void decide_direction() {
//interrupts();
if(sensorTimer1 > sensorUpdate1){
telem << "Entering Decide Direction Test" << endl;
update_sensors();
sensorTimer1 = 0;
// No forward obstacles
if(hds > fowardheadThreshold && lls > sideSensorThreshold &&
lcs > lcThreshold && lrs > sideSensorThreshold &&
irF > lcIRthreshold) {
nextMove = "Straight";
//telem << "(DC) Next Move Straight" << endl;
// If everything is blocked in the forward direction lets backupSensorThreshold
// and run the Bubble rebound/VFH routing
else if(lls < sideSensorThreshold && lrs < sideSensorThreshold &&
(hds < fowardheadThreshold || lcs < lcThreshold
|| irF < lcIRthreshold)) {
moveBackward();
nextMove = "RunBubble";
//telem << "(DC) Everything blocked Next Move Backup" << endl;
// Special Cases
else if(lls < sideSensorThreshold && lrs == MAX_DISTANCE &&
hds < fowardheadThreshold && lcs < lcThreshold
&& irF < lcIRthreshold) {
//moveBackward();
//nextMove = "RunBubble";
//nextMove = "Left";
//turn_time = left_45;
nextMove = "Right";
turn_time = right_45;
else if(lrs < sideSensorThreshold && lls == MAX_DISTANCE &&
// moveBackward();
// nextMove = "RunBubble";
//nextMove = "Right";
//turn_time = right_45;
nextMove = "Left";
// Do any of the front facing range sensors detect an obstacle closer than their
// threshold? If so, then prepare to turn left or right. hds < fowardheadThreshold ||
//else if( lcs < lcThreshold || irF < lcIRthreshold)
// If head sensor is blocked (less than threshold) run bubble and be done with iter_swap
// else if(hds < fowardheadThreshold) {
else if(irF < lcIRthreshold || lcs < fowardheadThreshold
//moveBackward();
if(lls < lrs) { //If left is greater than right distance move left
//turn_time = left_45; //was 37
nextMove = "Right";
//telem << "(DC) Next Move is left (Center Blocked)" << endl;
//mLeft();
//delay(turn_time); //was 1500, 700, 225 - calc at 275 change to 325
//mStop();
//nextMove = "Straight";
} else if(lls > lrs){ //If right is greater than left distance move right
//turn_time = right_45; //was 37
nextMove = "Left";
//telem << "(DC) Next Move is right (Center Blocked)" << endl;
//mRight();
//mStop();
} else { //if all else fails run bubble band algorithm
//telem << "(DC) Next Move Determined by bubble [fwd sensors blocked - backup first]" << endl;
// What about the angled looking detectors?
// If right and center distances is less than threshold move left alot
else if(lls < sideSensorThreshold && lcs < fowardheadThreshold){
//turn_time = left_57;
nextMove = "Right";
turn_time = right_57;
//telem << "(DC) Next Move alot Left" << endl;
// If left and center distances is less than threshold move right alot
else if(lrs < sideSensorThreshold && lcs < fowardheadThreshold){
//turn_time = right_57;
nextMove = "Left";
//telem << "(DC) Next Move alot Right" << endl;
// If right distances is less than threshold and center not blocked
// move left a little
else if (lls < sideSensorThreshold && lcs > fowardheadThreshold)
//turn_time = left_37;
nextMove = "Right";
turn_time = right_37;
//telem << "(DC) Next Move Left" << endl;
// If left distance is less than threshold and center not blocked
// move right a little
else if(lrs < sideSensorThreshold && lcs > fowardheadThreshold)
//turn_time = right_37;
nextMove = "Left";
//telem << "(DC) Next Move Right" << endl;
// If we can't go forward, stop and take the appropriate evasive action.
if (nextMove != "Straight")
// lets stop and figure out what's next
mStop();
set_speed(turnSpeed);
//telem << lastMove << ", " << nextMove << endl << endl;
if(lastMove == "Right" && nextMove == "Left") {
nextMove == "Right";
turnCounter = turnCounter + 1;
//telem << "(OSC) Next Move Right" << endl;
} else if(lastMove == "Left" && nextMove == "Right") {
nextMove == "Left";
//telem << "(OSC) Next Move Left" << endl;
if(turnCounter != 0 && nextMove != "RunBubble"){
nextMove = lastMove;
//telem << "Actual Move: " << nextMove << endl << endl;
turn_timer = 0;
if (nextMove == "Right") {
mRight();
gDirection = DIRECTION_RIGHT;
smartDelay(turn_time); //was 1500, 700, 225 - calc at 275 change to 325
mStop();
send_telemetry();
} else if (nextMove == "Left") {
gDirection = DIRECTION_LEFT;
mLeft();
mStop();
send_telemetry();
} else if (nextMove == "RunBubble") {
turnCounter = 0;
mBackward();
smartDelay(200);
mStop();
Select_Direction();
lastMove = nextMove;
// If no obstacles are detected close by, keep going straight ahead.
lastMove = "Straight";
set_speed(speed);
//reset counters after clearing obstacle
turnCounter = 0;
mForward();
//keep moving forward until next obstacle is found
while(hds > fowardheadThreshold && lls > sideSensorThreshold &&
irF > lcIRthreshold && stasis_flag == 0) {
if(telem.available() > 0) {
int val = telem.read(); //read telem input commands
if(val == 't') {
//telem.println("toggle Roam Mode");
//noInterrupts();
toggleRoam();
return;
//telem << "(DC) End of Tests Updating Sensors" << endl << endl;
//Send telemetry data to radio
gDirection = DIRECTION_FORWARD;
getTicks();
send_telemetry();
if(sensorTimer > sensorUpdate){
telem << "While Loop for Going Straight" << endl;
update_sensors();
sensorTimer = 0;
//read_sensors();
//oneSensorCycle();
mStop();
if(stasis_flag == 1) stasis_correction();
