steven32bits
I am working on a project to measure the acoustics of a room by playing a test tone through a speaker and analyzing FFT from the input of a mic. I want to generate correction filters using the biquad filters. Well I designed a complicated circuit in the GUI that will help me run the analysis as intended in order to prove that it is working as intended. I am using a Teensy 3.2 with a single audio shield attached. The speaker and mic are connected I2s line in and out ports on the shield.
Right now I have the controller first sending pink noise for 15 seconds and measuring the time domain audio amplitude coming in from the mic. This is simply a comparative number for when I generate the filters (during tonesweep3). Then I am playing tonesweep1 straight from computer to computer to receive a "perfect world" what the tonesweep should look like when playing through my speakers. Next I play the tonesweep2 through the speakers and record the FFT of the mic input to see the "distortion created by the room and speakers." And that's when I intend on generating correction filters, from parallel biquad filters and adjust gains through mixers they are connected to. After generating the filters and their desired gains, I will play the tonesweep3 through the filters out the speaker and back into the mic to see the FFT one more time to compare to tonesweep1.
I am pretty sure I have designed something to complex for Teensy's capability on the 3.2. I wasn't looking for the most accurate room correction, meaning the frequecy resolution of the FFT is 43Hz and it is sampling the FFT apporx 86 times a second instead of the same sampling frequency of the ADC/DAC, and thats all ok with me. The code I am uploading for you to help me with doesnt have the filters changing any gains because as soon as I introduced the amount of filters I am using there was instant distortion to the tonesweep signal. After increasing the Audiomemory() to allow for more audio processing, it still has distortion. Is this distortion fixable?
Here are some picture of my giant circuit in case you don't want to upload the auto-generated code that is clearly noted within the code. The code is also below.
// Steven's Room Analyzer and Room Correction Filter Generation
// A special thank you to Paul Stoffregen and his team for
// developing such a great open source device that supports audio
// DSP. This project was developed on Teensy 3.2 with and audio
// shield
#include <LiquidCrystal.h>
#include <Bounce.h>
#include <SerialFlash.h>
#include <Time.h>
#include <TimeAlarms.h>
AudioInputAnalog adc1; //xy=81,20
AudioInputI2S i2s1; //xy=80.88336181640625,296.8833312988281
AudioSynthNoisePink pink1; //xy=84.00003051757812,160
AudioSynthNoisePink pink3; //xy=83.88333129882812,232.88333129882812
AudioSynthNoisePink pink2; //xy=84.88333129882812,196.88333129882812
AudioSynthToneSweep tonesweep1; //xy=87.00003051757812,52
AudioSynthToneSweep tonesweep2; //xy=88.88333129882812,85.88333129882812
AudioSynthToneSweep tonesweep3; //xy=93.88333129882812,120.88333129882812
AudioMixer4 mixer1; //xy=111.00003051757812,408
AudioFilterBiquad biquad79; //xy=267.8833770751953,1577.883316040039
AudioFilterBiquad biquad77; //xy=269.8833770751953,1544.883316040039
AudioFilterBiquad biquad75; //xy=272.8833770751953,1511.883316040039
AudioFilterBiquad biquad73; //xy=273.8833770751953,1475.883316040039
AudioFilterBiquad biquad69; //xy=274.8833770751953,1403.883316040039
AudioFilterBiquad biquad71; //xy=274.8833770751953,1440.883316040039
AudioFilterBiquad biquad67; //xy=276.8833770751953,1366.883316040039
AudioFilterBiquad biquad63; //xy=279.8833770751953,1299.883316040039
AudioFilterBiquad biquad1; //xy=286.0000762939453,209.99998474121094
AudioFilterBiquad biquad15; //xy=285.8833770751953,452.8833465576172
AudioFilterBiquad biquad17; //xy=285.8833923339844,488.88331604003906
AudioFilterBiquad biquad3; //xy=286.8833770751953,245.88328552246094
AudioFilterBiquad biquad61; //xy=282.8833770751953,1266.883316040039
AudioFilterBiquad biquad11; //xy=286.8833770751953,381.8833465576172
AudioFilterBiquad biquad59; //xy=283.8833770751953,1229.883316040039
AudioFilterBiquad biquad5; //xy=287.8833770751953,277.8833465576172
AudioFilterBiquad biquad13; //xy=287.8833770751953,417.8833465576172
AudioFilterBiquad biquad57; //xy=284.8833770751953,1196.883316040039
AudioFilterBiquad biquad19; //xy=287.8833923339844,521.8833160400391
AudioFilterBiquad biquad7; //xy=288.8833770751953,312.8833465576172
AudioFilterBiquad biquad9; //xy=288.8833770751953,345.8833465576172
AudioFilterBiquad biquad21; //xy=288.8833923339844,556.8833160400391
AudioFilterBiquad biquad23; //xy=288.8833770751953,590.8833160400391
AudioFilterBiquad biquad25; //xy=288.8833770751953,625.8832550048828
AudioFilterBiquad biquad27; //xy=288.8833770751953,661.8832550048828
AudioFilterBiquad biquad65; //xy=286.8833770751953,1330.883316040039
AudioFilterBiquad biquad39; //xy=288.8833770751953,871.8833160400391
AudioFilterBiquad biquad55; //xy=287.8833770751953,1161.883316040039
AudioFilterBiquad biquad37; //xy=289.8833770751953,836.8833160400391
AudioFilterBiquad biquad51; //xy=288.8833770751953,1089.883316040039
AudioFilterBiquad biquad53; //xy=288.8833770751953,1124.883316040039
AudioFilterBiquad biquad41; //xy=289.8833770751953,909.8833160400391
AudioFilterBiquad biquad29; //xy=290.8833770751953,694.8832550048828
AudioFilterBiquad biquad33; //xy=290.8833770751953,766.8832550048828
AudioFilterBiquad biquad35; //xy=290.8833770751953,802.8832550048828
AudioFilterBiquad biquad49; //xy=290.8833770751953,1053.883316040039
AudioFilterBiquad biquad47; //xy=291.8833770751953,1016.8832550048828
AudioFilterBiquad biquad43; //xy=292.8833770751953,943.8833160400391
AudioFilterBiquad biquad31; //xy=293.8833770751953,731.8832550048828
AudioFilterBiquad biquad45; //xy=294.8833770751953,980.8833160400391
AudioMixer4 mixer5; //xy=407.88336181640625,262.8833770751953
AudioMixer4 mixer23; //xy=405.88336181640625,1532.883316040039
AudioMixer4 mixer33; //xy=412.8833312988281,34.883331298828125
AudioMixer4 mixer21; //xy=410.88336181640625,1384.883316040039
AudioMixer4 mixer7; //xy=414.88336181640625,402.8833465576172
AudioMixer4 mixer19; //xy=414.88336181640625,1252.2833404541016
AudioMixer4 mixer34; //xy=420.8833312988281,173.88333129882812
AudioMixer4 mixer9; //xy=419.88336181640625,538.8833160400391
AudioMixer4 mixer13; //xy=418.88336181640625,816.8832550048828
AudioMixer4 mixer11; //xy=420.88336181640625,676.8833160400391
AudioMixer4 mixer17; //xy=421.88336181640625,1108.683364868164
AudioMixer4 mixer15; //xy=427.88336181640625,966.6833038330078
AudioMixer4 mixer2; //xy=587,464
AudioAnalyzeFFT1024 fft1024_2; //xy=737.8833312988281,86.88333129882812
AudioAnalyzeFFT1024 fft1024_1; //xy=739,27
AudioFilterBiquad biquad6; //xy=755.88330078125,287.88330078125
AudioFilterBiquad biquad36; //xy=753.88330078125,840.8833312988281
AudioFilterBiquad biquad32; //xy=754.88330078125,765.8832702636719
AudioFilterBiquad biquad34; //xy=754.88330078125,800.8833312988281
AudioFilterBiquad biquad8; //xy=756.88330078125,326.88330078125
AudioFilterBiquad biquad10; //xy=756.8833312988281,362.8833312988281
AudioFilterBiquad biquad14; //xy=757.88330078125,431.8832702636719
AudioFilterBiquad biquad2; //xy=759,214.00003051757812
AudioFilterBiquad biquad24; //xy=757.88330078125,618.8833618164062
AudioFilterBiquad biquad12; //xy=758.88330078125,396.8832702636719
AudioFilterBiquad biquad28; //xy=757.88330078125,694.8833312988281
AudioFilterBiquad biquad30; //xy=757.88330078125,730.8832702636719
AudioFilterBiquad biquad4; //xy=759.88330078125,250.88330078125
AudioFilterBiquad biquad22; //xy=758.88330078125,578.8833618164062
AudioFilterBiquad biquad26; //xy=758.88330078125,655.8833312988281
AudioFilterBiquad biquad16; //xy=759.88330078125,468.88336181640625
AudioFilterBiquad biquad18; //xy=759.88330078125,504.8833312988281
AudioFilterBiquad biquad20; //xy=759.88330078125,544.8833312988281
AudioFilterBiquad biquad44; //xy=762.88330078125,997.8832702636719
AudioFilterBiquad biquad38; //xy=763.88330078125,880.8832702636719
AudioFilterBiquad biquad42; //xy=763.88330078125,959.8832702636719
AudioFilterBiquad biquad40; //xy=764.88330078125,918.8833312988281
AudioFilterBiquad biquad46; //xy=764.88330078125,1034.8833312988281
AudioFilterBiquad biquad48; //xy=764.88330078125,1071.8833312988281
AudioFilterBiquad biquad50; //xy=768.88330078125,1110.8833312988281
AudioFilterBiquad biquad52; //xy=769.88330078125,1154.8833312988281
AudioFilterBiquad biquad64; //xy=769.88330078125,1382.8833312988281
AudioFilterBiquad biquad66; //xy=770.88330078125,1418.8833312988281
AudioFilterBiquad biquad60; //xy=771.88330078125,1311.8833312988281
AudioFilterBiquad biquad78; //xy=770.88330078125,1635.8833312988281
AudioFilterBiquad biquad68; //xy=771.88330078125,1456.8833312988281
AudioFilterBiquad biquad58; //xy=772.88330078125,1272.8833312988281
AudioFilterBiquad biquad72; //xy=771.88330078125,1527.8833312988281
AudioFilterBiquad biquad62; //xy=772.88330078125,1348.8833312988281
AudioFilterBiquad biquad80; //xy=771.88330078125,1673.8833312988281
AudioFilterBiquad biquad70; //xy=772.88330078125,1492.8833312988281
AudioFilterBiquad biquad74; //xy=772.88330078125,1560.8833312988281
AudioFilterBiquad biquad54; //xy=775.88330078125,1192.8833923339844
AudioFilterBiquad biquad56; //xy=775.88330078125,1232.8833312988281
AudioFilterBiquad biquad76; //xy=774.88330078125,1598.8833312988281
AudioMixer4 mixer8; //xy=903.88330078125,423.88330078125
AudioMixer4 mixer22; //xy=902.88330078125,1474.8832397460938
AudioMixer4 mixer20; //xy=903.88330078125,1332.8832397460938
AudioMixer4 mixer24; //xy=902.88330078125,1614.8832397460938
AudioMixer4 mixer14; //xy=906.88330078125,864.88330078125
AudioMixer4 mixer12; //xy=907.88330078125,724.88330078125
AudioMixer4 mixer6; //xy=909.88330078125,248.88333129882812
AudioMixer4 mixer18; //xy=907.88330078125,1169.8832397460938
AudioMixer4 mixer16; //xy=910.88330078125,1016.88330078125
AudioMixer4 mixer10; //xy=919.88330078125,557.88330078125
AudioMixer4 mixer29; //xy=1217.7167053222656,281.0834655761719
AudioMixer4 mixer27; //xy=1221.7167053222656,209.48336791992188
AudioMixer4 mixer25; //xy=1222.7167053222656,125.48333740234375
AudioMixer4 mixer26; //xy=1227.7166748046875,429.88323974609375
AudioMixer4 mixer30; //xy=1227.7166748046875,581.0833129882812
AudioMixer4 mixer28; //xy=1228.7166748046875,506.2833251953125
AudioMixer4 mixer31; //xy=1538.88330078125,203.28326416015625
AudioMixer4 mixer32; //xy=1551.88330078125,414.28326416015625
AudioMixer4 mixer3; //xy=1848.88330078125,292.08331298828125
AudioMixer4 mixer4; //xy=1850.8832702636719,364.08331298828125
AudioAnalyzeRMS rms_L; //xy=1977.9999694824219,270.1999816894531
AudioAnalyzeRMS rms_R; //xy=1980.9999694824219,391.1999816894531
AudioAnalyzePeak peak_L;
AudioAnalyzePeak peak_R;
AudioAnalyzeRMS rms_L1; //xy=1977.9999694824219,270.1999816894531
AudioAnalyzeRMS rms_R1; //xy=1980.9999694824219,391.1999816894531
AudioAnalyzePeak peak_L1;
AudioAnalyzePeak peak_R1;
AudioOutputI2S i2s2; //xy=1981.8832702636719,334.08331298828125
AudioConnection c1(i2s1, 0, peak_L, 0);
AudioConnection c2(i2s1, 1, peak_R, 0);
AudioConnection c3(i2s1,0,rms_L,0);
AudioConnection c4(i2s1,1,rms_R,0);
AudioConnection c5(tonesweep1, 0, peak_L1, 0);
AudioConnection c6(tonesweep1, 1, peak_R1, 0);
AudioConnection c7(tonesweep1,0,rms_L1,0);
AudioConnection c8(tonesweep1,1,rms_R1,0);
AudioConnection patchCord1(adc1, 0, mixer33, 3);
AudioConnection patchCord2(i2s1, 0, mixer33, 0);
AudioConnection patchCord3(i2s1, 1, mixer33, 1);
AudioConnection patchCord4(pink1, 0, mixer34, 1);
AudioConnection patchCord5(pink3, 0, mixer1, 1);
AudioConnection patchCord6(pink3, 0, mixer2, 1);
AudioConnection patchCord7(pink2, 0, mixer29, 3);
AudioConnection patchCord8(pink2, 0, mixer30, 3);
AudioConnection patchCord9(tonesweep1, 0, mixer34, 0);
AudioConnection patchCord10(tonesweep2, 0, mixer31, 3);
AudioConnection patchCord11(tonesweep2, 0, mixer32, 3);
AudioConnection patchCord12(tonesweep3, 0, mixer1, 0);
AudioConnection patchCord13(tonesweep3, 0, mixer2, 0);
AudioConnection patchCord14(mixer1, biquad1);
AudioConnection patchCord15(mixer1, biquad3);
AudioConnection patchCord16(mixer1, biquad5);
AudioConnection patchCord17(mixer1, biquad7);
AudioConnection patchCord18(mixer1, biquad9);
AudioConnection patchCord19(mixer1, biquad11);
AudioConnection patchCord20(mixer1, biquad13);
AudioConnection patchCord21(mixer1, biquad15);
AudioConnection patchCord22(mixer1, biquad79);
AudioConnection patchCord23(mixer1, biquad77);
AudioConnection patchCord24(mixer1, biquad75);
AudioConnection patchCord25(mixer1, biquad73);
AudioConnection patchCord26(mixer1, biquad71);
AudioConnection patchCord27(mixer1, biquad69);
AudioConnection patchCord28(mixer1, biquad67);
AudioConnection patchCord29(mixer1, biquad65);
AudioConnection patchCord30(mixer1, biquad63);
AudioConnection patchCord31(mixer1, biquad61);
AudioConnection patchCord32(mixer1, biquad59);
AudioConnection patchCord33(mixer1, biquad57);
AudioConnection patchCord34(mixer1, biquad55);
AudioConnection patchCord35(mixer1, biquad53);
AudioConnection patchCord36(mixer1, biquad51);
AudioConnection patchCord37(mixer1, biquad49);
AudioConnection patchCord38(mixer1, biquad47);
AudioConnection patchCord39(mixer1, biquad45);
AudioConnection patchCord40(mixer1, biquad43);
AudioConnection patchCord41(mixer1, biquad41);
AudioConnection patchCord42(mixer1, biquad39);
AudioConnection patchCord43(mixer1, biquad37);
AudioConnection patchCord44(mixer1, biquad35);
AudioConnection patchCord45(mixer1, biquad33);
AudioConnection patchCord46(mixer1, biquad31);
AudioConnection patchCord47(mixer1, biquad29);
AudioConnection patchCord48(mixer1, biquad27);
AudioConnection patchCord49(mixer1, biquad25);
AudioConnection patchCord50(mixer1, biquad23);
AudioConnection patchCord51(mixer1, biquad21);
AudioConnection patchCord52(mixer1, biquad19);
AudioConnection patchCord53(mixer1, biquad17);
AudioConnection patchCord54(biquad79, 0, mixer23, 3);
AudioConnection patchCord55(biquad77, 0, mixer23, 2);
AudioConnection patchCord56(biquad75, 0, mixer23, 1);
AudioConnection patchCord57(biquad73, 0, mixer23, 0);
AudioConnection patchCord58(biquad69, 0, mixer21, 2);
AudioConnection patchCord59(biquad71, 0, mixer21, 3);
AudioConnection patchCord60(biquad67, 0, mixer21, 1);
AudioConnection patchCord61(biquad63, 0, mixer19, 3);
AudioConnection patchCord62(biquad1, 0, mixer5, 0);
AudioConnection patchCord63(biquad15, 0, mixer7, 3);
AudioConnection patchCord64(biquad17, 0, mixer9, 0);
AudioConnection patchCord65(biquad3, 0, mixer5, 1);
AudioConnection patchCord66(biquad61, 0, mixer19, 2);
AudioConnection patchCord67(biquad11, 0, mixer7, 1);
AudioConnection patchCord68(biquad59, 0, mixer19, 1);
AudioConnection patchCord69(biquad5, 0, mixer5, 2);
AudioConnection patchCord70(biquad13, 0, mixer7, 2);
AudioConnection patchCord71(biquad57, 0, mixer19, 0);
AudioConnection patchCord72(biquad19, 0, mixer9, 1);
AudioConnection patchCord73(biquad7, 0, mixer5, 3);
AudioConnection patchCord74(biquad9, 0, mixer7, 0);
AudioConnection patchCord75(biquad21, 0, mixer9, 2);
AudioConnection patchCord76(biquad23, 0, mixer9, 3);
AudioConnection patchCord77(biquad25, 0, mixer11, 0);
AudioConnection patchCord78(biquad27, 0, mixer11, 1);
AudioConnection patchCord79(biquad65, 0, mixer21, 0);
AudioConnection patchCord80(biquad39, 0, mixer13, 3);
AudioConnection patchCord81(biquad55, 0, mixer17, 3);
AudioConnection patchCord82(biquad37, 0, mixer13, 2);
AudioConnection patchCord83(biquad51, 0, mixer17, 1);
AudioConnection patchCord84(biquad53, 0, mixer17, 2);
AudioConnection patchCord85(biquad41, 0, mixer15, 0);
AudioConnection patchCord86(biquad29, 0, mixer11, 2);
AudioConnection patchCord87(biquad33, 0, mixer13, 0);
AudioConnection patchCord88(biquad35, 0, mixer13, 1);
AudioConnection patchCord89(biquad49, 0, mixer17, 0);
AudioConnection patchCord90(biquad47, 0, mixer15, 3);
AudioConnection patchCord91(biquad43, 0, mixer15, 1);
AudioConnection patchCord92(biquad31, 0, mixer11, 3);
AudioConnection patchCord93(biquad45, 0, mixer15, 2);
AudioConnection patchCord94(mixer5, 0, mixer25, 0);
AudioConnection patchCord95(mixer23, 0, mixer29, 1);
AudioConnection patchCord96(mixer33, fft1024_2);
AudioConnection patchCord97(mixer21, 0, mixer29, 0);
AudioConnection patchCord98(mixer7, 0, mixer25, 1);
AudioConnection patchCord99(mixer19, 0, mixer27, 3);
AudioConnection patchCord100(mixer34, fft1024_1);
AudioConnection patchCord101(mixer9, 0, mixer25, 2);
AudioConnection patchCord102(mixer13, 0, mixer27, 0);
AudioConnection patchCord103(mixer11, 0, mixer25, 3);
AudioConnection patchCord104(mixer17, 0, mixer27, 2);
AudioConnection patchCord105(mixer15, 0, mixer27, 1);
AudioConnection patchCord106(mixer2, biquad2);
AudioConnection patchCord107(mixer2, biquad80);
AudioConnection patchCord108(mixer2, biquad78);
AudioConnection patchCord109(mixer2, biquad76);
AudioConnection patchCord110(mixer2, biquad74);
AudioConnection patchCord111(mixer2, biquad72);
AudioConnection patchCord112(mixer2, biquad70);
AudioConnection patchCord113(mixer2, biquad68);
AudioConnection patchCord114(mixer2, biquad66);
AudioConnection patchCord115(mixer2, biquad64);
AudioConnection patchCord116(mixer2, biquad62);
AudioConnection patchCord117(mixer2, biquad60);
AudioConnection patchCord118(mixer2, biquad58);
AudioConnection patchCord119(mixer2, biquad56);
AudioConnection patchCord120(mixer2, biquad54);
AudioConnection patchCord121(mixer2, biquad52);
AudioConnection patchCord122(mixer2, biquad50);
AudioConnection patchCord123(mixer2, biquad48);
AudioConnection patchCord124(mixer2, biquad46);
AudioConnection patchCord125(mixer2, biquad44);
AudioConnection patchCord126(mixer2, biquad42);
AudioConnection patchCord127(mixer2, biquad40);
AudioConnection patchCord128(mixer2, biquad38);
AudioConnection patchCord129(mixer2, biquad36);
AudioConnection patchCord130(mixer2, biquad34);
AudioConnection patchCord131(mixer2, biquad32);
AudioConnection patchCord132(mixer2, biquad30);
AudioConnection patchCord133(mixer2, biquad28);
AudioConnection patchCord134(mixer2, biquad26);
AudioConnection patchCord135(mixer2, biquad24);
AudioConnection patchCord136(mixer2, biquad22);
AudioConnection patchCord137(mixer2, biquad20);
AudioConnection patchCord138(mixer2, biquad18);
AudioConnection patchCord139(mixer2, biquad16);
AudioConnection patchCord140(mixer2, biquad14);
AudioConnection patchCord141(mixer2, biquad12);
AudioConnection patchCord142(mixer2, biquad10);
AudioConnection patchCord143(mixer2, biquad8);
AudioConnection patchCord144(mixer2, biquad6);
AudioConnection patchCord145(mixer2, biquad4);
AudioConnection patchCord146(biquad6, 0, mixer6, 2);
AudioConnection patchCord147(biquad36, 0, mixer14, 1);
AudioConnection patchCord148(biquad32, 0, mixer12, 3);
AudioConnection patchCord149(biquad34, 0, mixer14, 0);
AudioConnection patchCord150(biquad8, 0, mixer6, 3);
AudioConnection patchCord151(biquad10, 0, mixer8, 0);
AudioConnection patchCord152(biquad14, 0, mixer8, 2);
AudioConnection patchCord153(biquad2, 0, mixer6, 0);
AudioConnection patchCord154(biquad24, 0, mixer10, 3);
AudioConnection patchCord155(biquad12, 0, mixer8, 1);
AudioConnection patchCord156(biquad28, 0, mixer12, 1);
AudioConnection patchCord157(biquad30, 0, mixer12, 2);
AudioConnection patchCord158(biquad4, 0, mixer6, 1);
AudioConnection patchCord159(biquad22, 0, mixer10, 2);
AudioConnection patchCord160(biquad26, 0, mixer12, 0);
AudioConnection patchCord161(biquad16, 0, mixer8, 3);
AudioConnection patchCord162(biquad18, 0, mixer10, 0);
AudioConnection patchCord163(biquad20, 0, mixer10, 1);
AudioConnection patchCord164(biquad44, 0, mixer16, 1);
AudioConnection patchCord165(biquad38, 0, mixer14, 2);
AudioConnection patchCord166(biquad42, 0, mixer16, 0);
AudioConnection patchCord167(biquad40, 0, mixer14, 3);
AudioConnection patchCord168(biquad46, 0, mixer16, 2);
AudioConnection patchCord169(biquad48, 0, mixer16, 3);
AudioConnection patchCord170(biquad50, 0, mixer18, 0);
AudioConnection patchCord171(biquad52, 0, mixer18, 1);
AudioConnection patchCord172(biquad64, 0, mixer20, 3);
AudioConnection patchCord173(biquad66, 0, mixer22, 0);
AudioConnection patchCord174(biquad60, 0, mixer20, 1);
AudioConnection patchCord175(biquad78, 0, mixer24, 2);
AudioConnection patchCord176(biquad68, 0, mixer22, 1);
AudioConnection patchCord177(biquad58, 0, mixer20, 0);
AudioConnection patchCord178(biquad72, 0, mixer22, 3);
AudioConnection patchCord179(biquad62, 0, mixer20, 2);
AudioConnection patchCord180(biquad80, 0, mixer24, 3);
AudioConnection patchCord181(biquad70, 0, mixer22, 2);
AudioConnection patchCord182(biquad74, 0, mixer24, 0);
AudioConnection patchCord183(biquad54, 0, mixer18, 2);
AudioConnection patchCord184(biquad56, 0, mixer18, 3);
AudioConnection patchCord185(biquad76, 0, mixer24, 1);
AudioConnection patchCord186(mixer8, 0, mixer26, 1);
AudioConnection patchCord187(mixer22, 0, mixer30, 0);
AudioConnection patchCord188(mixer20, 0, mixer28, 3);
AudioConnection patchCord189(mixer24, 0, mixer30, 1);
AudioConnection patchCord190(mixer14, 0, mixer28, 0);
AudioConnection patchCord191(mixer12, 0, mixer26, 3);
AudioConnection patchCord192(mixer6, 0, mixer26, 0);
AudioConnection patchCord193(mixer18, 0, mixer28, 2);
AudioConnection patchCord194(mixer16, 0, mixer28, 1);
AudioConnection patchCord195(mixer10, 0, mixer26, 2);
AudioConnection patchCord196(mixer29, 0, mixer31, 2);
AudioConnection patchCord197(mixer27, 0, mixer31, 1);
AudioConnection patchCord198(mixer25, 0, mixer31, 0);
AudioConnection patchCord199(mixer26, 0, mixer32, 0);
AudioConnection patchCord200(mixer30, 0, mixer32, 2);
AudioConnection patchCord201(mixer28, 0, mixer32, 1);
AudioConnection patchCord202(mixer31, 0, mixer3, 0);
AudioConnection patchCord203(mixer32, 0, mixer4, 0);
AudioConnection patchCord204(mixer3, 0, i2s2, 0);
AudioConnection patchCord205(mixer3, rms_L);
AudioConnection patchCord206(mixer4, 0, i2s2, 1);
AudioConnection patchCord207(mixer4, rms_R);
AudioControlSGTL5000 sgtl5000_1; //xy=1903.8832397460938,49.88328552246094
* Pete’s Tonesweep starts here
AudioSynthToneSweep tonesweep1; //xy=255,382
//AudioOutputI2S i2s3; //xy=763,360
AudioConnection patchCord6(tonesweep1, 0, i2s2, 0);
AudioConnection patchCord7(tonesweep1, 0, i2s2, 1);
//AudioControlSGTL5000 sgtl5000_1; //xy=242,174
* Pete’s Tonesweep ends here
//const int myInput = AUDIO_INPUT_LINEIN;
const int myInput = AUDIO_INPUT_MIC;
// The scale sets how much sound is needed in each frequency range to
// show all 8 bars. Higher numbers are more sensitive.
float scale = 60.0;
// An array to hold the 16 frequency bands
float level[16];
// This array holds the on-screen levels. When the signal drops quickly,
// these are used to lower the on-screen level 1 bar per update, which
// looks more pleasing to corresponds to human sound perception.
int shown[16];
// Use the LiquidCrystal library to display the spectrum
LiquidCrystal lcd(0, 1, 2, 3, 4, 5);
byte bar1[8] = {0,0,0,0,0,0,0,255};
byte bar2[8] = {0,0,0,0,0,0,255,255}; // 8 bar graph
byte bar3[8] = {0,0,0,0,0,255,255,255}; // custom
byte bar4[8] = {0,0,0,0,255,255,255,255}; // characters
byte bar5[8] = {0,0,0,255,255,255,255,255};
byte bar6[8] = {0,0,255,255,255,255,255,255};
byte bar7[8] = {0,255,255,255,255,255,255,255};
byte bar8[8] = {255,255,255,255,255,255,255,255};
void pinkOFF(){
pink2.amplitude(0.00);
Serial.println("Pink off initialized");
while(!Serial);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
//AudioMemory(4);
AudioProcessorUsageMaxReset();
AudioMemoryUsageMaxReset();
// Audio memory allocation
AudioMemory(95);
// Enable the audio shield and set the output volume.
// turn on the LCD and define the custom characters
lcd.begin(16, 2);
lcd.print("Audio Spectrum");
lcd.createChar(0, bar1);
lcd.createChar(1, bar2);
lcd.createChar(2, bar3);
lcd.createChar(3, bar4);
lcd.createChar(4, bar5);
lcd.createChar(5, bar6);
lcd.createChar(6, bar7);
lcd.createChar(7, bar8);
// configure the mixer to equally add left & right
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
// Compensation gain for additive gain from filters
// Reduce signal on Left and right channels by -9dB
mixer1.gain(0, powf(10.0f, -9 / 20.0f)); // any # between 0 and 1 instead of powf(10.0f, -9 / 20.0f)
mixer1.gain(1, powf(10.0f, -9 / 20.0f));
mixer2.gain(0, powf(10.0f, -9 / 20.0f) );
mixer2.gain(1, powf(10.0f, -9 / 20.0f));
// pin 21 will select rapid vs animated display
pinMode(21, INPUT_PULLUP);
// Butterworth filter, 12 db/octave
biquad1.setBandpass(0, 43, 0.716667);
biquad2.setBandpass(0, 43, 0.716667);
biquad3.setBandpass(0, 108, 2.5116);
biquad4.setBandpass(0, 108, 2.5116);
biquad5.setBandpass(0, 215, 2.5);
biquad6.setBandpass(0, 215, 2.5);
biquad7.setBandpass(0, 365, 2.829);
biquad8.setBandpass(0, 365, 2.829);
biquad9.setBandpass(0, 559, 3.25);
biquad10.setBandpass(0, 559, 3.25);
biquad11.setBandpass(0, 817, 3.16667);
biquad12.setBandpass(0, 817, 3.16667);
biquad13.setBandpass(0, 1182, 3.05);
biquad14.setBandpass(0, 1182, 3.05);
biquad15.setBandpass(0, 1699, 3);
biquad16.setBandpass(0, 1699, 3);
biquad17.setBandpass(0, 2430, 2.974);
biquad18.setBandpass(0, 2430, 2.974);
biquad19.setBandpass(0, 3440, 3.08);
biquad20.setBandpass(0, 3440, 3.08);
biquad21.setBandpass(0, 4838, 3);
biquad22.setBandpass(0, 4838, 3);
biquad23.setBandpass(0, 6816, 3);
biquad24.setBandpass(0, 6816, 3);
biquad25.setBandpass(0, 9546, 3.08);
biquad26.setBandpass(0, 9546, 3.08);
biquad27.setBandpass(0, 13309, 3.06);
biquad28.setBandpass(0, 13309, 3.06);
biquad29.setBandpass(0, 18770, 2.89);
biquad30.setBandpass(0, 18770, 2.89);
elapsedMillis fps;
uint8_t cnt=0;
float max1[20] = {0};
float max2[20] = {0};
delay[2500];
elapsedMillis pinkOFF;
while (pinkOFF < 15000){
pink2.amplitude(0.25);
if(fps > 24) {
if (peak_L.available() && peak_R.available() && rms_L.available() && rms_R.available()) {
fps=0;
uint8_t leftPeak = peak_L.read() * 30.0;
uint8_t rightPeak = peak_R.read() * 30.0;
float leftRMS = rms_L.read() * 30.0;
float rightRMS = rms_R.read() * 30.0;
for (cnt=0; cnt < 30-leftPeak; cnt++) {
Serial.print(" ");
while (cnt++ < 29 && cnt < 30-leftRMS) {
Serial.print("<");
while (cnt++ < 30) {
Serial.print("=");
Serial.print("||");
for(cnt=0; cnt < rightRMS; cnt++) {
Serial.print("=");
for(; cnt < rightPeak; cnt++) {
Serial.print(">");
while(cnt++ < 30) {
Serial.print(" ");
Serial.print(" ");
Serial.print(leftRMS / 30);
Serial.print("||");
Serial.print(rightRMS / 30);
Serial.print(" ");
Serial.print(AudioProcessorUsage());
Serial.print("/");
Serial.print(AudioProcessorUsageMax());
// Stop the Pink noise
delay(5000);
// First Analysis
delay[2500];
tonesweep1.play(1.0, 10, 22050, 30);
while(tonesweep1.isPlaying()){
//pink2.amplitude(0.5);
//while(pink2.amplitude(0.5)){
if (fps >24){
if (fft1024_1.available()) {
// read the 512 FFT frequencies into 16 levels
// music is heard in octaves, but the FFT data
// is linear, so for the higher octaves, read
// many FFT bins together.
level[0] = fft1024_1.read(0);
level[1] = fft1024_1.read(1);
level[2] = fft1024_1.read(2, 3);
level[3] = fft1024_1.read(4, 6);
level[4] = fft1024_1.read(7, 10);
level[5] = fft1024_1.read(11, 15);
level[6] = fft1024_1.read(16, 22);
level[7] = fft1024_1.read(23, 32);
level[8] = fft1024_1.read(33, 46);
level[9] = fft1024_1.read(47, 66);
level[10] = fft1024_1.read(67, 93);
level[11] = fft1024_1.read(94, 131);
level[12] = fft1024_1.read(132, 184);
level[13] = fft1024_1.read(185, 257);
level[14] = fft1024_1.read(258, 359);
level[15] = fft1024_1.read(360, 511);
// See this conversation to change this to more or less than 16 log-scaled bands?
// https://forum.pjrc.com/threads/32677-Is-there-a-logarithmic-function-for-FFT-bin-selection-for-any-given-of-bands
// if you have the volume pot soldered to your audio shield
// uncomment this line to make it adjust the full scale signal
//scale = 8.0 + analogRead(A1) / 5.0;
// begin drawing at the first character on the 2nd row
lcd.setCursor(0, 1);
for (int i=0; i<16; i++) {
Serial.print(level[i]);
if ( max1[i] < level[i])
max1[i] = level[i];
// TODO: conversion from FFT data to display bars should be
// exponentially scaled. But how keep it a simple example?
int val = level[i] * scale;
if (val > 8) val = 8;
if (val >= shown[i]) {
shown[i] = val;
if (shown[i] > 0) shown[i] = shown[i] - 1;
val = shown[i];
//Serial.print(shown[i]);
Serial.print(" ");
// print each custom digit
if (shown[i] == 0) {
lcd.write(' ');
lcd.write(shown[i] - 1);
fps=0;
uint8_t leftPeak = peak_L1.read() * 30.0;
uint8_t rightPeak = peak_R1.read() * 30.0;
float leftRMS = rms_L1.read() * 30.0;
float rightRMS = rms_R1.read() * 30.0;
Serial.print(" ");
Serial.print("<");
Serial.print("=");
Serial.print("||");
Serial.print("=");
Serial.print(">");
while(cnt++ < 30) {
Serial.print(" ");
Serial.print(" ");
Serial.print("||");
Serial.print(" ");
Serial.print("/");
Serial.print(" cpu:");
Serial.println(AudioProcessorUsageMax());
// This is the end of the max audio
Serial.println("Your Maximum Value:");
for (int j=0;j<16;j++)
Serial.print(max1[j]);
Serial.print(" ");
delay(5000);
Serial.println("");
// Second Part starts Here
delay[2500];
////////////////////////// Sweep 2 ////////////////////////////////
tonesweep2.play(0.25, 10, 22050, 30);
while(tonesweep2.isPlaying()){
if (fps >24){
if (fft1024_2.available()) {
level[0] = fft1024_2.read(0);
level[1] = fft1024_2.read(1);
level[2] = fft1024_2.read(2, 3);
level[3] = fft1024_2.read(4, 6);
level[4] = fft1024_2.read(7, 10);
level[5] = fft1024_2.read(11, 15);
level[6] = fft1024_2.read(16, 22);
level[7] = fft1024_2.read(23, 32);
level[8] = fft1024_2.read(33, 46);
level[9] = fft1024_2.read(47, 66);
level[10] = fft1024_2.read(67, 93);
level[11] = fft1024_2.read(94, 131);
level[12] = fft1024_2.read(132, 184);
level[13] = fft1024_2.read(185, 257);
level[14] = fft1024_2.read(258, 359);
level[15] = fft1024_2.read(360, 511);
if ( max2[i] < level[i])
max2[i] = level[i];
shown[i] = val;
val = shown[i];
Serial.print(" ");
lcd.write(' ');
fps=0;
Serial.print(" ");
Serial.print("<");
Serial.print("=");
Serial.print("||");
Serial.print("=");
Serial.print(">");
while(cnt++ < 30) {
Serial.print(" ");
Serial.print(" ");
Serial.print("||");
Serial.print(" ");
Serial.print("/");
Serial.print(max2[j]);
Serial.print(" ");
delay(5000);
Serial.println("");
// Filter 1 Gain
mixer5.gain(0, filter1gain_L );
mixer6.gain(0, filter1gain_R );
// Filter 2 Gain
mixer5.gain(1, filter2gain_L );
mixer6.gain(1, filter2gain_R );
// Filter 3 Gain
mixer5.gain(2, filter3gain_L );
mixer6.gain(2, filter3gain_R );
// Filter 4 Gain
mixer5.gain(3, filter4gain_L );
mixer6.gain(3, filter4gain_R );
// Filter 5 Gain
mixer7.gain(0, filter5gain_L );
mixer8.gain(0, filter5gain_R );
// Filter 6 Gain
mixer7.gain(1, filter6gain_L );
mixer8.gain(1, filter6gain_R );
// Filter 7 Gain
mixer7.gain(2, filter7gain_L );
mixer8.gain(2, filter7gain_R );
// Filter 8 Gain
mixer7.gain(3, filter8gain_L );
mixer8.gain(3, filter8gain_R );
// Filter 9 Gain
mixer9.gain(0, filter9gain_L );
mixer10.gain(0, filter9gain_R );
// Filter 10 Gain
mixer9.gain(1, filter10gain_L );
mixer10.gain(1, filter10gain_R );
// Filter 11 Gain
mixer9.gain(2, filter11gain_L );
mixer10.gain(2, filter11gain_R );
// Filter 12 Gain
mixer9.gain(3, filter12gain_L );
mixer10.gain(3, filter12gain_R );
// Filter 13 Gain
mixer11.gain(0, filter13gain_L );
mixer12.gain(0, filter13gain_R );
// Filter 14 Gain
mixer11.gain(1, filter14gain_L );
mixer12.gain(1, filter14gain_R );
// Filter 15 Gain
mixer11.gain(2, filter15gain_L );
mixer12.gain(2, filter15gain_R );
/////////////////////////////// Sweep 3 /////////////////////////////////////
tonesweep3.play(0.25, 10, 22050, 30);
while(tonesweep3.isPlaying()){
max2[i] = level[i];
shown[i] = val;
val = shown[i];
Serial.print(" ");
lcd.write(' ');
fps=0;
Serial.print(" ");
Serial.print("<");
Serial.print("=");
Serial.print("||");
Serial.print("=");
Serial.print(">");
while(cnt++ < 30) {
Serial.print(" ");
Serial.print(" ");
Serial.print("||");
Serial.print(" ");
Serial.print("/");
Serial.print(" ");
delay(5000);
Serial.println("");
