propa
Got a Teensy 4.1 and Rev D shield, trying to just get the audio passthrough working, and it's execution is intermittent, not predictable. I uploaded once successfully, but once the board is unplugged and plugged back in it ceases to work.
Just using simple passthrough example, and have neither been able to change the volume from external pot, nor could I get this code to work again after unplugging and pluggin the Teensy once it was working.
I've never had this sort of problem before with any of the 3.2 or 3.6, or other Audio Shields
Using Teensyduino 1.53, 1.8.13
Is this Audio board a dud? Unplugging while audio was playing into jack wouldn't hurt the audio board?
* A simple hardware test which receives audio from the audio shield
* Line-In pins and send it to the Line-Out pins and headphone jack.
* This example code is in the public domain.
#include <SerialFlash.h>
AudioInputI2S i2s1; //xy=200,69
AudioOutputI2S i2s2; //xy=365,94
AudioConnection patchCord1(i2s1, 0, i2s2, 0);
AudioConnection patchCord2(i2s1, 1, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=302,184
//const int myInput = AUDIO_INPUT_MIC;
// Audio connections require memory to work. For more
AudioMemory(12);
sgtl5000_1.enable();
sgtl5000_1.volume(0.8);
delay(20);
elapsedMillis volmsec=0;
// every 50 ms, adjust the volume
// if (volmsec > 50) {
float vol = analogRead(18);
//Serial.println(vol);
vol = vol / 1023.0;
sgtl5000_1.volume(vol); // <-- uncomment if you have the optional
// volmsec = 0; // volume pot on your audio shield
