jim lee
I comment out the Serial.begin() line and it still goes! I can't shut it down. Has anyone ran into this before?
Thanks!
-jim lee
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ILI9341.h> // Hardware-specific library
#include <colorObj.h>
#include <idlers.h>
#include <lists.h>
#include <mapper.h>
#include <multiMap.h>
#include <runningAvg.h>
#include <timeObj.h>
#include <adafruit_1947_Obj.h>
#include <bmpObj.h>
#include <displayObj.h>
#include <drawObj.h>
#include <label.h>
#include <screen.h>
#define TEXT_SIZE 2
#define LEFT_EDGE 36
#define BASELINE1 127
#define BASELINE2 237
#define PRECISION 1
#define TEXT_WIDTH 91
#define TEXT_HEIGHT 14
#define vacummPin A4
label vOutVac(LEFT_EDGE,BASELINE1,TEXT_WIDTH,TEXT_HEIGHT,"-000.0");
label vOutLeak(LEFT_EDGE,BASELINE2,TEXT_WIDTH,TEXT_HEIGHT,"-000.0");
mapper data2voltMapper(0, 1024, 0.0049, 5); // Update for 3.2V chip
mapper volt2psiMapper(0.2,4.5,-16.7,0);
mapper psi2hgMapper(-14.734624,2.2,30,-4.4792455);
float lastRead = 0;
timeObj mTimer(500);
void setup(void) {
point destPt;
colorObj labelColor;
/*Serial.begin(9600);while(!Serial);*/
Serial.println("init Screen..");
if (initScreen(ADAFRUIT_1947,PORTRAIT)) {
Serial.println("Success!");
screen->fillScreen(&black);
destPt.x = 0;
destPt.y = 0;
bmpObj mBitmap("vacPnl.bmp",destPt);
mBitmap.getInfo();
if (mBitmap.haveInfo){
Serial.println("Found bitmap, plotting..");
//mBitmap.outputInfo();
mBitmap.plotBmp();
Serial.println("Done plotting..");
Serial.println("No bitmap!");
Serial.println("Fail! Halting..");
while(true);
labelColor.setColor(&green);
labelColor.blend(&black,30);
vOutVac.setTextSize(TEXT_SIZE);
vOutVac.setJustify(TEXT_RIGHT);
vOutVac.setPrecision(PRECISION);
vOutVac.setColors(&labelColor);
viewList.addObj(&vOutVac);
//screen->drawRect(LEFT_EDGE,BASELINE1,TEXT_WIDTH,TEXT_HEIGHT,&red);
vOutLeak.setTextSize(TEXT_SIZE);
vOutLeak.setJustify(TEXT_RIGHT);
vOutLeak.setPrecision(PRECISION);
vOutLeak.setColors(&labelColor);
viewList.addObj(&vOutLeak);
//screen->drawRect(LEFT_EDGE,BASELINE2,TEXT_WIDTH,TEXT_HEIGHT,&red);
mTimer.start();
void readings(void) {
int sensorValue;
float volts;
float psi;
float inHg;
float leakdown;
sensorValue = analogRead(vacummPin);
volts = data2voltMapper.Map(sensorValue);
psi = volt2psiMapper.Map(volts);
inHg = psi2hgMapper.Map(psi);
vOutVac.setValue(inHg);
if (mTimer.ding()) {
mTimer.stepTime();
leakdown = (lastRead - inHg) * 120.0;
if (leakdown>999.9) {
vOutLeak.setValue("+++.+");
else if (leakdown<-999.99) {
vOutLeak.setValue("---.-");
else {
vOutLeak.setValue(leakdown);
lastRead = inHg;
void loop(void) {
idle();
readings();
Thanks!
-jim lee
