Lavanya rajan
I'm encountering unexpected behaviour with a Teensy 4.0 board. Currently, I'm utilizing it as the main controller on a custom PCB, integrating features such as analog voltage input, digital input and output, MAX31865 & MAX31855 interfaces, I2C interface, Serial2, and Serial1 interfaces. The PCB incorporates an alternative power supply to energize the Teensy board. The USB cable is used only for programming, rest of the time board shall work with alternative power supply. However, after uploading the code and disconnecting the USB cable, the board fails to execute the programmed instructions. For instance, even though I've uploaded code for digital output, the digital pins remain inactive until I reconnect the USB cable and open the serial monitor. Can anyone provide insights into this issue
