thecomfychair
I'm trying to use the Adafruit_VS1053 library which is included with Teensyduino 1.56 on a Teensy 4.1. Unfortunately, the player_simple example does not compile, returning these errors:
The SREG error disappears if I use the latest version of the library from Adafruit (downloaded using the Arduino Library Manager). However, the conversion issues remain.
The errors disappear if I change the board to a Teensy 3.6, so I'm guessing this is a AVR vs ARM issue - beyond that it's well above my head unfortunately!
Has anyone tried to port this to a T4.1?
Otherwise, can anyone recommend another library to use for the VS1053?
(I'm not using the Adafruit breakout board since we already have an SD reader on the T4.1)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp: In member function 'void Adafruit_VS1053_FilePlayer::feedBuffer()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp:218:14: error: 'SREG' was not declared in this scope
sregsave = SREG;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp: In constructor 'Adafruit_VS1053::Adafruit_VS1053(int8_t, int8_t, int8_t, int8_t, int8_t, int8_t, int8_t)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp:280:14: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
clkportreg = portOutputRegister(digitalPinToPort(_clk));
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp:282:15: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
misoportreg = portInputRegister(digitalPinToPort(_miso));
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_VS1053\Adafruit_VS1053.cpp:284:15: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
mosiportreg = portOutputRegister(digitalPinToPort(_mosi));
