Bus 001 Device 003: ID 04f3:0191 Elan Microelectronics Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x04f3 Elan Microelectronics Corp.
idProduct 0x0191
bcdDevice 10.11
iManufacturer 4 ELAN
iProduct 14 Touchscreen
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 925
Report Descriptor: (length is 925)
Item(Global): Usage Page, data= [ 0x0d ] 13
Digitizer
Item(Local ): Usage, data= [ 0x04 ] 4
Touch Screen
Item(Main ): Collection, data= [ 0x01 ] 1
Application
Item(Global): Report ID, data= [ 0x01 ] 1
Item(Local ): Usage, data= [ 0x22 ] 34
Finger
Item(Main ): Collection, data= [ 0x02 ] 2
Logical
Item(Local ): Usage, data= [ 0x42 ] 66
Tip Switch
Item(Global): Logical Minimum, data= [ 0x00 ] 0
Item(Global): Logical Maximum, data= [ 0x01 ] 1
Item(Global): Report Size, data= [ 0x01 ] 1
Item(Global): Report Count, data= [ 0x01 ] 1
Item(Main ): Input, data= [ 0x02 ] 2
Data Variable Absolute No_Wrap Linear
Preferred_State No_Null_Position Non_Volatile Bitfield
Item(Main ): Input, data= [ 0x03 ] 3
Constant Variable Absolute No_Wrap Linear
Item(Global): Report Size, data= [ 0x06 ] 6
Item(Local ): Usage, data= [ 0x51 ] 81
Contact ID
Item(Global): Logical Maximum, data= [ 0x3f ] 63
Item(Global): Logical Maximum, data= [ 0xff 0x00 ] 255
Item(Global): Report Size, data= [ 0x08 ] 8
Item(Local ): Usage, data= [ 0x48 ] 72
Width
Item(Local ): Usage, data= [ 0x49 ] 73
Height
Item(Global): Usage Page, data= [ 0x01 ] 1
Generic Desktop Controls
Item(Global): Logical Maximum, data= [ 0xc0 0x0c ] 3264
Item(Global): Report Size, data= [ 0x10 ] 16
Item(Global): Unit Exponent, data= [ 0x0f ] 15
Unit Exponent: 15
Item(Global): Unit, data= [ 0x11 ] 17
System: SI Linear, Unit: Centimeter
Item(Local ): Usage, data= [ 0x30 ] 48
Direction-X
Item(Global): Physical Minimum, data= [ 0x00 ] 0
Item(Global): Physical Maximum, data= [ 0x00 0x01 ] 256
Item(Global): Report Count, data= [ 0x02 ] 2
Item(Global): Logical Maximum, data= [ 0x40 0x07 ] 1856
Item(Global): Physical Maximum, data= [ 0x90 0x00 ] 144
Item(Local ): Usage, data= [ 0x31 ] 49
Direction-Y
Item(Main ): End Collection, data=none
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Finger
Logical
Digitizer
Tip Switch
Contact ID
Width
Height
Unit Exponent: 15
Direction-X
Direction-Y
Digitizer
Item(Local ): Usage, data= [ 0x56 ] 86
(null)
Item(Global): Unit Exponent, data= [ 0x00 ] 0
Unit Exponent: 0
Item(Global): Unit, data= [ 0x00 ] 0
System: None, Unit: (None)
Item(Global): Logical Maximum, data= [ 0xff 0xff 0xff 0x7f ] 2147483647
Item(Global): Report Size, data= [ 0x20 ] 32
Item(Local ): Usage, data= [ 0x54 ] 84
Contact Count
Item(Global): Logical Maximum, data= [ 0x7f ] 127
Item(Global): Report ID, data= [ 0x0a ] 10
Item(Local ): Usage, data= [ 0x55 ] 85
Maximum Contact Number
Item(Global): Logical Maximum, data= [ 0x0a ] 10
Item(Main ): Feature, data= [ 0x02 ] 2
Item(Global): Report ID, data= [ 0x44 ] 68
Item(Global): Usage Page, data= [ 0x00 0xff ] 65280
(null)
Item(Local ): Usage, data= [ 0xc5 ] 197
(null)
Item(Global): Report Count, data= [ 0x00 0x01 ] 256
Item(Global): Usage Page, data= [ 0xff 0x01 ] 511
(null)
Item(Local ): Usage, data= [ 0x01 ] 1
(null)
Application
Item(Global): Report ID, data= [ 0x02 ] 2
Item(Global): Report Count, data= [ 0x40 ] 64
Item(Local ): Usage, data= [ 0x00 ] 0
(null)
(null)
(null)
Application
Item(Global): Report ID, data= [ 0x03 ] 3
Item(Global): Report Count, data= [ 0x1f ] 31
(null)
Item(Main ): Output, data= [ 0x02 ] 2
Item(Global): Usage Page, data= [ 0x01 0xff ] 65281
(null)
(null)
Application
Item(Global): Report ID, data= [ 0x04 ] 4
Item(Global): Report Count, data= [ 0x13 ] 19
(null)
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 10
Device Status: 0x0001
Self Powered
