Trying to implement FOTA on Teensy 4.0
Hello,
Hello,
We have a Teensy 4.0 running with an Android tablet application. The tablet application has an Android app that controls (via command/response) the Teensy 4.0. The connection between the tablet and Teensy 4.0 is made through a Micro USB cable on the Teensy side and a USB-C cable to the tablet. The tablet is connected to the Internet.
I am trying to implement Firmware Over the Air (FOTA) on the Teensy 4.0 via USB. For this, I am using FlasherX, based on the link shared here https://github.com/joepasquariello/FlasherX . My process is as follows:
  1. First, I flash the FlasherX.ino file using the Arduino IDE.
  2. Then, I use the TeraTerm software to upload the .hex file generated by the Arduino IDE for FlasherX.ino.
However, when uploading the file, I receive the error shown below.
Could you please confirm whether I am following the correct steps and assist me in resolving this issue?
I'm not sure what's wrong, but can you please do a restore to factory blink program and then try to repeat the process? It looks like you may have some data in upper flash that is preventing FlasherX from creating a sufficient buffer.
You can find instructions to do the factory reset on this page (https://www.pjrc.com/store/teensy40.html) in the section labeled Programming.
The message "abort - new code missing string fw_teensy40" is also relevant. As a sanity check, FlasherX *REQUIRES* that string to be present in the hex file to ensure that the correct hardware is being flashed
@thebigg is correct, and that string *should* be in the file if you build the FlasherX example sketch with no changes to the source file. Perhaps you made some changes? You'll have to tell us more for us to help you solve the issue.
FlasherX assumes that your new code that you are uploading also includes FlasherX, after all why would you want to upgrade to a firmware that can't be upgraded again?
If you have a basic flasherX bootloader (FlasherX.ino) that loads your main application but your main application doesn't include flasherX (or includes it but doesn't then use it so the compiler optimised it out) then this is exactly the error you would expect to see.
There are three options:
1) Change the bootloader code to remove the check.
2) Include the string as a constant somewhere in your code (make sure it can't get optimised out).
3) Include flasherX in your main application so that it can update itself, this will result in the string being included automatically.
edit - you indicate that you're trying to upload the same code as is already running. This should work fine. Are you sure you're uploading the same .hex file and it was built for a teensy 4.0?
The check is that the board name is in the file. In order to check that it's correct the code must contain the string to look for which means by definition the correct string should be in there. Which means either a) you're using a different file or b) the compiler has done some very sneaky optimisation.
In your init() code add Serial.println(FLASH_ID); that will force it to print out the flash ID it thinks is correct for this board which in turn should stop it from trying to optimise the string out. You will need to #include "FlashTxx.h" if you aren't already for this to be defined.
Thank you for your reply. However, I need to implement the OTA feature in an Android application, not on a Windows system. Is there a solution for this? The entire flashing process needs to be managed through the Android app, with no involvement of a Windows system.
Is there any .apk file for FlasherX which will support android?
FlasherX provides only the Teensy side of the firmware update. It does not specify how the new firmware is moved to the Teensy, and it does not provide any host support for Windows or Android or MAC or anything else. If you have a terminal emulator for Android, it may have a file transfer capability that could be used in the same way that I use TinyTerm for Windows.
Did you ever manage the ota?
I have a similar situation to what you had described and had to bite the bullet, So I wrote an android app for flashing the t4.1. albeit I have not tested with the t4.0 and haven't bothered with anything lower as this is purely a production/tech app, but it would not be a difficult task to add the required functionality for t4.0 and lower
