I'm unfortunately seeing a MIDI issue in the USBHost_T3.6 library. With moderate levels of MIDI traffic between and host Teensy 3.6 and multiple child MIDI devices (T3.2), the host eventually hangs, usually after a few minutes, depending on how heavy the traffic is.
My tests have shown that this is related to a change to make sending MIDI faster.
https://github.com/PaulStoffregen/USBHost_t36/commit/cd4c2772096d49a134114a68e954350fc9430db4
During the debugging of the USB MassStorage driver several months back, a potential race condition with the USBDriverTimer was found, and I suspect this is the issue I'm seeing.
https://forum.pjrc.com/threads/5582...er-Experiments?p=323027&viewfull=1#post323027
After removing the changes in the above commit, a MIDI stress test I've been using has been running for over an hour without locking up.
Interestingly, I apparently brought this up 2 years ago, and then got sidetracked by another bug, only to be dupped again when I updated the usbhost library.
https://forum.pjrc.com/threads/6621...ormance-Issues?p=293367&viewfull=1#post293367
Here's the code I used for testing, both the host and child devices are set to MIDI USB type. First for the host:
And here's some code for multiple child devices that should be connected via a USB hub in the host port:
#include <USBHost_t36.h>
#include <stdint.h>
#define LEDPIN 5
#define TIME_BETWEEN_MIDI 5
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
#define NUM_CHILDREN 4
MIDIDevice_BigBuffer midi1(myusb);
MIDIDevice_BigBuffer midi2(myusb);
MIDIDevice_BigBuffer midi3(myusb);
MIDIDevice_BigBuffer midi4(myusb);
MIDIDevice_BigBuffer* midi[NUM_CHILDREN] = { &midi1, &midi2, &midi3, &midi4 };
bool ledOn = false;
elapsedMillis lastSentTime;
elapsedMillis ledTime;
delay(1500);
myusb.begin();
pinMode(LEDPIN, OUTPUT);
myusb.Task();
for (int i = 0; i < NUM_CHILDREN; i++) {
if (*midi[i]) {
midi[i]->read();
static bool sentNoteOn = false;
if (lastSentTime > TIME_BETWEEN_MIDI) {
lastSentTime = 0;
if (sentNoteOn) {
sendToHostMIDIDevices(0x80, 10, 10, 19);
sentNoteOn = false;
else {
sendToHostMIDIDevices(0x90, 10, 10, 10);
sentNoteOn = true;
if (ledTime > 100) {
ledTime = 0;
ledOn = !ledOn;
digitalWrite(LEDPIN, ledOn);
usbMIDI.read();
void sendToHostMIDIDevices(uint8_t type, uint8_t note, uint8_t vel, uint8_t chan) {
for (int i = 0; i < 4; i++) {
if (*midi[i]) {
switch (type) {
case 0x90:
midi[i]->sendNoteOn(note, vel, chan);
case 0x80:
midi[i]->sendNoteOff(note, vel, chan);
default:
#include <stdint.h>
#define LEDPIN 5
bool ledOn = false;
#define CHILD_SEND_MIDI
#define TIME_BETWEEN_MIDI 40
delay(1500);
#ifdef CHILD_SEND_MIDI
lastSentTime = 0;
if (sentNoteOn) {
usbMIDI.sendNoteOff(10, 10, 10);
sentNoteOn = false;
else {
usbMIDI.sendNoteOn(10, 10, 10);
sentNoteOn = true;
if (ledTime > 500) {
ledTime = 0;
ledOn = !ledOn;
if (usbMIDI.read()) {
ledTime = 0;
ledOn = !ledOn;
