Accidentally posted this first in "Bug Reports," which clearly isn't right. Couldn't see how to move the post, so this is just a copy. Sorry for the double-post!
I'm porting over an Arduino sketch that relied on the chip for timer-based interrupts. It looks to me from the documentation as though the proper timer to use for this on Teensy 3.0 is the periodic interrupt timer, PIT. So I did some setup:
I'm not completely certain that's correct, but it's similar to code included in the chip datasheet.
But I'm not really sure how to declare an interrupt handler for the PIT. The Arduino code is
but of course that's for the AVR timer interrupt. I tried to look through the hardware/teensy3 code, but I couldn't find the relevant bits. The datasheet just says "See the MCU specification for related vector addresses and priorities," and I couldn't work out what that meant. (My best guess was "http://cache.freescale.com/files/32bit/doc/data_sheet/K20P64M50SF0.pdf", but that doesn't have any relevant information.)
Is there a good source of documentation on this?
Thanks!
-Nick
// Constants for bitvalues within the TCTRL1 register
#define TIE 2
#define TEN 1
void timer_setup() {
/* Arduino version of timer setup
TCCR2A = 0;
TCNT2=455; //455 outputs 1.007khz
TCCR2B = B00000010;
//Timer2 Overflow Interrupt Enable
TIMSK2 = 1<<TOIE2;
// Teensy 3.0 version
// Turn on PIT
PIT_MCR = 0x00;
// Set the period of the timer. Unit is (1 / 50MHz) = 20ns
// So 1 kHz frequency -> 1 ms period -> 50000 * 20ns
PIT_LDVAL1 = 50000;
// Enable interrupts on Timer1
PIT_TCTRL1 = TIE;
// Start the timer
PIT_TCTRL1 |= TEN;
ISR(TIMER2_OVF_vect) {
// function body
Thanks!
-Nick
