Hi all,
I am trying to flash code on Teensy4.0 every time it is stuck after Rebooting..... it is waiting to push reboot button and then it is flashing the code.
But after that when i am opening serial monitor to see output nothing is printing
Processing teensy40 (platform: https://github.com/tsandmann/platform-teensy.git; board: teensy40; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
PlatformIO running on windows_amd64
CONFIGURATION: https://docs.platformio.org/page/boards/teensy-ts/teensy40.html
PLATFORM: Teensy (4.18.0+sha.f2a89fa) > Teensy 4.0
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 1.94MB Flash
DEBUG: Current (jlink) External (jlink)
PACKAGES:
- framework-arduinoteensy @ 1.159.0 (1.59)
- framework-arduinoteensy-ts @ 1.159.0+sha.7e53c09
- tool-teensy @ 1.159.0 (1.59)
- toolchain-arm-cortexm-win64 @ 13.2.0-5+sha.2af7627
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 96 compatible libraries
Scanning dependencies...
Dependency Graph
|-- freertos-teensy @ 11.0.1-1+sha.94fb21f
|-- FlexCAN_T4 @ 0.0.0+20240404124122.sha.b928bcb
|-- EEPROM @ 2.0.0+sha.6309212
|-- ACAN_T4 @ 1.1.8+sha.666278e
Building in release mode
Checking size .pio\build\teensy40\firmware.elf
RAM 1: [= ] 8.0% (used 41888 bytes from 524288 bytes)
RAM 2: [ ] 2.5% (used 13084 bytes from 524288 bytes)
Flash: [ ] 2.5% (used 50808 bytes from 2031616 bytes)
Configuring upload protocol...
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-cli
Rebooting...
PACKAGES:
Dependency Graph
Rebooting...
