#define AUDIO_kHz ((int) AUDIO_SAMPLE_RATE / 1000)
#define AUDIO_CHANNELS USB_AUDIO_NO_CHANNELS_480
extern "C"
struct usb_string_descriptor_struct
uint8_t bLength;
uint8_t bDescriptorType;
uint16_t wString[6+1+1+2+1];
usb_string_descriptor_struct usb_string_serial_number={
2+(6+1+1+2+1)*2,3,
{'A','u','d','i','o','-','0'+AUDIO_CHANNELS,'/','0'+(AUDIO_kHz / 10),'0' + (AUDIO_kHz % 10),'B'}
AudioSynthWaveform wav1; //xy=260,158
AudioSynthWaveform wav2; //xy=265,194
AudioSynthWaveform wav3; //xy=267,232
AudioSynthWaveform wav4; //xy=271,269
AudioSynthWaveform wav5; //xy=275,307
AudioSynthWaveform wav6; //xy=280,343
AudioSynthWaveform wav7; //xy=284,380
AudioSynthWaveform wav8; //xy=288,418
AudioInputUSBOct usb_oct_in; //xy=305,509
AudioRecordWAVoct recordWAVoct; //xy=569,599
AudioMixer4 mixer1; //xy=575,417
AudioMixer4 mixer2; //xy=580,489
AudioMixer4 mixer3; //xy=717,467
AudioOutputI2S i2sOut; //xy=810,344
AudioOutputUSBOct usb_oct_out; //xy=813,249
AudioConnection patchCord1(wav1, 0, usb_oct_out, 0);
AudioConnection patchCord2(wav1, 0, i2sOut, 0);
AudioConnection patchCord3(wav2, 0, usb_oct_out, 1);
AudioConnection patchCord4(wav3, 0, usb_oct_out, 2);
AudioConnection patchCord5(wav4, 0, usb_oct_out, 3);
AudioConnection patchCord6(wav5, 0, usb_oct_out, 4);
AudioConnection patchCord7(wav6, 0, usb_oct_out, 5);
AudioConnection patchCord8(wav7, 0, usb_oct_out, 6);
AudioConnection patchCord9(wav8, 0, usb_oct_out, 7);
AudioConnection patchCord10(usb_oct_in, 0, mixer1, 0);
AudioConnection patchCord11(usb_oct_in, 0, recordWAVoct, 0);
AudioConnection patchCord12(usb_oct_in, 1, mixer1, 1);
AudioConnection patchCord13(usb_oct_in, 1, recordWAVoct, 1);
AudioConnection patchCord14(usb_oct_in, 2, mixer1, 2);
AudioConnection patchCord15(usb_oct_in, 2, recordWAVoct, 2);
AudioConnection patchCord16(usb_oct_in, 3, mixer1, 3);
AudioConnection patchCord17(usb_oct_in, 3, recordWAVoct, 3);
AudioConnection patchCord18(usb_oct_in, 4, mixer2, 0);
AudioConnection patchCord19(usb_oct_in, 4, recordWAVoct, 4);
AudioConnection patchCord20(usb_oct_in, 5, mixer2, 1);
AudioConnection patchCord21(usb_oct_in, 5, recordWAVoct, 5);
AudioConnection patchCord22(usb_oct_in, 6, mixer2, 2);
AudioConnection patchCord23(usb_oct_in, 6, recordWAVoct, 6);
AudioConnection patchCord24(usb_oct_in, 7, mixer2, 3);
AudioConnection patchCord25(usb_oct_in, 7, recordWAVoct, 7);
AudioConnection patchCord26(mixer1, 0, mixer3, 0);
AudioConnection patchCord27(mixer2, 0, mixer3, 1);
AudioConnection patchCord28(mixer3, 0, i2sOut, 1);
AudioControlSGTL5000 sgtl5000; //xy=830,388
AudioSynthWaveform* wavs[] = {
&wav1,
&wav2,
&wav3,
&wav4,
&wav5,
&wav6,
&wav7,
&wav8
AudioMixer4* mixers[] = {&mixer1,&mixer2};
uint32_t ledOff;
pinMode(LED_BUILTIN,OUTPUT);
AudioMemory(150 * 128 / AUDIO_BLOCK_SAMPLES); // empirical calculation!
while (!Serial)
if (CrashReport)
Serial.print(CrashReport);
while (!SD.begin(BUILTIN_SDCARD))
Serial.println("SD wait...");
delay(250);
// At 8/96, we're generating 1,536,000 bytes/sec,
// so a 128kB buffer will give an SD write every
// 42.6ms - can be marginal on even a good card!
recordWAVoct.createBuffer(128*1024,AudioBuffer::inHeap);
// sgtl5000.setAddress(HIGH);
sgtl5000.enable();
sgtl5000.volume(0.05f);
for (int i=0;i<8;i++)
wavs[i]->begin(0.5f,220.0f + 110.0f*i,WAVEFORM_TRIANGLE);
wavs[i]->phase(15.0f*i);
for (int i=0;i<2;i++)
for (int j=0;j<4;j++)
mixers[i]->gain(j,0.25f);
Serial.printf("Audio block size %d samples; sample rate %.2f; %d channels\n",AUDIO_BLOCK_SAMPLES,AUDIO_SAMPLE_RATE_EXACT,AUDIO_CHANNELS);
Serial.println("Running");
uint32_t lastBlocks;
int idx;
#define BUFL 20
char sbuf[BUFL], filename[BUFL+6];
void startRecording(void)
sprintf(filename, "%s.wav", sbuf);
recordWAVoct.record(filename);
Serial.printf("Recording %s\n", filename);
void stopRecording(void)
recordWAVoct.stop();
Serial.println("Recording stopped");
while (Serial.available() > 0)
char ch = Serial.read();
if ('\n' == ch)
if (idx > 0)
sbuf[idx] = 0;
startRecording();
idx = 0;
stopRecording();
continue;
sbuf[idx] = ch;
if (idx < BUFL-1)
idx++;
if (millis() > ledOff)
digitalWrite(LED_BUILTIN,0);
if (millis() - lastBlocks > 500)
const char* rec = recordWAVoct.isRecording()?"; rec":"";
lastBlocks = millis();
Serial.printf("Blocks %d; max %d%s\n",AudioMemoryUsage(),AudioMemoryUsageMax(),rec);
AudioMemoryUsageMaxReset();
