System / VBAT register files
WMXZ
As during VLLS1 shutdown mode all SRAM data are lost and only the system and VBAT register files remain powered for critical user data (64 bytes total) , I was wondering if some has used this feature, or better, if all 64 bytes are freely available?
I think Frank B did something with this - I can't find that post now … searching "VBAT register file" got me here so far ...
4 bytes are used by the startup code, from 0x4003E01C to 0x4003E01F. These are used to remember if the RTC has been initialized after a cold boot using "stale" time info, and needs to be set again after a warm boot (presumably right after a code upload) when the time info is "fresh".
The rest should be available for any use.
If you really want those 4 bytes also, find and edit this code in mk20dx128.c.
        // RTC initialization
        if (RTC_SR & RTC_SR_TIF) {
                // this code will normally run on a power-up reset
                // when VBAT has detected a power-up.  Normally our
                // compiled-in time will be stale.  Write a special
                // flag into the VBAT register file indicating the
                // RTC is set with known-stale time and should be
                // updated when fresh time is known.
                #if ARDUINO >= 10600
                rtc_set((uint32_t)&__rtc_localtime);
                #else
                rtc_set(TIME_T);
                *(uint32_t *)0x4003E01C = 0x5A94C3A5;
        if ((RCM_SRS0 & RCM_SRS0_PIN) && (*(uint32_t *)0x4003E01C == 0x5A94C3A5)) {
                // this code should run immediately after an upload
                // where the Teensy Loader causes the Mini54 to reset.
                // Our compiled-in time will be very fresh, so set
                // the RTC with this, and clear the VBAT resister file
                // data so we don't mess with the time after it's been
                // set well.
                #else
                rtc_set(TIME_T);
                *(uint32_t *)0x4003E01C = 0;
