The following is a github repository with KiCAD files for a dual +/-5V supply that can be driven from USB power.
github repository for dual supply
When designing for microcontroller boards, it is tempting to try to do as much as you can with single ended supply. But there are some designs that are just hard to do without a negative rail. Here is a design that provides filtered positive and negative power from USB power. I have been using the negative side circuit for years and simply filtering the daylights out of the 5V supply. But recently i wanted to go for super low noise in a very high gain current to voltage amplifier, so it was finally time to spin a proper dual supply. I have built a few of them so far, they seem to work, but as always no guarantees or warranties implied or provided.
I don't have a picture handy, but it really does look like its rendering The jumpers are in case you want to run just one side or the other.
