Problem trying to read OV7670 camera under IRQ Teensy 4.0
I think the pin definitions in OV7670_MB are commented out. They should have been removed as they are not used.
The output is an 640 x 480 array of 16-bit RGB565 values. My PC host converts that frame to an array of RGB888 values for PC display. As I said, distributing PC executables is a questionable thing, so I'm thinking about code to write files to the SD in .bmp format.
It would be interesting to see if a Python program using PySerial could capture a transfer from the T4.1. That would solve the executable distribution problem and result in a nice cross-platform option. Alas, my Python skills are still at the "Hello World" stage.
@mborgerson - any chance you are on Windows - or using MSFT Visual Studio? myself, KurtE and afaik mjs513 are all current with that for projects on Windows like @luni does.
You posted what seemed a PC displayer app of some sort ...
Overrun with distractions here - have not even gotten the labels printed to solder against yet.
Ok just want to check I2C address but when I run I2c scanner it doesnt see the camera?
According to the code it should be:
// define I2C address for OV7670
static int const camAddress = 0x21; // i2c address of camera's sccb device
Just hooked up sda, scl, 3.3v and GND and ran scanner and got no i2c devices found. THought it s 0x21 as well
Tried with and without- going to try again though - 2.2k if i remember your note
(understood) 2.2K was typical for 3.3V - though @mBorg used 4K in his note.
Maybe one of the other lines is needed to be set properly and isn't? Reset? ???
Thanks,
Actually both sets were in comment blocks, but different. The one you used just happened to be the ones I had setup earlier so worked.
Have not done anything since posting... Changing tractor oil...
Will play again :D
Note: I did not add any and so far have not appeared to run into issues. Maybe I will throw on a QWIIC device to have it's resistors added
I'm using Arduino 1.8.13 on Win10x64.
I've added some code to save the bitmap to a .bmp file on the SD card so you can plug it in to your PC to view the image.
//  t4.1 PIN input  and image packet test
//  New CameraBB with new pinouts for wired breadboard
//  Use this version with an SD card to save your image
//  MJB  10/27/2020
#include <stdint.h>
#define FRAME_WIDTH 640l
#define FRAME_HEIGHT 480l
#define FB_WIDTH 640l
#define FB_HEIGHT 480l
#define FB_COUNT 2  // two frames in EXTMEM
#define FRAMEBYTES (FRAME_WIDTH * FRAME_HEIGHT *2)
#define FRAMEBUFFBYTES (FB_WIDTH *FB_HEIGHT *2)
uint8_t fb1[FRAMEBUFFBYTES] EXTMEM;
uint8_t fb2[FRAMEBUFFBYTES] EXTMEM;
uint32_t masterfreq = 24;
volatile uint32_t last_csistat, csiIrqCount;
volatile uint32_t fb1count, fb2count;
volatile uint32_t bswitcherrors;
uint32_t framecount;
const char compileTime [] = " Compiled on " __DATE__ " " __TIME__;
const int ledpin    = 13;
const int imarkpin = 32;
const int pinCamReset = 14;
// this file header structure needs to be packed because of the first uin16_t being
// followed by a uint32_t.  Without packing you get 2 0x00 bytes after the bfType.
# pragma pack (2)
typedef struct  tBMPHDR565{
  uint16_t  bfType = 0x4d42;   //'bm';
  uint32_t  bfSize = 614466;// 614400 pixels + 66 header
  uint16_t  bfReserved1 = 0;
  uint16_t  bfReserved2 = 0;
  uint32_t  bfOffBits =  66; // 14 bytes to here
  uint32_t  biSize = 40;
  int32_t   biWidth = 640;
  int32_t   biHeight = -480;  // windows wants negative for top-down image
  int16_t   biPlanes = 1;
  uint16_t  biBitCount = 16 ;
  uint32_t  biCompression = 3;  // bitfields used
  uint32_t  biSizeImage = 614400;  // 640 * 480 * 2
  int32_t   biXPelsPerMeter = 0;
  int32_t   biYPelsPerMeter = 0;
  uint32_t  biClrUsed  = 0;
  uint32_t  biClrImportant = 0;// 54 bytes
  uint32_t  rmask = 0x0000F800;
  uint32_t  gmask = 0x000007E0;
  uint32_t  bmask = 0x0000001F;  //66 bytes
} BMPHDR565;
tBMPHDR565 fileheader;
File bmpfile;
#define  LEDON digitalWriteFast(ledpin, HIGH); // Also marks IRQ handler timing
#define  LEDOFF digitalWriteFast(ledpin, LOW);
#define  LEDTOGGLE digitalToggleFast(ledpin);
#define  IMARKHI digitalWriteFast(imarkpin, HIGH); // Also marks IRQ handler timing
#define  IMARKLO digitalWriteFast(imarkpin, LOW);
#define  IMARKTOGGLE digitalToggleFast(imarkpin);
  delay(200);
  Wire.begin();
  pinMode(ledpin, OUTPUT);
  pinMode(imarkpin, OUTPUT);
  pinMode(pinCamReset, OUTPUT);
  if (!SD.begin(BUILTIN_SDCARD)) {
    Serial.println("initialization failed!");
    while (1){
        LEDON; delay(100);
        LEDOFF; delay(100);
  Serial.println("initialization done.");
  memset(&fb1, 0, FRAMEBUFFBYTES * 2);
  digitalWriteFast(pinCamReset, LOW);
  delay(10);
  digitalWriteFast(pinCamReset, HIGH);  // subsequent resets via SCB
  Serial.printf("\n\nOV7670 Camera Test 3 %s\n", compileTime);
   cameraBegin(640, 480, fb1, fb2);
   Serial.printf("Size of file header is %u\n",sizeof(fileheader));
  static uint32_t lastfc;
  static uint32_t fc = 0;
  char ch;
  if(Serial.available()){
    ch = Serial.read();
    if (ch == 's') CMSI();
    if (ch == 'c') CMCS();
    if (ch == 'r') CMCR();
    if (ch == 'f') CMGF();
  //  This extends frame count from 16 to 32 bits
  fc  = CSI_CSICR3 >> 16; // get the 16-bit frame count
  framecount += (fc - lastfc);
  lastfc = fc;
// Show information
void CMSI(void) {
  Serial.printf("buff1 at %p   buff2 at %p\n", &fb1, &fb2);
  Serial.printf("Camera frame count = %lu \n", framecount);
  Serial.printf("Base Address Change errors: %lu\n", bswitcherrors);
  Serial.printf("csistat: %08X, csiIrqCount: %lu\n", CSI_CSISR, csiIrqCount);
  Serial.printf("fb1 count: %6lu   fb2 count %6lu\n",fb1count,fb2count);
void CMCS(void) {  // Show CSI registers
  print_csi_registers();
// Show Camera Registers
void CMCR(void) {
  uint8_t regs[200];
  cameraReadAll(regs);
  cameraShowAll(regs);
// Get a frame of data and write to .bmp file
void CMGF(void) {
  uint32_t imagesize, fbc;
  imagesize = (FRAME_WIDTH * FRAME_HEIGHT * 2);
  fbc = fb2count;
  while (fbc == fb2count); // wait until a new frame in fb2 is finished
  // Don't try sending unless your program can handle 614400 bytes in a hurry!
  //Serial.write(fb2,magesize);
  Serial.printf("fb2 ready to save %lu bytes.", imagesize);
  Serial.println("Saving OV7670.bmp ");
  if (SD.exists("OV7670.bmp")) {
    // delete the file:
    Serial.println("Removing OV7670.bmp...");
    SD.remove("OV7670.bmp");
  bmpfile = SD.open("OV7670.bmp", FILE_WRITE);
  bmpfile.write((const uint8_t *)&fileheader, sizeof(fileheader));
  bmpfile.write(fb2, imagesize);
  bmpfile.close();
  Serial.println("File saved to SD card.");
I used the standard SD library, so you don't need SDFat. This has two effects:
1. writing to SD is slow because there are no multi-sector writes.
2. You have to use an SD card formatted as FAT16 of FAT32, an EXFAT card won't work.
When you plug in the card, you can double-click on OV7670 to see the image. Because the image is stored top down, the height is negative in the BMP file header. It will be right-side-up if opened in photos, but the preview pane may show it upside down.
I'm not sure why people are having I2C comm problems. 4K pullups seem OK on my board. Perhaps they aren't OK on board with more capacitance like plugboards. Those boards may require lower resistance values to get clean rising edges.
Ok after spending most of the day wiring and rewiring finally got it working I think:
OV7670 Camera Test 3  Compiled on Oct 27 2020 20:36:31
buff1 at 0x70096000   buff2 at 0x70000000
Camera frame count = 483
Base Address Change errors: 476
csistat: 84204001, csiIrqCount: 484
fb1 count:     45   fb2 count     44
==== CSI ====
CSI_CSICR1: 401B0912
CSI_CSICR2: C0000000
CSI_CSICR3: 73311020
CSI_CSISTATFIFO: 0
CSI_CSIRFIFO: 61704180
CSI_CSIRXCNT: 9600
CSI_CSISR: 80204001
CSI_CSIDMASA_STATFIFO: 0
CSI_CSIDMATS_STATFIFO: 0
CSI_CSIDMASA_FB1: 70096000
CSI_CSIDMASA_FB2: 70000000
CSI_CSIFBUF_PARA: 0
CSI_CSIIMAG_PARA: 50001E0
CSI_CSICR18: 800AD210
CSI_CSICR19: 10
CSI_CSIRFIFO: FDFDFDFD
fb2 ready for processing 614400 nytes.
Did have to modify the posted sketch to read:
  delay(10);
  delay(10);
as opposed to
  delay(10);
Now I guess tomorrow I can play some more :)
Good morning all,
I am playing with the code but so far I am seeing garbage on a display... Need to figure out what is going on.
Current sketch included. Was not sure if bytes reversed or not. Thought maybe something else going on...
I am trying to display the data on an ILI9341 display...
But then I also added dumping the data at the center... Maybe I am calculating something wrong. Will try some more stuff...
I tried double checking the wiring. Will check again
I probably screwed up something simple.
@mjs513 adding the change to reset pin, caused mine not to read frames...
  • CSI_41_main-201028a.zip
Good morning all,
Interesting just copied your version and loaded it up and got nothing until I added the reset to LOW? Strange....
Yes is strange If I uncomment those two lines I then try running and f command I see:
OV7670 Camera Test 3  Compiled on Oct 28 2020 08:02:01
EXT Memory size: 16
cam clock  12.00 with pll=1 and div=1
After cameraBegin(end setup)
s - Show Information
c - Print CSI Registers
r - Show Camera registers
f - Show a frame
Command character received: f
Waiting for next FB2
And it hangs. But maybe I have it hooked up on wrong pin?
I have it on the Camera to the one RET? Smaybe should be the one PWDN?
Nope it was me - I had PWDN and RET reversed. Once I fixed it all works as originally posted :) Dumb mistake on my part.
BTW: went back to my arducam stuff to try and get the bmp sent to there windows application, data gets sent but the image that comes across looks more like its smeared:
EDIT: It does look like it wants low byte first in my case.
@mjs513 - I have that one installed through library manager. Note: I believe it is based off of the Arduino library: https://github.com/arduino-libraries/Arduino_OV767X
That is/was the one my other library code is off of... The one trying to get DMA to work...
At some point should combine the two parts... i.e. Teensy41_OV670.
Also thought about trying to build this in Sublimetext... But not sure the tset stuff is working very well for multiple INO files... So as an intermediate step I am thinking of renaming the INO files except the main one to be .cpp files.
Will need to setup extern... stuff probably in header files.
Thanks Kurt - didn't come across that one during the search - that processing sketch looks interesting,
EDIT: Processing at least at know a bit. Just tried the processing sketch after modifying it for 640x480 but am pretty much seeing the same thing as in post #139 = are we sure we are dumpling RGB565?
Hi again, yep I am wondering about some of the settings and the like.
I included my current set of hacks. Where I did rename most of the .ino files to .cpp and add header file with externals.
Wondering about comparing the settings that are set versus the ones I have for the other camera using the hacked up library.
May turn out we are trying to run the camera too fast for the jumper wires, or maybe I have something totally screwed up. Or???
  • CSI_41_main-201028b.zip
@KurtE
Have 3 ways now to view the BMP - Arducam_Viewer (a little flaky to use since its a hack), that Processing sketch that was in the link you provided and save to an SD card. Al three show the distorted image. I also rewired it again but still shows same behavior.
I have seen this before - a couple years ago when I was playing with Arducam - you may be right that we are trying to run the camera too fast. Guess next step is look at the settings as you said.
heres what I have been playing with:
  • camtest_v2.zip
Will have to take a look!
Here is running the other (posted earlier up on github more or less)...
Calling the init currently with: if (!Camera.begin(VGA, RGB565, 20)) {
The I2C registers set are:
EXT Memory size: 8
EXT Memory size: 8 EXTMEM variables: 25800 End: 70096000
::begin 0 255 255 255
ILI9488_t3::begin - End
frame_buffer: 7009600cframe_buffer aligned: 70096020OV767X Camera Capture
OV767X::begin
  VS=41, HR=40, PC=4 XC=5
  _dpins(0)=14
  _dpins(1)=15
  _dpins(2)=17
  _dpins(3)=16
  _dpins(4)=22
  _dpins(5)=23
  _dpins(6)=20
  _dpins(7)=21
arduino_i2c_write: address = 0x21, reg = 0x12, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x11, value = 0x1
arduino_i2c_write: address = 0x21, reg = 0x3A, value = 0x4
arduino_i2c_write: address = 0x21, reg = 0x12, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x17, value = 0x13
arduino_i2c_write: address = 0x21, reg = 0x18, value = 0x1
arduino_i2c_write: address = 0x21, reg = 0x32, value = 0xB6
arduino_i2c_write: address = 0x21, reg = 0x19, value = 0x2
arduino_i2c_write: address = 0x21, reg = 0x1A, value = 0x7A
arduino_i2c_write: address = 0x21, reg = 0x3, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0xC, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x3E, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x70, value = 0x3A
arduino_i2c_write: address = 0x21, reg = 0x71, value = 0x35
arduino_i2c_write: address = 0x21, reg = 0x72, value = 0x11
arduino_i2c_write: address = 0x21, reg = 0x73, value = 0xF0
arduino_i2c_write: address = 0x21, reg = 0xA2, value = 0x2
arduino_i2c_write: address = 0x21, reg = 0x15, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x7A, value = 0x20
arduino_i2c_write: address = 0x21, reg = 0x7B, value = 0x10
arduino_i2c_write: address = 0x21, reg = 0x7C, value = 0x1E
arduino_i2c_write: address = 0x21, reg = 0x7D, value = 0x35
arduino_i2c_write: address = 0x21, reg = 0x7E, value = 0x5A
arduino_i2c_write: address = 0x21, reg = 0x7F, value = 0x69
arduino_i2c_write: address = 0x21, reg = 0x80, value = 0x76
arduino_i2c_write: address = 0x21, reg = 0x81, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x82, value = 0x88
arduino_i2c_write: address = 0x21, reg = 0x83, value = 0x8F
arduino_i2c_write: address = 0x21, reg = 0x84, value = 0x96
arduino_i2c_write: address = 0x21, reg = 0x85, value = 0xA3
arduino_i2c_write: address = 0x21, reg = 0x86, value = 0xAF
arduino_i2c_write: address = 0x21, reg = 0x87, value = 0xC4
arduino_i2c_write: address = 0x21, reg = 0x88, value = 0xD7
arduino_i2c_write: address = 0x21, reg = 0x89, value = 0xE8
arduino_i2c_write: address = 0x21, reg = 0x13, value = 0xE0
arduino_i2c_write: address = 0x21, reg = 0x0, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x10, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0xD, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x14, value = 0x18
arduino_i2c_write: address = 0x21, reg = 0xA5, value = 0x5
arduino_i2c_write: address = 0x21, reg = 0xAB, value = 0x7
arduino_i2c_write: address = 0x21, reg = 0x24, value = 0x95
arduino_i2c_write: address = 0x21, reg = 0x25, value = 0x33
arduino_i2c_write: address = 0x21, reg = 0x26, value = 0xE3
arduino_i2c_write: address = 0x21, reg = 0x9F, value = 0x78
arduino_i2c_write: address = 0x21, reg = 0xA0, value = 0x68
arduino_i2c_write: address = 0x21, reg = 0xA1, value = 0x3
arduino_i2c_write: address = 0x21, reg = 0xA6, value = 0xD8
arduino_i2c_write: address = 0x21, reg = 0xA7, value = 0xD8
arduino_i2c_write: address = 0x21, reg = 0xA8, value = 0xF0
arduino_i2c_write: address = 0x21, reg = 0xA9, value = 0x90
arduino_i2c_write: address = 0x21, reg = 0xAA, value = 0x94
arduino_i2c_write: address = 0x21, reg = 0x13, value = 0xE5
arduino_i2c_write: address = 0x21, reg = 0xE, value = 0x61
arduino_i2c_write: address = 0x21, reg = 0xF, value = 0x4B
arduino_i2c_write: address = 0x21, reg = 0x16, value = 0x2
arduino_i2c_write: address = 0x21, reg = 0x1E, value = 0x7
arduino_i2c_write: address = 0x21, reg = 0x21, value = 0x2
arduino_i2c_write: address = 0x21, reg = 0x22, value = 0x91
arduino_i2c_write: address = 0x21, reg = 0x29, value = 0x7
arduino_i2c_write: address = 0x21, reg = 0x33, value = 0xB
arduino_i2c_write: address = 0x21, reg = 0x35, value = 0xB
arduino_i2c_write: address = 0x21, reg = 0x37, value = 0x1D
arduino_i2c_write: address = 0x21, reg = 0x38, value = 0x71
arduino_i2c_write: address = 0x21, reg = 0x39, value = 0x2A
arduino_i2c_write: address = 0x21, reg = 0x3C, value = 0x78
arduino_i2c_write: address = 0x21, reg = 0x4D, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x4E, value = 0x20
arduino_i2c_write: address = 0x21, reg = 0x69, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x6B, value = 0x4A
arduino_i2c_write: address = 0x21, reg = 0x74, value = 0x10
arduino_i2c_write: address = 0x21, reg = 0x8D, value = 0x4F
arduino_i2c_write: address = 0x21, reg = 0x8E, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x8F, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x90, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x91, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x96, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x9A, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0xB0, value = 0x84
arduino_i2c_write: address = 0x21, reg = 0xB1, value = 0xC
arduino_i2c_write: address = 0x21, reg = 0xB2, value = 0xE
arduino_i2c_write: address = 0x21, reg = 0xB3, value = 0x82
arduino_i2c_write: address = 0x21, reg = 0xB8, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0x43, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0x44, value = 0xF0
arduino_i2c_write: address = 0x21, reg = 0x45, value = 0x34
arduino_i2c_write: address = 0x21, reg = 0x46, value = 0x58
arduino_i2c_write: address = 0x21, reg = 0x47, value = 0x28
arduino_i2c_write: address = 0x21, reg = 0x48, value = 0x3A
arduino_i2c_write: address = 0x21, reg = 0x59, value = 0x88
arduino_i2c_write: address = 0x21, reg = 0x5A, value = 0x88
arduino_i2c_write: address = 0x21, reg = 0x5B, value = 0x44
arduino_i2c_write: address = 0x21, reg = 0x5C, value = 0x67
arduino_i2c_write: address = 0x21, reg = 0x5D, value = 0x49
arduino_i2c_write: address = 0x21, reg = 0x5E, value = 0xE
arduino_i2c_write: address = 0x21, reg = 0x6C, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0x6D, value = 0x55
arduino_i2c_write: address = 0x21, reg = 0x6E, value = 0x11
arduino_i2c_write: address = 0x21, reg = 0x6F, value = 0x9F
arduino_i2c_write: address = 0x21, reg = 0x6A, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x1, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x2, value = 0x60
arduino_i2c_write: address = 0x21, reg = 0x13, value = 0xE7
arduino_i2c_write: address = 0x21, reg = 0x4F, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x50, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x51, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x52, value = 0x22
arduino_i2c_write: address = 0x21, reg = 0x53, value = 0x5E
arduino_i2c_write: address = 0x21, reg = 0x54, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x58, value = 0x9E
arduino_i2c_write: address = 0x21, reg = 0x41, value = 0x8
arduino_i2c_write: address = 0x21, reg = 0x3F, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x75, value = 0x5
arduino_i2c_write: address = 0x21, reg = 0x76, value = 0xE1
arduino_i2c_write: address = 0x21, reg = 0x4C, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x77, value = 0x1
arduino_i2c_write: address = 0x21, reg = 0x3D, value = 0xC3
arduino_i2c_write: address = 0x21, reg = 0x4B, value = 0x9
arduino_i2c_write: address = 0x21, reg = 0xC9, value = 0x60
arduino_i2c_write: address = 0x21, reg = 0x41, value = 0x38
arduino_i2c_write: address = 0x21, reg = 0x56, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x34, value = 0x11
arduino_i2c_write: address = 0x21, reg = 0x3B, value = 0x12
arduino_i2c_write: address = 0x21, reg = 0xA4, value = 0x88
arduino_i2c_write: address = 0x21, reg = 0x97, value = 0x30
arduino_i2c_write: address = 0x21, reg = 0x98, value = 0x20
arduino_i2c_write: address = 0x21, reg = 0x99, value = 0x30
arduino_i2c_write: address = 0x21, reg = 0x9A, value = 0x84
arduino_i2c_write: address = 0x21, reg = 0x9B, value = 0x29
arduino_i2c_write: address = 0x21, reg = 0x9C, value = 0x3
arduino_i2c_write: address = 0x21, reg = 0x9D, value = 0x4C
arduino_i2c_write: address = 0x21, reg = 0x9E, value = 0x3F
arduino_i2c_write: address = 0x21, reg = 0x78, value = 0x4
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x1
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0xF0
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0xF
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x10
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x7E
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x80
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0xB
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x1
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0xC
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0xD
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x20
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x9
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x2
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0xC0
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x3
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x40
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x5
arduino_i2c_write: address = 0x21, reg = 0xC8, value = 0x30
arduino_i2c_write: address = 0x21, reg = 0x79, value = 0x26
arduino_i2c_read: address = 0x21, reg = 0x1C, value = 0x7F
arduino_i2c_read: address = 0x21, reg = 0x1D, value = 0xA2
arduino_i2c_read: address = 0x21, reg = 0xA, value = 0x76
arduino_i2c_read: address = 0x21, reg = 0xB, value = 0x73
arduino_i2c_write: address = 0x21, reg = 0x12, value = 0x4
arduino_i2c_write: address = 0x21, reg = 0x15, value = 0x20
arduino_i2c_write: address = 0x21, reg = 0x8C, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x4, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x40, value = 0x10
arduino_i2c_write: address = 0x21, reg = 0x14, value = 0x38
arduino_i2c_write: address = 0x21, reg = 0x4F, value = 0xB3
arduino_i2c_write: address = 0x21, reg = 0x50, value = 0xB3
arduino_i2c_write: address = 0x21, reg = 0x52, value = 0x3D
arduino_i2c_write: address = 0x21, reg = 0x53, value = 0xA7
arduino_i2c_write: address = 0x21, reg = 0x54, value = 0xE4
arduino_i2c_write: address = 0x21, reg = 0x3D, value = 0xC0
arduino_i2c_read: address = 0x21, reg = 0x32, value = 0xB6
arduino_i2c_read: address = 0x21, reg = 0x3, value = 0xA
arduino_i2c_write: address = 0x21, reg = 0x11, value = 0x0
arduino_i2c_write: address = 0x21, reg = 0x11, value = 0x3
Camera settings:
	width = 640
	height = 480
	bits per pixel = 16
Send the 'c' character to read a frame ...
Send the 'd' character to read a frame using DMA ...
Setup for ILI9488 and my function to do partial frame my not be fully correct, but is showing some reasonable stuff... (Not with DMA, but reading direct...)
Now to see what they all do... versus this one...
@KurtE
Ok did a quick hack to add in ability to change resolution and format in setup. I also coverted over to your sketch but I added in my additions :) Still can't get a decent image. Wonder if bytes reverse?
  • CSI_41_main.zip
Good Morning,
Will take a look. I was playing some later yesterday with the other library where I am reading in data using the reading of GPIO port...
I hacked up their I2C write and read functions debug code to use a table to when possible show the register names. Probably should fill in their table more. I also added a command to dump the complete register set like the code we are debugging now. although one per line... So I can then maybe compare settings. Example output:
EXT Memory size: 8
OV767X::begin
  _dpins(0)=14
  _dpins(1)=15
  _dpins(2)=17
  _dpins(3)=16
  _dpins(4)=22
  _dpins(5)=23
  _dpins(6)=20
  _dpins(7)=21
I2C Write: reg: 0x12(REG_COM7), value = 0x80
I2C Write: reg: 0x11(REG_CLKRC), value = 0x01
I2C Write: reg: 0x3a(REG_TSLB), value = 0x04
I2C Write: reg: 0x12(REG_COM7), value = 0x00
I2C Write: reg: 0x17(REG_HSTART), value = 0x13
I2C Write: reg: 0x18(REG_HSTOP), value = 0x01
I2C Write: reg: 0x32(REG_HREF), value = 0xb6
I2C Write: reg: 0x19(REG_VSTART), value = 0x02
I2C Write: reg: 0x1a(REG_VSTOP), value = 0x7a
I2C Write: reg: 0x03(REG_VREF), value = 0x0a
I2C Write: reg: 0x0c(REG_COM3), value = 0x00
I2C Write: reg: 0x3e(REG_COM14), value = 0x00
I2C Write: reg: 0x70(REG_SCALING_XSC), value = 0x3a
I2C Write: reg: 0x71(REG_SCALING_YSC), value = 0x35
I2C Write: reg: 0x72(REG_SCALING_DCWCTR), value = 0x11
I2C Write: reg: 0x73(REG_SCALING_PCLK_DIV), value = 0xf0
I2C Write: reg: 0xa2(REG_SCALING_PCLK_DELAY), value = 0x02
I2C Write: reg: 0x15(REG_COM10), value = 0x00
I2C Write: reg: 0x7a(REG_SLOP), value = 0x20
I2C Write: reg: 0x7b(REG_GAM_BASE), value = 0x10
I2C Write: reg: 0x7c, value = 0x1e
I2C Write: reg: 0x7d, value = 0x35
I2C Write: reg: 0x7e, value = 0x5a
I2C Write: reg: 0x7f, value = 0x69
I2C Write: reg: 0x80(COM7_RESET), value = 0x76
I2C Write: reg: 0x81, value = 0x80
I2C Write: reg: 0x82, value = 0x88
I2C Write: reg: 0x83, value = 0x8f
I2C Write: reg: 0x84, value = 0x96
I2C Write: reg: 0x85, value = 0xa3
I2C Write: reg: 0x86, value = 0xaf
I2C Write: reg: 0x87, value = 0xc4
I2C Write: reg: 0x88, value = 0xd7
I2C Write: reg: 0x89, value = 0xe8
I2C Write: reg: 0x13(REG_COM8), value = 0xe0
I2C Write: reg: 0x00(REG_GAIN), value = 0x00
I2C Write: reg: 0x10(COM2_SSLEEP), value = 0x00
I2C Write: reg: 0x0d(REG_COM4), value = 0x40
I2C Write: reg: 0x14(REG_COM9), value = 0x18
I2C Write: reg: 0xa5(REG_BD50MAX), value = 0x05
I2C Write: reg: 0xab(REG_BD60MAX), value = 0x07
I2C Write: reg: 0x24(REG_AEW), value = 0x95
I2C Write: reg: 0x25(REG_AEB), value = 0x33
I2C Write: reg: 0x26(REG_VPT), value = 0xe3
I2C Write: reg: 0x9f(REG_HAECC1), value = 0x78
I2C Write: reg: 0xa0(REG_HAECC2), value = 0x68
I2C Write: reg: 0xa1, value = 0x03
I2C Write: reg: 0xa6(REG_HAECC3), value = 0xd8
I2C Write: reg: 0xa7(REG_HAECC4), value = 0xd8
I2C Write: reg: 0xa8(REG_HAECC5), value = 0xf0
I2C Write: reg: 0xa9(REG_HAECC6), value = 0x90
I2C Write: reg: 0xaa(REG_HAECC7), value = 0x94
I2C Write: reg: 0x13(REG_COM8), value = 0xe5
I2C Write: reg: 0x0e(REG_COM5), value = 0x61
I2C Write: reg: 0x0f(REG_COM6), value = 0x4b
I2C Write: reg: 0x16, value = 0x02
I2C Write: reg: 0x1e(REG_MVFP), value = 0x07
I2C Write: reg: 0x21(REG_ADCCTR1), value = 0x02
I2C Write: reg: 0x22(REG_ADCCTR2), value = 0x91
I2C Write: reg: 0x29, value = 0x07
I2C Write: reg: 0x33(REG_CHLF), value = 0x0b
I2C Write: reg: 0x35, value = 0x0b
I2C Write: reg: 0x37(REG_ADC), value = 0x1d
I2C Write: reg: 0x38(COM7_SIZE_MASK), value = 0x71
I2C Write: reg: 0x39(REG_OFON), value = 0x2a
I2C Write: reg: 0x3c(REG_COM12), value = 0x78
I2C Write: reg: 0x4d, value = 0x40
I2C Write: reg: 0x4e, value = 0x20
I2C Write: reg: 0x69(REG_GFIX), value = 0x00
I2C Write: reg: 0x6b(REG_DBLV), value = 0x4a
I2C Write: reg: 0x74(REG_REG74), value = 0x10
I2C Write: reg: 0x8d, value = 0x4f
I2C Write: reg: 0x8e, value = 0x00
I2C Write: reg: 0x8f, value = 0x00
I2C Write: reg: 0x90, value = 0x00
I2C Write: reg: 0x91, value = 0x00
I2C Write: reg: 0x96, value = 0x00
I2C Write: reg: 0x9a, value = 0x00
I2C Write: reg: 0xb0, value = 0x84
I2C Write: reg: 0xb1(REG_ABLC1), value = 0x0c
I2C Write: reg: 0xb2, value = 0x0e
I2C Write: reg: 0xb3(REG_THL_ST), value = 0x82
I2C Write: reg: 0xb8, value = 0x0a
I2C Write: reg: 0x43(REG_AWBC1), value = 0x0a
I2C Write: reg: 0x44(REG_AWBC2), value = 0xf0
I2C Write: reg: 0x45(REG_AWBC3), value = 0x34
I2C Write: reg: 0x46(REG_AWBC4), value = 0x58
I2C Write: reg: 0x47(REG_AWBC5), value = 0x28
I2C Write: reg: 0x48(REG_AWBC6), value = 0x3a
I2C Write: reg: 0x59, value = 0x88
I2C Write: reg: 0x5a, value = 0x88
I2C Write: reg: 0x5b, value = 0x44
I2C Write: reg: 0x5c, value = 0x67
I2C Write: reg: 0x5d, value = 0x49
I2C Write: reg: 0x5e, value = 0x0e
I2C Write: reg: 0x6c(REG_AWBCTR3), value = 0x0a
I2C Write: reg: 0x6d(REG_AWBCTR2), value = 0x55
I2C Write: reg: 0x6e(REG_AWBCTR1), value = 0x11
I2C Write: reg: 0x6f(REG_AWBCTR0), value = 0x9f
I2C Write: reg: 0x6a(REG_GGAIN), value = 0x40
I2C Write: reg: 0x01(REG_BLUE), value = 0x40
I2C Write: reg: 0x02(REG_RED), value = 0x60
I2C Write: reg: 0x13(REG_COM8), value = 0xe7
I2C Write: reg: 0x4f(REG_MTX1), value = 0x80
I2C Write: reg: 0x50(REG_MTX2), value = 0x80
I2C Write: reg: 0x51(REG_MTX3), value = 0x00
I2C Write: reg: 0x52(REG_MTX4), value = 0x22
I2C Write: reg: 0x53(REG_MTX5), value = 0x5e
I2C Write: reg: 0x54(REG_MTX6), value = 0x80
I2C Write: reg: 0x58(REG_MTXS), value = 0x9e
I2C Write: reg: 0x41(REG_COM16), value = 0x08
I2C Write: reg: 0x3f(CLK_SCALE), value = 0x00
I2C Write: reg: 0x75, value = 0x05
I2C Write: reg: 0x76(REG_REG76), value = 0xe1
I2C Write: reg: 0x4c(REG_DNSTH), value = 0x00
I2C Write: reg: 0x77, value = 0x01
I2C Write: reg: 0x3d(REG_COM13), value = 0xc3
I2C Write: reg: 0x4b(REG_REG4B), value = 0x09
I2C Write: reg: 0xc9(REG_SATCTR), value = 0x60
I2C Write: reg: 0x41(REG_COM16), value = 0x38
I2C Write: reg: 0x56(REG_CONTRAS), value = 0x40
I2C Write: reg: 0x34(REG_ARBLM), value = 0x11
I2C Write: reg: 0x3b(REG_COM11), value = 0x12
I2C Write: reg: 0xa4, value = 0x88
I2C Write: reg: 0x97, value = 0x30
I2C Write: reg: 0x98, value = 0x20
I2C Write: reg: 0x99, value = 0x30
I2C Write: reg: 0x9a, value = 0x84
I2C Write: reg: 0x9b, value = 0x29
I2C Write: reg: 0x9c, value = 0x03
I2C Write: reg: 0x9d, value = 0x4c
I2C Write: reg: 0x9e, value = 0x3f
I2C Write: reg: 0x78, value = 0x04
I2C Write: reg: 0x79, value = 0x01
I2C Write: reg: 0xc8, value = 0xf0
I2C Write: reg: 0x79, value = 0x0f
I2C Write: reg: 0xc8, value = 0x00
I2C Write: reg: 0x79, value = 0x10
I2C Write: reg: 0xc8, value = 0x7e
I2C Write: reg: 0x79, value = 0x0a
I2C Write: reg: 0xc8, value = 0x80
I2C Write: reg: 0x79, value = 0x0b
I2C Write: reg: 0xc8, value = 0x01
I2C Write: reg: 0x79, value = 0x0c
I2C Write: reg: 0xc8, value = 0x0f
I2C Write: reg: 0x79, value = 0x0d
I2C Write: reg: 0xc8, value = 0x20
I2C Write: reg: 0x79, value = 0x09
I2C Write: reg: 0x79, value = 0x02
I2C Write: reg: 0xc8, value = 0xc0
I2C Write: reg: 0x79, value = 0x03
I2C Write: reg: 0xc8, value = 0x40
I2C Write: reg: 0x79, value = 0x05
I2C Write: reg: 0xc8, value = 0x30
I2C Write: reg: 0x79, value = 0x26
I2C Read: reg: 0x1c(REG_MIDH), value = 0x7F
I2C Read: reg: 0x1d(REG_MIDL), value = 0xA2
I2C Read: reg: 0x0a(REG_PID), value = 0x76
I2C Read: reg: 0x0b(REG_VER), value = 0x73
I2C Write: reg: 0x12(REG_COM7), value = 0x04
I2C Write: reg: 0x15(REG_COM10), value = 0x20
I2C Write: reg: 0x8c(REG_RGB444), value = 0x00
I2C Write: reg: 0x04(REG_COM1), value = 0x00
I2C Write: reg: 0x40(COM1_R656), value = 0x10
I2C Write: reg: 0x14(REG_COM9), value = 0x38
I2C Write: reg: 0x4f(REG_MTX1), value = 0xb3
I2C Write: reg: 0x50(REG_MTX2), value = 0xb3
I2C Write: reg: 0x52(REG_MTX4), value = 0x3d
I2C Write: reg: 0x53(REG_MTX5), value = 0xa7
I2C Write: reg: 0x54(REG_MTX6), value = 0xe4
I2C Write: reg: 0x3d(REG_COM13), value = 0xc0
I2C Read: reg: 0x32(REG_HREF), value = 0xB6
I2C Read: reg: 0x03(REG_VREF), value = 0xA
I2C Write: reg: 0x11(REG_CLKRC), value = 0x00
I2C Write: reg: 0x11(REG_CLKRC), value = 0x03
Camera settings:
	width = 640
	height = 480
	bits per pixel = 16
Send the 's' character to start/stop continuous display mode
send the 'r' Show Camera register settings
I2C Read: reg: 0x00(REG_GAIN), value = 0x7F
I2C Read: reg: 0x01(REG_BLUE), value = 0xF0
I2C Read: reg: 0x02(REG_RED), value = 0x40
I2C Read: reg: 0x04(REG_COM1), value = 0x0
I2C Read: reg: 0x05(REG_BAVE), value = 0x50
I2C Read: reg: 0x06(REG_GbAVE), value = 0x58
I2C Read: reg: 0x07(REG_AECHH), value = 0x40
I2C Read: reg: 0x08(REG_RAVE), value = 0x57
I2C Read: reg: 0x09(REG_COM2), value = 0x1
I2C Read: reg: 0x0c(REG_COM3), value = 0x0
I2C Read: reg: 0x0d(REG_COM4), value = 0x40
I2C Read: reg: 0x0e(REG_COM5), value = 0x61
I2C Read: reg: 0x0f(REG_COM6), value = 0x4B
I2C Read: reg: 0x10(COM2_SSLEEP), value = 0x7E
I2C Read: reg: 0x11(REG_CLKRC), value = 0x3
I2C Read: reg: 0x12(REG_COM7), value = 0x4
I2C Read: reg: 0x13(REG_COM8), value = 0xE7
I2C Read: reg: 0x14(REG_COM9), value = 0x38
I2C Read: reg: 0x15(REG_COM10), value = 0x20
I2C Read: reg: 0x16, value = 0x2
I2C Read: reg: 0x17(REG_HSTART), value = 0x13
I2C Read: reg: 0x18(REG_HSTOP), value = 0x1
I2C Read: reg: 0x19(REG_VSTART), value = 0x2
I2C Read: reg: 0x1a(REG_VSTOP), value = 0x7A
I2C Read: reg: 0x1b(REG_PSHFT), value = 0x0
I2C Read: reg: 0x1e(REG_MVFP), value = 0x7
I2C Read: reg: 0x1f(REG_LAEC), value = 0x0
I2C Read: reg: 0x20(COM7_SIZE_CIF), value = 0x4
I2C Read: reg: 0x21(REG_ADCCTR1), value = 0x2
I2C Read: reg: 0x22(REG_ADCCTR2), value = 0x91
I2C Read: reg: 0x23(REG_ADCCTR3), value = 0x0
I2C Read: reg: 0x24(REG_AEW), value = 0x95
I2C Read: reg: 0x25(REG_AEB), value = 0x33
I2C Read: reg: 0x26(REG_VPT), value = 0xE3
I2C Read: reg: 0x27(REG_BBIAS), value = 0x80
I2C Read: reg: 0x28(REG_GbBIAS), value = 0x80
I2C Read: reg: 0x29, value = 0x7
I2C Read: reg: 0x2a(REG_EXHCH), value = 0x0
I2C Read: reg: 0x2b(REG_EXHCL), value = 0x0
I2C Read: reg: 0x2c(REG_RBIAS), value = 0x80
I2C Read: reg: 0x2d(REG_ADVFL), value = 0x0
I2C Read: reg: 0x2e(REG_ADVFH), value = 0x0
I2C Read: reg: 0x2f(REG_YAVE), value = 0x2D
I2C Read: reg: 0x30(REG_HSYST), value = 0x8
I2C Read: reg: 0x31(REG_HSYEN), value = 0x30
I2C Read: reg: 0x33(REG_CHLF), value = 0xB
I2C Read: reg: 0x34(REG_ARBLM), value = 0x11
I2C Read: reg: 0x35, value = 0xB
I2C Read: reg: 0x36, value = 0x0
I2C Read: reg: 0x37(REG_ADC), value = 0x1D
I2C Read: reg: 0x38(COM7_SIZE_MASK), value = 0x71
I2C Read: reg: 0x39(REG_OFON), value = 0x2A
I2C Read: reg: 0x3a(REG_TSLB), value = 0x4
I2C Read: reg: 0x3b(REG_COM11), value = 0x12
I2C Read: reg: 0x3c(REG_COM12), value = 0x78
I2C Read: reg: 0x3d(REG_COM13), value = 0xC0
I2C Read: reg: 0x3e(REG_COM14), value = 0x0
I2C Read: reg: 0x3f(CLK_SCALE), value = 0x1
I2C Read: reg: 0x40(COM1_R656), value = 0x10
I2C Read: reg: 0x41(REG_COM16), value = 0x38
I2C Read: reg: 0x42(REG_COM17), value = 0x0
I2C Read: reg: 0x43(REG_AWBC1), value = 0xA
I2C Read: reg: 0x44(REG_AWBC2), value = 0xF0
I2C Read: reg: 0x45(REG_AWBC3), value = 0x34
I2C Read: reg: 0x46(REG_AWBC4), value = 0x58
I2C Read: reg: 0x47(REG_AWBC5), value = 0x28
I2C Read: reg: 0x48(REG_AWBC6), value = 0x3A
I2C Read: reg: 0x49, value = 0x0
I2C Read: reg: 0x4a, value = 0x0
I2C Read: reg: 0x4b(REG_REG4B), value = 0x9
I2C Read: reg: 0x4c(REG_DNSTH), value = 0x20
I2C Read: reg: 0x4d, value = 0x40
I2C Read: reg: 0x4e, value = 0x20
I2C Read: reg: 0x4f(REG_MTX1), value = 0xB3
I2C Read: reg: 0x50(REG_MTX2), value = 0xB3
I2C Read: reg: 0x51(REG_MTX3), value = 0x0
I2C Read: reg: 0x52(REG_MTX4), value = 0x3D
I2C Read: reg: 0x53(REG_MTX5), value = 0xA7
I2C Read: reg: 0x54(REG_MTX6), value = 0xE4
I2C Read: reg: 0x55(REG_BRIGHT), value = 0x0
I2C Read: reg: 0x56(REG_CONTRAS), value = 0x40
I2C Read: reg: 0x57(REG_CONTRAS_CENTER), value = 0x80
I2C Read: reg: 0x58(REG_MTXS), value = 0x9E
I2C Read: reg: 0x59, value = 0x88
I2C Read: reg: 0x5a, value = 0x88
I2C Read: reg: 0x5b, value = 0x44
I2C Read: reg: 0x5c, value = 0x67
I2C Read: reg: 0x5d, value = 0x49
I2C Read: reg: 0x5e, value = 0xE
I2C Read: reg: 0x5f, value = 0xF0
I2C Read: reg: 0x60(COM11_NMFR), value = 0xF0
I2C Read: reg: 0x61, value = 0xF0
I2C Read: reg: 0x62(REG_LCC1), value = 0x0
I2C Read: reg: 0x63(REG_LCC2), value = 0x0
I2C Read: reg: 0x64(REG_LCC3), value = 0x50
I2C Read: reg: 0x65(REG_LCC4), value = 0x30
I2C Read: reg: 0x66(REG_LCC5), value = 0x0
I2C Read: reg: 0x67(REG_MANU), value = 0x80
I2C Read: reg: 0x68(REG_MANV), value = 0x80
I2C Read: reg: 0x69(REG_GFIX), value = 0x0
I2C Read: reg: 0x6a(REG_GGAIN), value = 0x5A
I2C Read: reg: 0x6b(REG_DBLV), value = 0x4A
I2C Read: reg: 0x6c(REG_AWBCTR3), value = 0xA
I2C Read: reg: 0x6d(REG_AWBCTR2), value = 0x55
I2C Read: reg: 0x6e(REG_AWBCTR1), value = 0x11
I2C Read: reg: 0x6f(REG_AWBCTR0), value = 0x9F
I2C Read: reg: 0x70(REG_SCALING_XSC), value = 0x3A
I2C Read: reg: 0x71(REG_SCALING_YSC), value = 0x35
I2C Read: reg: 0x72(REG_SCALING_DCWCTR), value = 0x11
I2C Read: reg: 0x73(REG_SCALING_PCLK_DIV), value = 0xF0
I2C Read: reg: 0x74(REG_REG74), value = 0x10
I2C Read: reg: 0x75, value = 0x5
I2C Read: reg: 0x76(REG_REG76), value = 0xE1
I2C Read: reg: 0x77, value = 0x1
I2C Read: reg: 0x78, value = 0x4
I2C Read: reg: 0x79, value = 0x26
I2C Read: reg: 0x7a(REG_SLOP), value = 0x20
I2C Read: reg: 0x7b(REG_GAM_BASE), value = 0x10
I2C Read: reg: 0x7c, value = 0x1E
I2C Read: reg: 0x7d, value = 0x35
I2C Read: reg: 0x7e, value = 0x5A
I2C Read: reg: 0x7f, value = 0x69
I2C Read: reg: 0x80(COM7_RESET), value = 0x76
I2C Read: reg: 0x81, value = 0x80
I2C Read: reg: 0x82, value = 0x88
I2C Read: reg: 0x83, value = 0x8F
I2C Read: reg: 0x84, value = 0x96
I2C Read: reg: 0x85, value = 0xA3
I2C Read: reg: 0x86, value = 0xAF
I2C Read: reg: 0x87, value = 0xC4
I2C Read: reg: 0x88, value = 0xD7
I2C Read: reg: 0x89, value = 0xE8
I2C Read: reg: 0x8a, value = 0x0
I2C Read: reg: 0x8b, value = 0x0
I2C Read: reg: 0x8c(REG_RGB444), value = 0x0
I2C Read: reg: 0x8d, value = 0x4F
I2C Read: reg: 0x8e, value = 0x0
I2C Read: reg: 0x8f, value = 0x0
I2C Read: reg: 0x90, value = 0x0
I2C Read: reg: 0x91, value = 0x0
I2C Read: reg: 0x92(REG_DM_LNL), value = 0x0
I2C Read: reg: 0x93, value = 0x0
I2C Read: reg: 0x94(REG_LCC6), value = 0x50
I2C Read: reg: 0x95(REG_LCC7), value = 0x50
I2C Read: reg: 0x96, value = 0x0
I2C Read: reg: 0x97, value = 0x30
I2C Read: reg: 0x98, value = 0x20
I2C Read: reg: 0x99, value = 0x30
I2C Read: reg: 0x9a, value = 0x84
I2C Read: reg: 0x9b, value = 0x29
I2C Read: reg: 0x9c, value = 0x3
I2C Read: reg: 0x9d, value = 0x4C
I2C Read: reg: 0x9e, value = 0x3F
I2C Read: reg: 0x9f(REG_HAECC1), value = 0x78
I2C Read: reg: 0xa0(REG_HAECC2), value = 0x68
I2C Read: reg: 0xa1, value = 0x3
I2C Read: reg: 0xa2(REG_SCALING_PCLK_DELAY), value = 0x2
I2C Read: reg: 0xa3, value = 0x0
I2C Read: reg: 0xa4, value = 0x88
I2C Read: reg: 0xa5(REG_BD50MAX), value = 0x5
I2C Read: reg: 0xa6(REG_HAECC3), value = 0xD8
I2C Read: reg: 0xa7(REG_HAECC4), value = 0xD8
I2C Read: reg: 0xa8(REG_HAECC5), value = 0xF0
I2C Read: reg: 0xa9(REG_HAECC6), value = 0x90
I2C Read: reg: 0xaa(REG_HAECC7), value = 0x94
I2C Read: reg: 0xab(REG_BD60MAX), value = 0x7
I2C Read: reg: 0xac, value = 0x0
I2C Read: reg: 0xad, value = 0x80
I2C Read: reg: 0xae, value = 0x80
I2C Read: reg: 0xaf, value = 0x80
I2C Read: reg: 0xb0, value = 0x84
I2C Read: reg: 0xb1(REG_ABLC1), value = 0xC
I2C Read: reg: 0xb2, value = 0xE
I2C Read: reg: 0xb3(REG_THL_ST), value = 0x82
I2C Read: reg: 0xb4, value = 0x0
I2C Read: reg: 0xb5, value = 0x4
I2C Read: reg: 0xb6, value = 0x0
I2C Read: reg: 0xb7, value = 0x66
I2C Read: reg: 0xb8, value = 0xA
I2C Read: reg: 0xb9, value = 0x6
I2C Read: reg: 0xba, value = 0x0
I2C Read: reg: 0xbb, value = 0x0
I2C Read: reg: 0xbc, value = 0x0
I2C Read: reg: 0xbd, value = 0x0
I2C Read: reg: 0xbe, value = 0x5
I2C Read: reg: 0xbf, value = 0x5
I2C Read: reg: 0xc0(COM15_RMASK), value = 0x44
I2C Read: reg: 0xc1, value = 0x45
I2C Read: reg: 0xc2, value = 0x0
I2C Read: reg: 0xc3, value = 0x0
I2C Read: reg: 0xc4, value = 0x0
I2C Read: reg: 0xc5, value = 0x0
I2C Read: reg: 0xc6, value = 0x0
I2C Read: reg: 0xc7, value = 0x0
I2C Read: reg: 0xc8, value = 0xE0
I2C Read: reg: 0xc9(REG_SATCTR), value = 0x69
I think I edited out all of the double line spacing from Terminal Monitor (CRLF issue). As TyCommander is currently not working well with the updated USB descriptor for Serial USB type.
Morning again - tried to go back to sleep after I posted but no luck.
Anyway, problem is when you go through the manuals each register has to be broken down into the various options. Still wondering about frame rates while trying to get an image. Are we getting good images from the sketch at all? or are they all corrupted?
@KurtE
If you have byte reversal, the image will look like a thermal sensor image with lots of bright red and green, but with the expected shapes.
You can fix that by starting your bitmap upload offset by one byte. Instead of
Serial.write(fb2, imagesize);
do
Serial.write(fb2+1, imagesize-1);
If the image looks slanted, it is usually a problem with the HSTART and HSTOP settings.
There is a function in the camera software to set the camera clock. If you suspect problems with noisy signals in the wiring, you can set the camera clock to 4MHz. I found that 3 or 4Mhz worked well with my plugboard prototype.
