porting schetch 3.6 to 4.1
v1studio
Hi guys, I have a problem with this mentioned scheme.
//POV
#include <Bounce.h>
int PinButton0 = 31; // COMM
int PinButton1 = 29; // A- Top
int PinButton2 = 30; //B- Right
int PinButton3 = 27; //C-Left
int PinButton4 = 28; //X-bottom
Bounce button0 = Bounce(PinButton0, 10);
Bounce button1 = Bounce(PinButton1, 10); // 10 = 10 ms debounce time
Bounce button2 = Bounce(PinButton2, 10); // which is appropriate for
Bounce button3 = Bounce(PinButton3, 10); // most mechanical pushbuttons
Bounce button4 = Bounce(PinButton4, 10);
//--End
//Clutches
#define CLUTCHLH A1
#define CLUTCHRH A0
#define WINDOW_SIZE 50
//Upload
#define HWSERIAL Serial1
void UploadNextionHMI() {
int incomingByte;
if (Serial.available() > 0) {
incomingByte = Serial.read();
HWSERIAL.write(incomingByte);
if (HWSERIAL.available()>0){
incomingByte = HWSERIAL.read();
Serial.write(incomingByte);
int INDEXLH = 0;
int VALUELH = 0;
int SUMLH = 0;
int READINGSLH[WINDOW_SIZE];
int AVERAGEDLH = 0;
int AVERAGEDLHBEFORE = 0;
int AVERAGEDLHMAPPED = 0;
int INDEXRH = 0;
int VALUERH = 0;
int SUMRH = 0;
int READINGSRH[WINDOW_SIZE];
int AVERAGEDRH = 0;
int AVERAGEDRHBEFORE = 0;
int AVERAGEDRHMAPPED = 0;
int AVERAGEDCLUTCH = 0;
int CLUTCH = 0;
int MAXLH = 1023;
int MINLH = 1023;
int MAXRH = 1023;
int MINRH = 1023;
int CLUTCHRANGELH;
int CLUTCHRANGERH;
int CLUTCHRANGE;
//EG added 21/03/21- Clutch Calibration
#include <EEPROM.h>
unsigned long pressedTime = 0;
unsigned long releasedTime = 0;
int currentButtonState;
int configMode = 0;
int lastButtonState = HIGH;
int pressStarted=0;
float BITINGPOINT;
int BITINGPOINTFOREEPROM = 50;
//Used For saving
int button6;
int button10;
//Used for Clutch calibration
int button7;
int button8;
int isConfigAlreadyBeenSaved = 0;
int isMaxCalibrationBeenDone = 0;
int isMinCalibrationBeenDone = 0;
int MAXLHaddress = 0;
int MAXRHaddress = 1;
int MINLHaddress = 2;
int MINRHaddress = 3;
int BITINGPOINTaddress = 4;
//EG 07202021 - Clutches preset
int preset01 =35;
int preset02 =45;
int preset03 =55;
int preset04 =65;
int BITINGPOINT01address = 5;
int BITINGPOINT02address = 6;
int BITINGPOINT03address = 7;
int BITINGPOINT04address = 8;
int selectedPresetAddress = 9;
int buttonClutchPreset = 0;
int selectedPreset = 0;
//End
//Upload Mode
unsigned long UppressedTime = 0;
unsigned long UpreleasedTime = 0;
int UpcurrentButtonState;
int UplastButtonState = HIGH;
int UppressStarted=0;
int UploadingMode =0;
//End
// ----- LEDS ---------
// Uncomment to enable leds
#define INCLUDE_WS2812B
// How many leds
#define WS2812B_RGBLEDCOUNT 18
// Data pin
#define WS2812B_DATAPIN 33
// 0 left to right, 1 right to left
#define WS2812B_RIGHTTOLEFT 0
//From AMS studio
#define ENABLE_PULLUPS
#define NUMROTARIESHALF 3
#define NUMROTARIESFULL 4
struct rotariesdefHalf{
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
struct rotariesdefFull{
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
rotariesdefHalf rotariesHalf[NUMROTARIESHALF]{
{6,7,19,20,0},
{8,9,21,22,0},
{10,11,23,24,0},
//{2,3,14,15,0},
rotariesdefFull rotariesFull[NUMROTARIESFULL]{
//{4,5,28,29,0},
{2,3,25,26,0},
{4,5,27,28,0},
{25,26,29,30,0},
{12,24,31,32,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttableHalf[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#define R_CW_FINAL 0x1
#define R_CW_BEGINFULL 0x2
#define R_CW_NEXT 0x3
#define R_CCW_BEGINFULL 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttableFull[7][4] = {
// R_START
{R_START, R_CW_BEGINFULL, R_CCW_BEGINFULL, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGINFULL, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGINFULL, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGINFULL, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGINFULL, R_START},
//End by EG
#include <Adafruit_NeoPixel.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
byte rowPins[ROWS] = {16, 18, 19, 20}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {23,22,21}; //connect to the column pinouts of the keypad
char keyMap[ROWS][COLS] = {
{2,3,4},
{5,6,7},
{8,9,10},
{11,12,13}
Keypad buttbx = Keypad( makeKeymap(keyMap), rowPins, colPins, ROWS, COLS);
void WriteToComputer() {
while (HWSERIAL.available()) {
char c = (char)HWSERIAL.read();
Serial.write(c);
#ifdef INCLUDE_WS2812B
Adafruit_NeoPixel WS2812B_strip = Adafruit_NeoPixel(WS2812B_RGBLEDCOUNT, WS2812B_DATAPIN, NEO_RGB + NEO_KHZ400);
bool LedsDisabled = false;
byte r, g, b;
void ReadLeds() {
while (!Serial.available()) {}
WS2812B_strip.setBrightness(Serial.read());
for (int i = 0; i < WS2812B_RGBLEDCOUNT; i++) {
r = Serial.read();
g = Serial.read();
b = Serial.read();
if (WS2812B_RIGHTTOLEFT > 0)
WS2812B_strip.setPixelColor(WS2812B_RGBLEDCOUNT - 1 - i, r, g, b);
else {
WS2812B_strip.setPixelColor(i, r, g, b);
WriteToComputer();
WS2812B_strip.show();
for (int i = 0; i < 3; i++) {
Serial.read();
void DisableLeds() {
LedsDisabled = true;
Serial.write("Leds disabled");
static long baud = 921600;
static long newBaud = baud;
void lineCodingEvent(long baud, byte databits, byte parity, byte charFormat)
newBaud = baud;
//EEPROM.write(MAXLHaddress,MAXLH/4);
//EEPROM.write(MAXRHaddress,MAXRH/4);
//EEPROM.write(MINLHaddress,MINLH/4);
//EEPROM.write(MINRHaddress,MINRH/4);
//EEPROM.write(BITINGPOINTaddress,BITINGPOINTFOREEPROM);
MAXLH = EEPROM.read(MAXLHaddress)*4;
MAXRH = EEPROM.read(MAXRHaddress)*4;
MINLH = EEPROM.read(MINLHaddress)*4;
MINRH = EEPROM.read(MINRHaddress)*4;
//EG 07202021
preset01 = EEPROM.read(BITINGPOINT01address);
preset02 = EEPROM.read(BITINGPOINT02address);
preset03 = EEPROM.read(BITINGPOINT03address);
preset04 = EEPROM.read(BITINGPOINT04address);
selectedPreset = EEPROM.read(selectedPresetAddress);
//End
BITINGPOINT = EEPROM.read(BITINGPOINTaddress);
CLUTCHRANGELH = (MAXLH-MINLH);
CLUTCHRANGERH = (MAXRH-MINRH);
CLUTCHRANGE = CLUTCHRANGELH +CLUTCHRANGERH;
pinMode(CLUTCHLH, INPUT_PULLUP);
pinMode(CLUTCHRH, INPUT_PULLUP);
pinMode(PinButton0, INPUT_PULLUP);
pinMode(PinButton1, INPUT_PULLUP);
pinMode(PinButton2, INPUT_PULLUP);
pinMode(PinButton3, INPUT_PULLUP);
pinMode(PinButton4, INPUT_PULLUP);
pinMode(17,INPUT_PULLUP);
pinMode(18,INPUT_PULLUP);
pinMode(19,INPUT_PULLUP);
pinMode(20,INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(baud);
HWSERIAL.begin(baud);
WS2812B_strip.begin();
WS2812B_strip.setPixelColor(0, 0, 0, 0);
rotary_initHalf();
rotary_initFull();
//Joystick.useManualSend(true);
//EG 07212021
if (selectedPreset == 0){
Serial1.print(F("clutch_m.txt=\"Map 1\""));
printEnd();
Serial1.print(F("clutch_v.val="));
Serial1.print(preset01);
printEnd();
if (selectedPreset == 1){
Serial1.print(F("clutch_m.txt=\"Map 2\""));
printEnd();
Serial1.print(preset02);
printEnd();
if (selectedPreset == 2){
Serial1.print(F("clutch_m.txt=\"Map 3\""));
printEnd();
Serial1.print(preset03);
printEnd();
if (selectedPreset == 3){
Serial1.print(F("clutch_m.txt=\"Map 4\""));
printEnd();
Serial1.print(preset04);
printEnd();
//end
int readSize = 0;
int endofOutcomingMessageCount = 0;
int messageend = 0;
String command = "";
void UpdateBaudRate() {
// Update baudrate if required
newBaud = Serial.baud();
if (newBaud != baud) {
baud = newBaud;
HWSERIAL.end();
if (UploadingMode == 1){
UploadNextionHMI();
}else{
switchUploadMode();
switchMode();
CheckClutch();
CheckAllEncodersHalf();
CheckAllEncodersFull();
CheckAllButtons();
CheckPOV();
if (configMode ==1){
configClutches();
}else{//Added by EG on 07202021 to avoid having Simhub overwriting Elemento
if (HWSERIAL.available())
Serial.write(HWSERIAL.read());
if (Serial.available())
HWSERIAL.write(Serial.read());
while (Serial.available()) {
WriteToComputer();
char c = (char)Serial.read();
if (!LedsDisabled) {
if (messageend < 6) {
if (c == (char)0xFF) {
messageend++;
else {
messageend = 0;
if (messageend >= 3 && c != (char)(0xff)) {
command += c;
while (command.length() < 5) {
WriteToComputer();
command += c;
if (command == "sleds") {
ReadLeds();
if (command == "dleds") {
DisableLeds();
else {
HWSERIAL.print(command);
command = "";
messageend = 0;
else {
HWSERIAL.write(c);
else {
HWSERIAL.write(c);
#else
HWSERIAL.write(c);
WriteToComputer();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key.stateChanged )
switch (buttbx.key.kstate) {
case PRESSED:
case HOLD:
Joystick.button(buttbx.key.kchar, 1);
//Added EG 23/03
if (configMode == 1){
//Added EG 07202021
if (buttbx.key.kchar == 4){
buttonClutchPreset = 1;
if (buttbx.key.kchar == 6){
button6 = 1;
if (buttbx.key.kchar == 10){
button10 = 1;
if (buttbx.key.kchar == 7){
button7 = 1;
if (buttbx.key.kchar == 8){
button8 = 1;
//End
case RELEASED:
case IDLE:
Joystick.button(buttbx.key.kchar, 0);
//Added EG 072021
//Added EG 23/03
button6 = 0;
button10 = 0;
button7 = 0;
button8 = 0;
//End
//HalfStep
void rotary_initHalf() {
for (int i=0;i<NUMROTARIESHALF;i++) {
pinMode(rotariesHalf.pin1, INPUT);
pinMode(rotariesHalf.pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotariesHalf.pin1, HIGH);
digitalWrite(rotariesHalf.pin2, HIGH);
unsigned char rotary_processHalf(int _i) {
unsigned char pinstate = (digitalRead(rotariesHalf[_i].pin2) << 1) | digitalRead(rotariesHalf[_i].pin1);
rotariesHalf[_i].state = ttableHalf[rotariesHalf[_i].state & 0xf][pinstate];
return (rotariesHalf[_i].state & 0x30);
void CheckAllEncodersHalf(void) {
unsigned char result = rotary_processHalf(i);
if (result == DIR_CCW) {
Joystick.button(rotariesHalf.ccwchar, 1); delay(50); Joystick.button(rotariesHalf.ccwchar, 0);
if (result == DIR_CW) {
Joystick.button(rotariesHalf.cwchar, 1); delay(50); Joystick.button(rotariesHalf.cwchar, 0);
//End Half Step
//Full Step
void rotary_initFull() {
for (int i=0;i<NUMROTARIESFULL;i++) {
pinMode(rotariesFull.pin1, INPUT);
pinMode(rotariesFull.pin2, INPUT);
digitalWrite(rotariesFull.pin1, HIGH);
digitalWrite(rotariesFull.pin2, HIGH);
unsigned char rotary_processFull(int _i) {
unsigned char pinstate = (digitalRead(rotariesFull[_i].pin2) << 1) | digitalRead(rotariesFull[_i].pin1);
rotariesFull[_i].state = ttableFull[rotariesFull[_i].state & 0xf][pinstate];
return (rotariesFull[_i].state & 0x30);
void CheckAllEncodersFull(void) {
unsigned char result = rotary_processFull(i);
Joystick.button(rotariesFull.ccwchar, 1); delay(50); Joystick.button(rotariesFull.ccwchar, 0);
Joystick.button(rotariesFull.cwchar, 1); delay(50); Joystick.button(rotariesFull.cwchar, 0);
//End Full Step
void CheckPOV() {
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
if (button0.fallingEdge() && digitalRead(PinButton1) == HIGH && digitalRead(PinButton2) == HIGH && digitalRead(PinButton3) == HIGH && digitalRead(PinButton4) == HIGH ) { // This prevents an accidental PUSH IN to be activated if we are pushing the button Forward, Reverse, Left or Right
Joystick.button(1, 1);
if (button1.fallingEdge()) {
Joystick.button(1, 0); // If pushed IN button is active, deactivate it
Joystick.hat(0);
if (button2.fallingEdge()) {
Joystick.hat(270);
if (button3.fallingEdge()) {
Joystick.hat(180);
if (button4.fallingEdge()) {
Joystick.hat(90);
if (button0.risingEdge()) {
if (button1.risingEdge()) {
Joystick.hat(-1); }
if (button2.risingEdge()) {
Joystick.hat(-1); }
if (button3.risingEdge()) {
Joystick.hat(-1);
if (button4.risingEdge()) {
Joystick.hat(-1);
//End 07212021
int launchMode = 0;
void CheckClutch(){
//Left Clutch
SUMLH = SUMLH - READINGSLH[INDEXLH]; // Remove the oldest entry from the sum
VALUELH = analogRead(CLUTCHLH); // Read the next sensor value
READINGSLH[INDEXLH] = VALUELH; // Add the newest reading to the window
SUMLH = SUMLH + VALUELH; // Add the newest reading to the sum
INDEXLH = (INDEXLH+1) % WINDOW_SIZE; // Increment the index, and wrap to 0 if it exceeds the window size
AVERAGEDLH = SUMLH/ WINDOW_SIZE; // Divide the sum of the window by the window size for the result
//Right Clutch
SUMRH = SUMRH - READINGSRH[INDEXRH]; // Remove the oldest entry from the sum
VALUERH = analogRead(CLUTCHRH); // Read the next sensor value
READINGSRH[INDEXRH] = VALUERH; // Add the newest reading to the window
SUMRH = SUMRH + VALUERH; // Add the newest reading to the sum
INDEXRH = (INDEXRH+1) % WINDOW_SIZE; // Increment the index, and wrap to 0 if it exceeds the window size
AVERAGEDRH = SUMRH/ WINDOW_SIZE; // Divide the sum of the window by the window size for the result
//Added by EG 11/04/21
if (abs(AVERAGEDLHBEFORE - AVERAGEDLH)<2){
AVERAGEDLH = AVERAGEDLHBEFORE;
if (abs(AVERAGEDRHBEFORE - AVERAGEDRH)<2){
AVERAGEDRH = AVERAGEDRHBEFORE;
//End
//EG 10/04/2021
AVERAGEDLHMAPPED = map(MAXLH-AVERAGEDLH,0,CLUTCHRANGELH,0,100);
AVERAGEDRHMAPPED = map(MAXRH-AVERAGEDRH,0,CLUTCHRANGERH,0,100);
//AVERAGEDCLUTCH = (AVERAGEDRHMAPPED*BITINGPOINT/100)+(AVERAGEDLHMAPPED*(1-BITINGPOINT/100));
//End
//EG 07212021
if (AVERAGEDCLUTCH<0){
AVERAGEDCLUTCH = 0;
if (AVERAGEDRHMAPPED>5){
launchMode = 1;
if (AVERAGEDCLUTCH==0){
launchMode = 0;
if (launchMode == 0){
AVERAGEDCLUTCH = AVERAGEDLHMAPPED;
}else{
AVERAGEDCLUTCH = 0;
//End
Joystick.Z(map(AVERAGEDCLUTCH,0,100,0,1023));
delay(0);
AVERAGEDLHBEFORE = AVERAGEDLH;
AVERAGEDRHBEFORE = AVERAGEDRH;
//Added by EG 22/03/21
//Config Functions
void configModeChange(){
if (UploadingMode == 0){
if (configMode==0){
configMode = 1;
setLedConfig(0x00FFFF);
setLedConfigUnSaved(0xFFFF00);
//Serial.println("Config mode entered");
HWSERIAL.end();
HWSERIAL.begin(921600);
HWSERIAL.print("page 1");
printEnd();
}else if (configMode == 1){
HWSERIAL.print("page 0");
printEnd();
HWSERIAL.end();
//Serial.println("Config mode exited");
configMode = 0;
setLedConfig(0x000000);
setLedConfigUnSaved(0x000000);
int COMBINEDCLUTCHCONFIGTOSEND;
int CLUTCHLHCONFIG;
int CLUTCHRHCONFIG;
float COMBINEDCLUTCHCONFIG;
void configClutches(){
clutchMaxCalibration();
clutchMinCalibration();
CheckClutch();
//EG 07202021
changeClutchBitePreset();
//End
UpdateBitingPoint();
//Serial.println(BITINGPOINT);
CLUTCHLHCONFIG = map(MAXLH-AVERAGEDLH,0,CLUTCHRANGELH,0,100);
CLUTCHRHCONFIG= map(MAXRH-AVERAGEDRH,0,CLUTCHRANGERH,0,100);
HWSERIAL.print("j0.val=");
HWSERIAL.print(CLUTCHLHCONFIG);
printEnd();
HWSERIAL.print("j1.val=");
HWSERIAL.print(CLUTCHRHCONFIG);
printEnd();
CLUTCHRHCONFIG = CLUTCHRHCONFIG*BITINGPOINT/100;
CLUTCHLHCONFIG = CLUTCHLHCONFIG*(1-BITINGPOINT/100);
COMBINEDCLUTCHCONFIG = CLUTCHLHCONFIG+ CLUTCHRHCONFIG;
//Serial.println(CLUTCHRHCONFIG);
//Serial.println(CLUTCHLHCONFIG);
//Serial.println(COMBINEDCLUTCHCONFIG);
COMBINEDCLUTCHCONFIGTOSEND= COMBINEDCLUTCHCONFIG;
HWSERIAL.print("j2.val=");
HWSERIAL.print(COMBINEDCLUTCHCONFIGTOSEND);
printEnd();
HWSERIAL.print("n0.val=");
HWSERIAL.print(BITINGPOINT/100);
printEnd();
saveClutchConfig();
void printEnd(){
HWSERIAL.write(0xff);
void switchMode(){
currentButtonState = digitalRead(PinButton0);
if(lastButtonState == HIGH && currentButtonState == LOW){ // button is pressed
pressedTime = millis();
pressStarted = 1;
if (pressStarted ==1){
if (currentButtonState == LOW){
//Serial.println("pressed");
releasedTime = millis();
long pressDuration = releasedTime - pressedTime;
//Serial.println(pressDuration/1000);
if( pressDuration > 3000 ){
//Serial.println("Changing Mode");
//configModeChange();
UppressStarted = 0;
pressStarted = 0;
configModeChange();
//Serial.println(configMode);
//Serial.println("Mode Changed");
lastButtonState = currentButtonState;
int currentButton6State = 0;
int lastButton6State = 0;
int currentButton10State = 0;
int lastButton10State = 0;
void saveClutchConfig(){
if (button6 == 1 & button10 == 1 & isConfigAlreadyBeenSaved == 0){
//Serial.println("Config has been saved");
EEPROM.write(BITINGPOINTaddress,BITINGPOINT);
//EG 07212021
EEPROM.write(BITINGPOINT01address,preset01);
EEPROM.write(BITINGPOINT02address,preset02);
EEPROM.write(BITINGPOINT03address,preset03);
EEPROM.write(BITINGPOINT04address,preset04);
setLedConfigSaved(0x00FF00);
isConfigAlreadyBeenSaved = 1;
void UpdateBitingPoint(){
currentButton6State = button6;
currentButton10State = button10;
//EG 07212021
BITINGPOINT = preset01;
BITINGPOINT = preset02;
BITINGPOINT = preset03;
BITINGPOINT = preset04;
//End
if(currentButton6State == 1 & lastButton6State == 0){ // button is pressed
BITINGPOINT = BITINGPOINT +5;
if(currentButton10State == 1 & lastButton10State == 0){ // button is pressed
BITINGPOINT = BITINGPOINT -5;
if (BITINGPOINT>100){
BITINGPOINT = 100;
}else if (BITINGPOINT <0){
BITINGPOINT = 0;
lastButton6State = currentButton6State;
lastButton10State = currentButton10State;
//EG 07212021
preset01 = BITINGPOINT;
preset02 = BITINGPOINT;
preset03 = BITINGPOINT;
preset04 = BITINGPOINT;
//End
void setLedConfig(uint32_t color){
WS2812B_strip.setBrightness(50);
WS2812B_strip.setPixelColor(0,color);
WS2812B_strip.setPixelColor(1,color);
WS2812B_strip.setPixelColor(2,color);
WS2812B_strip.setPixelColor(15,color);
WS2812B_strip.setPixelColor(16,color);
WS2812B_strip.setPixelColor(17,color);
void setLedConfigSaved(uint32_t color){
WS2812B_strip.setPixelColor(3,color);
WS2812B_strip.setPixelColor(14,color);
void setLedConfigUnSaved(uint32_t color){
void clutchMaxCalibration(){
if (button7 == 1 & button8 == 1 & isMaxCalibrationBeenDone == 0){
MAXLH = 1023;
MAXRH = 1023;
clutchMaxCalibrationLed(0x00FFFF);
//Serial.println("CurrentMax");
//Serial.println(MAXLH);
isMaxCalibrationBeenDone = 1;
for (int i = 1; i<10000;i++){
//Serial.println(i);
CheckClutch();
if (AVERAGEDLH<MAXLH){
MAXLH =AVERAGEDLH;
if (AVERAGEDRH<MAXRH){
MAXRH =AVERAGEDRH;
MAXLH = MAXLH-2;
MAXRH = MAXRH-2;
//Serial.println("NexMax");
clutchMaxCalibrationLed(0x000000);
void clutchMinCalibration(){
if (button7 == 1 & button8 == 1 & isMinCalibrationBeenDone == 0){
MINLH = 1023;
MINRH = 1023;
clutchMinCalibrationLed(0x00FFFF);
//Serial.println("CurrentMin");
//Serial.println(MINLH);
isMinCalibrationBeenDone = 1;
CheckClutch();
//Serial.println(AVERAGEDLH);
if (AVERAGEDLH<MINLH){
MINLH =AVERAGEDLH;
if (AVERAGEDRH<MINRH){
MINRH =AVERAGEDRH;
MINLH = MINLH +2;
MINRH = MINRH +2;
clutchMinCalibrationLed(0x000000);
void clutchMaxCalibrationLed(uint32_t color){
WS2812B_strip.setBrightness(30);
WS2812B_strip.setPixelColor(4,color);
WS2812B_strip.setPixelColor(5,color);
WS2812B_strip.setPixelColor(6,color);
WS2812B_strip.setPixelColor(7,color);
WS2812B_strip.setPixelColor(8,color);
void clutchMinCalibrationLed(uint32_t color){
WS2812B_strip.setPixelColor(9,color);
WS2812B_strip.setPixelColor(10,color);
WS2812B_strip.setPixelColor(11,color);
WS2812B_strip.setPixelColor(12,color);
WS2812B_strip.setPixelColor(13,color);
//Upload Mode function
void UploadeModeChange(){
if (configMode == 0){
if (UploadingMode==0){
UploadingMode= 1;
setLedConfig(0xFF0000);
}else if (UploadingMode== 1){
UploadingMode= 0;
void switchUploadMode(){
UpcurrentButtonState = digitalRead(PinButton1);
if(UplastButtonState == HIGH && UpcurrentButtonState == LOW){ // button is pressed
UppressedTime = millis();
UppressStarted = 1;
if (UppressStarted ==1){
if (UpcurrentButtonState == LOW){
UpreleasedTime = millis();
long UppressDuration = UpreleasedTime - UppressedTime;
if( UppressDuration > 2000 ){
pressStarted = 0;
//Serial.println("Changing Mode to Uploading Mode");
UppressStarted = 0;
UploadeModeChange();
UplastButtonState = UpcurrentButtonState;
//EG 07202021 - Clutche Biting point preset
int currentbuttonClutchPresetState = 0;
int lastbuttonClutchPresetState = 0;
void changeClutchBitePreset (){
currentbuttonClutchPresetState = buttonClutchPreset;
if(currentbuttonClutchPresetState == 1 & lastbuttonClutchPresetState == 0){ // button is pressed
selectedPreset = selectedPreset +1;
if (selectedPreset>3){
selectedPreset =0;
printEnd();
printEnd();
printEnd();
printEnd();
printEnd();
printEnd();
printEnd();
printEnd();
lastbuttonClutchPresetState = currentbuttonClutchPresetState;
When I try to calibrate the analog signal (A0 and A1) with the Teensy 3.6 it works correctly but with the 4.1 it doesn't.
Compared to the video in the link (video) which is working with teensy 3.6 the LED switching times are much quicker
Furthermore, teensy 4.1 does not send information to the connected Nextion monitor.
I have only this problem the other function: button, pov, rotary and enter and out to configuration mode are ok
Does anyone have any advice for me on this.
You have the code below in your setup......
    Serial.begin(baud);
    rotary_initHalf();
    rotary_initFull();
    //EG 07212021
    if (selectedPreset == 0) {
.... it is likely that code after Serial.begin(baud) is executing before the Serial link is made, also, because the T4.1 is much faster than the T3.6, that you are talking to the WS2812B before they have completed their power up, reset sequence.
All this can be over come by having the following code with Serial.begin
    Serial.begin(baud);
    while( !Serial & millis()<3000); // waits for up to 3 seconds for Serial to be available.
As a side note, when you post code can you enclose it between code tags using the </> button.
I have done that with your code below:
//POV
#include <Bounce.h>
//--End
//Clutches
#define CLUTCHLH A1
#define CLUTCHRH A0
//Upload
    int incomingByte;
    if (HWSERIAL.available() > 0) {
int INDEXLH = 0;
int VALUELH = 0;
int SUMLH = 0;
int AVERAGEDLH = 0;
int INDEXRH = 0;
int VALUERH = 0;
int SUMRH = 0;
int AVERAGEDRH = 0;
int CLUTCH = 0;
int MAXLH = 1023;
int MINLH = 1023;
int MAXRH = 1023;
int MINRH = 1023;
int CLUTCHRANGELH;
int CLUTCHRANGERH;
int CLUTCHRANGE;
#include <EEPROM.h>
int configMode = 0;
int pressStarted = 0;
float BITINGPOINT;
//Used For saving
int button6;
int button10;
int button7;
int button8;
int preset01 = 35;
int preset02 = 45;
int preset03 = 55;
int preset04 = 65;
//End
//Upload Mode
int UppressStarted = 0;
int UploadingMode = 0;
//End
// How many leds
// Data pin
//From AMS studio
struct rotariesdefHalf {
    byte pin1;
    byte pin2;
    int ccwchar;
    int cwchar;
struct rotariesdefFull {
    byte pin1;
    byte pin2;
    int ccwchar;
    int cwchar;
{6,7,19,20,0},
{8,9,21,22,0},
{10,11,23,24,0},
//{2,3,14,15,0},
    //{4,5,28,29,0},
    {2,3,25,26,0},
    {4,5,27,28,0},
    {25,26,29,30,0},
    {12,24,31,32,0},
#define DIR_CW 0x20
#define R_START 0x0
    // R_START (00)
    // R_CCW_BEGIN
    // R_CW_BEGIN
    // R_START_M (11)
    // R_CW_BEGIN_M
    // R_CCW_BEGIN_M
    // R_START
    // R_CW_FINAL
    // R_CW_BEGIN
    // R_CW_NEXT
    // R_CCW_BEGIN
    // R_CCW_FINAL
    // R_CCW_NEXT
//End by EG
#include <Keypad.h>
byte rowPins[ROWS] = { 16, 18, 19, 20 }; //connect to the row pinouts of the keypad
byte colPins[COLS] = { 23,22,21 }; //connect to the column pinouts of the keypad
{2,3,4},
{5,6,7},
{8,9,10},
{11,12,13}
Keypad buttbx = Keypad(makeKeymap(keyMap), rowPins, colPins, ROWS, COLS);
        Serial.write(c);
byte r, g, b;
void ReadLeds() {
        r = Serial.read();
        g = Serial.read();
        b = Serial.read();
        else {
        WriteToComputer();
        Serial.read();
    newBaud = baud;
    MAXLH = EEPROM.read(MAXLHaddress) * 4;
    MAXRH = EEPROM.read(MAXRHaddress) * 4;
    MINLH = EEPROM.read(MINLHaddress) * 4;
    MINRH = EEPROM.read(MINRHaddress) * 4;
    //EG 07202021
    //End
    CLUTCHRANGELH = (MAXLH - MINLH);
    CLUTCHRANGERH = (MAXRH - MINRH);
    CLUTCHRANGE = CLUTCHRANGELH + CLUTCHRANGERH;
    pinMode(17, INPUT_PULLUP);
    pinMode(18, INPUT_PULLUP);
    pinMode(19, INPUT_PULLUP);
    pinMode(20, INPUT_PULLUP);
    Serial.begin(baud);
    while (!Serial & (millis() < 3000));
    rotary_initHalf();
    rotary_initFull();
    //EG 07212021
        printEnd();
        printEnd();
    if (selectedPreset == 1) {
        printEnd();
        printEnd();
    if (selectedPreset == 2) {
        printEnd();
        printEnd();
    if (selectedPreset == 3) {
        printEnd();
        printEnd();
    //end
int readSize = 0;
int messageend = 0;
        baud = newBaud;
        HWSERIAL.end();
    if (UploadingMode == 1) {
        UploadNextionHMI();
    else {
        switchUploadMode();
        switchMode();
        CheckClutch();
        CheckAllButtons();
        CheckPOV();
        if (configMode == 1) {
            configClutches();
        else {//Added by EG on 07202021 to avoid having Simhub overwriting Elemento
                WriteToComputer();
                            messageend++;
                        else {
                            messageend = 0;
                        command += c;
                            WriteToComputer();
                            command += c;
                            ReadLeds();
                            DisableLeds();
                        else {
                        command = "";
                        messageend = 0;
                    else {
                        HWSERIAL.write(c);
                else {
                    HWSERIAL.write(c);
#else
                HWSERIAL.write(c);
            WriteToComputer();
        for (int i = 0; i < LIST_MAX; i++)
            if (buttbx.key.stateChanged)
                case PRESSED:
                case HOLD:
                    //Added EG 23/03
                        //Added EG 07202021
                        if (buttbx.key.kchar == 4) {
                        if (buttbx.key.kchar == 6) {
                            button6 = 1;
                        if (buttbx.key.kchar == 10) {
                            button10 = 1;
                        if (buttbx.key.kchar == 7) {
                            button7 = 1;
                        if (buttbx.key.kchar == 8) {
                            button8 = 1;
                    //End
                case RELEASED:
                case IDLE:
                    //Added EG 072021
                    //Added EG 23/03
                        button6 = 0;
                        button10 = 0;
                        button7 = 0;
                        button8 = 0;
                    //End
//HalfStep
    for (int i = 0; i < NUMROTARIESHALF; i++) {
//End Half Step
//Full Step
    for (int i = 0; i < NUMROTARIESFULL; i++) {
//End Full Step
void CheckPOV() {
    button0.update();
    button1.update();
    button2.update();
    button3.update();
    button4.update();
    if (button0.fallingEdge() && digitalRead(PinButton1) == HIGH && digitalRead(PinButton2) == HIGH && digitalRead(PinButton3) == HIGH && digitalRead(PinButton4) == HIGH) { // This prevents an accidental PUSH IN to be activated if we are pushing the button Forward, Reverse, Left or Right
        Joystick.hat(0);
        Joystick.hat(270);
        Joystick.hat(180);
        Joystick.hat(90);
        Joystick.hat(-1);
        Joystick.hat(-1);
        Joystick.hat(-1);
        Joystick.hat(-1);
//End 07212021
int launchMode = 0;
void CheckClutch() {
    //Left Clutch
    INDEXLH = (INDEXLH + 1) % WINDOW_SIZE; // Increment the index, and wrap to 0 if it exceeds the window size
    AVERAGEDLH = SUMLH / WINDOW_SIZE; // Divide the sum of the window by the window size for the result
    //Right Clutch
    INDEXRH = (INDEXRH + 1) % WINDOW_SIZE; // Increment the index, and wrap to 0 if it exceeds the window size
    AVERAGEDRH = SUMRH / WINDOW_SIZE; // Divide the sum of the window by the window size for the result
    if (abs(AVERAGEDLHBEFORE - AVERAGEDLH) < 2) {
    if (abs(AVERAGEDRHBEFORE - AVERAGEDRH) < 2) {
    //End
    //EG 10/04/2021
    AVERAGEDLHMAPPED = map(MAXLH - AVERAGEDLH, 0, CLUTCHRANGELH, 0, 100);
    AVERAGEDRHMAPPED = map(MAXRH - AVERAGEDRH, 0, CLUTCHRANGERH, 0, 100);
    //End
    //EG 07212021
    AVERAGEDCLUTCH = (AVERAGEDRHMAPPED * BITINGPOINT / 100) + (AVERAGEDLHMAPPED * (1 - BITINGPOINT / 100));
    if (AVERAGEDCLUTCH < 0) {
        AVERAGEDCLUTCH = 0;
    if (AVERAGEDRHMAPPED > 5) {
        launchMode = 1;
    if (AVERAGEDCLUTCH == 0) {
        launchMode = 0;
    if (launchMode == 0) {
    else {
        AVERAGEDCLUTCH = 0;
    //End
    Joystick.Z(map(AVERAGEDCLUTCH, 0, 100, 0, 1023));
    delay(0);
//Config Functions
void configModeChange() {
    if (UploadingMode == 0) {
        if (configMode == 0) {
            configMode = 1;
            HWSERIAL.end();
            printEnd();
        else if (configMode == 1) {
            printEnd();
            HWSERIAL.end();
            configMode = 0;
int CLUTCHLHCONFIG;
int CLUTCHRHCONFIG;
void configClutches() {
    CheckClutch();
    //EG 07202021
    //End
    CLUTCHLHCONFIG = map(MAXLH - AVERAGEDLH, 0, CLUTCHRANGELH, 0, 100);
    CLUTCHRHCONFIG = map(MAXRH - AVERAGEDRH, 0, CLUTCHRANGERH, 0, 100);
    printEnd();
    printEnd();
    CLUTCHRHCONFIG = CLUTCHRHCONFIG * BITINGPOINT / 100;
    CLUTCHLHCONFIG = CLUTCHLHCONFIG * (1 - BITINGPOINT / 100);
    COMBINEDCLUTCHCONFIG = CLUTCHLHCONFIG + CLUTCHRHCONFIG;
    COMBINEDCLUTCHCONFIGTOSEND = COMBINEDCLUTCHCONFIG;
    printEnd();
    HWSERIAL.print(BITINGPOINT / 100);
    printEnd();
    saveClutchConfig();
void printEnd() {
void switchMode() {
    if (lastButtonState == HIGH && currentButtonState == LOW) { // button is pressed
        pressStarted = 1;
    if (pressStarted == 1) {
        if (currentButtonState == LOW) {
            if (pressDuration > 3000) {
                UppressStarted = 0;
                pressStarted = 0;
                configModeChange();
void saveClutchConfig() {
    if (button6 == 1 & button10 == 1 & isConfigAlreadyBeenSaved == 0) {
        EEPROM.write(MAXLHaddress, MAXLH / 4);
        EEPROM.write(MAXRHaddress, MAXRH / 4);
        EEPROM.write(MINLHaddress, MINLH / 4);
        EEPROM.write(MINRHaddress, MINRH / 4);
        EEPROM.write(BITINGPOINTaddress, BITINGPOINT);
        //EG 07212021
        EEPROM.write(BITINGPOINT01address, preset01);
        EEPROM.write(BITINGPOINT02address, preset02);
        EEPROM.write(BITINGPOINT03address, preset03);
        EEPROM.write(BITINGPOINT04address, preset04);
void UpdateBitingPoint() {
    //EG 07212021
    //End
    if (currentButton6State == 1 & lastButton6State == 0) { // button is pressed
        BITINGPOINT = BITINGPOINT + 5;
    if (currentButton10State == 1 & lastButton10State == 0) { // button is pressed
        BITINGPOINT = BITINGPOINT - 5;
    if (BITINGPOINT > 100) {
        BITINGPOINT = 100;
    else if (BITINGPOINT < 0) {
        BITINGPOINT = 0;
    //EG 07212021
    //End
void setLedConfig(uint32_t color) {
    WS2812B_strip.setPixelColor(0, color);
    WS2812B_strip.setPixelColor(1, color);
    WS2812B_strip.setPixelColor(2, color);
    WS2812B_strip.setPixelColor(15, color);
    WS2812B_strip.setPixelColor(16, color);
    WS2812B_strip.setPixelColor(17, color);
void setLedConfigSaved(uint32_t color) {
    WS2812B_strip.setPixelColor(3, color);
    WS2812B_strip.setPixelColor(14, color);
void setLedConfigUnSaved(uint32_t color) {
void clutchMaxCalibration() {
    if (button7 == 1 & button8 == 1 & isMaxCalibrationBeenDone == 0) {
        MAXLH = 1023;
        MAXRH = 1023;
        for (int i = 1; i < 10000; i++) {
            CheckClutch();
            if (AVERAGEDLH < MAXLH) {
                MAXLH = AVERAGEDLH;
            if (AVERAGEDRH < MAXRH) {
                MAXRH = AVERAGEDRH;
        MAXLH = MAXLH - 2;
        MAXRH = MAXRH - 2;
void clutchMinCalibration() {
    if (button7 == 1 & button8 == 1 & isMinCalibrationBeenDone == 0) {
        MINLH = 1023;
        MINRH = 1023;
            CheckClutch();
            if (AVERAGEDLH < MINLH) {
                MINLH = AVERAGEDLH;
            if (AVERAGEDRH < MINRH) {
                MINRH = AVERAGEDRH;
        MINLH = MINLH + 2;
        MINRH = MINRH + 2;
void clutchMaxCalibrationLed(uint32_t color) {
    WS2812B_strip.setPixelColor(4, color);
    WS2812B_strip.setPixelColor(5, color);
    WS2812B_strip.setPixelColor(6, color);
    WS2812B_strip.setPixelColor(7, color);
    WS2812B_strip.setPixelColor(8, color);
void clutchMinCalibrationLed(uint32_t color) {
    WS2812B_strip.setPixelColor(9, color);
    WS2812B_strip.setPixelColor(10, color);
    WS2812B_strip.setPixelColor(11, color);
    WS2812B_strip.setPixelColor(12, color);
    WS2812B_strip.setPixelColor(13, color);
void UploadeModeChange() {
            UploadingMode = 1;
        else if (UploadingMode == 1) {
            UploadingMode = 0;
void switchUploadMode() {
    if (UplastButtonState == HIGH && UpcurrentButtonState == LOW) { // button is pressed
        UppressStarted = 1;
    if (UppressStarted == 1) {
        if (UpcurrentButtonState == LOW) {
            if (UppressDuration > 2000) {
                pressStarted = 0;
                UppressStarted = 0;
void changeClutchBitePreset() {
    if (currentbuttonClutchPresetState == 1 & lastbuttonClutchPresetState == 0) { // button is pressed
        selectedPreset = selectedPreset + 1;
        if (selectedPreset > 3) {
            selectedPreset = 0;
        printEnd();
        printEnd();
        printEnd();
        printEnd();
        printEnd();
        printEnd();
        printEnd();
        printEnd();
I tried to load the sketch, inserting in some strings, otherwise it wouldn't pass the check, but the problem remains.
The only difference noted is that if I try to calibrate the signal as in the video I can make the signals go with 0-50-100% steps but in a single way and not in a summed way.
While as far as nextion is concerned, nothing seems to be missed
I copied your code into Arduino IDE. But it does not compile for Teensy 3.6 or Teensy 4.1. Error is regarding use of Keypad library.
Maybe you're using an old copy of Arduino IDE or Teensyduino? Or perhaps some other software?
i use Arduino IDE ver. 2.3.2 CLI: 0.35.3
library: esplora 1.0.1 - hx711_adc 1.2.12 - joystick 2.1.1
on tools i have setting usb type with serial+keyboard+mouse+joystick
cpu mhz to 528mhz
I use the app to install the library...
So I noticed that by changing the scheme the time is increased to read/record the analog signal, but the reading is only 0-50-100% for both signals and not linear. However, the signal is single (max a1=100 and max a2=100) and not added together (max a1+max a2=100 since max a1=50 and max A2=50 or based on how it is calibrated in the calibration procedure That too seems to work since from the control panel I see that if I press and adjust the bar as in the video above it goes to maximum or 0% but without other values)
