derplecbob
Is it possible to hook up a 2w 28mm speaker directly to the mqsr and mqsl of the teensy 4.0 alone?
Demo of the audio sweep function.
The user specifies the amplitude,
start and end frequencies (which can sweep up or down)
and the length of time of the sweep.
Modified to eliminate the audio shield, and use MQS output. Because of the
use of fixed pins (10, 12), you probably cannot use the main SPI bus when you
are using the MQS output.
Pins: Teensy 4.0
MQSR: Pin 10
MQSL: Pin 12. */
#include <SerialFlash.h>
// GUItool: begin automatically generated code (edited by meissner afterwards).
AudioSynthToneSweep tonesweep; //xy=99,198
AudioMixer4 mixer2; //xy=280,253
AudioMixer4 mixer1; //xy=280,175
AudioOutputMQS mqs; //xy=452,189
AudioConnection patchCord1 (tonesweep, 0, mixer1, 0);
AudioConnection patchCord2 (tonesweep, 0, mixer2, 0);
AudioConnection patchCord3 (mixer2, 0, mqs, 1);
AudioConnection patchCord4 (mixer1, 0, mqs, 0);
const float t_ampx = 0.8;
const int t_lox = 10;
const int t_hix = 22000;
const float t_timex = 10; // Length of time for the sweep in seconds
// Do a sweep in both directions, enabling or disabling the left/right speakers
void do_sweep (int i)
int do_left = (i & 1) != 0;
int do_right = (i & 2) != 0;
float gain = (do_left && do_right) ? 0.5f : 1.0f;
Serial.printf ("Sweep up, left = %c, right = %c\n",
(do_left) ? 'Y' : 'N',
(do_right) ? 'Y' : 'N');
mixer1.gain (0, do_left ? gain : 0.0f);
mixer2.gain (0, do_right ? gain : 0.0f);
if (!tonesweep.play (t_ampx, t_lox, t_hix, t_timex)) {
Serial.println ("ToneSweep - play failed");
while (1)
// wait for the sweep to end
while (tonesweep.isPlaying ())
// and now reverse the sweep
Serial.printf ("Sweep down, left = %c, right = %c\n",
if (!tonesweep.play (t_ampx, t_hix, t_lox, t_timex)) {
Serial.println("ToneSweep - play failed");
while (1)
Serial.println ("Sweep done");
void setup(void)
// Wait for at least 3 seconds for the USB serial connection
Serial.begin (9600);
while (!Serial && millis () < 3000)
AudioMemory (8);
Serial.println ("setup done");
for (int i = 1; i <= 3; i++)
do_sweep (i);
Serial.println ("Done");
void loop (void)
Or would I choose one of them, and the other ground?
