
The core idea with this particular algorithm is that it estimates the "noise level" by keeping track of the long-term average loudness at each frequency. Having this threshold for what is "noise" and what is "signal", it can now operate on in-coming audio to reduce the noise. This algorithm declares that anything louder than the "noise level" must be good signal and is let through. But, anything that is near the noise level (or quieter) is considered bad and is attenuated. Because good/bad decision is being done for each frequency, it can really slice around the good signal to attenuate the noise.
Do be aware that the example code does assume that you're using the Tympan hardware. The core algorithm doesn't care, but the overll program assumes that the audio is coming in/out of the Tympan audio interface. If you're using the Teensy audio board instead of a Tympan, you'll need to modify the example. Specifically, you'll need to:
  • Swap out (or comment out) all of lines referring to "myTympan". These are the lines that control the audio hardware, so they fill the same role as the Teensy audio library's calls to AudioControlSTGL5000.
  • Comment out the lines invoking the Bluetooth (BLE) system. Unless you have a Tympan, your Teensy audio hardware has no bluetooth system.
The Tympan Library also has a couple of LMS algorithms, but these are a lot harder to work with, so I'd stick with the example showing the frequency-domain noise reduction.
Chip
