Hi, i've connected a bounch of components to a teensy 4.0 according to this diagram (i know that on the sd card slot positive and ground are swapped, that was made according to the footprint of the breackout board i used):
When i try to use the mpu6050 or the bmp280 i can't get a connection over i2c.
The connection are made trought a custom pcb designed around this schematic and it doesn't seam to be a connection kind of issue because i checked with a multimeter the continuity between i2c pins a power pins.
Any help will be apreciated.
