KrisKasprzak
I have a DC motor controller that requires a 0-5 VDC input to vary the PWM for a DC motor controller. I bought a motorcycle-style handgrip to control the controller. Unfortuntatly the handgrip is based on a 49E hall sensor and outputs 0.8 to 4.2 VDC. Meaning the controller will never shut the motor off, or drive to full on.
My main requirement is that the throttle must be spring loaded to automatically turn off if the hand is removed.
I'm guessing I can build a simple circuit with an OP-AMP to bias the signal down, then amplify it up to get an output of 0-5. Maybe there is another way, but I'm not sure. Or maybe someone knows of a throttle that is potentiometer based?
Here's where you come in...if such conversion is possible, anyone wanna draw up a schematic?
Thanks in advance.
Link to controller
Link to throttle
Thanks in advance.
Link to controller
Link to throttle
