Just to be clear the data I posted is from gyrotest2
Yes. But remember what I said about the error in your sketch for getting dcc and dy.
You have to set prevquat to currentquat after you calculate dcc and dy.
#include "quaternion.h"
#include "SparkFun_BNO080_Arduino_Library.h"
BNO080 myIMU;
#define X_AXIS_SENSITIVITY 50
#define Y_AXIS_SENSITIVITY 50
Serial.println("BNO080 Read");
Wire.begin();
if (myIMU.begin() == false)
Serial.println(F("BNO080 not detected at default I2C address. Check your jumpers and the hookup guide. Freezing..."));
while (1)
Wire.setClock(400000);
myIMU.enableGyroIntegratedRotationVector(5);
Serial.println("Started!!!");
imu::Quaternion prevQuat;
int dx = 0, dy = 0;
//Look for reports from the IMU
if (myIMU.dataAvailable() == true)
float dqw = myIMU.getQuatReal(); float dqx = myIMU.getQuatI(); float dqy = myIMU.getQuatJ(); float dqz = myIMU.getQuatK();
imu::Quaternion currQuat(dqw, dqx, dqy, dqz);
Serial.print(dqx, 2);
Serial.print(F(","));
Serial.print(dqy, 2);
Serial.print(dqz, 2);
Serial.println(dqw, 2);
Serial.printf("currQuat--> %2.2f, %2.2f, %2.2f, %2.2f, %2.2f\n", currQuat.w(), currQuat.x(), currQuat.y(), currQuat.z());
imu::Quaternion newQuat = currQuat * prevQuat.conjugate();
newQuat.normalize();
imu::Vector<3> euler = newQuat.toEuler();
dx = getValue(euler.z() * 180 / PI, X_AXIS_SENSITIVITY, false);
dy = getValue(euler.y() * 180 / PI, Y_AXIS_SENSITIVITY, false);
[B][COLOR="#FF0000"] prevQuat = currQuat;
[/COLOR][/B] Serial.printf("dx, dy: %d, %d\n", dx, dy);
int getValue(double val, double sensitivity, bool is_rotation)
constexpr double c[] = { 3e-1, 1e-1 };
return (int)round(val * sensitivity * c[unsigned(is_rotation)]);
@marcob - very cool project.
Ps this is the main sketch I am using that I fixed so the setting of the prevQuat is in the correct spot:
I highlighted in red where I moved your setting the currQuat to the prevQuat. You had it before the calculation so dx and dy would always be zero. Nothing else was changed that matter.Code:#include <Wire.h> #include "quaternion.h" #include "SparkFun_BNO080_Arduino_Library.h" BNO080 myIMU; #define X_AXIS_SENSITIVITY 50 #define Y_AXIS_SENSITIVITY 50 void setup() { Serial.begin(115200); Serial.println(); Serial.println("BNO080 Read"); Wire.begin(); if (myIMU.begin() == false) { Serial.println(F("BNO080 not detected at default I2C address. Check your jumpers and the hookup guide. Freezing...")); while (1) ; } Wire.setClock(400000); myIMU.enableGyroIntegratedRotationVector(5); Serial.println("Started!!!"); } imu::Quaternion prevQuat; int dx = 0, dy = 0; void loop() { //Look for reports from the IMU if (myIMU.dataAvailable() == true) { float dqw = myIMU.getQuatReal(); float dqx = myIMU.getQuatI(); float dqy = myIMU.getQuatJ(); float dqz = myIMU.getQuatK(); imu::Quaternion currQuat(dqw, dqx, dqy, dqz); /* Serial.print(dqx, 2); Serial.print(F(",")); Serial.print(dqy, 2); Serial.print(F(",")); Serial.print(dqz, 2); Serial.print(F(",")); Serial.println(dqw, 2); Serial.printf("currQuat--> %2.2f, %2.2f, %2.2f, %2.2f, %2.2f\n", currQuat.w(), currQuat.x(), currQuat.y(), currQuat.z()); */ imu::Quaternion newQuat = currQuat * prevQuat.conjugate(); newQuat.normalize(); imu::Vector<3> euler = newQuat.toEuler(); dx = getValue(euler.z() * 180 / PI, X_AXIS_SENSITIVITY, false); dy = getValue(euler.y() * 180 / PI, Y_AXIS_SENSITIVITY, false); [B][COLOR="#FF0000"] prevQuat = currQuat; [/COLOR][/B] Serial.printf("dx, dy: %d, %d\n", dx, dy); } } int getValue(double val, double sensitivity, bool is_rotation) { constexpr double c[] = { 3e-1, 1e-1 }; return (int)round(val * sensitivity * c[unsigned(is_rotation)]); }
[COLOR="#FF0000"] while(!Serial && millis() < 3000) ; // wait up to 3 seconds for the Serial port to be ready.[/COLOR]
Wire.begin();
[COLOR="#FF0000"] while(millis() < 3000) ; // Wait from startup 3 seconds before we try the IMU... [/COLOR]
while (myIMU.begin() == false)
delay(200);
Wonder what would happen if you put in a delay at startup... Maybe something like:
Code:void setup() { [COLOR="#FF0000"] while(!Serial && millis() < 3000) ; // wait up to 3 seconds for the Serial port to be ready.[/COLOR] Serial.begin(115200); Serial.println(); Serial.println("BNO080 Read"); Wire.begin(); [COLOR="#FF0000"] while(millis() < 3000) ; // Wait from startup 3 seconds before we try the IMU... [/COLOR] while (myIMU.begin() == false) { Serial.println(F("BNO080 not detected at default I2C address. Check your jumpers and the hookup guide. Freezing...")); delay(100); } Wire.setClock(400000); ...
Again not sure how you have setup. Example do you have the reset pin hooked up? If so I don't see anything setting the state of that pin.
Ditto I don't think you are using the interrupt pin...
I just gave the gyroTest2 sketch (no radio) with the following minor change:
it worked for me everytime - max tries i saw by pulling the usb cable out and putting it back in was 2, i.e, total 400ms. Most of the time it started on the second try every time it failed to detect.Code:while (myIMU.begin() == false) { Serial.println(F("BNO080 not detected at default I2C address. Check your jumpers and the hookup guide. Freezing...")); delay(200); }
Not sure why its not working for you - can you test the BNO080 with just that change with the radio. To make sure you don;t have some other problem
EDIT:
What library are you using for your radio?
TMRh20 2014
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
General Data Transfer Rate Test
This example demonstrates basic data transfer functionality with the
updated library. This example will display the transfer rates acheived
using the slower form of high-speed transfer using blocking-writes.
#include "RF24.h"
#include "printf.h"
/************* USER Configuration *****************************/
// Hardware configuration
RF24 radio(7, 8); // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
const uint64_t pipes[2] = { 0xABCDABCD71LL, 0x544d52687CLL }; // Radio pipe addresses for the 2 nodes to communicate.
byte data[32]; //Data buffer for testing data transfer speeds
unsigned long counter, rxTimer; //Counter and timer for keeping track transfer info
unsigned long startTime, stopTime;
bool TX = 1, RX = 0, role = 0;
void setup(void) {
printf_begin();
radio.begin(); // Setup and configure rf radio
radio.setChannel(1);
radio.setPALevel(RF24_PA_LOW); // If you want to save power use "RF24_PA_MIN" but keep in mind that reduces the module's range
radio.setDataRate(RF24_2MBPS);
radio.setAutoAck(1); // Ensure autoACK is enabled
radio.setRetries(2, 15); // Optionally, increase the delay between retries & # of retries
radio.setCRCLength(RF24_CRC_8); // Use 8-bit CRC for performance
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1, pipes[1]);
radio.startListening(); // Start listening
radio.printDetails(); // Dump the configuration of the rf unit for debugging
Serial.println(F("\n\rRF24/examples/Transfer/"));
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
randomSeed(analogRead(0)); //Seed for random number generation
for (int i = 0; i < 32; i++) {
data[i] = random(255); //Load the buffer with random data
radio.powerUp(); //Power up the radio
void loop(void) {
while (radio.available()) {
radio.read(&data, 32);
counter++;
if (millis() - rxTimer > 100) {
rxTimer = millis();
unsigned long numBytes = counter * 32;
Serial.print(F("Rate: "));
//Prevent dividing into 0, which will cause issues over a period of time
Serial.println(numBytes > 0 ? numBytes / 1000.0 : 0);
Serial.print(F("Payload Count: "));
Serial.println(counter);
counter = 0;
Hi guys, I am going crazy.
Could anyone of you please run this code and see if you have any issue?
I have also attached the arduino console during the uploading of the code
