Hi, I am recompiling an old sketch using i2c_t3 on the new Arduino IDE and it no longer builds. I get a library error saying that Wire and Wire1 have multiple definitions like the original Wire library is getting defined somewhere.
How do I fix this? I also tried on an older Teensyduino IDE install with similar results, something has changed as it's been about a year since I've had to build this sketch.
Here is my error:
Here is the section of my code that uses i2c_t3
Here is my main file that includes this file:
Here is my error:
C-like:
/Users/emmettpalaima/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/Wire/WireKinetis.cpp.o: in function `i2c0_isr':
/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/Wire/WireKinetis.cpp:914: multiple definition of `i2c0_isr'; /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/i2c_t3/i2c_t3.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/i2c_t3/i2c_t3.cpp:1134: first defined here
/Users/emmettpalaima/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/Wire/WireKinetis.cpp.o: in function `i2c1_isr':
/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/Wire/WireKinetis.cpp:919: multiple definition of `i2c1_isr'; /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/i2c_t3/i2c_t3.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/i2c_t3/i2c_t3.cpp:1141: first defined here
/Users/emmettpalaima/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/Wire/WireKinetis.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/Wire/WireKinetis.cpp:918: multiple definition of `Wire1'; /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/i2c_t3/i2c_t3.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/i2c_t3/i2c_t3.cpp:1659: first defined here
/Users/emmettpalaima/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/Wire/WireKinetis.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/Wire/WireKinetis.cpp:913: multiple definition of `Wire'; /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino/sketches/454FF7FE197B280F1F02F6D915A39469/libraries/i2c_t3/i2c_t3.cpp.o:/Users/emmettpalaima/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/libraries/i2c_t3/i2c_t3.cpp:1657: first defined here
C++:
#include <i2c_t3.h>
#define IS31_ADDR 0x3C
#define EN_PIN 20
#define FOIL 5
#define TCP 6
#define BCP 7
#define ATK 8
#define DEF 9
#define HRT 10
const uint8_t rfall[9] = { 19, 18, 17, 16, 15, 14, 13, 12, 11 };
const uint8_t lfall[9] = { 20, 21, 22, 23, 24, 25, 26, 27, 28 };
#define HG 29
uint8_t data_buf[37] = {};
uint8_t led_default[36] = {};
void write_is31_buffer(uint8_t reg, uint8_t *data, int len){
Wire.beginTransmission(IS31_ADDR);
Wire.write(reg);
Wire.write(data, len);
Wire.sendTransmission();
void write_is31_byte(uint8_t reg, uint8_t data){
Wire.write(reg);
Wire.write(data);
void write_is31_pwm(uint8_t *data){
Wire.write(0x01);
Wire.write(data, 37); //37 is zero written to update reg
// for(int i = 0; i < 37; ++i){
// Wire.write(data[i]);
void init_is31( void ){
pinMode(EN_PIN, OUTPUT);
digitalWriteFast(EN_PIN, HIGH);
for(int i = 5; i < 30; ++i){ led_default[i] = 1; }
delay(10);
write_is31_byte(0x00, 0x01);
delay(10);
write_is31_byte(0x4B, 0x01);
delay(10);
write_is31_buffer(0x26, led_default, 36);
delay(10);
#include "HarmonicDistortion.h"
AudioSynthWaveformDc dc1; //xy=55,1513
AudioSynthWaveformDc dc2; //xy=62,1783
AudioEffectEnvelope env2; //xy=74,1724
AudioSynthWaveformDc dc3; //xy=85,1651
AudioEffectEnvelope env1; //xy=155,1441
AudioSynthWaveformSineModulated sine4; //xy=225,1878
AudioSynthWaveformSineModulated sine3; //xy=231,1827
AudioSynthWaveformSine sine5; //xy=232,1935
AudioMixer4 mix3; //xy=262,1662
AudioSynthWaveformSineModulated sine2; //xy=279,1578
AudioMixer4 mix2; //xy=365,1450
AudioMixer4 sinemix2; //xy=420,1818
AudioSynthWaveformDc dc4; //xy=437,1995
AudioSynthWaveformSineModulated testSine; //xy=469,1603
AudioSynthWaveformDc testDc;
AudioEffectMultiply testMult;
AudioEffectMultiply mult2; //xy=469,1678
AudioSynthWaveformSineModulated sine1; //xy=494,1449
AudioEffectMultiply mult1; //xy=529,1571
AudioEffectEnvelope env3; //xy=628,1895
AudioEffectEnvelope env4; //xy=641,1950
AudioMixer4 sinemix1; //xy=663,1451
AudioSynthNoiseWhite noise1; //xy=670,1768
AudioMixer4 mix1; //xy=671,1623
AudioSynthWaveformDc dc5; //xy=710,2041
AudioMixer4 mixer6; //xy=835,1936
AudioAmplifier amp1; //xy=846,1618
AudioAmplifier amp2; //xy=846,1618
HarmonicDistortion dist1;
AudioEffectMultiply multiply3; //xy=956,1817
AudioOutputAnalog dac1; //xy=997,1615
AudioFilterBiquad filt;
AudioAmplifier makeup;
AudioConnection patchCord1(dc1, env1);
AudioConnection patchCord2(dc2, env2);
AudioConnection patchCord3(env2, 0, mix3, 0);
AudioConnection patchCord4(env2, 0, mult2, 1);
AudioConnection patchCord5(dc3, 0, mix3, 1);
AudioConnection patchCord6(dc3, 0, mix2, 1);
AudioConnection patchCord7(env1, 0, mult1, 1);
AudioConnection patchCord8(env1, 0, mix2, 0);
AudioConnection patchCord9(sine4, 0, sinemix1, 2);
AudioConnection patchCord10(sine4, 0, sinemix2, 2);
AudioConnection patchCord11(sine3, 0, sinemix1, 1);
AudioConnection patchCord12(sine3, 0, sinemix2, 1);
AudioConnection patchCord13(sine5, 0, sinemix1, 3);
AudioConnection patchCord14(sine5, 0, sinemix2, 3);
AudioConnection patchCord15(mix3, sine2);
AudioConnection patchCord16(sine2, 0, sinemix2, 0);
AudioConnection patchCord17(mix2, sine1);
AudioConnection patchCord18(sinemix2, 0, mult2, 0);
AudioConnection patchCord19(dc4, env3);
AudioConnection patchCord20(dc4, env4);
//AudioConnection patchCord21(testSine, 0, mix1, 3);
AudioConnection patchCord22(mult2, 0, mix1, 1);
AudioConnection patchCord23(sine1, 0, sinemix1, 0);
AudioConnection patchCord24(mult1, 0, mix1, 0);
AudioConnection patchCord25(env3, 0, mixer6, 0);
AudioConnection patchCord26(env4, 0, mixer6, 1);
AudioConnection patchCord27(sinemix1, 0, mult1, 0);
AudioConnection patchCord28(noise1, 0, multiply3, 0);
AudioConnection patchCord29(mix1, amp2);
AudioConnection patchCord30(dc5, 0, mixer6, 2);
AudioConnection patchCord31(mixer6, 0, multiply3, 1);
AudioConnection patchCord32(amp1, filt);
AudioConnection patchCord32b(filt, makeup);
AudioConnection patchCord32c(makeup, dac1);
AudioConnection patchCord33(multiply3, 0, mix1, 2);
AudioConnection patchCordA(amp2, dist1);
AudioConnection patchCordB(dist1, amp1);
AudioConnection patchCordC(testSine, 0, testMult, 0);
AudioConnection patchCordD(testDc, 0, testMult, 1);
AudioConnection patchCordE(testMult, 0, mix1, 3);
unsigned long audioTimer = 0;
bool at = false;
float atk = 50;
float dec = 300;
float atk2 = atk;
float dec2 = dec;
float amp = 1;
float freq = 35;
float topper = amp;
void setupAudio(){
AudioMemory(100);
dist1.thirdOrder(1);
dist1.secondOrder(0);
dist1.gain(6);
sine1.amplitude(amp);
sine1.frequency(freq);
sine2.amplitude(amp);
sine2.frequency(freq-1);
sine3.frequency(200);
sine3.amplitude(0.01*topper);
sine4.frequency(100);
sine4.amplitude(0.01*topper);
sine5.frequency(400);
sine5.amplitude(0.01*topper);
testSine.amplitude(1);
testSine.frequency(120);
noise1.amplitude(1);
env1.attack(atk);
env1.hold(0);
env1.decay(dec);
env1.sustain(0);
env1.release(1.0f);
env1.releaseNoteOn(1);
env2.attack(atk);
env2.hold(0);
env2.decay(dec);
env2.sustain(0);
env2.release(1.0f);
env2.releaseNoteOn(1);
env3.attack(atk2);
env3.hold(0);
env3.decay(dec2);
env3.sustain(0);
env3.release(1.0f);
env3.releaseNoteOn(1);
env4.attack(atk2);
env4.hold(0);
env4.decay(dec2);
env4.sustain(0);
env4.release(1.0f);
env4.releaseNoteOn(1);
dc1.amplitude(1);
dc2.amplitude(1);
dc3.amplitude(-1);
dc4.amplitude(-1);
dc5.amplitude(1);
testDc.amplitude(0);
const float sine_mix = 1;
const float noise_mix = 1;
const float test_mix = 4;
mix1.gain(0, sine_mix);
mix1.gain(1, sine_mix);
mix1.gain(2, noise_mix);
mix1.gain(3, test_mix);
mix2.gain(0, 1);
mix2.gain(1, 1);
mix2.gain(2, 1);
mix2.gain(3, 1);
mix3.gain(0, 1);
mix3.gain(1, 1);
mix3.gain(2, 1);
mix3.gain(3, 1);
sinemix1.gain(0, 1);
sinemix1.gain(1, 1);
sinemix1.gain(2, 1);
sinemix1.gain(3, 1);
sinemix2.gain(0, 1);
sinemix2.gain(1, 1);
sinemix2.gain(2, 1);
sinemix2.gain(3, 1);
float vol = float(analogRead(A8)) / 1023.0f;
amp2.gain(1);
amp1.gain(vol);
dac1.analogReference(EXTERNAL);
for(int i = 0; i < 3; ++i){
filt.setLowpass(i, 250, 0.7);
makeup.gain(2);
#include "TombAudio.h"
#include "IS31_I2C.h"
#include "Utility.h"
#define REFRESH 40
#define CLK_IN 21
#define CLK_NORM 17
#define ATK_OUT 16
const uint8_t pot[3] = { A1, A0, A8 };
pwm_port foil_led;
pwm_port tcp_led;
pwm_port bcp_led;
pwm_port atk_led;
pwm_port def_led;
pwm_port hrt_led;
pwm_port hg_led;
pwm_port lfall_led[9];
pwm_port rfall_led[9];
pwm_port clk_norm;
ms_delta clk_pulse;
ms_delta clk_delta;
ms_delta beat_delta;
trig_delay beat2;
trig_delay beat3;
ms_timer led_refresh;
ms_timer fall_timer;
pinMode(CLK_NORM, OUTPUT);
pinMode(CLK_IN, INPUT_PULLUP);
pinMode(ATK_OUT, OUTPUT);
foil_led.init(0, REFRESH);
tcp_led.init(0, REFRESH);
bcp_led.init(0, REFRESH);
atk_led.init(0, REFRESH);
def_led.init(0, REFRESH);
hrt_led.init(0, REFRESH);
hg_led.init(0, REFRESH);
for(int i = 0; i < 9; ++i){
rfall_led[i].init(0, REFRESH);
lfall_led[i].init(0, REFRESH);
led_refresh.set_timer(REFRESH);
clk_pulse.set_pulse_len(100);
// Serial.begin(115200);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(EN_PIN, HIGH);
setupAudio();
// Setup for Master mode, pins 18/19, external pullups, 400kHz
Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
Wire.begin();
Wire.setDefaultTimeout(250000); // 250ms default timeout
digitalWrite(LED_BUILTIN,LOW); // LED on
// Set operating mode to DMA
// Serial.print("Trying to set DMA mode : ");
Wire.setOpMode(I2C_OP_MODE_DMA);
// if(Wire.i2c->opMode == I2C_OP_MODE_DMA){
//// Serial.printf("OK (Channel %d)\n",Wire.i2c->DMA->channel);
// }else{
//// Serial.print("Failed, using DMA\n");
init_is31();
unsigned long beat_del = 1000;
bool firstfall = true;
void heartbeat(unsigned long stamp){
if(clk_delta.last_delta < 100){
// if(!env1.isActive() || env1.isSustain()){
if(firstfall){
firstfall = false;
// Serial.println("long");
AudioNoInterrupts();
// testDc.amplitude(0.01, 1);
env1.decay(11880*2.5);
env3.decay(11880*2.5);
env1.release(11880*2.5);
env3.release(11880*2.5);
env1.sustain(0.5);
env3.sustain(0.5);
env1.noteOn();
env3.noteOn();
AudioInterrupts();
}else if(env3.isSustain()){
env1.noteOff();
env3.noteOff();
hrt_led.line(255, 0, clk_delta.last_delta * 0.4);
tcp_led.line(255, 0, clk_delta.last_delta);
}else if(stamp == clk_delta.stamp){
firstfall = true;
unsigned long len = clk_delta.last_delta * 0.25;
unsigned long atk = len < 100 ? len / 2 : 50;
unsigned long dec = 400;
// testDc.amplitude(0, 1);
// if(dec > 400){ dec = 400; }
// if(len < 40 ){
//// dec += (40 - len;
// if(len < 100){
// testDc.amplitude((100.0f - float(len)) / 50.0f, 1);
// }else{
// if(len < 50){
// dec = 11880;
// atk = 0;
// env1.decay(dec);
// env2.decay(dec);
// env3.decay(dec);
// env4.decay(dec);
env1.sustain(0);
env3.sustain(0);
env2.sustain(0);
env4.sustain(0);
env1.attack(atk);
env2.attack(atk);
env3.attack(atk);
env4.attack(atk);
env1.decay(dec);
env2.decay(dec);
env3.decay(dec);
env4.decay(dec);
env1.release(0.0f);
env3.release(0.0f);
env1.noteOn();
env3.noteOn();
env2.noteOff();
env4.noteOff();
AudioInterrupts();
// Serial.println(clk_delta.get_delta(stamp));
// if(!clk_delta.get_delta(stamp)){
// AudioNoInterrupts();
// env1.attack(0);
// env3.attack(0);
// env1.attack(0);
// env4.attack(0);
// AudioInterrupts();
// }else{
// env1.attack(atk);
// env3.attack(atk);
// env4.attack(atk);
beat2.set_len(len);
beat2.set_trig(stamp);
}else if(beat2.get_trig(stamp)){
env1.noteOff();
env3.noteOff();
env2.noteOn();
env4.noteOn();
AudioInterrupts();
bcp_led.line(255, 0, clk_delta.last_delta);
int light = 0;
unsigned long ledTimer = 0;
unsigned long i2cTimer = 0;
unsigned long clk_norm_timer = 0;
bool clk_in_flag = false;
unsigned long rn = 0;
int norm_pulse = 0;
bool clk_in = digitalReadFast(CLK_IN);
digitalWriteFast(ATK_OUT, clk_in);
if(rn != millis()){
rn = millis();
if(rn > clk_norm_timer + analogRead(pot[0]) * 2 + 1){
clk_norm_timer = rn;
norm_pulse = 10;
bool pulse = norm_pulse > 0;
digitalWriteFast(CLK_NORM, pulse);
if(pulse){ --norm_pulse; }
if(clk_in && !clk_in_flag){
clk_delta.get_delta(rn);
clk_delta.set_stamp(rn);
hg_led.line(255, 0, 500);
def_led.line(255, 0, 500);
atk_led.line(255, 0, 500);
fall_timer.set_timer(clk_delta.last_delta * 0.25);
foil_led.set(random(255), clk_delta.last_delta);
clk_in_flag = clk_in;
heartbeat(rn);
if(fall_timer.check_timer(rn)){
if(i == light){
lfall_led[i].set_broken(255);
rfall_led[i].set_broken(255);
}else{
lfall_led[i].set(random(10), 100);
rfall_led[i].set(random(10), 100);
data_buf[36] = 0; //update leds register write
light = ((light + 1) % 9);
ledTimer = rn;
float vol = (float(analogRead(A8)) - 5.0) / 1018.0f;
if(vol < 0){ vol = 0; }
vol = powf(vol, 4);
amp1.gain(vol*100);
float cut = 100.0f + 300.0f * (float(analogRead(pot[1])) / 1023.0f);
filt.setLowpass(i, cut, 0.7);
if(led_refresh.check_timer(rn)){
data_buf[FOIL] = foil_led.port();
data_buf[TCP] = tcp_led.port();
data_buf[BCP] = bcp_led.port();
data_buf[ATK] = atk_led.port();
data_buf[DEF] = def_led.port();
data_buf[HRT] = hrt_led.port();
data_buf[HG] = hg_led.port();
data_buf[rfall[i]] = rfall_led[i].port();
data_buf[lfall[i]] = lfall_led[i].port();
i2cTimer = rn;
write_is31_pwm(data_buf);
