#include <EventResponder.h>
#define SPIT SPI2
#define DBGSerial Serial4
#define CS_PIN 10
#define SMALL_TRANSFER_SIZE 128
//#define BUFFER_SIZE 70000 //(320*240*2) // size of ILI9341 display...
#define BUFFER_SIZE 0x12000l // More than 64K
//uint8_t buffer[BUFFER_SIZE];
uint8_t *buffer; // lets malloc it...
//uint8_t rxBuffer[SMALL_TRANSFER_SIZE];
DMAMEM uint8_t rxBuffer[BUFFER_SIZE];
//uint8_t *rxBuffer;
uint8_t *foo_bar = nullptr;
uint8_t static_buffer[16];
#define SERIAL_tt Serial1
// Trigger spare interrupts
IntervalTimer ITtest;
volatile uint32_t kk, jj = 0;
uint32_t tt = 0;
void TimeSome() {
jj++;
kk = micros();
if ( !(jj % 10000) ) SERIAL_tt.print("*");
if ( !(jj % 130000) ) SERIAL_tt.print("!\n");
#define CHANGE_SPEED // define to cycle the CPU speed
extern "C" uint32_t set_arm_clock(uint32_t frequency);
#define MAX_SPEED 800000000
#define MIN_SPEED 96000000
uint32_t ArmSpeed = 6 * 100000000;
[COLOR="#FF0000"]EventResponder event;
volatile bool event_happened = false;
void asyncEventResponder(EventResponderRef event_responder)
digitalWriteFast(CS_PIN, HIGH);
event_happened = true;
[/COLOR]
// debug pins
uint8_t stack_buffer[10];
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
digitalWrite(0, LOW);
digitalWrite(1, LOW);
extern unsigned long _heap_start;
extern unsigned long _heap_end;
pinMode(CS_PIN, OUTPUT);
while (!Serial && millis() < 4000) ; // wait for Serial port
DBGSerial.begin(115200);
SPIT.begin();
DBGSerial.println("SPI Test program");
buffer = (uint8_t *)malloc(BUFFER_SIZE);
//rxBuffer = (uint8_t *)malloc(BUFFER_SIZE);
SERIAL_tt.begin( 115200 );
SERIAL_tt.println("\n********\n T4 connected Serial1 *******\n");
DBGSerial.print("Buffer: ");
DBGSerial.print((uint32_t)buffer, HEX);
DBGSerial.print(" RX Buffer: ");
DBGSerial.print((uint32_t)rxBuffer, HEX);
DBGSerial.print(" ");
DBGSerial.println(BUFFER_SIZE, DEC);
DBGSerial.printf("Static buffer: %x, Stack Buffer: %x\n", (uint32_t)static_buffer, (uint32_t)stack_buffer);
DBGSerial.printf("Heap Start: %x, Heap End: %x\n", (uint32_t)&_heap_start, (uint32_t)&_heap_end);
[COLOR="#FF0000"] event.attachImmediate(&asyncEventResponder);[/COLOR]
ITtest.begin( TimeSome, 2);
int nn = 0;
while (DBGSerial.read() != -1) ; // Make sure queue is empty.
DBGSerial.println("Press any key to run test");
//while (!DBGSerial.available()) ; // will loop until it receives something
while (DBGSerial.read() != -1) ; // loop until queue is empty
DBGSerial.println("Ready to start tests");
DBGSerial.print("IntvTimer jj=");
DBGSerial.print( jj );
DBGSerial.print("\tIntvTimer jj=");
DBGSerial.print("\tms Time=");
DBGSerial.println( millis() - tt );
DBGSerial.print( millis() - tt );
tt = millis();
jj = 0;
DBGSerial.printf( " deg C=%2.2f\n" , tempmonGetTemp() );
delay( 500 );
#ifdef CHANGE_SPEED
if ( !(nn % 4) ) { // Change Clock Speed
ArmSpeed -= 100000000;
if ( ArmSpeed < MIN_SPEED ) ArmSpeed = MAX_SPEED;
set_arm_clock( ArmSpeed );
if ( F_CPU_ACTUAL < MIN_SPEED ) ArmSpeed = MAX_SPEED;
DBGSerial.printf("\t>>> Clock Speed is:%u", F_CPU_ACTUAL);
delay( 500 );
nn++;
SPIT.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
DBGSerial.println("After Begin Transaction");
// Transfer Sync
for (uint32_t i = 0; i < BUFFER_SIZE; i++) buffer[i] = i & 0xff;
for (uint32_t i = 0; i < BUFFER_SIZE; i++) rxBuffer[i] = 0x5a;
DBGSerial.println("Transfer Small"); //DBGSerial.flush();
digitalWriteFast(CS_PIN, LOW);
SPIT.transfer(buffer, rxBuffer, SMALL_TRANSFER_SIZE);
DBGSerial.println("*** Completed ***"); DBGSerial.flush();
dumpBuffer(buffer, SMALL_TRANSFER_SIZE);
DBGSerial.println();
dumpBuffer(rxBuffer, SMALL_TRANSFER_SIZE);
validateTXBuffer(0);
delay(5);
DBGSerial.println("write Small"); DBGSerial.flush();
SPIT.transfer(buffer, NULL, SMALL_TRANSFER_SIZE);
delay(5);
DBGSerial.println("read Small"); DBGSerial.flush();
SPIT.transfer(NULL, rxBuffer, SMALL_TRANSFER_SIZE);
delay(5);
SPI.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE0));
for (uint32_t i = 0; i < BUFFER_SIZE; i++)buffer[i] = i / 1024;
DBGSerial.println("Transfer Full"); DBGSerial.flush();
SPIT.transfer(buffer, rxBuffer, BUFFER_SIZE);
validateTXBuffer(1);
delay(5);
for (uint32_t i = 0; i < BUFFER_SIZE; i++) buffer[i] = i / 1024;
DBGSerial.println("write full"); DBGSerial.flush();
SPIT.transfer(buffer, NULL, BUFFER_SIZE);
delay(5);
DBGSerial.println("read full"); DBGSerial.flush();
SPIT.transfer(NULL, buffer, BUFFER_SIZE);
delay(5);
// Transfer Async
for (uint32_t i = 0; i < 5; i++) {
delay(1);
delay(1);
DBGSerial.println("Async write Small"); DBGSerial.flush();
[COLOR="#FF0000"] SPIT.transfer(buffer, NULL, SMALL_TRANSFER_SIZE, event);[/COLOR]
DBGSerial.println("After write call, waiting for event");
while (!event_happened) ;
delay(5);
DBGSerial.println("Async Transfer Small"); DBGSerial.flush();
SPIT.transfer(buffer, rxBuffer, SMALL_TRANSFER_SIZE, event);
DBGSerial.println("After Transfer call, waiting for event");
delay(5);
DBGSerial.println("Async read Small"); DBGSerial.flush();
SPIT.setTransferWriteFill(0x42);
SPIT.transfer(NULL, rxBuffer, SMALL_TRANSFER_SIZE, event);
//arm_dcache_delete(rxBuffer, SMALL_TRANSFER_SIZE);
delay(5);
DBGSerial.println("Async Transfer Full"); DBGSerial.flush();
SPIT.transfer(buffer, rxBuffer, BUFFER_SIZE, event);
dumpBuffer(rxBuffer, 512);
delay(5);
DBGSerial.println("Async write full"); DBGSerial.flush();
SPIT.transfer(buffer, NULL, BUFFER_SIZE, event);
delay(5);
DBGSerial.println("Async read full"); DBGSerial.flush();
SPIT.transfer(NULL, rxBuffer, BUFFER_SIZE, event);
delay(5);
DBGSerial.println("Tests completed");
SPIT.endTransaction();
void dumpBuffer(uint8_t *pb, int cb) {
uint8_t i = 0;
while (cb) {
DBGSerial.print(*pb++, HEX);
cb--;
i++;
if (i == 16) {
i = 0;
void validateTXBuffer(uint8_t test)
uint8_t error_count = 0;
for (int i = 0; i < BUFFER_SIZE; i++) {
if (((test == 0) && (buffer[i] != (i & 0xff)))
|| ((test == 1) && (buffer[i] != (i / 1024)))) {
DBGSerial.print("Tx Buffer validate failed Index: ");
DBGSerial.print(i, DEC);
DBGSerial.print(" Value: ");
DBGSerial.println(buffer[i], HEX);
error_count++;
if (error_count == 10)
