Posting Float array to database
Lavanya rajan
I'm attempting to upload two arrays of float values to a MySQL database table using Teensy 4.0 and ESP8266. Each array consists of 512 elements with precision up to two digits. However, upon uploading the code, I encounter the following error. Could anyone provide assistance in resolving this issue?
Attaching the code
#include <ArduinoJson.h>
String SSID = "xxxx";
String PASSWORD = "xxxx";
String HOST_NAME = "xxxx";
void sendCommand(String command, unsigned long timeout);
bool recFind(String target, uint32_t timeout, bool prntln);
  Serial1.begin(115200);
  delay(2000);
  flushSerial();
  delay(200);
  Serial.println(F("Started"));
  // Check communications with the ESP8266
  sendCommand("AT+GMR", 5000);
  sendCommand("AT", 5000);
  sendCommand("AT+CWMODE?", 5000);
  sendCommand("AT+CWMODE=1", 5000);
  // Join WiFi
  String joinstring = "AT+CWJAP=\"" + SSID + "\",\"" + PASSWORD + "\"";
  sendCommand(joinstring, 7000);
  // Get IP Address
  sendCommand("AT+CIFSR", 7000);
  StaticJsonDocument<8192> doc;
  JsonArray xvalues = doc.createNestedArray("x");
  JsonArray yvalues = doc.createNestedArray("y");
  // Populate arrays with float values
  for (int i = 0; i < 512; i++) {
    xvalues.add(round_range(i * 1.23));  // Add some arbitrary value as x values
    yvalues.add(round_range(i * 2.34));  // Add some arbitrary value as y values
  // Serialize JSON document
  String jsonPayload;
  serializeJson(doc, jsonPayload);
  // Send HTTP request
  sendCommand("AT+CIPSTART=\"TCP\",\"" + HOST_NAME + "\",80", 10000);
  String data = "POST /xxx/xxx.php HTTP/1.1\r\n";
  data += "Host: " + HOST_NAME + "\r\n";
  data += "Content-Type: application/json\r\n";
  data += "Content-Length: " + String(jsonPayload.length()) + "\r\n\r\n";
  data += jsonPayload;
  // Send the HTTP request
  String sendRequest = "AT+CIPSEND=" + String(data.length());
  sendCommand(sendRequest, 5000);
  sendCommand(data, 5000);
  delay(100); // Small delay between sending each array element
  // Wait for response from server
  if (recFind("CLOSED", 5000, true)) {
    Serial.println("CLOSED");
    Serial.println("No response from server");
void sendCommand(String command, unsigned long timeout) {
  Serial1.println(command);
  if (recFind("OK", timeout, true)) {
    Serial.println("Success: " + command);
    Serial.println("Failed: " + command);
void flushSerial() {
  while (Serial1.available() > 0) {
    Serial1.read();
bool recFind(String target, uint32_t timeout, bool prntln) {
  String rdBuff = "";
  unsigned long startMillis = millis();
  while (millis() - startMillis < timeout) {
      char rdChar = Serial1.read();
      rdBuff += rdChar;
      if (prntln) {
        Serial.write(rdChar);
      if (rdBuff.indexOf(target) != -1) {
        return true;
  return false;
double round_range(double value) {
  return (int)(value * 100 + 0.5) / 100.0;
Error I'm getting
AT+CIPSEND=7047
too long
ERROR
Failed: AT+CIPSEND=7047
I would guess that the data is TOO long for the esp8266 software to handle as written.
Have you examined the specification of the esp8266 AT software?
A quick look:
AT+CIPSEND Response Wrap return ">" after execute command. Enters unvarnished transmission, 20ms interval between each packet, maximum 2048 bytes per packet. When single packet containing "+++" is received, it returns to normal command mode. Please wait at least 1 second before sending next AT command. This command can only be used in transparent transmission mode which require to be single connection mode. For UDP transparent transmission, has to be 0 in command "AT+CIPSTART" Espressif Systems / Friday, May 13, 201
